$ cat /etc/os-release
NAME="ROSA Desktop Fresh R11.1"
VERSION="EE 2016.1 Desktop"
ID=rosa
VERSION_ID=2016.1
PRETTY_NAME="ROSA Desktop Fresh R11.1 EE 2016.1 Desktop"
ANSI_COLOR="1;43"
CPE_NAME="cpe:/o:rosa:rosalinux:2016.1"
HOME_URL="http://www.rosalinux.com/"
BUG_REPORT_URL="https://bugs.rosalinux.ru/"
$ cat /etc/rosa-release
ROSA Desktop Fresh R11.1 release 2016.1 for x86_64
$ uname -a
Linux VRT-ROSAXFCE001 4.15.0-desktop-94.1rosa-x86_64 #1 SMP PREEMPT Fri Mar 27 14:59:04 UTC 2020 x86_64 x86_64 x86_64 GNU/LinuxПопробовал запуск через SYSTEMD - тоже ерунда какая ть получается?
# systemctl status runscriptxvncserv
● runscriptxvncserv.service - X11VNC San Server
Loaded: loaded (/lib/systemd/system/runscriptxvncserv.service; enabled; vendor preset: disabled)
Active: inactive (dead) since Sun 2020-09-27 11:50:51 +07; 2min 19s ago
Process: 5200 ExecStart=/usr/bin/vnc.sh (code=exited, status=0/SUCCESS)
Main PID: 5200 (code=exited, status=0/SUCCESS)
сен 27 11:50:45 VRT-ROSAXFCE001 systemd[1]: Started X11VNC San Server.
сен 27 11:50:51 VRT-ROSAXFCE001 systemd[1]: runscriptxvncserv.service: Succeeded.
# systemctl restart runscriptxvncserv
Warning: The unit file, source configuration file or drop-ins of runscriptxvncserv.service changed on disk. Run 'systemctl daemon-reload' to reload units.
# systemctl daemon-reload
Active: failed (Result: exit-code) since Sun 2020-09-27 12:00:22 +07; 5s ago
Process: 22784 ExecStart=/usr/bin/vnc.sh (code=exited, status=0/SUCCESS)
Main PID: 22785 (code=exited, status=1/FAILURE)
сен 27 12:00:22 VRT-ROSAXFCE001 systemd[1]: Starting X11VNC San Server...
сен 27 12:00:22 VRT-ROSAXFCE001 systemd[1]: Started X11VNC San Server.
сен 27 12:00:22 VRT-ROSAXFCE001 vnc.sh[22784]: 27/09/2020 12:00:22 HOME unset in -usepw mode.
сен 27 12:00:22 VRT-ROSAXFCE001 systemd[1]: runscriptxvncserv.service: Main process exited, code=exited, status=1/FAILURE
сен 27 12:00:22 VRT-ROSAXFCE001 systemd[1]: runscriptxvncserv.service: Failed with result 'exit-code'.Код: Выделить всё
# /usr/bin/vnc.sh
The VNC desktop is: VRT-ROSAXFCE001:0
PORT=5900
PS: Нужно запустить скрипт ДО запуска SDDM. Тоесть, включили просто удаленный компьютер и все, других телодвижений не нужно.
