Kget версии 26.03.90 из репозитория kde6 не запускается.
При запуске из консоли вот что:
$ kget
kf.coreaddons: The plugin "/usr/lib64/qt6/plugins/kget/kget_mirrorsearchfactory.so" explicitly states an Id in the embedded metadata, which is different from the one derived from the filename The Id field from the KPlugin object in the metadata should be removed
kf.coreaddons: The plugin "/usr/lib64/qt6/plugins/kget/kget_checksumsearchfactory.so" explicitly states an Id in the embedded metadata, which is different from the one derived from the filename The Id field from the KPlugin object in the metadata should be removed
kf.coreaddons: The plugin "/usr/lib64/qt6/plugins/kget/kget_metalinkfactory.so" explicitly states an Id in the embedded metadata, which is different from the one derived from the filename The Id field from the KPlugin object in the metadata should be removed
kf.coreaddons: The plugin "/usr/lib64/qt6/plugins/kget/kget_bittorrent.so" explicitly states an Id in the embedded metadata, which is different from the one derived from the filename The Id field from the KPlugin object in the metadata should be removed
kf.coreaddons: The plugin "/usr/lib64/qt6/plugins/kget/kget_mmsfactory.so" explicitly states an Id in the embedded metadata, which is different from the one derived from the filename The Id field from the KPlugin object in the metadata should be removed
kf.coreaddons: The plugin "/usr/lib64/qt6/plugins/kget/kget_multisegkiofactory.so" explicitly states an Id in the embedded metadata, which is different from the one derived from the filename The Id field from the KPlugin object in the metadata should be removed
kf.coreaddons: The plugin "/usr/lib64/qt6/plugins/kget/kget_kio.so" explicitly states an Id in the embedded metadata, which is different from the one derived from the filename The Id field from the KPlugin object in the metadata should be removed
QAbstractItemView::commitData called with an editor that does not belong to this view
kf.windowsystem: static void KX11Extras::setState(WId, NET::States) may only be used on X11
QWidget::insertAction: Attempt to insert null action
KCrash: Application 'kget' crashing... crashRecursionCounter = 2
Ошибка сегментирования (стек памяти сброшен на диск)
