FrostWire не работает [РЕШЕНО]
Белослав
Operating system: ROSA Fresh R10 (Plasma 5)
Сообщение Белослав »
Ставил из стандартного "Установка и удаление программ":
Сначала кратковременно появляется экран загрузки:
Затем вылазит fatal error:
Гласящий:
FrostWire version 6.3.5 build 198
Java version 1.8.0_181 from Oracle Corporation
Linux v. 4.9.124-nrj-desktop-1rosa-x86_64 on amd64
Free/total memory: 44913696/62390272
FATAL ERROR!
java.lang.LinkageError: Look for your architecture binary instructions at: https://github.com/frostwire/frostwire-jlibtorrent
	at com.frostwire.jlibtorrent.swig.libtorrent_jni.<clinit>(libtorrent_jni.java:22)
	at com.frostwire.jlibtorrent.swig.torrent_alert.<clinit>(torrent_alert.java:55)
	at com.frostwire.jlibtorrent.alerts.AlertType.<clinit>(AlertType.java:11)
	at com.frostwire.bittorrent.BTEngine.<clinit>(BTEngine.java:46)
	at com.limegroup.gnutella.gui.Initializer.startBittorrentCore(Initializer.java:476)
	at com.limegroup.gnutella.gui.Initializer.initialize(Initializer.java:113)
	at com.limegroup.gnutella.gui.GUILoader.load(GUILoader.java:58)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.lang.reflect.Method.invoke(Method.java:498)
	at com.limegroup.gnutella.gui.Main.main(Main.java:80)
Caused by: java.lang.UnsatisfiedLinkError: no jlibtorrent in java.library.path
	at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1867)
	at java.lang.Runtime.loadLibrary0(Runtime.java:870)
	at java.lang.System.loadLibrary(System.java:1122)
	at com.frostwire.jlibtorrent.swig.libtorrent_jni.<clinit>(libtorrent_jni.java:17)
	... 11 more
-- class path --
frostwire.jar
-- listing session information --
Current thread: main
Active Threads: 6
Peak Number of Thread: 13
System Load Avg: 3.38
Objects Pending GC: 0
Free Space In Settings: 168689704960
Free Space In Incomplete:
Heap Memory Usage: init = 65011712(63488K) used = 17476576(17066K) committed = 62390272(60928K) max = 921174016(899584K)
Non-Heap Memory Usage: init = 2555904(2496K) used = 27544288(26898K) committed = 28098560(27440K) max = -1(-1K)
-- listing threads --
Deadlock Detection Thread: 1
IdleThread: 1
OkHttp ConnectionPool: 1
main: 1
AWT-EventQueue-0: 1
Thread-2: 1
-- listing properties --
INSTALLED=true
UX_STATS_ENABLED=false
COUNTRY=
FILECHOOSER_Y_POS=0
LAST_EXPIRE_TIME=1539266832572
FILECHOOSER_X_POS=0
Собственно, этот Фростваир мне бы даром не сдался. Нужен был торрент-клиент с возможностью предпросмотра видео во время скачки. Гугление первой ссылкой посоветовало FrostWire…
Последний раз редактировалось Белослав 18 окт 2018, 17:28, всего редактировалось 1 раз.
Survolog
Писать в Телеграм или ВК.
Сообщение Survolog »
На всякий случай выхлоп терминала:
$ frostwire
/usr/share/frostwire /mnt/data/survolog/Софт/Исходники/gimp/gimp-help-2/sites(2.10)(pngnq -e.png -f -n64)
HOSTNAME IS survolog-desktop
Starting FrostWire...
Java exec found in PATH. Verifying...
Suitable java version found [java = 1.8.0_181]
Configuring environment...
Loading FrostWire:
os.name="Linux"
Could not load properties from property file.
... 11 more
Something went wrong with FrostWire.
Maybe you're using the wrong version of Java?
(FrostWire is tested against and works best with with Sun's JRE, Java 1.7+)
The version of Java in your PATH is:
openjdk version "1.8.0_181"
OpenJDK Runtime Environment (build 1.8.0_181-b13)
OpenJDK 64-Bit Server VM (build 25.181-b13, mixed mode)
Белослав
Frostwire после последнего обновления заработал. Благодарю за оперативность! :good: Буду дальше испытывать…
