[solved] PAE
[solved] PAE
Is Rosa Desktop Fresh R1 included PAE ???
I just installed my new rams and i wanna be sure that it is ok with my system as it is 32 bit...
Thanks.
Thanks.
Последний раз редактировалось Majestic 22 окт 2013, 01:19, всего редактировалось 2 раза.
Think twice before giving a decide...
Re: PAE
# LC_ALL=POSIX urpmi -a --test pae
<blah-blah-blah...>
(test only, installation will not be actually done)
Package Version Release Dist DEpoch Arch
(medium "main")
texlive-ipaex 20111103 4 rosa 2012.1 noarch
(medium "main updates")
kernel-nrj-desktop-pae-3.8.12> 1 1 rosa 2012.1 i586
kernel-nrj-desktop-pae-devel-> 1 1 rosa 2012.1 i586
kernel-nrj-laptop-pae-3.10.9-> 1 1 rosa 2012.1 i586
kernel-nrj-laptop-pae-devel-3> 1 1 rosa 2012.1 i586
kernel-nrj-laptop-pae-devel-l> 3.10.9 1 rosa 2012.1 i586
kernel-nrj-laptop-pae-latest 3.10.9 1 rosa 2012.1 i586
163MB of additional disk space will be used.
102MB of packages will be retrieved.
Proceed with the installation of the 7 packages? (Y/n) or
allllbbbert
Re: PAE
А как включить поддержку PAE/ выбрать ядро с PAE установив все пакеты?
Нашёл несколько рецептов (пр. http://unixblog.in.ua/ram-больше-4гб-на ... ernel-pae/), но они для других дистрибутивов и не подходят.
Re: PAE
In order to install this kernel you have to install 'kernel-nrj-laptop-pae-latest' then reboot. The most recently installed kernel becomes the default kernel to boot. After reboot run XFdrake and install again NVidia/ATI drivers if needed then reboot again. That's it.
Re: PAE
If you need to use proprietary video drivers like Ati and/or Nvidia, Virtualization soft like VirtualBox or VMWare, or other soft needing rebuild their modules, you ever need to install also the -devel packages, so you must add another metapackage to your install, otherwise you can't use XFdrake properly...
so, for your desktop PC
or for your laptop PC
Each of those metapackages will call with them and install the most recent PAE flavour kernel available in the repository
For the most recent Kernel 3.10 available, that now is 3.10.12, even if not QA tested like 3.10.9 has been, you can add the specific Kernel 3.10 repo, with which you can always stay updated with mainstream lts 3.10
Examples for ROSA Fresh:
for ROSA Fresh i586 (for PAE and others...)
for ROSA Fresh x86_64 (all flavours, no PAE need for 64 bit
bye, NicCo
- kernel-nrj-desktop-pae-devel-latest
- kernel-nrj-desktop-pae-latest
# urpmi kernel-nrj-desktop-pae-devel-latest kernel-nrj-desktop-pae-latest- kernel-nrj-laptop-pae-devel-latest
- kernel-nrj-laptop-pae-latest
# urpmi kernel-nrj-laptop-pae-devel-latest kernel-nrj-laptop-pae-latestFor the most recent Kernel 3.10 available, that now is 3.10.12, even if not QA tested like 3.10.9 has been, you can add the specific Kernel 3.10 repo, with which you can always stay updated with mainstream lts 3.10
# urmi.addmedia Kernel_3.10 --update http://abf.rosalinux.ru/downloads/kernels_3_10x_personal/repository/rosa2012.1/i586/main/release/Код: Выделить всё
# urmi.addmedia Kernel_3.10 --update http://abf.rosalinux.ru/downloads/kernels_3_10x_personal/repository/rosa2012.1/x86_64/main/release/
Последний раз редактировалось NicCo 23 окт 2013, 10:48, всего редактировалось 6 раз.
Re: PAE
Thank you very much. I will try as i am at home..
I report you for the result.
Thanks again.
Thanks again.
Re: PAE
i tried 2 times but not installing neither on software manager nor console....
and also i saw i have a very old kernel, which is not even seen on updates... what can be wrong?
Thanks.
And a long update needed... i saw.. making update then will try pae again...
Thanks.
[root@localhost majestic]# urpmi -a pae
Packages gcc-4.7.3_2012.10-3.1-rosa2012.1.i586, sysfsutils-2.1.0-20-rosa2012.1.i586, kernel-firmware-20120909-1-rosa2012.1.noarch, dracut-027-4-rosa2012.1.i586, kmod-9-9-rosa2012.1.i586, texlive-ipaex-20111103-4-rosa2012.1.noarch, bootloader-utils-1.15-9-rosa2012.1.noarch, libncurses-devel-5.9-6.20120811.1-rosa2012.1.i586, make-3.82-6-rosa2012.1.i586, glibc-devel-2.15-8-rosa2012.1.i586, perl-base-5.14.2-8-rosa2012.1.i586, perl-5.14.2-8-rosa2012.1.i586, glibc-2.15-8-rosa2012.1.i586 are already installed
(medium "main updates (distrib2)")
kernel-nrj-desktop-pae-devel-> 3.8.12 2 rosa 2012.1 i586
kernel-nrj-desktop-pae-latest 3.8.12 2 rosa 2012.1 i586
67MB of additional disk space will be used.
43MB of packages will be retrieved.
Proceed with the installation of the 4 packages? (Y/n) y
$MIRRORLIST: media/main/updates/kernel-nrj-desktop-pae-latest-3.8.12-2-rosa2012.1.i586.rpm
...retrieving failed: 0B/s|/var/cache/urpmi/partial/kernel-nrj-desktop-pae-latest-3.8.12-2-rosa2012.1.i586.rpm
aria2 failed: exited with 3
Failed to download kernel-nrj-desktop-pae-latest-3.8.12-2-rosa2012.1.i586.rpm
Retry? (y/N) y
Retry? (y/N) y
Re: PAE
With latest fully update (by the way i fixed an update problem, software medias) then installing all "pae" packages as in the picture you sent, it is working great.
Spasibo
Spasibo
Re: [solved] PAE
The most recent version is longterm Kernel 3.10.17:
if you installed the kernel 3.10 repo as I suggested, in the example, you should have this version
More Info on Kernels 3.10.17:
http://forum.rosalab.ru/viewtopic.php?f ... 815#p20815
bye, NicCo
bye, NicCo
Re: [solved] PAE
No, i installed from the software center choosing 4 packages.
-kernel-nrj-desktop-pae-3.10.9-1rosa
-kernel-nrj-desktop-pae-devel-3.10.9-1rosa
-kernel-nrj-desktop-pae-devel-latest
-kernel-nrj-desktop-pae-latest
i choosed these and installed. this solved pae problem, ram is showing 4gb now. But if you offer me that what i should do in this case now? And for sure i would like to have latest kernel....
Sincerely.
Sincerely.
Re: [solved] PAE
I already wrote this, but here below I'm repeating the related partMajestic писал(а):i choosed these and installed. this solved pae problem, ram is showing 4gb now. But if you offer me that what i should do in this case now?
Sincerely.
If you add the repository called "Kernel_3.10", you can receive all the most recent kernel versions, now is 3.10.17, soon will be 3.10.18, and so on...NicCo писал(а): For the most recent Kernel 3.10 available, that now is 3.10.12, even if not QA tested like 3.10.9 has been, you can add the specific Kernel 3.10 repo, with which you can always stay updated with mainstream lts 3.10
for ROSA Fresh i586 (open a Konsole windows, log as 'root' user, copy the below text, press Enter, start the updates > You'll see new kernels)bye, NicCoКод: Выделить всё
on average, every week, a new kernel version, with few new drivers and some fixes, is released. - occasionally remove older versions, no longer used!
bye, NicCo
Re: [solved] PAE
Thank you Nicco...
I have missed that part of your message as i was involved to get pae first....
I am realy appreciate.
