usb modem not work with knetworkmanager plasma applet
cron
Сообщение cron »
I've updated from Mandriva 2011.0 to ROSA and now I can't connect with my usb modem using knetworkmanager plasma.
It detects my usb modem but never connects, i introduce my PIN but never save it.
Thanks
akdengi
Re: usb modem not work with knetworkmanager plasma applet
Сообщение akdengi »
Some workaround - try install networkmanager-applet, run it (like nm-applet) and try setup with it. If work, you will may replace for it.
cron
Сообщение cron »
it doesn't work too
In the NW in the connection properties include the PAP / CHAP / ... authentication. This option is disabled by default.
cron
Сообщение cron »
@PastorDi-> It doesn't work, nm-applet and kde-nm-applet don't save my PIN.
cron
What kind (model/name) of modem you're using?
Did it work in 2011? If so, did you set it up from MCC or from NM in 2011?
cron писал(а):@PastorDi-> It doesn't work, nm-applet and kde-nm-applet don't save my PIN.
Do you problem is not save PIN? Then reboot in Windows and in the program attached to your ISP, disable PIN code request.
Or in property your Mobile connections, the first tab on the contrary Mobile PIN from the drop down list, set the "Keep".
cron
Сообщение cron »
My usb-modem is K4505. Actually i don't have windows.
In mdv 2011.0 it worked ok from knetworkmanager-applet, and with kernel 3.1.6 mib it worked ok.
It seems now it saved my PIN correctly but it follows not connected. It is very strange
I'm using modemmanager 0..5..2 version.
Actually, my usb-modem only works with Sakis3G application.
Thanks
Do you mind if I ask you to file a bug on bugzilla? HERE
lisa
Сообщение lisa »
Hello,
I am new here and don't have my Rosa iso yet to try it, but I too have a usb dialup modem, so I will be following this bug. I often have problem where I can connect ok, but can't ping, that /etc/resolv.conf is empty after a connection is made when it should list nameservers.
Regards, Lisa
Lisa, do so, and welcome to the forums everybody! :)
lisa писал(а):Hello,
Regards, Lisa
Dialup modem - it's not 3G modem. This is different modems and different ways to connect. With dialup modem you need to use only KPPP. Typically, the first modem initialization string ATZ, second line ATQ0V1E1S0=0&C1&D2. Initialization string to dial: ATDP9999999999 or ATDT99999999999, where "99999999999" numer modem pull from your ISP and "P" - pulse dial, "T" - tone dial.
lisa
Сообщение lisa »
Hello, ДроноваЮ. Thank you for the welcome!
:oops: PastorDi . My first reply and I got it wrong. I did wonder what was meant by PIN.
Regards, Lisa
cron
Сообщение cron »
well, i've updated kernel to 3.2.18-nrj-netbook-1rosa.lts from MIB and all works good, 3.2.16 version fails about this theme.
linuxlover
Сообщение linuxlover »
I was having the same problem too.But then I installed nm-applet and everything seems to work fine with my 3g modem.I would like to replace the plasma network management applet with this one.Which packages should I remove?Please help.
linuxlover писал(а):I was having the same problem too.But then I installed nm-applet and everything seems to work fine with my 3g modem.I would like to replace the plasma network management applet with this one.Which packages should I remove?Please help.
plasma-applet-networkmanagement
linuxlover
Thank you VictorR2007.I have purged the kde network management plasma plugin and using network-applet.Working like a charm.Thanks again for the help.
Вернуться в «Marathon (ROSA LTS)»
