UEFI
UEFI
Hello
I have problem with Asus laptop X55A,it have UEFI , I tray install Rosa GNOME,because I see it have Uefi option,but I have Not success,I not find any
instruction or manual for install it.
Please HELP !!?
REGARDS
Goran
Please HELP !!?
REGARDS
Goran
Re: UEFI
What about special_builds/ —
http://mirror.rosalab.ru/rosa/rosa2014. ... .Fresh.R7/
http://mirror.rosalab.ru/rosa/rosa2014. ... al_builds/
and the newest iso —
https://abf.rosalinux.ru/platforms/rosa ... ists/15218
Linus Torvalds
Linus Torvalds
Re: UEFI
Hello !
Thanks for quickly replay !!
http://mirror.rosalab.ru/rosa/rosa2014. ... .Fresh.R7/ - Yes,from this link I download
ROSA.FRESH.GNOME.R7.x86_64.uefi.iso 20-Feb-2016 03:14 1551892480
I tray install it, but no success !
I already install Rosa on few laptop and pc for my friend, ( all is very satisfaction) but this laptop Asus X55A,have this UEFI !
http://mirror.rosalab.ru/rosa/rosa2014. ... al_builds/ - This link I see first time,I will tray install !
https://abf.rosalinux.ru/platforms/rosa ... ists/15218 - Also this link I see first time,I will tray install !
Problem is through installation in partition manager installer ask me - MAKE UEFI PARTITION - I make it but I don't to know how it must to be 500Mb or 10GB ??
Also I don't to know install procedure for UEFI !!?
REGARDS
Goran
REGARDS
Goran
Re: UEFI
On my new machine, I just switched uefi off in the 'bios' settings and switched legacy on instead; then I installed ROSA.
Linus Torvalds
Linus Torvalds
Re: UEFI
Hello !
I understand,I also tray to switch,I find on YouTube how to switched on Asus X55A , but in this laptop (from my friend) in BIOS Not have this option,I CAN NOT switch it-That is problem !!!
And because that I need some instruction for install Rosa on UEFI !
REGARDS
Goran
REGARDS
Goran
- Zeffanyx
Re: UEFI
UEFi is equally supported in all recent ROSA images, regardless of desktop environment used by default. Just boot in the live mode and issue the # efibootmgr to find out whether you booted in UEFI or in legacy mode. In case of UEFI there will be EFI variables in your output - that means there's no issue.gogovan писал(а):Hello
Goran
Re: UEFI
Hello ! I again !!
Download ROSA.FRESH.KDE.R7.15218.b.x86_64.uefi.iso - 2016-05-26 - Latest version
1. Shrink windows partition and give install : Use the free space on a Microsoft Windows partition - I think this is better !!
But after finish installations I get this message :
Coping file (sync) failed with code 23
That is firs way on which I tray install on UEFI Rosa.
Later I will tray install : Custom disc partitions !
I already install on a few PC and Laptop Rosa,but without UEFI , and that it is not problem for me , but UEFI is something else !!??
REGARDS
Goran
REGARDS
Goran
Re: UEFI
According to man rsync,
in other words, it means either lack of permissions or insufficient / unavailable space. Perhaps, it would be reasonable to create partitions manually (including EFI partition which must be not less than 35 Mb and labeled as EFI) and then try to install the system “on the existing partitions”.
23 Partial transfer due to errorTalk is cheap. Show me the code.
Linus Torvalds
Linus Torvalds
Re: UEFI
Hello !
I create partitions manually , on this link is photo step by step - please check it if I do some wrong !?
https://www.photobox.co.uk/album/temporary
Installations is finished without any problem,but I not get last photo IMG_20160531_211204 - (It is from other PC) - BOOT LOADER !!!
What I need to do for get Boot Loader (grub2) ?
When I before install Rosa on PC or Laptop without UEFI ,always do manually partition and it perfectly working !!!!
REGARDS
Goran
REGARDS
Goran
