Jun 11 00:31:15 localhost udisks-daemon[1920]: ** (udisks-daemon:1920): WARNING **: Property get or set does not have an interface string as first arg
Jun 11 00:31:15 localhost udisks-daemon[1920]: ** (udisks-daemon:1920): WARNING **: Property get or set does not have an interface string as first argНа втором месте по бессмысленности сообщений в логах некий upowerd:
[root@4320s vasiliy5]# grep -oiP '\(.*?\)' /var/log/messages | sed -e 's!:[0-9]*!!' |sort | uniq -c | sort -n | tail -5
70 (wlan0)
372 (eth0)
516 (polkitd)
5955 (upowerd)
167519 (udisks-daemon)Код: Выделить всё
Jun 10 21:41:58 localhost dbus-daemon[1960]: (upowerd:3460): UPower-Linux-DEBUG: SYSFS change /sys/devices/LNXSYSTM:00/device:00/PNP0C0A:00/power_supply/BAT0
Jun 10 21:41:58 localhost dbus-daemon[1960]: (upowerd:3460): UPower-Linux-DEBUG: using min design voltage
Jun 10 21:41:58 localhost dbus-daemon[1960]: (upowerd:3460): UPower-Linux-DEBUG: resetting unknown timeout after 0 retries
Jun 10 21:41:58 localhost dbus-daemon[1960]: (upowerd:3460): UPower-DEBUG: deferring as others queued
Jun 10 21:41:58 localhost dbus-daemon[1960]: (upowerd:3460): UPower-DEBUG: emitting changed on /sys/devices/LNXSYSTM:00/device:00/PNP0C0A:00/power_supply/BAT0
Jun 10 21:41:58 localhost dbus-daemon[1960]: (upowerd:3460): UPower-DEBUG: emitting device-changed: /org/freedesktop/UPower/devices/battery_BAT0
Jun 10 21:41:58 localhost dbus-daemon[1960]: ** (upowerd:3460): WARNING **: Property get or set does not have an interface string as first arg
Jun 10 21:41:58 localhost dbus-daemon[1960]: ** (upowerd:3460): WARNING **: Property get or set does not have an interface string as first argКод: Выделить всё
[root@4320s vasiliy5]# tail /etc/rsyslog.d/blacklist.conf
:msg, contains, "upowerd" ~
:msg, contains, "udisks-daemon" ~
