При последнем обновлении возникла ошибка:
1 установочных транзакций не удались
Во время установки возникла ошибка:
installing package lib64glapi0-20.1.2-1.x86_64 needs 24KB on the / filesystem
installing package lib64OpenImageIO1.6-1.6.18-3.x86_64 needs 12KB on the / filesystem
installing package libdrm-common-2.4.102-3.x86_64 needs 20KB on the / filesystem
installing package mesa-20.1.2-1.x86_64 needs 36KB on the / filesystem
installing package libdrm2-2.4.102-3.i586 needs 44KB on the / filesystem
installing package lib64drm_amdgpu1-2.4.102-3.x86_64 needs 48KB on the / filesystem
installing package lib64gbm1-20.1.2-1.x86_64 needs 60KB on the / filesystem
installing package lib64kms1-2.4.102-3.x86_64 needs 56KB on the / filesystem
installing package lib64osmesa8-20.1.2-1.x86_64 needs 4MB on the / filesystem
installing package libdri-drivers-20.1.2-1.i586 needs 164MB on the / filesystem
installing package lib64xatracker2-20.1.2-1.x86_64 needs 171MB on the / filesystem
installing package lib64dri-drivers-20.1.2-1.x86_64 needs 333MB on the / filesystem
installing package lib64d3dtracker1-20.1.2-1.x86_64 needs 342MB on the / filesystem
installing package lib64vulkan-drivers-20.1.2-1.x86_64 needs 353MB on the / filesystem
installing package lib64egl1-20.1.2-1.x86_64 needs 353MB on the / filesystem
installing package lib64drm-devel-2.4.102-3.x86_64 needs 353MB on the / filesystem
installing package lib64avcodec58-4.1.6-1plf.x86_64 needs 353MB on the / filesystem
installing package libgl1-20.1.2-1.i586 needs 354MB on the / filesystem
installing package lib64gl1-20.1.2-1.x86_64 needs 350MB on the / filesystem
installing package lib64avformat58-4.1.6-1plf.x86_64 needs 350MB on the / filesystem
installing package lib64VirtualGL-2.3.1-6.x86_64 needs 350MB on the / filesystem
installing package lib64gl-devel-20.1.2-1.x86_64 needs 358MB on the / filesystem
installing package lib64egl-devel-20.1.2-1.x86_64 needs 358MB on the / filesystem
installing package VirtualGL-2.3.1-6.x86_64 needs 358MB on the / filesystem
installing package digikam-6.3.0-2.x86_64 needs 358MB on the / filesystem
installing package lib64v4l0-1.10.1-4.x86_64 needs 358MB on the / filesystem
installing package blender-2.79-4.x86_64 needs 358MB on the / filesystem
После этого система стала сбоить. Например, при вызове консоли возникает ошибка: сбой программы консоль.
Если высвать параметры, то сбой программы drkongk
Буду признателен за помощь.
Судя всего часть пакетов учтановилась.
Ошибки при обновлении
papahander
- Zeffanyx
У вас кончилось место на диске. Если удалить ненужное, то всё вернётся в норму.
papahander
Как. Не вызывается ни консоль, ни файловый менеджер, не менеджер управления пакетами.
- Zeffanyx
Ctrl+Alt+F2. Логинитесь. И дальше с помощью rm -rf удаляете ненужное.papahander писал(а): 11 авг 2020, 15:17 Как. Не вызывается ни консоль, ни файловый менеджер, не менеджер управления пакетами.
