Recommended sites-related with Linux
Non-Desktop related topics
dareksmok
i5-4570 CPU @ 3.20GHz
NVIDIA GeForce GT 1030
8 GB RAM
Сообщение dareksmok »
Linux Free Software Catalog and Packages Search: http://pkgs.org/
ROSA Fresh R10 MATE - 64 bit
dareksmok
8 GB RAM
Re: Recommended sites-related with Linux
DVB - TV LINUX
Hardware Device Information - http://www.linuxtv.org/wiki/index.php/H ... nformation
dareksmok
8 GB RAM
Free Master PDF Editor for Linux
Master PDF Editor a convenient and smart XPS and PDF editor for Linux.
Master PDF Editor provides you advanced functions for working with PDF and XPS formats:
• Createnew PDF and XPS files or edit existing ones.
• Add and/or edit bookmarks in PDF files.
• Encrypt and/or protect PDF files using 128 bit encryption.
• Convert XPS files into PDF.
• Add PDF controls (like buttons, checkboxes, lists, etc.) into your PDFs.
• Import/export PDF pages into commong raphical formats including BMP, JPG, PNG, and TIFF.
• Free PDF Editor on Linux ( for non-commercial use)
The type of portable, download and unzip the file, then go to the directory and run the program by pressing twice on the file named "pdfeditor". Change the language using: Change the language using: Tools-> Settings-> Language-> .............-> OK
http://code-industry.net/free-pdf-editor.php
tried to:ROSA.MARATHON.GNOME.2012
2013.09.25
MasterPDFEditor-1.9.10-Stan8-rosa2012.1.i586.rpm -> http://abf-downloads.rosalinux.ru/stan8 ... n/release/
Последний раз редактировалось dareksmok 25 сен 2013, 23:25, всего редактировалось 2 раза.
dareksmok
8 GB RAM
XnConvert is a powerful and free cross-platform batch image processor, allowing you to combine over 80 actions. Compatible with 500 formats. It uses the batch processing module of XnViewMP.
http://www.xnview.com/en/xnconvert.php
Note - The installer "XnConvert.i386.rpm" can be broken, so I recommend to download archives "XnConvert-linux.tgz".
Последний раз редактировалось dareksmok 14 дек 2013, 18:46, всего редактировалось 1 раз.
dareksmok
8 GB RAM
dareksmok
8 GB RAM
dareksmok
8 GB RAM
Nightingale chirps your favorite tunes!
A beautiful interface with a wide range of supported audio formats, all with multi-platform support!
http://getnightingale.com/
After unpacking the archives, go into the directory and run the two clique file called "nightingale", followed by [Start] - the program will start after a few seconds.
dareksmok
8 GB RAM
Repository - created by user "Stan8" Mandriva.Org.PL forum for distribution ROSA Fresh ->http://mandriva.org.pl/forum/17-konfigu ... .html#6105
Manually download packages -> http://abf-downloads.rosalinux.ru/stan8 ... n/release/
Recommended packages:
enemy-territory-2.60b-Stan8-rosa2012.1.i586.rpm -> http://www.splashdamage.com/content/wol ... y-barracks
truecrypt-7.1a-Stan8-rosa2012.1.i586.rpm -> http://www.truecrypt.org/
task-codecs-2.0-Stan8-rosa2012.1.noarch.rpm + ( libstdc++5-3.3.6-4mdv2009.0.i586.rpm ) -> http://rpm.pbone.net/index.php3/stat/4/ ... 6.rpm.html
kadu-0.12.3-Stan8-rosa2012.1.i586.rpm -> http://www.kadu.im/w/English:Main_Page
1#
instal
urpmi packagekit-gtk-module
2# system updates
3#
When you start Kadu - appears "It seems your Qt library does not provide support for selected database. Please install Qt with QSQLITE plugin".
install
urpmi qt4-database-plugin-sqlite
xnviewmp-0.61-Stan8-rosa2012.1.i586.rpm -> http://www.xnview.com/en/xnviewmp/
2013.09.04
's homepage "Stan8" ->> http://rosalinux.strefa.pl/#
dareksmok
8 GB RAM
VLC - Skin
Alieware VLC Invader - http://addons.videolan.org/content/show ... ent=160460
needs
1 # Install vlc + svlc
urpmi vlc
urpmi svlc
2 # Download and unzip archives - "AlienWareVLCInvader.zip"
3 # Configure VLC (run VLC)
Tools-> Preferences - (photo below)
Use custom skin -> Save - (photo below)
Then restart VLC
Interface-> Open skin (specify the file location "AlienwareVLCInvader.vlt" - (photo below)
dareksmok
8 GB RAM
Rainlendar2
Rainlendar is a customizable calendar application which stays out of your way
but keeps all your important events and tasks always visible on your desktop.
http://www.rainlendar.net/cms/index.php ... &Itemid=35
needs:
# Linux distributions should work too
32bit or 64bit operating system
# 20 MB of available hard disk space
# 512 MB of RAM or higher recommended
# Window manager capable of showing transparent windows
" Window manager capable of showing transparent windows" - Get the first run, and save the configuration Cairo-Dock
urpmi cairo-dock
Rainlendar2 - recommended version 32 bit -> http://www.rainlendar.net/download/Rain ... 86.tar.bz2
libjpeg62-1.1.1-3-rosa.lts2012.0.i586.rpm
urpmi libjpeg62
More ->http://www.rainlendar.net/download/
Последний раз редактировалось dareksmok 13 окт 2014, 21:54, всего редактировалось 2 раза.
dareksmok
8 GB RAM
Zero Ballistics
http://www.zeroballistics.com/
Zero Ballistics is a unique blend of first person shooter and tank combat, focusing on multiplayer gaming exclusively. To learn more about the details, read the Game section.
zero-ballistics-2.0-Stan8-rosa2012.1.i586.rpm 31-Oct-2013 21:41 http://abf-downloads.rosalinux.ru/stan8 ... n/release/
Edit 12.03.2014
zero-ballistics-2.0-2.Stan8-rosa2012.1.x86_64.rpm 20-Feb-2014 20:11 http://abf-downloads.rosalinux.ru/stan8 ... n/release/
Последний раз редактировалось dareksmok 12 мар 2014, 22:19, всего редактировалось 1 раз.
dareksmok
8 GB RAM
Savage 2
Home http://www.savage2.com/en/download.php
Info http://www.desura.com/games/savage-2-a-tortured-soul
TANK@WAR
Home http://tankatwar.com/download/
Info http://www.desura.com/games/tankwar
PlaneShift
Home http://www.planeshift.it/download.html
Info http://www.desura.com/games/planeshift
Projekt “W” – Phase 2
Home http://www.saschawillems.de/?page_id=829
Info http://www.desura.com/games/projekt-w-phase-2
dareksmok
8 GB RAM
Kingsoft Office
Info: http://www.techlw.com/2013/05/kingsoft- ... edora.html
kingsoft-office-9.1.0.4207-0.1.a12p2.i686.rpm http://wps-community.org/download.html
dareksmok
8 GB RAM
FastPhotoTagger
FastPhotoTagger - http://sourceforge.net/projects/fastphototagger/
FastPhotoTagger tries to be the fastest way to set the metadata tags in your photos. By defining abbreviations for the most common tag values, you can tag an image with a few keystrokes in a matter of seconds and then view the tags in a slideshow.
With FastPhotoTagger, you can
- Set multiple images to have the same tag values
- Set individual images to have unique tag values
- Choose the metadata fields to work with
- Define abbreviations for the most common tag values
- Modify or undo tag changes before committing to image files
- View images and slideshows that display tag values as captions
- Create and search a metadata database
FastPhotoTagger uses ExifTool to read & write tags and HyperSQL to manage its database.
1 - ExifTool -
urpmi perl-Image-ExifTool
info: ExifTool provides an extensible set of perl modules to read and write meta information in image, audio and video files, including the maker note information of many digital cameras by various manufacturers such as Canon, Casio, FujiFilm, JVC/Victor, Kodak, Leaf, Minolta/Konica-Minolta, Nikon, Olympus/Epson, Panasonic/Leica, Pentax/Asahi, Ricoh, Sanyo and Sigma/Foveon.
/usr/bin/exiftool
2 - Java: http://www.java.com/en/download/linux_manual.jsp
FastPhotoTagger.jar OPEN
Последний раз редактировалось dareksmok 21 янв 2014, 01:01, всего редактировалось 2 раза.
dareksmok
8 GB RAM
VietOCR
VietOCR - http://sourceforge.net/projects/vietocr/
Features
# Java & .NET GUI frontends for Tesseract OCR engine
# Supports all languages provided by Tesseract
# Supports automatic download and installation of language packs
# PDF, TIFF, JPEG, GIF, PNG, BMP image formats
# Paste image from clipboard
# Selection box for Region of Interest (ROI)
# File drag-and-drop
# Bulk & batch operations
# Text replacement postprocessing
# Integrated scanning support
# Spellcheck with Hunspell
dareksmok
8 GB RAM
Gameplay Football - http://www.properlydecent.com/
Последний раз редактировалось dareksmok 25 фев 2014, 18:49, всего редактировалось 1 раз.
dareksmok
8 GB RAM
Nyagua
A java based aquarium management database.
Nyagua - http://sourceforge.net/projects/nyagua/ ... =directory
dareksmok
8 GB RAM
Copy is a cloud-based file storage, sync and sharing platform, similar to Dropbox or Google Drive, which has clients available for Linux (including Raspberry Pi), Windows, Mac OS X as well as iOS, Android and Windows Mobile.
Copy info -> http://www.webupd8.org/2014/06/install- ... tu-or.html
Copy -> https://www.copy.com/home/
Download for Linux 32bit and 64bit https://copy.com/install/linux/Copy.tgz
copy-> x86-> CopyAgent (32bit)
copy-> x86_64-> CopyAgent (64bit)
dareksmok
8 GB RAM
Max Remote http://bitunitsstudio.com/max-remote.html
Description
Max Remote turns your Android device into a universal remote WiFi to your computer. With it you have complete control over the mouse, keyboard, slide shows, video players your favorite games and more. Max Remote is available for free download on Google Play.
Controls
In Max Remote you can create your own remotes with up to 20 buttons, and you can choose the icon and the sequence of keys to each button. There you will also find a collection of various types of controls for key functions of the computer, know a bit more about them .......
Android https://play.google.com/store/apps/deta ... .maxremote
Linux Max Remote Server.jar http://bitunitsstudio.com/max-remote-server.html
Java http://www.java.com/en/download/linux_manual.jsp
dareksmok
8 GB RAM
StreamRipStar is a java written graphical frontend (gui) for streamripper, which saves separate options for each stream. In addition is has a scheduler and can load stream from the web.
StreamRipStar http://sourceforge.net/projects/strippe ... =directory
Edit 08.02.2015
urpmi streamripper
Streamripper records shoutcast compatible and live365 streams. For shoutcast style streams it finds the "meta data" or track separation data, and uses that as a marker for where the track should be separated. For live365 streams it hits the website and finds when a track has changed. Either way, the MP3 data will be decoded and scanned for a silent point which is where tracks will be created. http://pkgs.org/rosa-2014.1/rosa-contri ... 6.rpm.html
TeXLive uri package. http://pkgs.org/rosa-2014.1/rosa-main-r ... h.rpm.html
urpmi texlive-uri
Edit 07.03.2015
Since in the case of programs written in Java, is not always the option to "Copy" and "Paste" from the context menu. Use the following key combination:
Ctrl + c
= "Copy"
Ctrl + v
= "Paste"
Последний раз редактировалось dareksmok 01 янв 2016, 12:27, всего редактировалось 4 раза.
awl
Сообщение awl »
dareksmok писал(а):StreamRipStar is a java written graphical frontend (gui) for streamripper, which saves separate options for each stream. In addition is has a scheduler and can load stream from the web.
Excellent application!
Thank you very much for the info about this program.
OMNE NIMIUM NOCET
dareksmok
8 GB RAM
Substitutes programs on Linux: http://alternativeto.net/?platform=linux
(Zamienniki programów na linux-a)
dareksmok
8 GB RAM
Aura http://www.umopit.ru/AuraEng.htm
Aura is a desktop utility that uses soothing nature sounds in order to create a comfortable atmosphere.
The program appears as an icon in the system tray and plays real delectable sounds of a forest.
A click on the icon turns on or off the sounding. Right click opens the Aura Control Board.
File Aura.zip (118,377 K) http://umopit.ru/Aura.zip
Tested ROSA Fresh R6 MATE (wine 1.57.2)
Virtual Ambience 1.0: http://transonix.20m.com/
Downloads: https://db.tt/23Qmet7I
Features:
# Background ambience noise with random volume controls.
# Sound effects with random panning and volume controls.
# Randomize button.
# 6 pre-loaded scenarios.
# Auto mode that controls the sounds settings with a changeable aggression level.
# Able to run from system tray
A Funny Photo Maker!
Funny Photo Maker helps edit photos with 300+ splendid photo frames, face fun, artistic effects & collage, export photos in image file and GIF animation, and easily turns your photos into artistic and interesting masterpiece!
Funny Photo Maker http://www.funny-photo-maker.com/
dareksmok
8 GB RAM
Search drivers for printers EPSON:
Wyszukiwarka sterowników do drukarek EPSON: http://download.ebz.epson.net/dsc/searc ... FromResult
dareksmok
8 GB RAM
Keybord Test Online
Test klawiatury i myszki online. http://en.key-test.ru/index.html
