Сломал менеджер пакетов(dnfdragora)
Polevic
Operating system: Win98
XPsp3
Win7,10
ROSA 13
Сообщение Polevic »
Подскажите пожалуйста, как исправить днф
О систее:
если запускать через пуск, менеджер пакетов то в правом нижнем углу всплывает окно
Если нажать кнопку Подробности
Полный текст
PID: 41136 (rpm)
UID: 500 (polevic)
GID: 500 (polevic)
Signal: 6 (ABRT)
Timestamp: Fri 2026-04-17 13:14:59 MSK (2s ago)
Command Line: /usr/bin/rpm --eval %_arch
Executable: /usr/bin/rpm
Control Group: /user.slice/user-500.slice/user@500.service/app.slice/app-dnfdragora@5fe09eaef789444988212ddad173187b.service
Unit: user@500.service
User Unit: app-dnfdragora@5fe09eaef789444988212ddad173187b.service
Slice: user-500.slice
Owner UID: 500 (polevic)
Boot ID: c577afc67fb04111930f930557068811
Machine ID: 3fcfd07c995c48fd8d95f3acf1f2663d
Hostname: rosa-ba4tkc
Storage: /var/lib/systemd/coredump/core.rpm.500.c577afc67fb04111930f930557068811.41136.1776420899000000.zst (present)
Size on Disk: 202.9K
Message: Process 41136 (rpm) of user 500 dumped core.
Stack trace of thread 41136:
#0 0x00007fc408816f9c __pthread_kill_implementation (libc.so.6 + 0x94f9c)
#1 0x00007fc4087c2536 raise (libc.so.6 + 0x40536)
#2 0x00007fc4087aa8b8 abort (libc.so.6 + 0x288b8)
#3 0x00007fc408bcae19 luaD_throw.cold (liblua.so.5.4 + 0x8e19)
#4 0x00007fc408bd4950 luaG_errormsg (liblua.so.5.4 + 0x12950)
#5 0x00007fc408bd4a62 lua_error (liblua.so.5.4 + 0x12a62)
#6 0x00007fc408bec654 luaL_error (liblua.so.5.4 + 0x2a654)
#7 0x00007fc408fed5a6 luaopen_posix (librpmio.so.9 + 0x295a6)
#8 0x00007fc408bd47cf luaD_precall (liblua.so.5.4 + 0x127cf)
#9 0x00007fc408bd51c8 lua_callk (liblua.so.5.4 + 0x131c8)
#10 0x00007fc408beed4c luaL_requiref (liblua.so.5.4 + 0x2cd4c)
#11 0x00007fc408fe8075 rpmluaNew (librpmio.so.9 + 0x24075)
#12 0x00007fc408fe81c9 rpmluaGetGlobalState (librpmio.so.9 + 0x241c9)
#13 0x00007fc409040dad rpmReadConfigFiles (librpm.so.9 + 0x42dad)
#14 0x00007fc40902ccb9 rpmcliConfigured (librpm.so.9 + 0x2ecb9)
#15 0x00007fc4090319a2 rpmcliAllArgCallback (librpm.so.9 + 0x339a2)
#16 0x00007fc4089b0e87 n/a (libpopt.so.0 + 0x3e87)
#17 0x00007fc4089b0f16 n/a (libpopt.so.0 + 0x3f16)
#18 0x00007fc4089b5be6 poptGetNextOpt (libpopt.so.0 + 0x8be6)
#19 0x00007fc40902cdc8 rpmcliInit (librpm.so.9 + 0x2edc8)
#20 0x000000000040228a main (rpm + 0x228a)
#21 0x00007fc4087ac3ac __libc_start_call_main (libc.so.6 + 0x2a3ac)
#22 0x00007fc4087ac469 __libc_start_main (libc.so.6 + 0x2a469)
#23 0x0000000000402d35 _start (rpm + 0x2d35)
ELF object binary architecture: AMD x86-64
если запустить через консоль
Может есть какая команда восстановления файлов
Re: Сломал менеджер пакетов(dnfdragora)
Polevic писал(а): 17 апр 2026, 13:39 Может есть какая команда восстановления файлов
Если ранее об этом не озаботились (например не настроили timeshift) то - нет.
А тут ещё, вроде как, и rpm сломался, если действительно так то остаётся только один вариант - переустановка системы.
Lua ставили какую-то левую?
irton писал(а): 17 апр 2026, 16:11 Lua ставили какую-то левую?
Тут все нестандартное.
Система с дополнительными репами, включая репы kde6,
но очень давно не обновлялась.
Polevic
XPsp3
Win7,10
ROSA 13
Сообщение Polevic »
VictorR2007 писал(а): 18 апр 2026, 01:52 давно не обновлялась.
Ну да, на обновлении и сломал))
Раз вы не написали, как восстановить, значить только переустанавкой можно вылечить(
Думал РОСУ сломать сложнее чем "окно"
Просто переустановить это самый лёгкий вариант,
думал есть варианты по интересней, ну да ладно)
Polevic писал(а): 18 апр 2026, 03:15 Думал РОСУ сломать сложнее чем "окно"
Вроде Росу вы не сломали.
Сломали dnfdragora.
Polevic писал(а): 18 апр 2026, 03:15 думал есть варианты по интересней, ну да ладно)
Варианты есть, особенно когда пользователь более подготовленный.
А мы даже не знаем, сломан у вас dnf или нет.
Не знаем, какие репозитории подключены.
Вы не проверили, работает ли обновление
dnf dsync --refresh
И прочие мелочи. :)
VictorR2007 писал(а): 18 апр 2026, 03:37 Не знаем, какие репозитории подключены.
dnf dsync --refresh
И прочие мелочи. :)
Проверил же, вон скрин прикрепил: не работает.
нифига дружок, это не только Роса так сломать можно.
Предлагаю (раз уж все сломано):
https://abf.io/build_lists/5525511 это сборка lua-5.4.7 (debuginfo,debugsource, и devel)
https://abf.io/build_lists/5526629 это сборка dnf (src ненадо ставить)
https://abf.io/build_lists/5557097 это сборка rpm (debuginfo, src и plugin ненадо ставить)
Качаем пакеты, заходим в них как в каталог через mc например, копируем в / заменяя файлы которые есть
