[SOLVED] Rosa sync problem
- 100janovic
Hi,
As a new forum member and a rookie user of the Rosa desktop, I found the problem with the advertised RosaSync feature and I don't know how to proceed.
The RosaSync client (http://wiki.rosalab.ru/en/index.php/ROSA_Sync_Client) defaults to opening an account at mandrivasync.com which is offline.
I found that I'd need to register on https://www.2safe.com/.
After that, I used the registered username and password from 2safe account to log-in with RosaSync client.
To my surprise, the RosaSync Client would not accept that account data.
Am I supposed to provide the correct URL of the sync server and how / where?
Thanks in advance.
100janovic
Thanks in advance.
100janovic
Последний раз редактировалось 100janovic 09 окт 2012, 01:24, всего редактировалось 2 раза.
Virtualbox: ROSA 2012 Marathon EE x86_64 | Kernel 3.4.11 nrj-desktop | KDE 4.8.4
Laptop: ROSA 2012 Marathon EE i686 | Kernel 3.0.28 nrj-netbook 2 | KDE 4.8.3 | NVIDIA 295.40
Re: Rosa sync problem
You may need to update your system.
It seems to have a problem with kwallet.
The latest versions of KDE to be corrected.
- 100janovic
I use the latest (?) KDE Platform Version 4.8.3 (4.8.3).
I do not remember.
It seems to have fixed in version 4.8.5.
You need to create a profile in kwallet.
I can not tell in English, how to do it.
Sorry.
Sorry.
- 100janovic
Victor,
I have tried option "Don't use KDE Wallet" and the problem is still here.
I have also upgraded KDE to platform version 4.8.5.1
I still have the same error message from ROSA Sync
Error connecting to server.
100janovic
You may want to use our helpdesk and ask for help there (in English). See the link on the pinkish "forum rules" section on top of this forum.
After I have read those guidelines http://wiki.rosalab.ru/en/index.php/Gui ... vice_2Safe100janovic писал(а):Victor,
I tried to change line 5 in ~/.psyncclient/sync.cfg to
address = "dav.2safe.com";Unfortunately when I clicked on Account setting button it tryed to open https://www.mandrivasync.com, so do not click on it.
I also tried to find some more info, and I found this bug report
http://bugs.rosalinux.ru/show_bug.cgi?f ... ple&id=494
Basically, you can try what Sergey A. Sokolov suggested in last post in that bug report (same thing I did, but with use of sed) or you can try to set 2safe as WebDAV following guidelines from first link.
- 100janovic
Thank you Viking,
your reply solved it. I've found the /mnt/LoginName method very useful.
- 100janovic
I would like to suggest to admin to mark the topic as [solved].
Done, but users can do it, too, by editing the subject line in the first post in the thread100janovic писал(а):I would like to suggest to admin to mark the topic as [solved].
- 100janovic
Re: Rosa sync service problem
This is probably not the ROSA issue, but still, I'll try to post the problem here.
As from last couple of days I receive the error: "Server interaction error" as the sync attempt fails.
Can anyone decode this error message and point me to right place to look for answers?
- 100janovic
The problem has been solved today, after psync client has received an update.
