[решено] Не показывает rtsp в VLC (liblive555_plugin.so)
tihij
Operating system: ROSA Linux 2021.1
Сообщение tihij »
Доброго дня.
Не проигрывает VLC rtsp-потоки с видео, на предыдущей версии ROSA показывает нормально.
Предполагаю, что из-за
cannot load module `/usr/lib64/vlc/plugins/access/liblive555_plugin.so' (/usr/lib64/libliveMedia.so.79: undefined symbol: TLS_client_method)
---- чуть лога
[00007f8d8c000c80] main input debug: Creating an input for 'rtsp://192.168.xxx.xxx:8554/live1.264'
[0000000000606810] main playlist debug: requesting art for new input thread
[00007f8d8c000c80] main input debug: using timeshift granularity of 50 MiB
[00007f8d8c000c80] main input debug: using default timeshift path
[00007f8d8c000c80] main input debug: `rtsp://192.168.xxx.xxx:8554/live1.264' gives access `rtsp' demux `any' path `192.168.xxx.xxx:8554/live1.264'
[00007f8d90000fa0] main input source debug: creating demux: access='rtsp' demux='any' location='192.168.xxx.xxx:8554/live1.264' file='(null)'
[00007f8d90001130] main demux debug: looking for access_demux module matching "rtsp": 17 candidates
[00007f8d88000c20] main meta fetcher debug: looking for meta fetcher module matching "any": 1 candidates
[00007f8d88000c20] lua meta fetcher debug: Trying Lua scripts in /home/xxx/.local/share/vlc/lua/meta/fetcher
[00007f8d88000c20] lua meta fetcher debug: Trying Lua scripts in /usr/lib64/vlc/lua/meta/fetcher
[00007f8d88000c20] lua meta fetcher debug: Trying Lua scripts in /usr/share/vlc/lua/meta/fetcher
[00007f8d88000c20] main meta fetcher debug: no meta fetcher modules matched
[00007f8d88000c20] main art finder debug: looking for art finder module matching "any": 2 candidates
[00007f8d90001130] main demux warning: cannot load module `/usr/lib64/vlc/plugins/access/liblive555_plugin.so' (/usr/lib64/libliveMedia.so.79: undefined symbol: TLS_client_method)
[00007f8d90001130] main demux debug: no access_demux modules matched
[00007f8d90002090] main stream debug: creating access: rtsp://192.168.xxx.xxx:8554/live1.264
[00007f8d90002090] main stream debug: looking for access module matching "rtsp": 29 candidates
[00007f8d88000c20] lua art finder debug: Trying Lua scripts in /home/xxx/.local/share/vlc/lua/meta/art
[00007f8d88000c20] lua art finder debug: Trying Lua scripts in /usr/lib64/vlc/lua/meta/art
[00007f8d88000c20] lua art finder debug: Trying Lua playlist script /usr/lib64/vlc/lua/meta/art/00_musicbrainz.luac
[00007f8d90002090] satip stream debug: try to open 'rtsp://192.168.xxx.xxx:8554/live1.264'
[00007f8d90002090] satip stream debug: connect to host '192.168.xxx.xxx'
[00007f8d90002090] main stream debug: net: connecting to 192.168.xxx.xxx port 8554
[00007f8d88000c20] lua art finder debug: skipping script (unmatched scope) /usr/lib64/vlc/lua/meta/art/00_musicbrainz.luac
[00007f8d88000c20] lua art finder debug: Trying Lua playlist script /usr/lib64/vlc/lua/meta/art/01_googleimage.luac
[00007f8d88000c20] lua art finder debug: skipping script (unmatched scope) /usr/lib64/vlc/lua/meta/art/01_googleimage.luac
[00007f8d88000c20] lua art finder debug: Trying Lua playlist script /usr/lib64/vlc/lua/meta/art/02_frenchtv.luac
[00007f8d88000c20] lua art finder debug: skipping script (unmatched scope) /usr/lib64/vlc/lua/meta/art/02_frenchtv.luac
[00007f8d88000c20] lua art finder debug: Trying Lua playlist script /usr/lib64/vlc/lua/meta/art/03_lastfm.luac
[00007f8d88000c20] lua art finder debug: skipping script (unmatched scope) /usr/lib64/vlc/lua/meta/art/03_lastfm.luac
[00007f8d88000c20] lua art finder debug: Trying Lua scripts in /usr/share/vlc/lua/meta/art
[00007f8d88000c20] main art finder debug: no art finder modules matched
[00007f8d90002090] main stream debug: connection succeeded (socket = 26)
[0000000000665b40] qt interface debug: IM: Setting an input
[00007f8d90002090] main stream debug: net: opening 0.0.0.0 datagram port 9426
[00007f8d90002090] main stream debug: net: opening 0.0.0.0 datagram port 9427
[000000000064d480] pulse audio output debug: changing sink 1: alsa_output.pci-0000_00_1b.0.analog-stereo (Встроенное аудио Аналоговый стерео)
Последний раз редактировалось tihij 03 дек 2021, 23:36, всего редактировалось 1 раз.
tihij
Сообщение tihij »
Забыл добавить, что заканчивается попытка подключения следующими строками
[00007fed780020d0] satip stream error: read error: Operation now in progress
[00007fed780020d0] satip stream error: Failed to setup RTSP session
[00007fed780020d0] main stream debug: net: connecting to 192.168.xxx.xxx port 8554
[00007fed780020d0] main stream debug: connection succeeded (socket = 17)
[00007fed780020d0] access_realrtsp stream warning: Cseq mismatch, got 1, assumed 0
[00007fed780020d0] access_realrtsp stream debug: rtsp connected
[00007fed780020d0] access_realrtsp stream warning: only real/helix rtsp servers supported for now
[00007fed780020d0] main stream debug: no access modules matched
Этот плагин есть, в пакете vlc-plugins-main. Можт пакет не установлен?
tihij
Сообщение tihij »
# rpm -qa | grep vlc
vlc-plugin-upnp-3.0.16-9.x86_64
vlc-plugin-kate-3.0.16-9.x86_64
vlc-plugin-wayland-3.0.16-9.x86_64
vlc-plugin-vdpau-3.0.16-9.x86_64
vlc-plugin-vaapi-3.0.16-9.x86_64
vlc-plugin-lua-3.0.16-9.x86_64
vlc-plugin-libass-3.0.16-9.x86_64
vlc-plugin-gnutls-3.0.16-9.x86_64
vlc-plugin-dv-3.0.16-9.x86_64
vlc-plugin-schroedinger-3.0.16-9.x86_64
vlc-plugin-mpc-3.0.16-9.x86_64
vlc-3.0.16-9.x86_64
vlc-plugin-sdl-3.0.16-9.x86_64
vlc-plugin-ncurses-3.0.16-9.x86_64
vlc-plugin-opengl-3.0.16-9.x86_64
vlc-plugin-main-3.0.16-9.x86_64
vlc-plugin-rist-3.0.16-9.x86_64
vlc-plugin-shout-3.0.16-9.x86_64
vlc-plugin-flac-3.0.16-9.x86_64
vlc-plugin-fluidsynth-3.0.16-9.x86_64
vlc-plugin-opus-3.0.16-9.x86_64
vlc-plugin-pulse-3.0.16-9.x86_64
vlc-plugin-speex-3.0.16-9.x86_64
vlc-plugin-theora-3.0.16-9.x86_64
vlc-plugin-twolame-3.0.16-9.x86_64
lib64vlccore9-3.0.16-9.x86_64
lib64vlc5-3.0.16-9.x86_64
libliveMedia, возможно собрана без поддержки TLS.
Судя по форумам была подобная ошибка в начале года в upstream, но её быстро исправили.
ArturS
Operating system: Rosa Desktop
Сообщение ArturS »
tihij писал(а): 14 ноя 2021, 00:36 Не проигрывает VLC rtsp-потоки с видео, на предыдущей версии ROSA показывает нормально.
Подскажите, как Вы это смотрите? Просто интересно.
tihij
Сообщение tihij »
# vlc --verbose=2 "rtsp://192.168.xxx.xxx:8554/live1.264"
Нашел в чем проблема, отдал на тестирование
tihij
Сообщение tihij »
Спасибо. Жду обновления. :D
tihij
Сообщение tihij »
Не успело протестироваться?
Неа, не от меня зависит, у них свой график :( но говорят работает
tihij
Сообщение tihij »
Ясно. Спасибо за информацию. :)
tihij
Сообщение tihij »
После сегодняшнего обновления vlc заработал с rtsp (пришлось ещё снять туннелирование через HTTP, по умолчанию).
Спасибо. Тему можно закрывать.
