Не работает левая кнопка тачпада
В первый раз с таким сталкиваюсь.
Система Rosa R6 64-bit.
Ноутбук Lenovo B50
lsusb:
Bus 001 Device 002: ID 8087:8000 Intel Corp.
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 005: ID 138a:0011 Validity Sensors, Inc. VFS5011 Fingerprint Reader
Bus 002 Device 004: ID 0bda:b728 Realtek Semiconductor Corp.
Bus 002 Device 003: ID 5986:0652 Acer, Inc
Bus 002 Device 002: ID 0458:003a KYE Systems Corp. (Mouse Systems) NetScroll+ Mini Traveler / Genius NetScroll 120
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
lspci:
00:00.0 Host bridge: Intel Corporation Haswell-ULT DRAM Controller (rev 0b)
00:02.0 VGA compatible controller: Intel Corporation Haswell-ULT Integrated Graphics Controller (rev 0b)
00:03.0 Audio device: Intel Corporation Haswell-ULT HD Audio Controller (rev 0b)
00:14.0 USB controller: Intel Corporation Lynx Point-LP USB xHCI HC (rev 04)
00:16.0 Communication controller: Intel Corporation Lynx Point-LP HECI #0 (rev 04)
00:1b.0 Audio device: Intel Corporation Lynx Point-LP HD Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation Lynx Point-LP PCI Express Root Port 1 (rev e4)
00:1c.1 PCI bridge: Intel Corporation Lynx Point-LP PCI Express Root Port 2 (rev e4)
00:1c.2 PCI bridge: Intel Corporation Lynx Point-LP PCI Express Root Port 3 (rev e4)
00:1c.3 PCI bridge: Intel Corporation Lynx Point-LP PCI Express Root Port 4 (rev e4)
00:1d.0 USB controller: Intel Corporation Lynx Point-LP USB EHCI #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation Lynx Point-LP LPC Controller (rev 04)
00:1f.2 SATA controller: Intel Corporation Lynx Point-LP SATA Controller 1 [AHCI mode] (rev 04)
00:1f.3 SMBus: Intel Corporation Lynx Point-LP SMBus Controller (rev 04)
02:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5229 PCI Express Card Reader (rev 01)
08:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 10)
09:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8723BE PCIe Wireless Network Adapter
В остальном тачпад работает: движения есть, жесты есть, тап есть и даже правая физическая кнопка вызывает контекстное меню. А вот левая вообще ничего не делает. Проверил на живой флешке с убунтой - там всё работает.
Что это может быть?
Re: Не работает левая кнопка тачпада
Zeffanyx писал(а):В первый раз с таким сталкиваюсь.
Ноутбук Lenovo B50
lsusb:
lspci:
Что это может быть?
su
hw-probe -all -upload -id PC_NAME
Заслать пробу - хорошая идея, но саму проблему это не решает. В настройках kcm_touchpad до фига опций, но про физические кнопки под тачпадом ничего нет.
я бы разные ядра попробовал поставить. Те же НикКовские, например.
