ROSA as VirtualBox host
hung.nguyengia
Operating system: ROSA Linux Fresh R11.1 XFCE4 - 64 bit
Сообщение hung.nguyengia »
VirtualBox 6.0 is outdated and no longer supported. The Guest Additions ISO is not included with VirtualBox itself, has to be downloaded from the internet. The download of this ISO is always failed, seemed because this VirtualBox version is EOL-ed so the link moved. The result is I can't install the needed Guest Additions for my Windows 7 Guest and it runs with degraded experience without the Guest Additions.
There is a virtualbox-6.1.{18,22} in this repo
http://abf-downloads.rosalinux.ru/alzim ... n/release/
hung.nguyengia
va9(2) писал(а): 13 авг 2021, 10:43 There is a virtualbox-6.1.{18,22} in this repo
How to use this repo?
sudo urpmi.addmedia alzim-repo http://abf-downloads.rosalinux.ru/alzim2_personal/repository/rosa2016.1/x86_64/main/release/
sudo urpmi virtualbox
sudo urpmi.removemedia alzim-repo
hung.nguyengia
va9(2) писал(а): 13 авг 2021, 17:34
Could I keep this repo? The last command seems about removing it.
hung.nguyengia писал(а): 13 авг 2021, 20:20 Could I keep this repo?
Yes, but why? You can add it at any time again.
hung.nguyengia
va9(2) писал(а): 14 авг 2021, 09:07
Do you think I install it once and never update again? Keeping the repo I could receive new updates from it if there is any. On Ubuntu/Debian, we rarely remove a repo once we added it.
