VirtualBox startup issues (D-Bus) - Linux
KaraL
Operating system: Rosa Linux
Сообщение KaraL »
Добрый день, установил из репозитория VirtualBox , при нажатии не запускается , при запуске из консоли выдает :
(gksu:10360): GConf-WARNING **: Client failed to connect to the D-BUS daemon:
Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Ошибка системы GConf: Служба D-BUS не запущена
проверил и включил d-bus
$ service dbus start
$ service dbus status
Redirecting to /bin/systemctl status  dbus.service
в—Џ dbus.service - D-Bus System Message Bus
   Loaded: loaded (/lib/systemd/system/dbus.service; static; vendor preset: disabled)
   Active: active (running) since Wed 2017-08-30 10:23:01 MSK; 43min ago
     Docs: man:dbus-daemon(1)
 Main PID: 7669 (dbus-daemon)
   CGroup: /system.slice/dbus.service
           в””в”Ђ7669 /bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
Aug 30 10:24:07 miller dbus[7669]: [system] Successfully activated service 'org.freedesktop.hostname1'
Aug 30 10:25:34 miller systemd[1]: Started D-Bus System Message Bus.
Aug 30 10:28:18 miller dbus[7669]: [system] Activating via systemd: service name='org.freedesktop.login1' unit='dbus-org.freedesktop.l....service'
Aug 30 10:29:08 miller dbus[7669]: [system] Failed to activate service 'org.freedesktop.login1': timed out
Aug 30 10:29:09 miller dbus[7669]: [system] Activating via systemd: service name='org.freedesktop.login1' unit='dbus-org.freedesktop.l....service'
Aug 30 10:29:59 miller dbus[7669]: [system] Failed to activate service 'org.freedesktop.login1': timed out
Aug 30 10:34:09 miller dbus[7669]: [system] Activating via systemd: service name='org.freedesktop.UDisks2' unit='udisks2.service'
Aug 30 10:34:09 miller dbus[7669]: [system] Successfully activated service 'org.freedesktop.UDisks2'
Aug 30 11:01:02 miller dbus[7669]: [system] Activating via systemd: service name='org.freedesktop.login1' unit='dbus-org.freedesktop.l....service'
Aug 30 11:01:52 miller dbus[7669]: [system] Failed to activate service 'org.freedesktop.login1': timed out
Hint: Some lines were ellipsized, use -l to show in full.
Но ситуация с VirtualBox не изменилась...
Подскажите в чем проблема.
Re: VirtualBox startup issues (D-Bus) - Linux
хотя бы какая платформа узнать и включены ли тестинги...
KaraL
Сообщение KaraL »
uname -a
Linux miller 4.9.41-nrj-desktop-1rosa-i586 #1 SMP PREEMPT Fri Aug 11 20:41:29 UTC 2017 i686 i686 i686 GNU/Linux
тестинги ... вы имеете в виду репозиторий testing?
Для разных платформ, разные версии ВиртуалБокса.
И даже для одной платформы в разных репозитория есть разные версии.
