проблемы после обновления
papahander
Operating system: rosa fresh R6
Сообщение papahander »
добрый день, при последнем обновлении возникла ошибка:
1 установочных транзакций не удались
Во время установки возникла ошибка:
installing package nimbus-icon-theme-2.20.2-12.noarch needs 17MB on the / filesystem
installing package gtk-clearlooks-engine-2.20.2-12.x86_64 needs 17MB on the / filesystem
installing package gtk-engines2-2.20.2-12.x86_64 needs 21MB on the / filesystem
installing package lib64atk1.0_0-2.28.1-1.x86_64 needs 21MB on the / filesystem
installing package atk1.0-common-2.28.1-1.x86_64 needs 21MB on the / filesystem
installing package opera-blink-68.0.3618.56-1.x86_64 needs 18MB on the / filesystem
installing package libatk1.0_0-2.28.1-1.i586 needs 18MB on the / filesystem
installing package lib64atk1.0-devel-2.28.1-1.x86_64 needs 18MB on the / filesystem
installing package chromium-browser-stable-81.0.4044.122-1.x86_64 needs 14MB on the / filesystem
Мало того, при установке любой программы вылетает ошибка:
installing package lib64ical1-1.0.1-3.x86_64 needs 404KB on the / filesystem
installing package lib64goa1.0_0-3.22.4-3.x86_64 needs 712KB on the / filesystem
installing package lib64camel1.2_59-3.22.5-1.x86_64 needs 2MB on the / filesystem
installing package lib64gsf-1_114-1.14.42-1.x86_64 needs 3MB on the / filesystem
installing package lib64aiksaurus1.2_0-1.2.1-11.x86_64 needs 3MB on the / filesystem
installing package lib64t1lib5-5.1.2-20.x86_64 needs 3MB on the / filesystem
installing package lib64champlain0.12_0-0.12.14-3.x86_64 needs 3MB on the / filesystem
installing package lib64loudmouth-1_0-1.5.3-3.x86_64 needs 4MB on the / filesystem
installing package lib64psiconv6-0.9.8-30.x86_64 needs 4MB on the / filesystem
installing package lib64geocode-glib0-3.20.1-3.x86_64 needs 4MB on the / filesystem
installing package lib64telepathy-glib0-0.24.0-5.x86_64 needs 6MB on the / filesystem
installing package lib64ots1_0-0.5.0-11.x86_64 needs 6MB on the / filesystem
installing package lib64oauth0-1.0.3-12.x86_64 needs 6MB on the / filesystem
installing package lib64link-grammar4-4.8.5-4.x86_64 needs 7MB on the / filesystem
installing package wayland-protocols-devel-1.17-1.noarch needs 7MB on the / filesystem
installing package libgdata-i18n-0.17.6-4.x86_64 needs 8MB on the / filesystem
installing package geocode-glib-3.20.1-3.x86_64 needs 8MB on the / filesystem
installing package telepathy-filesystem-0.0.1-13.noarch needs 8MB on the / filesystem
installing package libgweather-3.20.3-3.x86_64 needs 30MB on the / filesystem
installing package aiksaurus-data-1.2.1-11.x86_64 needs 31MB on the / filesystem
installing package lib64goffice0.10_10-0.10.32-3.x86_64 needs 33MB on the / filesystem
installing package lib64wv1.2_4-1.2.9-8.x86_64 needs 33MB on the / filesystem
installing package lib64gtkmathview0-0.8.0-11.x86_64 needs 37MB on the / filesystem
installing package t1lib-config-5.1.2-20.x86_64 needs 37MB on the / filesystem
installing package lib64champlain-gtk0.12_0-0.12.14-3.x86_64 needs 37MB on the / filesystem
installing package lib64gweather3_6-3.20.3-3.x86_64 needs 38MB on the / filesystem
installing package lib64gdata22-0.17.6-4.x86_64 needs 39MB on the / filesystem
installing package lib64epoxy-devel-1.5.4-1.x86_64 needs 41MB on the / filesystem
installing package lib64aiksaurus-devel-1.2.1-11.x86_64 needs 41MB on the / filesystem
installing package lib64xkbcommon-devel-0.7.2-1.x86_64 needs 41MB on the / filesystem
installing package lib64atspi-devel-2.24.1-1.x86_64 needs 43MB on the / filesystem
installing package lib64atk-bridge2.0-devel-2.24.1-1.x86_64 needs 43MB on the / filesystem
installing package lib64edataserver1.2_22-3.22.5-1.x86_64 needs 44MB on the / filesystem
А дополнительно virtualbox перестал запускаться
papahander
и половина программ перестала запускаться
Место на диске закончилось.
На корневом.
papahander
как освободить
у меня даже консоль не запускается
Попробуйте перезагрузить.
Может появится немного места после очистки /tmp
Или загрузиться с флешки, если есть загрузочная, и почистить раздел.
Наверное что-то в папку /var/log/ вам нафигачило.
Хотя может и другие варианты.
Sartorius
Сообщение Sartorius »
Можно вопрос - а как вообще можно почистить корневой раздел? Какие-то утилиты для этого есть?
papahander
загрузился с флешки и почистил. На диске мало места. Спасибо.
Sartorius
papahander писал(а): 29 апр 2020, 11:35 загрузился с флешки и почистил. На диске мало места. Спасибо.
А как? Чего удаляли?
papahander
в этой ситуации я "сам дурак". Корневой был забит по самое нехочу и система отказывалась совершкть любые действия даже послеперезагрузки. Загрузился с флэшки и удалил часть /var/log. После перезагрузки основная система ожила. Дальше снес все лишние программы, которые забили диск.
Sartorius
Спасибо, учту на будущее.
Сообщение notauser »
Похоже, nimbus-icon-theme-2.20.2-12.noarch
остался без лицензии и авторства. Возможно весь doc попал в другой пакет (который реально 2.20.2 :)), что, вроде как, не совсем соответствует взятому для сборки. Вы или магеевцы. Могу ошибаться, конечно, но всё-таки. :)
PS Похоже, оно такое не одно... Или может быть я не туда смотрел.
