Hello,
how can I run immediate check for updates in OS? And how am I notified that new updates are available?
Only way how to invoke updates install now, I found, is to run "Software management - dfndragora", then in 2nd combo box to choose "To update" and "Select All" and "Apply". But this is very inconvenient.
Thanks
How to check for updates?
- ДонВенчензо
install dnfdragora-updater. It will appear on the panel next to the clock and will check for updates.
