unable to update after 4.1.34 nrj
dujevu
Operating system: rosa fresh R3
Сообщение dujevu »
Hi
I am using HP DV6 Notebook with Rosa Linux 4.1.34-nrj-desktop-2rosa-x86_64 #1 SMP PREEMPT
After the last update to 4.1.34 the system does not update, it always freezes when starting the update process after displaying the update window as in the attached screen shot and even when trying to install or remove software. The update process can not be stopped or killed even with kill command.
Any solution...
Thank you
Re: unable to update after 4.1.34 nrj
restore rpm base
dujevu
Сообщение dujevu »
I tried to do that using "rpm --rebuilddb" and some other methods I found on the net but did not work. Is there any method you can help with...
andreas
Operating system: Rosa Fresh R6 x64
Сообщение andreas »
I would try to launch rpmdrake from Konsole and read there the errors that are generated
dujevu
Сообщение dujevu »
Attached is an image after running rpmdrake and it also started the software management application which froze as before.
dujevu
Сообщение dujevu »
Hi is there any solution or do I need to reinstall Linux....
dujevu
Сообщение dujevu »
Hi and thank you for the help I found this article about restoring the rpm db helpful and it help me restore the rpm db on my laptop with a little changes..
http://people.redhat.com/berrange/notes ... overy.html
Вернуться в «Desktop»
