Hello,
autologin generally works in ROSA Marathon 2012 LXDE (32 bit) but only with ATI opensource driver. If Catalyst driver is used seems that x server is initiated and then restarted and user is prompted by display manager for his password despite the fact autologin is enabled for my user and LXDE session.
Is it possible to have autologin with catalyst drivers (fglrx) and, if yes, how to do it? Thank you.
Autologin in ROSA Marathon LXDE
Последний раз редактировалось Laskaris 12 мар 2013, 14:51, всего редактировалось 2 раза.
Re: Autologin in ROSA Marathon LXDE
Hello, can you please attach /var/log/Xorg.0.log and /var/log/messages ?
Hello Vegatron,Vegatron писал(а):Hello, can you please attach /var/log/Xorg.0.log and /var/log/messages ?
attached please find both requested files. Thank you for your feedback!
- Вложения
- files.zip
- Requested files packed in zip format
- (445.88 КБ) 947 скачиваний
edit: Not solved. After thorough testing I find power management for ATI cards as bad as before even with newest kernels. Performance is somewhat better but not power management
If someone can help with this issue please post your solution-proposal here. Thank you.
Последний раз редактировалось Laskaris 12 мар 2013, 14:53, всего редактировалось 1 раз.
