update-system under root?
trencan
Сообщение trencan »
Hello,
when I run update-system not under root I get:
xxx@HomeLinuxPC ~ $ update-system
(process:7613): Gtk-WARNING **: 08:18:31.624: Locale not supported by C library.
        Using the fallback 'C' locale.
Failed to set locale, defaulting to C.UTF-8
This option is not available. Please see --help for all possible usages.
/usr/sbin/update-system: line 6: echo: write error: Broken pipe
/usr/sbin/update-system: line 7: echo: write error: Broken pipe
/usr/sbin/update-system: line 9: echo: write error: Broken pipe
/usr/sbin/update-system: line 10: echo: write error: Broken pipe
/usr/sbin/update-system: line 12: echo: write error: Broken pipe
/usr/sbin/update-system: line 13: echo: write error: Broken pipe
so not working. But this "update" I can see in KDE search, so should be invokable without root privileges?
Thanks.
ДонВенчензо
Сообщение ДонВенчензо »
I didn't find the update-system command in dnf--help
