Перестал запускаться S.T.A.L.K.E.R.: Call of Pripyat. Решено.
kravetsa
Operating system: All
Сообщение kravetsa »
Всем доброго!
Моё железо Probe URL: https://linux-hardware.org/?probe=fd3a2fb571.
Выхлоп запуска из терминала:
andry@Z87-K ~ $ steam
Running Steam on rosadesktopfresh 2016.1 64-bit
STEAM_RUNTIME is enabled automatically
Pins up-to-date!
Steam client's requirements are satisfied
/home/andry/.local/share/Steam/ubuntu12_32/steam
[2020-06-04 11:12:24] Startup - updater built Jun 4 2020 05:50:42
[2020-06-04 11:12:24] Opted in to client beta 'publicbeta' via beta file
You are in the 'publicbeta' client beta.
Installing breakpad exception handler for appid(steam)/version(1591251555)
Looks like steam didn't shutdown cleanly, scheduling immediate update check
[2020-06-04 11:12:24] Checking for update on startup
[2020-06-04 11:12:24] Проверка на наличие обновлений...
[2020-06-04 11:12:24] Downloading manifest: client-download.steampowered.com/client/steam_client_publicbeta_ubuntu12
[2020-06-04 11:12:24] Download skipped by HTTP 304 Not Modified
[2020-06-04 11:12:24] Nothing to do
[2020-06-04 11:12:24] Проверка установки...
[2020-06-04 11:12:24] Performing checksum verification of executable files
[2020-06-04 11:12:25] Verification complete
Loaded SDL version 2.0.13-5893924
(steam:6216): Gtk-WARNING **: 11:12:25.482: Загружаемый модуль тем не найден в module_path: «adwaita»,
/usr/share/themes/Vertex-Light-Rospo/gtk-2.0/gtkrc:1163: error: unexpected identifier 'direction', expected character '}'
STEAM_RUNTIME_HEAVY: ./steam-runtime-heavy
[0604/111225.698071:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: browser
[0604/111225.723815:WARNING:crash_reporting.cc(286)] Failed to set crash key: UserID with value: 0
[0604/111225.723894:WARNING:crash_reporting.cc(286)] Failed to set crash key: BuildID with value: 1591249846
[0604/111225.723900:WARNING:crash_reporting.cc(286)] Failed to set crash key: SteamUniverse with value: Public
[0604/111225.723905:WARNING:crash_reporting.cc(286)] Failed to set crash key: Vendor with value: Valve
[0604/111225.770356:WARNING:crash_reporting.cc(286)] Failed to set crash key: UserID with value: 0
[0604/111225.770445:WARNING:crash_reporting.cc(286)] Failed to set crash key: BuildID with value: 1591249846
[0604/111225.770467:WARNING:crash_reporting.cc(286)] Failed to set crash key: SteamUniverse with value: Public
[0604/111225.770526:WARNING:crash_reporting.cc(286)] Failed to set crash key: Vendor with value: Valve
[0604/111225.771272:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: gpu-process
Warning: failed to set thread priority: set failed for 8: -1: setpriority() failed
Warning: failed to set thread priority: set failed for priority 8
Warning: support for elevated priorities is most likely unavailable, suppressing future warnings
CAppInfoCacheReadFromDiskThread took 70 milliseconds to initialize
[0604/111225.888224:WARNING:crash_reporting.cc(286)] Failed to set crash key: UserID with value: 0
[0604/111225.888286:WARNING:crash_reporting.cc(286)] Failed to set crash key: BuildID with value: 1591249846
[0604/111225.888295:WARNING:crash_reporting.cc(286)] Failed to set crash key: SteamUniverse with value: Public
[0604/111225.888302:WARNING:crash_reporting.cc(286)] Failed to set crash key: Vendor with value: Valve
[0604/111225.888875:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: utility
Proceed to auto login
CApplicationManagerPopulateThread took 235 milliseconds to initialize (will have waited on CAppInfoCacheReadFromDiskThread)
Opted-in Controller Mask for AppId 0: 0
(steam:6216): Gtk-WARNING **: 11:12:26.374: gtk_disable_setlocale() must be called before gtk_init()
(steam:6216): LIBDBUSMENU-GLIB-WARNING **: 11:12:26.430: Trying to remove a child that doesn't believe we're it's parent.
Fossilize INFO: Overriding serialization path: "/home/andry/.local/share/Steam/shader_cache_temp_dir_vk_64/fozpipelinesv4/steamapprun_pipeline_cache".
roaming config store loaded successfully - 6715 bytes.
migrating temporary roaming config store
BRefreshApplicationsInLibrary 1: 5ms
[0604/111229.014317:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
[0604/111229.066433:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
[0604/111229.110219:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
Failed to init SteamVR because it isn't installed
ExecCommandLine: "'/home/andry/.local/share/Steam/ubuntu12_32/steam'"
System startup time: 3.99 seconds
Warning: failed to set thread priority: set failed for 4: -1: setpriority() failed
Warning: failed to set thread priority: set failed for priority 4
[0604/111229.464130:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
[0604/111229.468740:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
BuildCompleteAppOverviewChange: 112
RegisterForAppOverview 1: 8ms
RegisterForAppOverview 2: 8ms
[41700]Non-Steam Controller Configs Enabled: 1
CAPIJobRequestUserStats - Server response failed 2
GameAction [AppID 41700, ActionID 1] : LaunchApp changed task to ProcessingInstallScript with ""
esync: up and running.
GameAction [AppID 41700, ActionID 1] : LaunchApp changed task to SynchronizingCloud with ""
GameAction [AppID 41700, ActionID 1] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 41700, ActionID 1] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 41700, ActionID 1] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 41700, ActionID 1] : LaunchApp continues with user response "CreatingProcess"
Opted-in Controller Mask for AppId 41700: 0
Game update: AppID 41700 "", ProcID 7007, IP 0.0.0.0:0
ERROR: ld.so: object '/home/andry/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
Starting app 41700
>>> Adding process 7007 for game ID 41700
GameAction [AppID 41700, ActionID 1] : LaunchApp changed task to WaitingGameWindow with ""
GameAction [AppID 41700, ActionID 1] : LaunchApp changed task to Completed with ""
>>> Adding process 7008 for game ID 41700
>>> Adding process 7009 for game ID 41700
ERROR: ld.so: object '/home/andry/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
>>> Adding process 7015 for game ID 41700
>>> Adding process 7017 for game ID 41700
>>> Adding process 7020 for game ID 41700
>>> Adding process 7022 for game ID 41700
>>> Adding process 7025 for game ID 41700
>>> Adding process 7039 for game ID 41700
>>> Adding process 7047 for game ID 41700
Game update: AppID 41700 "", ProcID 7015, IP 0.0.0.0:0
RecordSteamInterfaceCreation (PID 7015): SteamUtils009 / Utils
Setting breakpad minidump AppID = 41700
RecordSteamInterfaceCreation (PID 7015): SteamUser019 / User
Steam_SetMinidumpSteamID: Caching Steam ID: 76561198183417542 [API loaded no]
RecordSteamInterfaceCreation (PID 7015): SteamFriends015 / Friends
RecordSteamInterfaceCreation (PID 7015): SteamMatchMaking009 / Matchmaking
RecordSteamInterfaceCreation (PID 7015): SteamMatchMakingServers002 / MatchmakingServers
RecordSteamInterfaceCreation (PID 7015): STEAMUSERSTATS_INTERFACE_VERSION011 / UserStats
RecordSteamInterfaceCreation (PID 7015): STEAMAPPS_INTERFACE_VERSION008 / Apps
RecordSteamInterfaceCreation (PID 7015): SteamNetworking005 / Networking
RecordSteamInterfaceCreation (PID 7015): STEAMREMOTESTORAGE_INTERFACE_VERSION014 / RemoteStorage
RecordSteamInterfaceCreation (PID 7015): STEAMSCREENSHOTS_INTERFACE_VERSION003 / Screenshots
RecordSteamInterfaceCreation (PID 7015): STEAMHTTP_INTERFACE_VERSION002 / HTTP
RecordSteamInterfaceCreation (PID 7015): SteamController006 / Controller
RecordSteamInterfaceCreation (PID 7015): STEAMUGC_INTERFACE_VERSION010 / UGC
RecordSteamInterfaceCreation (PID 7015): STEAMAPPLIST_INTERFACE_VERSION001 / AppList
RecordSteamInterfaceCreation (PID 7015): STEAMMUSIC_INTERFACE_VERSION001 / Music
RecordSteamInterfaceCreation (PID 7015): STEAMMUSICREMOTE_INTERFACE_VERSION001 / MusicRemote
RecordSteamInterfaceCreation (PID 7015): STEAMHTMLSURFACE_INTERFACE_VERSION_004 / HTMLSurface
RecordSteamInterfaceCreation (PID 7015): STEAMINVENTORY_INTERFACE_V002 / Inventory
RecordSteamInterfaceCreation (PID 7015): STEAMVIDEO_INTERFACE_V002 / Video
RecordSteamInterfaceCreation (PID 7015): STEAMPARENTALSETTINGS_INTERFACE_VERSION001 / ParentalSettings
>>> Adding process 7064 for game ID 41700
Game update: AppID 41700 "", ProcID 7064, IP 0.0.0.0:0
RecordSteamInterfaceCreation (PID 7064): SteamUtils007 / Utils
RecordSteamInterfaceCreation (PID 7064): SteamUser017 / User
RecordSteamInterfaceCreation (PID 7064): STEAMAPPTICKET_INTERFACE_VERSION001 /
Unable to read VR Path Registry from C:\users\steamuser\Local Settings\Application Data\openvr\openvrpaths.vrpath
Fossilize INFO: Overriding serialization path: "/mnt/18ca8e6a-04f2-4b36-be60-4f31986b5ac1/GAMES/SteamLibrary/steamapps/shadercache/41700/fozpipelinesv4/steamapprun_pipeline_cache".
ERROR: Could Not Get Primary Adapter Handle
С аглицким у меня совсем никак. В чём причина, почему игра перестала запускаться ?
Вижу запись об отсутствии модуля. А что за модуль, мне не понятно. Могу я его добавить, или нет?
P.S. Проблема решена удалением файла user.ltx из папки _appdata_ игры. Спасибо Сергею из поддержки игры.
Z87-K/i7 4770K/GTX 1070
Puwok
Operating system: Linux Distros
Сообщение Puwok »
вот спасибо!!! я долго искал... :)
В качестве хобби модифицирую игры. Если кому интересно, можете скачать кс 1.6 со скинами из кс го моего творения на пробу.
Max Volkov
Operating system: W10
Сообщение Max Volkov »
Спасибо, попробую.
Вернуться в «Игры и Steam»
