screen record video
qap
Operating system: ROSA R5, Netrunner 14
screen record video
Сообщение qap »
As a normal everyday user I like what I see in ROSA R5, but I miss one practical functionality and it is screen recording.
The ROSA video player has this option, but it is not good enough and the player is using like 100% of my cpu i3. I can not record just selected parts of the screen or just windows, can not choose between microphone or line in, can not choose video output, can not pause and then continue when I wish. For the moment I have to use ffmpeg, which is much better then ROSA player record option, but still not satisfying for me.
I would be more then happy to see vokosreen or ssr*(simple screen recorder) in ROSA :)
So if anyone has the time and knows how to put together ROSA package for vokoscreen with all dependencies I will be really using ROSA with gladness.
Thank you in advance!
Here is a video I made with ffmpeg if someone really wish to see that I use ROSA
http://vk.com/video231695057_171217372
Re: screen record video
You can use the FDesktopRecorder, qt-recordmydesktop and recorditnow.
ShalokShalom
Сообщение ShalokShalom »
qap писал(а):I would be more then happy to see vokosreen or ssr*(simple screen recorder) in ROSA :)
Simple Screen Recorder is in the Repos: http://i.imgur.com/487F3hW.png
Soever, you have to change from "show all Apps with a GUI" to "show all Apps" in rpmdrake. (the graphical Package Manager.)
You can choose between 0.1.2 and 0.3.1 and this Tool is only available for 64 Bit.
urpmi simplescreenrecorder work as well. :)
qap
Сообщение qap »
Thank you so much!!!
I didn't knew SSR is available :D
Great job done!!!
Now I am in love with ROSA!
ShalokShalom
Denis Silakov solve this Issue:
"Advisory:
Updated list of gui packages in rpmdrake - added Simplescreenrecorder and a lot of other applications.
Build lists:
https://abf.io/build_lists/2422829
https://abf.io/build_lists/2422830"
http://bugs.rosalinux.ru/show_bug.cgi?id=5019#c1
Вернуться в «ROSA Fresh R4-R7 (2014.1)»
