[+0,01s] DEBUG: simple-scan.vala
Starting simple-scan 46.0, PID=20469
[+0,47s] CRITICAL: g_application_set_application_id: assertion 'application_id == NULL || g_application_id_is_valid (application_id)' failed
[+0,58s] DEBUG: _g_io_module_get_default: Found default implementation local (GLocalVfs) for ‘gio-vfs’
[+0,63s] DEBUG: Setting org.freedesktop.appearance.accent-color of type (ddd) not found
[+0,63s] DEBUG: _g_io_module_get_default: Found default implementation dconf (DConfSettingsBackend) for ‘gsettings-backend’
[+0,74s] DEBUG: app-window.vala
Loading state from /root/.config/simple-scan/state
[+0,75s] DEBUG: app-window.vala
Restoring window to 1920x1036 pixels
Restoring window to maximized
[23:55:36.235909] [sanei_debug] Setting debug level of dll to 255.
[23:55:36.236021] [dll] sane_init: SANE dll backend version 1.0.13 from sane-backends 1.2.1
[23:55:36.236046] [dll] sane_init/read_dlld: attempting to open directory `./dll.d'
[23:55:36.236068] [dll] sane_init/read_dlld: attempting to open directory `/etc/sane.d/dll.d'
[23:55:36.236092] [dll] sane_init/read_dlld: using config directory `/etc/sane.d/dll.d'
[23:55:36.236118] [dll] sane_init/read_dlld: considering /etc/sane.d/dll.d/hpaio
[23:55:36.236155] [dll] sane_init/read_config: reading dll.d/hpaio
[23:55:36.236182] [dll] add_backend: adding backend `hpaio'
[23:55:36.236202] [dll] sane_init/read_dlld: considering /etc/sane.d/dll.d/epkowa.conf
[23:55:36.236229] [dll] sane_init/read_config: reading dll.d/epkowa.conf
[23:55:36.236244] [dll] add_backend: adding backend `epkowa'
[23:55:36.236260] [dll] sane_init/read_dlld: considering /etc/sane.d/dll.d/airscan
[23:55:36.236286] [dll] sane_init/read_config: reading dll.d/airscan
[23:55:36.236301] [dll] add_backend: adding backend `airscan'
[23:55:36.236316] [dll] sane_init/read_dlld: considering /etc/sane.d/dll.d/epsonscan2
[23:55:36.236341] [dll] sane_init/read_config: reading dll.d/epsonscan2
[23:55:36.236356] [dll] add_backend: adding backend `epsonscan2'
[23:55:36.236376] [dll] sane_init/read_dlld: done.
[23:55:36.236411] [dll] sane_init/read_config: reading dll.conf
[23:55:36.236432] [dll] add_backend: adding backend `net'
[23:55:36.236445] [dll] add_backend: adding backend `abaton'
[23:55:36.236457] [dll] add_backend: adding backend `agfafocus'
[23:55:36.236469] [dll] add_backend: adding backend `apple'
[23:55:36.236482] [dll] add_backend: adding backend `artec'
[23:55:36.236494] [dll] add_backend: adding backend `artec_eplus48u'
[23:55:36.236507] [dll] add_backend: adding backend `as6e'
[23:55:36.236519] [dll] add_backend: adding backend `avision'
[23:55:36.236532] [dll] add_backend: adding backend `bh'
[23:55:36.236544] [dll] add_backend: adding backend `canon'
[23:55:36.236556] [dll] add_backend: adding backend `canon630u'
[23:55:36.236568] [dll] add_backend: adding backend `canon_dr'
[23:55:36.236581] [dll] add_backend: adding backend `canon_lide70'
[23:55:36.236593] [dll] add_backend: adding backend `cardscan'
[23:55:36.236606] [dll] add_backend: adding backend `coolscan'
[23:55:36.236619] [dll] add_backend: adding backend `coolscan3'
[23:55:36.236631] [dll] add_backend: adding backend `dell1600n_net'
[23:55:36.236644] [dll] add_backend: adding backend `dmc'
[23:55:36.236656] [dll] add_backend: adding backend `epjitsu'
[23:55:36.236669] [dll] add_backend: adding backend `escl'
[23:55:36.236681] [dll] add_backend: adding backend `fujitsu'
[23:55:36.236694] [dll] add_backend: adding backend `genesys'
[23:55:36.236706] [dll] add_backend: adding backend `gt68xx'
[23:55:36.236718] [dll] add_backend: adding backend `hp'
[23:55:36.236731] [dll] add_backend: adding backend `hp3500'
[23:55:36.236743] [dll] add_backend: adding backend `hp3900'
[23:55:36.236756] [dll] add_backend: adding backend `hp4200'
[23:55:36.236768] [dll] add_backend: adding backend `hp5400'
[23:55:36.236780] [dll] add_backend: adding backend `hp5590'
[23:55:36.236792] [dll] add_backend: adding backend `hpljm1005'
[23:55:36.236804] [dll] add_backend: adding backend `hpsj5s'
[23:55:36.236816] [dll] add_backend: adding backend `hs2p'
[23:55:36.236828] [dll] add_backend: adding backend `ibm'
[23:55:36.236840] [dll] add_backend: adding backend `kodak'
[23:55:36.236853] [dll] add_backend: adding backend `kodakaio'
[23:55:36.236868] [dll] add_backend: adding backend `kvs1025'
[23:55:36.236881] [dll] add_backend: adding backend `kvs20xx'
[23:55:36.236893] [dll] add_backend: adding backend `kvs40xx'
[23:55:36.236905] [dll] add_backend: adding backend `leo'
[23:55:36.236951] [dll] add_backend: adding backend `lexmark'
[23:55:36.236983] [dll] add_backend: adding backend `ma1509'
[23:55:36.237000] [dll] add_backend: adding backend `magicolor'
[23:55:36.237016] [dll] add_backend: adding backend `matsushita'
[23:55:36.237031] [dll] add_backend: adding backend `microtek'
[23:55:36.237051] [dll] add_backend: adding backend `microtek2'
[23:55:36.237066] [dll] add_backend: adding backend `mustek'
[23:55:36.237082] [dll] add_backend: adding backend `mustek_usb'
[23:55:36.237097] [dll] add_backend: adding backend `mustek_usb2'
[23:55:36.237114] [dll] add_backend: adding backend `nec'
[23:55:36.237131] [dll] add_backend: adding backend `niash'
[23:55:36.237146] [dll] add_backend: adding backend `pie'
[23:55:36.237161] [dll] add_backend: adding backend `pieusb'
[23:55:36.237174] [dll] add_backend: adding backend `pint'
[23:55:36.237188] [dll] add_backend: adding backend `pixma'
[23:55:36.237202] [dll] add_backend: adding backend `plustek'
[23:55:36.237216] [dll] add_backend: adding backend `qcam'
[23:55:36.237231] [dll] add_backend: adding backend `ricoh'
[23:55:36.237244] [dll] add_backend: adding backend `ricoh2'
[23:55:36.237257] [dll] add_backend: adding backend `rts8891'
[23:55:36.237271] [dll] add_backend: adding backend `s9036'
[23:55:36.237285] [dll] add_backend: adding backend `sceptre'
[23:55:36.237298] [dll] add_backend: adding backend `sharp'
[23:55:36.237311] [dll] add_backend: adding backend `sm3600'
[23:55:36.237330] [dll] add_backend: adding backend `sm3840'
[23:55:36.237344] [dll] add_backend: adding backend `snapscan'
[23:55:36.237358] [dll] add_backend: adding backend `sp15c'
[23:55:36.237372] [dll] add_backend: adding backend `tamarack'
[23:55:36.237386] [dll] add_backend: adding backend `teco1'
[23:55:36.237416] [dll] add_backend: adding backend `teco2'
[23:55:36.237430] [dll] add_backend: adding backend `teco3'
[23:55:36.237443] [dll] add_backend: adding backend `u12'
[23:55:36.237456] [dll] add_backend: adding backend `umax'
[23:55:36.237468] [dll] add_backend: adding backend `umax1220u'
[23:55:36.237481] [dll] add_backend: adding backend `v4l'
[23:55:36.237494] [dll] add_backend: adding backend `xerox_mfp'
[23:55:36.237507] [dll] add_backend: adding backend `epkowa'
[23:55:36.237519] [dll] add_backend: `epkowa' is already there
[23:55:36.237554] [dll] sane_init/read_aliases: reading dll.aliases
[23:55:36.237572] [dll] sane_init/read_aliases_d: attempting to open directory `./dll.aliases.d'
[23:55:36.237588] [dll] sane_init/read_aliases_d: attempting to open directory `/etc/sane.d/dll.aliases.d'
[23:55:36.237611] [dll] sane_init/read_aliases_d: using config directory `/etc/sane.d/dll.aliases.d'
[23:55:36.237634] [dll] sane_init/read_aliases_d: done.
[+0,85s] DEBUG: scanner.vala
sane_init () -> SANE_STATUS_GOOD
SANE version 1.4.0
Requesting redetection of scan devices
[+0,85s] DEBUG: scanner.vala:863: Processing request
[23:55:36.237710] [dll] sane_get_devices
[23:55:36.237727] [dll] load: searching backend `epkowa' in `/usr/lib64/sane'
[23:55:36.237743] [dll] load: trying to load `/usr/lib64/sane/libsane-epkowa.so.1'
[23:55:36.237773] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-epkowa.so.1'
[23:55:36.238287] [dll] init: initializing backend `epkowa'
[23:55:36.370544] [dll] init: backend `epkowa' is version 1.0.213
[23:55:36.371055] [dll] load: searching backend `xerox_mfp' in `/usr/lib64/sane'
[23:55:36.371065] [dll] load: trying to load `/usr/lib64/sane/libsane-xerox_mfp.so.1'
[23:55:36.371088] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-xerox_mfp.so.1'
[23:55:36.371365] [dll] init: initializing backend `xerox_mfp'
[23:55:36.378882] [dll] init: backend `xerox_mfp' is version 1.0.13
[23:55:36.378986] [dll] load: searching backend `v4l' in `/usr/lib64/sane'
[23:55:36.378997] [dll] load: trying to load `/usr/lib64/sane/libsane-v4l.so.1'
[23:55:36.379019] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-v4l.so.1'
[23:55:36.379538] [dll] init: initializing backend `v4l'
[23:55:36.545120] [dll] init: backend `v4l' is version 1.0.5
[23:55:36.545159] [dll] load: searching backend `umax1220u' in `/usr/lib64/sane'
[23:55:36.545175] [dll] load: trying to load `/usr/lib64/sane/libsane-umax1220u.so.1'
[23:55:36.545209] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-umax1220u.so.1'
[23:55:36.545544] [dll] init: initializing backend `umax1220u'
[23:55:36.546126] [dll] init: backend `umax1220u' is version 1.0.2
[23:55:36.546147] [dll] load: searching backend `umax' in `/usr/lib64/sane'
[23:55:36.546161] [dll] load: trying to load `/usr/lib64/sane/libsane-umax.so.1'
[23:55:36.546186] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-umax.so.1'
[23:55:36.546500] [dll] init: initializing backend `umax'
[23:55:36.549676] [dll] init: backend `umax' is version 1.0.45
[23:55:36.549711] [dll] load: searching backend `u12' in `/usr/lib64/sane'
[23:55:36.549734] [dll] load: trying to load `/usr/lib64/sane/libsane-u12.so.1'
[23:55:36.549770] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-u12.so.1'
[23:55:36.550169] [dll] init: initializing backend `u12'
[23:55:36.550856] [dll] init: backend `u12' is version 1.0.0
[23:55:36.550881] [dll] load: searching backend `teco3' in `/usr/lib64/sane'
[23:55:36.550899] [dll] load: trying to load `/usr/lib64/sane/libsane-teco3.so.1'
[23:55:36.550933] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-teco3.so.1'
[23:55:36.551214] [dll] init: initializing backend `teco3'
[23:55:36.552484] [dll] init: backend `teco3' is version 1.0.1
[23:55:36.552508] [dll] load: searching backend `teco2' in `/usr/lib64/sane'
[23:55:36.552526] [dll] load: trying to load `/usr/lib64/sane/libsane-teco2.so.1'
[23:55:36.552558] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-teco2.so.1'
[23:55:36.552825] [dll] init: initializing backend `teco2'
[23:55:36.554990] [dll] init: backend `teco2' is version 1.0.10
[23:55:36.555015] [dll] load: searching backend `teco1' in `/usr/lib64/sane'
[23:55:36.555033] [dll] load: trying to load `/usr/lib64/sane/libsane-teco1.so.1'
[23:55:36.555066] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-teco1.so.1'
[23:55:36.555329] [dll] init: initializing backend `teco1'
[23:55:36.556716] [dll] init: backend `teco1' is version 1.0.10
[23:55:36.556739] [dll] load: searching backend `tamarack' in `/usr/lib64/sane'
[23:55:36.556757] [dll] load: trying to load `/usr/lib64/sane/libsane-tamarack.so.1'
[23:55:36.556792] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-tamarack.so.1'
[23:55:36.557052] [dll] init: initializing backend `tamarack'
[23:55:36.557697] [dll] init: backend `tamarack' is version 1.0.0
[23:55:36.557720] [dll] load: searching backend `sp15c' in `/usr/lib64/sane'
[23:55:36.557739] [dll] load: trying to load `/usr/lib64/sane/libsane-sp15c.so.1'
[23:55:36.557776] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-sp15c.so.1'
[23:55:36.558039] [dll] init: initializing backend `sp15c'
[23:55:36.558299] [dll] init: backend `sp15c' is version 1.0.0
[23:55:36.558319] [dll] load: searching backend `snapscan' in `/usr/lib64/sane'
[23:55:36.558334] [dll] load: trying to load `/usr/lib64/sane/libsane-snapscan.so.1'
[23:55:36.558362] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-snapscan.so.1'
[23:55:36.558672] [dll] init: initializing backend `snapscan'
[23:55:36.702982] [dll] init: backend `snapscan' is version 1.4.53
[23:55:36.703003] [dll] load: searching backend `sm3840' in `/usr/lib64/sane'
[23:55:36.703012] [dll] load: trying to load `/usr/lib64/sane/libsane-sm3840.so.1'
[23:55:36.703030] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-sm3840.so.1'
[23:55:36.703261] [dll] init: initializing backend `sm3840'
[23:55:36.703576] [dll] init: backend `sm3840' is version 1.0.0
[23:55:36.703597] [dll] load: searching backend `sm3600' in `/usr/lib64/sane'
[23:55:36.703609] [dll] load: trying to load `/usr/lib64/sane/libsane-sm3600.so.1'
[23:55:36.703635] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-sm3600.so.1'
[23:55:36.703903] [dll] init: initializing backend `sm3600'
[23:55:36.704384] [dll] init: backend `sm3600' is version 1.0.6
[23:55:36.704422] [dll] load: searching backend `sharp' in `/usr/lib64/sane'
[23:55:36.704495] [dll] load: trying to load `/usr/lib64/sane/libsane-sharp.so.1'
[23:55:36.704534] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-sharp.so.1'
[23:55:36.704810] [dll] init: initializing backend `sharp'
[23:55:36.705389] [dll] init: backend `sharp' is version 1.0.0
[23:55:36.705465] [dll] load: searching backend `sceptre' in `/usr/lib64/sane'
[23:55:36.705487] [dll] load: trying to load `/usr/lib64/sane/libsane-sceptre.so.1'
[23:55:36.705525] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-sceptre.so.1'
[23:55:36.705805] [dll] init: initializing backend `sceptre'
[23:55:36.706456] [dll] init: backend `sceptre' is version 1.0.10
[23:55:36.706479] [dll] load: searching backend `s9036' in `/usr/lib64/sane'
[23:55:36.706495] [dll] load: trying to load `/usr/lib64/sane/libsane-s9036.so.1'
[23:55:36.706525] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-s9036.so.1'
[23:55:36.706784] [dll] init: initializing backend `s9036'
[23:55:36.707205] [dll] init: backend `s9036' is version 1.0.0
[23:55:36.707225] [dll] load: searching backend `rts8891' in `/usr/lib64/sane'
[23:55:36.707238] [dll] load: trying to load `/usr/lib64/sane/libsane-rts8891.so.1'
[23:55:36.707263] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-rts8891.so.1'
[23:55:36.707577] [dll] init: initializing backend `rts8891'
[23:55:36.708078] [dll] init: backend `rts8891' is version 1.0.2401
[23:55:36.708612] [dll] load: searching backend `ricoh2' in `/usr/lib64/sane'
[23:55:36.708633] [dll] load: trying to load `/usr/lib64/sane/libsane-ricoh2.so.1'
[23:55:36.708662] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-ricoh2.so.1'
[23:55:36.708955] [dll] init: initializing backend `ricoh2'
[23:55:36.709423] [dll] init: backend `ricoh2' is version 1.0.0
[23:55:36.709445] [dll] load: searching backend `ricoh' in `/usr/lib64/sane'
[23:55:36.709460] [dll] load: trying to load `/usr/lib64/sane/libsane-ricoh.so.1'
[23:55:36.709491] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-ricoh.so.1'
[23:55:36.709732] [dll] init: initializing backend `ricoh'
[23:55:36.710137] [dll] init: backend `ricoh' is version 1.0.0
[23:55:36.710157] [dll] load: searching backend `qcam' in `/usr/lib64/sane'
[23:55:36.710173] [dll] load: trying to load `/usr/lib64/sane/libsane-qcam.so.1'
[23:55:36.710206] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-qcam.so.1'
[23:55:36.710473] [dll] init: initializing backend `qcam'
[23:55:36.710554] [dll] init: backend `qcam' is version 1.0.0
[23:55:36.710573] [dll] load: searching backend `plustek' in `/usr/lib64/sane'
[23:55:36.710588] [dll] load: trying to load `/usr/lib64/sane/libsane-plustek.so.1'
[23:55:36.710616] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-plustek.so.1'
[23:55:36.710893] [dll] init: initializing backend `plustek'
[23:55:36.711565] [dll] init: backend `plustek' is version 1.0.0
[23:55:36.711587] [dll] load: searching backend `pixma' in `/usr/lib64/sane'
[23:55:36.711602] [dll] load: trying to load `/usr/lib64/sane/libsane-pixma.so.1'
[23:55:36.711630] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-pixma.so.1'
[23:55:36.711957] [dll] init: initializing backend `pixma'
[23:55:36.712485] [dll] init: backend `pixma' is version 1.0.28
[23:55:37.233441] [dll] load: searching backend `pint' in `/usr/lib64/sane'
[23:55:37.233478] [dll] load: trying to load `/usr/lib64/sane/libsane-pint.so.1'
[23:55:37.233508] [dll] load: couldn't open `/usr/lib64/sane/libsane-pint.so.1' (Net takogo fajla ili kataloga)
[23:55:37.233521] [dll] load: couldn't find backend `pint' (Net takogo fajla ili kataloga)
[23:55:37.233535] [dll] load: searching backend `pieusb' in `/usr/lib64/sane'
[23:55:37.233547] [dll] load: trying to load `/usr/lib64/sane/libsane-pieusb.so.1'
[23:55:37.233574] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-pieusb.so.1'
[23:55:37.233954] [dll] init: initializing backend `pieusb'
[23:55:37.355646] [dll] init: backend `pieusb' is version 1.0.1
[23:55:37.355672] [dll] load: searching backend `pie' in `/usr/lib64/sane'
[23:55:37.355685] [dll] load: trying to load `/usr/lib64/sane/libsane-pie.so.1'
[23:55:37.355710] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-pie.so.1'
[23:55:37.356000] [dll] init: initializing backend `pie'
[23:55:37.356865] [dll] init: backend `pie' is version 1.0.9
[23:55:37.356883] [dll] load: searching backend `niash' in `/usr/lib64/sane'
[23:55:37.356898] [dll] load: trying to load `/usr/lib64/sane/libsane-niash.so.1'
[23:55:37.356928] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-niash.so.1'
[23:55:37.357195] [dll] init: initializing backend `niash'
[23:55:37.357656] [dll] init: backend `niash' is version 1.0.1
[23:55:37.357674] [dll] load: searching backend `nec' in `/usr/lib64/sane'
[23:55:37.357686] [dll] load: trying to load `/usr/lib64/sane/libsane-nec.so.1'
[23:55:37.357713] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-nec.so.1'
[23:55:37.357970] [dll] init: initializing backend `nec'
[23:55:37.358379] [dll] init: backend `nec' is version 1.0.0
[23:55:37.358414] [dll] load: searching backend `mustek_usb2' in `/usr/lib64/sane'
[23:55:37.358429] [dll] load: trying to load `/usr/lib64/sane/libsane-mustek_usb2.so.1'
[23:55:37.358460] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-mustek_usb2.so.1'
[23:55:37.358802] [dll] init: initializing backend `mustek_usb2'
[23:55:37.358853] [dll] init: backend `mustek_usb2' is version 1.0.10
[23:55:37.359493] [dll] load: searching backend `mustek_usb' in `/usr/lib64/sane'
[23:55:37.359522] [dll] load: trying to load `/usr/lib64/sane/libsane-mustek_usb.so.1'
[23:55:37.359553] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-mustek_usb.so.1'
[23:55:37.359965] [dll] init: initializing backend `mustek_usb'
[23:55:37.360497] [dll] init: backend `mustek_usb' is version 1.0.18
[23:55:37.360510] [dll] load: searching backend `mustek' in `/usr/lib64/sane'
[23:55:37.360520] [dll] load: trying to load `/usr/lib64/sane/libsane-mustek.so.1'
[23:55:37.360537] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-mustek.so.1'
[23:55:37.360780] [dll] init: initializing backend `mustek'
[23:55:37.361324] [dll] init: backend `mustek' is version 1.0.138
[23:55:37.361335] [dll] load: searching backend `microtek2' in `/usr/lib64/sane'
[23:55:37.361345] [dll] load: trying to load `/usr/lib64/sane/libsane-microtek2.so.1'
[23:55:37.361363] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-microtek2.so.1'
[23:55:37.361506] [dll] init: initializing backend `microtek2'
[23:55:37.361808] [dll] init: backend `microtek2' is version 1.0.0
[23:55:37.361820] [dll] load: searching backend `microtek' in `/usr/lib64/sane'
[23:55:37.361827] [dll] load: trying to load `/usr/lib64/sane/libsane-microtek.so.1'
[23:55:37.361842] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-microtek.so.1'
[23:55:37.361967] [dll] init: initializing backend `microtek'
[23:55:37.362258] [dll] init: backend `microtek' is version 1.0.0
[23:55:37.362268] [dll] load: searching backend `matsushita' in `/usr/lib64/sane'
[23:55:37.362274] [dll] load: trying to load `/usr/lib64/sane/libsane-matsushita.so.1'
[23:55:37.362288] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-matsushita.so.1'
[23:55:37.362427] [dll] init: initializing backend `matsushita'
[23:55:37.363034] [dll] init: backend `matsushita' is version 1.0.7
[23:55:37.363043] [dll] load: searching backend `magicolor' in `/usr/lib64/sane'
[23:55:37.363050] [dll] load: trying to load `/usr/lib64/sane/libsane-magicolor.so.1'
[23:55:37.363064] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-magicolor.so.1'
[23:55:37.363234] [dll] init: initializing backend `magicolor'
[23:55:37.363493] [dll] init: backend `magicolor' is version 1.0.1
[23:55:37.363734] [dll] load: searching backend `ma1509' in `/usr/lib64/sane'
[23:55:37.363742] [dll] load: trying to load `/usr/lib64/sane/libsane-ma1509.so.1'
[23:55:37.363757] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-ma1509.so.1'
[23:55:37.363902] [dll] init: initializing backend `ma1509'
[23:55:37.364146] [dll] init: backend `ma1509' is version 1.0.3
[23:55:37.364156] [dll] load: searching backend `lexmark' in `/usr/lib64/sane'
[23:55:37.364164] [dll] load: trying to load `/usr/lib64/sane/libsane-lexmark.so.1'
[23:55:37.364179] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-lexmark.so.1'
[23:55:37.364329] [dll] init: initializing backend `lexmark'
[23:55:37.364584] [dll] init: backend `lexmark' is version 1.0.32
[23:55:37.364814] [dll] load: searching backend `leo' in `/usr/lib64/sane'
[23:55:37.364823] [dll] load: trying to load `/usr/lib64/sane/libsane-leo.so.1'
[23:55:37.364837] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-leo.so.1'
[23:55:37.364969] [dll] init: initializing backend `leo'
[23:55:37.365344] [dll] init: backend `leo' is version 1.0.11
[23:55:37.365354] [dll] load: searching backend `kvs40xx' in `/usr/lib64/sane'
[23:55:37.365362] [dll] load: trying to load `/usr/lib64/sane/libsane-kvs40xx.so.1'
[23:55:37.365377] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-kvs40xx.so.1'
[23:55:37.365536] [dll] init: initializing backend `kvs40xx'
[23:55:37.365766] [dll] init: backend `kvs40xx' is version 1.0.1
[23:55:37.366028] [dll] load: searching backend `kvs20xx' in `/usr/lib64/sane'
[23:55:37.366037] [dll] load: trying to load `/usr/lib64/sane/libsane-kvs20xx.so.1'
[23:55:37.366053] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-kvs20xx.so.1'
[23:55:37.366203] [dll] init: initializing backend `kvs20xx'
[23:55:37.366439] [dll] init: backend `kvs20xx' is version 1.0.2
[23:55:37.366929] [dll] load: searching backend `kvs1025' in `/usr/lib64/sane'
[23:55:37.366937] [dll] load: trying to load `/usr/lib64/sane/libsane-kvs1025.so.1'
[23:55:37.366950] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-kvs1025.so.1'
[23:55:37.367093] [dll] init: initializing backend `kvs1025'
[23:55:37.367533] [dll] init: backend `kvs1025' is version 1.0.5
[23:55:37.367545] [dll] load: searching backend `kodakaio' in `/usr/lib64/sane'
[23:55:37.367551] [dll] load: trying to load `/usr/lib64/sane/libsane-kodakaio.so.1'
[23:55:37.367567] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-kodakaio.so.1'
[23:55:37.367727] [dll] init: initializing backend `kodakaio'
[23:55:37.367947] [dll] init: backend `kodakaio' is version 1.0.3
[23:55:37.368173] [dll] load: searching backend `kodak' in `/usr/lib64/sane'
[23:55:37.368180] [dll] load: trying to load `/usr/lib64/sane/libsane-kodak.so.1'
[23:55:37.368193] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-kodak.so.1'
[23:55:37.368329] [dll] init: initializing backend `kodak'
[23:55:37.368341] [dll] init: backend `kodak' is version 1.0.7
[23:55:37.368467] [dll] load: searching backend `ibm' in `/usr/lib64/sane'
[23:55:37.368475] [dll] load: trying to load `/usr/lib64/sane/libsane-ibm.so.1'
[23:55:37.368489] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-ibm.so.1'
[23:55:37.368609] [dll] init: initializing backend `ibm'
[23:55:37.368816] [dll] init: backend `ibm' is version 1.0.0
[23:55:37.368826] [dll] load: searching backend `hs2p' in `/usr/lib64/sane'
[23:55:37.368834] [dll] load: trying to load `/usr/lib64/sane/libsane-hs2p.so.1'
[23:55:37.368849] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-hs2p.so.1'
[23:55:37.368976] [dll] init: initializing backend `hs2p'
[23:55:37.369262] [dll] init: backend `hs2p' is version 1.0.0
[23:55:37.369277] [dll] load: searching backend `hpsj5s' in `/usr/lib64/sane'
[23:55:37.369284] [dll] load: trying to load `/usr/lib64/sane/libsane-hpsj5s.so.1'
[23:55:37.369299] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-hpsj5s.so.1'
[23:55:37.369435] [dll] init: initializing backend `hpsj5s'
[23:55:37.369487] [dll] init: backend `hpsj5s' is version 1.0.3
[23:55:37.369495] [dll] load: searching backend `hpljm1005' in `/usr/lib64/sane'
[23:55:37.369502] [dll] load: trying to load `/usr/lib64/sane/libsane-hpljm1005.so.1'
[23:55:37.369516] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-hpljm1005.so.1'
[23:55:37.369660] [dll] init: initializing backend `hpljm1005'
[23:55:37.369882] [dll] init: backend `hpljm1005' is version 1.0.1
[23:55:37.369892] [dll] load: searching backend `hp5590' in `/usr/lib64/sane'
[23:55:37.369899] [dll] load: trying to load `/usr/lib64/sane/libsane-hp5590.so.1'
[23:55:37.369914] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-hp5590.so.1'
[23:55:37.370065] [dll] init: initializing backend `hp5590'
[23:55:37.370288] [dll] init: backend `hp5590' is version 1.0.8
[23:55:37.370299] [dll] load: searching backend `hp5400' in `/usr/lib64/sane'
[23:55:37.370307] [dll] load: trying to load `/usr/lib64/sane/libsane-hp5400.so.1'
[23:55:37.370324] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-hp5400.so.1'
[23:55:37.370513] [dll] init: initializing backend `hp5400'
[23:55:37.370762] [dll] init: backend `hp5400' is version 1.0.3
[23:55:37.370771] [dll] load: searching backend `hp4200' in `/usr/lib64/sane'
[23:55:37.370777] [dll] load: trying to load `/usr/lib64/sane/libsane-hp4200.so.1'
[23:55:37.370791] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-hp4200.so.1'
[23:55:37.370938] [dll] init: initializing backend `hp4200'
[23:55:37.371181] [dll] init: backend `hp4200' is version 1.0.0
[23:55:37.371191] [dll] load: searching backend `hp3900' in `/usr/lib64/sane'
[23:55:37.371199] [dll] load: trying to load `/usr/lib64/sane/libsane-hp3900.so.1'
[23:55:37.371215] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-hp3900.so.1'
[23:55:37.371456] [dll] init: initializing backend `hp3900'
[23:55:37.371703] [dll] init: backend `hp3900' is version 1.0.0
[23:55:37.371713] [dll] load: searching backend `hp3500' in `/usr/lib64/sane'
[23:55:37.371720] [dll] load: trying to load `/usr/lib64/sane/libsane-hp3500.so.1'
[23:55:37.371736] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-hp3500.so.1'
[23:55:37.371888] [dll] init: initializing backend `hp3500'
[23:55:37.372114] [dll] init: backend `hp3500' is version 1.0.0
[23:55:37.372128] [dll] load: searching backend `hp' in `/usr/lib64/sane'
[23:55:37.372136] [dll] load: trying to load `/usr/lib64/sane/libsane-hp.so.1'
[23:55:37.372155] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-hp.so.1'
[23:55:37.372326] [dll] init: initializing backend `hp'
[23:55:37.372354] [dll] init: backend `hp' is version 1.0.8
[23:55:37.372896] [dll] load: searching backend `gt68xx' in `/usr/lib64/sane'
[23:55:37.372905] [dll] load: trying to load `/usr/lib64/sane/libsane-gt68xx.so.1'
[23:55:37.372921] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-gt68xx.so.1'
[23:55:37.373081] [dll] init: initializing backend `gt68xx'
[23:55:37.373352] [dll] init: backend `gt68xx' is version 1.0.84
[23:55:37.373622] [dll] load: searching backend `genesys' in `/usr/lib64/sane'
[23:55:37.373630] [dll] load: trying to load `/usr/lib64/sane/libsane-genesys.so.1'
[23:55:37.373645] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-genesys.so.1'
[23:55:37.374608] [dll] init: initializing backend `genesys'
[23:55:37.374628] [sanei_debug] Setting debug level of genesys to 255.
[23:55:37.374647] [genesys] void genesys::sane_init_impl(SANE_Int*, SANE_Auth_Callback): start
[23:55:37.374656] [genesys] void genesys::sane_init_impl(SANE_Int*, SANE_Auth_Callback): [23:55:37.374662] [genesys] authorize != null[23:55:37.374670] [genesys]
[23:55:37.374678] [genesys] SANE Genesys backend from sane-backends 1.2.1
[23:55:37.374692] [genesys] SANE Genesys backend built with libusb-1.0
[23:55:37.375297] [genesys] sane_init_impl: little endian machine
[23:55:37.375310] [genesys] void genesys::probe_genesys_devices(): start
[23:55:37.375337] [genesys] SANE_Status genesys::attach_one_device(SANE_String_Const): start
[23:55:37.375344] [genesys] genesys::Genesys_Device* genesys::attach_device_by_name(SANE_String_Const, bool): start
[23:55:37.375352] [genesys] genesys::Genesys_Device* genesys::attach_device_by_name(SANE_String_Const, bool): [23:55:37.375359] [genesys] devname: libusb:003:003, may_wait = 0[23:55:37.375368] [genesys]
[23:55:37.375375] [genesys] attach_device_by_name: trying to open device `libusb:003:003'
[23:55:37.375384] [genesys] virtual void genesys::UsbDevice::open(const char*): start
[23:55:37.375451] [genesys] virtual void genesys::UsbDevice::open(const char*): completed
[23:55:37.375460] [genesys] attach_device_by_name: device `libusb:003:003' successfully opened
[23:55:37.375476] [genesys] virtual uint16_t genesys::UsbDevice::get_vendor_id(): start
[23:55:37.375488] [genesys] virtual uint16_t genesys::UsbDevice::get_vendor_id(): completed
[23:55:37.375499] [genesys] virtual uint16_t genesys::UsbDevice::get_product_id(): start
[23:55:37.375507] [genesys] virtual uint16_t genesys::UsbDevice::get_product_id(): completed
[23:55:37.375516] [genesys] virtual void genesys::UsbDevice::close(): start
[23:55:37.375540] [genesys] virtual void genesys::UsbDevice::close(): completed
[23:55:37.375554] [genesys] attach_device_by_name: found 1193 flatbed scanner 8732 at libusb:003:003
[23:55:37.375565] [genesys] genesys::Genesys_Device* genesys::attach_device_by_name(SANE_String_Const, bool): completed
[23:55:37.375572] [genesys] SANE_Status genesys::attach_one_device(SANE_String_Const): completed
[23:55:37.375598] [genesys] probe_genesys_devices: 1 devices currently attached
[23:55:37.375605] [genesys] void genesys::probe_genesys_devices(): completed
[23:55:37.375612] [genesys] void genesys::sane_init_impl(SANE_Int*, SANE_Auth_Callback): completed
[23:55:37.375623] [dll] init: backend `genesys' is version 1.0.0
[23:55:37.375633] [genesys] void genesys::sane_get_devices_impl(const SANE_Device***, SANE_Bool): start
[23:55:37.375640] [genesys] void genesys::sane_get_devices_impl(const SANE_Device***, SANE_Bool): [23:55:37.375649] [genesys] local_only = false[23:55:37.375656] [genesys]
[23:55:37.375868] [genesys] void genesys::probe_genesys_devices(): start
[23:55:37.375894] [genesys] SANE_Status genesys::attach_one_device(SANE_String_Const): start
[23:55:37.375902] [genesys] genesys::Genesys_Device* genesys::attach_device_by_name(SANE_String_Const, bool): start
[23:55:37.375909] [genesys] genesys::Genesys_Device* genesys::attach_device_by_name(SANE_String_Const, bool): [23:55:37.375915] [genesys] devname: libusb:003:003, may_wait = 0[23:55:37.375922] [genesys]
[23:55:37.375932] [genesys] attach_device_by_name: device `libusb:003:003' was already in device list
[23:55:37.375939] [genesys] genesys::Genesys_Device* genesys::attach_device_by_name(SANE_String_Const, bool): completed
[23:55:37.375947] [genesys] SANE_Status genesys::attach_one_device(SANE_String_Const): completed
[23:55:37.375971] [genesys] probe_genesys_devices: 1 devices currently attached
[23:55:37.375978] [genesys] void genesys::probe_genesys_devices(): completed
[23:55:37.375985] [genesys] SANE_Status genesys::check_present(SANE_String_Const): start
[23:55:37.375992] [genesys] SANE_Status genesys::check_present(SANE_String_Const): [23:55:37.375998] [genesys] libusb:003:003 detected.[23:55:37.376004] [genesys]
[23:55:37.376012] [genesys] SANE_Status genesys::check_present(SANE_String_Const): completed
[23:55:37.376024] [genesys] void genesys::sane_get_devices_impl(const SANE_Device***, SANE_Bool): completed
[23:55:37.376033] [dll] load: searching backend `fujitsu' in `/usr/lib64/sane'
[23:55:37.376041] [dll] load: trying to load `/usr/lib64/sane/libsane-fujitsu.so.1'
[23:55:37.376057] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-fujitsu.so.1'
[23:55:37.376215] [dll] init: initializing backend `fujitsu'
[23:55:37.376238] [dll] init: backend `fujitsu' is version 1.0.140
[23:55:37.376609] [dll] load: searching backend `escl' in `/usr/lib64/sane'
[23:55:37.376619] [dll] load: trying to load `/usr/lib64/sane/libsane-escl.so.1'
[23:55:37.376630] [dll] load: couldn't open `/usr/lib64/sane/libsane-escl.so.1' (Net takogo fajla ili kataloga)
[23:55:37.376639] [dll] load: couldn't find backend `escl' (Net takogo fajla ili kataloga)
[23:55:37.376648] [dll] load: searching backend `epjitsu' in `/usr/lib64/sane'
[23:55:37.376658] [dll] load: trying to load `/usr/lib64/sane/libsane-epjitsu.so.1'
[23:55:37.376676] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-epjitsu.so.1'
[23:55:37.376831] [dll] init: initializing backend `epjitsu'
[23:55:37.376846] [dll] init: backend `epjitsu' is version 1.0.33
[23:55:37.377089] [dll] load: searching backend `dmc' in `/usr/lib64/sane'
[23:55:37.377097] [dll] load: trying to load `/usr/lib64/sane/libsane-dmc.so.1'
[23:55:37.377112] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-dmc.so.1'
[23:55:37.377232] [dll] init: initializing backend `dmc'
[23:55:37.377444] [dll] init: backend `dmc' is version 1.0.0
[23:55:37.377453] [dll] load: searching backend `dell1600n_net' in `/usr/lib64/sane'
[23:55:37.377460] [dll] load: trying to load `/usr/lib64/sane/libsane-dell1600n_net.so.1'
[23:55:37.377475] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-dell1600n_net.so.1'
[23:55:37.377608] [dll] init: initializing backend `dell1600n_net'
[23:55:37.377620] [dll] init: backend `dell1600n_net' is version 1.0.0
[23:55:37.678056] [dll] load: searching backend `coolscan3' in `/usr/lib64/sane'
[23:55:37.678090] [dll] load: trying to load `/usr/lib64/sane/libsane-coolscan3.so.1'
[23:55:37.678128] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-coolscan3.so.1'
[23:55:37.678565] [dll] init: initializing backend `coolscan3'
[23:55:37.798582] [dll] init: backend `coolscan3' is version 1.0.0
[23:55:37.798909] [dll] load: searching backend `coolscan' in `/usr/lib64/sane'
[23:55:37.798927] [dll] load: trying to load `/usr/lib64/sane/libsane-coolscan.so.1'
[23:55:37.798952] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-coolscan.so.1'
[23:55:37.799327] [dll] init: initializing backend `coolscan'
[23:55:37.800042] [dll] init: backend `coolscan' is version 1.0.0
[23:55:37.800078] [dll] load: searching backend `cardscan' in `/usr/lib64/sane'
[23:55:37.800097] [dll] load: trying to load `/usr/lib64/sane/libsane-cardscan.so.1'
[23:55:37.800132] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-cardscan.so.1'
[23:55:37.800541] [dll] init: initializing backend `cardscan'
[23:55:37.800978] [dll] init: backend `cardscan' is version 1.0.3
[23:55:37.801034] [dll] load: searching backend `canon_lide70' in `/usr/lib64/sane'
[23:55:37.801051] [dll] load: trying to load `/usr/lib64/sane/libsane-canon_lide70.so.1'
[23:55:37.801080] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-canon_lide70.so.1'
[23:55:37.801394] [dll] init: initializing backend `canon_lide70'
[23:55:37.801871] [dll] init: backend `canon_lide70' is version 1.0.0
[23:55:37.801905] [dll] load: searching backend `canon_dr' in `/usr/lib64/sane'
[23:55:37.801921] [dll] load: trying to load `/usr/lib64/sane/libsane-canon_dr.so.1'
[23:55:37.801952] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-canon_dr.so.1'
[23:55:37.802233] [dll] init: initializing backend `canon_dr'
[23:55:37.802272] [dll] init: backend `canon_dr' is version 1.0.65
[23:55:37.803132] [dll] load: searching backend `canon630u' in `/usr/lib64/sane'
[23:55:37.803150] [dll] load: trying to load `/usr/lib64/sane/libsane-canon630u.so.1'
[23:55:37.803179] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-canon630u.so.1'
[23:55:37.803476] [dll] init: initializing backend `canon630u'
[23:55:37.803932] [dll] init: backend `canon630u' is version 1.0.1
[23:55:37.803950] [dll] load: searching backend `canon' in `/usr/lib64/sane'
[23:55:37.803965] [dll] load: trying to load `/usr/lib64/sane/libsane-canon.so.1'
[23:55:37.803994] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-canon.so.1'
[23:55:37.804278] [dll] init: initializing backend `canon'
[23:55:37.804555] [dll] init: backend `canon' is version 1.0.0
[23:55:37.804575] [dll] load: searching backend `bh' in `/usr/lib64/sane'
[23:55:37.804590] [dll] load: trying to load `/usr/lib64/sane/libsane-bh.so.1'
[23:55:37.804619] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-bh.so.1'
[23:55:37.804860] [dll] init: initializing backend `bh'
[23:55:37.805433] [dll] init: backend `bh' is version 1.0.4
[23:55:37.805453] [dll] load: searching backend `avision' in `/usr/lib64/sane'
[23:55:37.805468] [dll] load: trying to load `/usr/lib64/sane/libsane-avision.so.1'
[23:55:37.805498] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-avision.so.1'
[23:55:37.805839] [dll] init: initializing backend `avision'
[23:55:37.815321] [dll] init: backend `avision' is version 1.0.297
[23:55:37.825796] [dll] load: searching backend `as6e' in `/usr/lib64/sane'
[23:55:37.825822] [dll] load: trying to load `/usr/lib64/sane/libsane-as6e.so.1'
[23:55:37.825860] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-as6e.so.1'
[23:55:37.826131] [dll] init: initializing backend `as6e'
[23:55:37.826192] [dll] load: searching backend `artec_eplus48u' in `/usr/lib64/sane'
[23:55:37.826209] [dll] load: trying to load `/usr/lib64/sane/libsane-artec_eplus48u.so.1'
[23:55:37.826244] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-artec_eplus48u.so.1'
[23:55:37.826582] [dll] init: initializing backend `artec_eplus48u'
[23:55:37.827185] [dll] init: backend `artec_eplus48u' is version 1.0.0
[23:55:37.827209] [dll] load: searching backend `artec' in `/usr/lib64/sane'
[23:55:37.827226] [dll] load: trying to load `/usr/lib64/sane/libsane-artec.so.1'
[23:55:37.827256] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-artec.so.1'
[23:55:37.827531] [dll] init: initializing backend `artec'
[23:55:37.828138] [dll] init: backend `artec' is version 1.0.0
[23:55:37.828158] [dll] load: searching backend `apple' in `/usr/lib64/sane'
[23:55:37.828174] [dll] load: trying to load `/usr/lib64/sane/libsane-apple.so.1'
[23:55:37.828204] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-apple.so.1'
[23:55:37.828476] [dll] init: initializing backend `apple'
[23:55:37.829043] [dll] init: backend `apple' is version 1.0.0
[23:55:37.829061] [dll] load: searching backend `agfafocus' in `/usr/lib64/sane'
[23:55:37.829074] [dll] load: trying to load `/usr/lib64/sane/libsane-agfafocus.so.1'
[23:55:37.829112] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-agfafocus.so.1'
[23:55:37.829358] [dll] init: initializing backend `agfafocus'
[23:55:37.829785] [dll] init: backend `agfafocus' is version 1.0.0
[23:55:37.829805] [dll] load: searching backend `abaton' in `/usr/lib64/sane'
[23:55:37.829820] [dll] load: trying to load `/usr/lib64/sane/libsane-abaton.so.1'
[23:55:37.829853] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-abaton.so.1'
[23:55:37.830184] [dll] init: initializing backend `abaton'
[23:55:37.830762] [dll] init: backend `abaton' is version 1.0.0
[23:55:37.830784] [dll] load: searching backend `net' in `/usr/lib64/sane'
[23:55:37.830797] [dll] load: trying to load `/usr/lib64/sane/libsane-net.so.1'
[23:55:37.830822] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-net.so.1'
[23:55:37.831137] [dll] init: initializing backend `net'
[23:55:37.831191] [dll] init: backend `net' is version 1.4.0
[23:55:37.831210] [dll] load: searching backend `epsonscan2' in `/usr/lib64/sane'
[23:55:37.831226] [dll] load: trying to load `/usr/lib64/sane/libsane-epsonscan2.so.1'
[23:55:37.831254] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-epsonscan2.so.1'
[23:55:37.832465] [dll] init: initializing backend `epsonscan2'
[23:55:37.832501] [dll] init: backend `epsonscan2' is version 1.1.0
[23:55:38.867704] [dll] load: searching backend `airscan' in `/usr/lib64/sane'
[23:55:38.867731] [dll] load: trying to load `/usr/lib64/sane/libsane-airscan.so.1'
[23:55:38.867758] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-airscan.so.1'
[23:55:38.871230] [dll] init: initializing backend `airscan'
[23:55:38.875173] [dll] init: backend `airscan' is version 1.0.0
[23:55:41.463086] [dll] load: searching backend `hpaio' in `/usr/lib64/sane'
[23:55:41.463117] [dll] load: trying to load `/usr/lib64/sane/libsane-hpaio.so.1'
[23:55:41.463149] [dll] load: dlopen()ing `/usr/lib64/sane/libsane-hpaio.so.1'
[23:55:41.466592] [dll] init: initializing backend `hpaio'
[23:55:41.467364] [dll] init: backend `hpaio' is version 1.0.0
[23:55:41.538264] [dll] sane_get_devices: found 3 devices
[+6,15s] DEBUG: scanner.vala:348: sane_get_devices () -> SANE_STATUS_GOOD
[+6,15s] DEBUG: scanner.vala:374: Device: name="genesys:libusb:003:003" vendor="Canon" model="LiDE 60" type="flatbed scanner"
[+13,38s] DEBUG: simple-scan.vala
Requesting scan at 150 dpi from device 'genesys:libusb:003:003'
[+13,38s] DEBUG: scanner.vala
Scanner.scan ("genesys:libusb:003:003", dpi=150, scan_mode=ScanMode.GRAY, depth=2, type=batch, side=both, paper_width=0, paper_height=0, brightness=0, contrast=0, delay=0ms)
[+13,38s] DEBUG: scanner.vala:863: Processing request
[23:55:48.767576] [dll] sane_open: trying to open `genesys:libusb:003:003'
[23:55:48.767608] [genesys] void genesys::sane_open_impl(SANE_String_Const, void**): start
[23:55:48.767621] [genesys] void genesys::sane_open_impl(SANE_String_Const, void**): [23:55:48.767633] [genesys] devicename = libusb:003:003[23:55:48.767644] [genesys]
[23:55:48.767659] [genesys] sane_open_impl: found `libusb:003:003' in devlist
[23:55:48.767689] [genesys] virtual void genesys::UsbDevice::open(const char*): start
[23:55:48.767790] [genesys] virtual void genesys::UsbDevice::open(const char*): completed
[23:55:48.767804] [genesys] virtual uint16_t genesys::UsbDevice::get_bcd_device(): start
[23:55:48.767818] [genesys] virtual uint16_t genesys::UsbDevice::get_bcd_device(): completed
[23:55:48.767857] [genesys] void genesys::sane_open_impl(SANE_String_Const, void**): Opened device canon-lide-60
[23:55:48.767898] [genesys] void genesys::sanei_genesys_init_structs(Genesys_Device*): start
[23:55:48.767913] [genesys] void genesys::sanei_genesys_init_structs(Genesys_Device*): completed
[23:55:48.767931] [genesys] void genesys::init_options(Genesys_Scanner*): start
[23:55:48.767948] [genesys] const genesys::Genesys_Sensor& genesys::sanei_genesys_find_sensor_any(const Genesys_Device*): start
[23:55:48.767961] [genesys] const genesys::Genesys_Sensor& genesys::sanei_genesys_find_sensor_any(const Genesys_Device*): completed
[23:55:48.768014] [genesys] void genesys::calc_parameters(Genesys_Scanner*): start
[23:55:48.768026] [genesys] genesys::Genesys_Settings genesys::calculate_scan_settings(Genesys_Scanner*): start
[23:55:48.768042] [genesys] unsigned int genesys::pick_resolution(const std::vector<unsigned int, std::allocator<unsigned int> >&, unsigned int, const char*): start
[23:55:48.768059] [genesys] unsigned int genesys::pick_resolution(const std::vector<unsigned int, std::allocator<unsigned int> >&, unsigned int, const char*): completed
[23:55:48.768075] [genesys] unsigned int genesys::pick_resolution(const std::vector<unsigned int, std::allocator<unsigned int> >&, unsigned int, const char*): start
[23:55:48.768090] [genesys] unsigned int genesys::pick_resolution(const std::vector<unsigned int, std::allocator<unsigned int> >&, unsigned int, const char*): completed
[23:55:48.768110] [genesys] const genesys::Genesys_Sensor& genesys::sanei_genesys_find_sensor(const Genesys_Device*, unsigned int, unsigned int, ScanMethod): start
[23:55:48.768125] [genesys] const genesys::Genesys_Sensor& genesys::sanei_genesys_find_sensor(const Genesys_Device*, unsigned int, unsigned int, ScanMethod): [23:55:48.768139] [genesys] dpi: 75, channels: 1, scan_method: 0[23:55:48.768151] [genesys]
[23:55:48.768166] [genesys] genesys::Genesys_Sensor* genesys::find_sensor_impl(const Genesys_Device*, unsigned int, unsigned int, ScanMethod): start
[23:55:48.768178] [genesys] genesys::Genesys_Sensor* genesys::find_sensor_impl(const Genesys_Device*, unsigned int, unsigned int, ScanMethod): [23:55:48.768189] [genesys] dpi: 75, channels: 1, scan_method: 0[23:55:48.768201] [genesys]
[23:55:48.768212] [genesys] genesys::Genesys_Sensor* genesys::find_sensor_impl(const Genesys_Device*, unsigned int, unsigned int, ScanMethod): completed
[23:55:48.768224] [genesys] const genesys::Genesys_Sensor& genesys::sanei_genesys_find_sensor(const Genesys_Device*, unsigned int, unsigned int, ScanMethod): completed
[23:55:48.768245] [genesys] genesys::Genesys_Settings genesys::calculate_scan_settings(Genesys_Scanner*): completed
[23:55:48.768257] [genesys] SANE_Parameters genesys::calculate_scan_parameters(const Genesys_Device&, const Genesys_Settings&): start
[23:55:48.768269] [genesys] const genesys::Genesys_Sensor& genesys::sanei_genesys_find_sensor(const Genesys_Device*, unsigned int, unsigned int, ScanMethod): start
[23:55:48.768284] [genesys] const genesys::Genesys_Sensor& genesys::sanei_genesys_find_sensor(const Genesys_Device*, unsigned int, unsigned int, ScanMethod): [23:55:48.768297] [genesys] dpi: 75, channels: 1, scan_method: 0[23:55:48.768308] [genesys]
[23:55:48.768319] [genesys] genesys::Genesys_Sensor* genesys::find_sensor_impl(const Genesys_Device*, unsigned int, unsigned int, ScanMethod): start
[23:55:48.768332] [genesys] genesys::Genesys_Sensor* genesys::find_sensor_impl(const Genesys_Device*, unsigned int, unsigned int, ScanMethod): [23:55:48.768344] [genesys] dpi: 75, channels: 1, scan_method: 0[23:55:48.768355] [genesys]
[23:55:48.768367] [genesys] genesys::Genesys_Sensor* genesys::find_sensor_impl(const Genesys_Device*, unsigned int, unsigned int, ScanMethod): completed
[23:55:48.768379] [genesys] const genesys::Genesys_Sensor& genesys::sanei_genesys_find_sensor(const Genesys_Device*, unsigned int, unsigned int, ScanMethod): completed
[23:55:48.768412] [genesys] virtual genesys::ScanSession genesys::gl841::CommandSetGl841::calculate_scan_session(const genesys::Genesys_Device*, const genesys::Genesys_Sensor&, const genesys::Genesys_Settings&) const: start
[23:55:48.768510] [genesys] Genesys_Settings{
xres: 75 yres: 75
lines: 882
pixels per line (actual): 643
pixels per line (requested): 643
depth: 8
tl_x: 0 tl_y: 0
scan_mode: GRAY
[23:55:48.768542] [genesys] void genesys::compute_session(const Genesys_Device*, ScanSession&, const Genesys_Sensor&): start
[23:55:48.768649] [genesys] void genesys::compute_session(const Genesys_Device*, ScanSession&, const Genesys_Sensor&): failed
[23:55:48.768671] [genesys] virtual genesys::ScanSession genesys::gl841::CommandSetGl841::calculate_scan_session(const genesys::Genesys_Device*, const genesys::Genesys_Sensor&, const genesys::Genesys_Settings&) const: failed
[23:55:48.768693] [genesys] SANE_Parameters genesys::calculate_scan_parameters(const Genesys_Device&, const Genesys_Settings&): failed
[23:55:48.768706] [genesys] void genesys::calc_parameters(Genesys_Scanner*): failed
[23:55:48.768722] [genesys] void genesys::init_options(Genesys_Scanner*): failed
[23:55:48.768734] [genesys] void genesys::sane_open_impl(SANE_String_Const, void**): failed during
pen device 'libusb:003:003'
[23:55:48.768752] [genesys] sane_genesys_open: got uncaught exception: SetupParams are not valid
[+13,38s] DEBUG: scanner.vala:924: sane_open ("genesys:libusb:003:003") -> SANE_STATUS_INVAL
[+13,38s] WARNING: scanner.vala:928: Unable to open device: Invalid argument
[+19,62s] DEBUG: app-window.vala
Saving state to /root/.config/simple-scan/state
[+19,67s] DEBUG: autosave-manager.vala:209: Deleting autosave records
[+19,67s] WARNING: autosave-manager.vala:222: Failed to delete autosaves: Ошибка при открытии каталога «/root/.cache/simple-scan/autosaves»: Нет такого файла или каталога
[+19,67s] DEBUG: scanner.vala
Stopping scan thread
[+19,67s] DEBUG: scanner.vala:863: Processing request
[23:55:55.058669] [dll] sane_exit: exiting
[23:55:55.058702] [dll] sane_exit: calling backend `epkowa's exit function
[23:55:55.059032] [dll] sane_exit: calling backend `xerox_mfp's exit function
[23:55:55.059144] [dll] sane_exit: calling backend `v4l's exit function
[23:55:55.059348] [dll] sane_exit: calling backend `umax1220u's exit function
[23:55:55.059465] [dll] sane_exit: calling backend `umax's exit function
[23:55:55.059560] [dll] sane_exit: calling backend `u12's exit function
[23:55:55.059656] [dll] sane_exit: calling backend `teco3's exit function
[23:55:55.059735] [dll] sane_exit: calling backend `teco2's exit function
[23:55:55.059809] [dll] sane_exit: calling backend `teco1's exit function
[23:55:55.059893] [dll] sane_exit: calling backend `tamarack's exit function
[23:55:55.059976] [dll] sane_exit: calling backend `sp15c's exit function
[23:55:55.060140] [dll] sane_exit: calling backend `snapscan's exit function
[23:55:55.060242] [dll] sane_exit: calling backend `sm3840's exit function
[23:55:55.060336] [dll] sane_exit: calling backend `sm3600's exit function
[23:55:55.060452] [dll] sane_exit: calling backend `sharp's exit function
[23:55:55.060546] [dll] sane_exit: calling backend `sceptre's exit function
[23:55:55.060632] [dll] sane_exit: calling backend `s9036's exit function
[23:55:55.060719] [dll] sane_exit: calling backend `rts8891's exit function
[23:55:55.060815] [dll] sane_exit: calling backend `ricoh2's exit function
[23:55:55.060994] [dll] sane_exit: calling backend `ricoh's exit function
[23:55:55.061081] [dll] sane_exit: calling backend `qcam's exit function
[23:55:55.061245] [dll] sane_exit: calling backend `plustek's exit function
[23:55:55.061348] [dll] sane_exit: calling backend `pixma's exit function
[23:55:55.061490] [dll] sane_exit: calling backend `pieusb's exit function
[23:55:55.061583] [dll] sane_exit: calling backend `pie's exit function
[23:55:55.061673] [dll] sane_exit: calling backend `niash's exit function
[23:55:55.061767] [dll] sane_exit: calling backend `nec's exit function
[23:55:55.061857] [dll] sane_exit: calling backend `mustek_usb2's exit function
[23:55:55.061956] [dll] sane_exit: calling backend `mustek_usb's exit function
[23:55:55.062053] [dll] sane_exit: calling backend `mustek's exit function
[23:55:55.062151] [dll] sane_exit: calling backend `microtek2's exit function
[23:55:55.062247] [dll] sane_exit: calling backend `microtek's exit function
[23:55:55.062339] [dll] sane_exit: calling backend `matsushita's exit function
[23:55:55.062436] [dll] sane_exit: calling backend `magicolor's exit function
[23:55:55.062532] [dll] sane_exit: calling backend `ma1509's exit function
[23:55:55.062622] [dll] sane_exit: calling backend `lexmark's exit function
[23:55:55.062709] [dll] sane_exit: calling backend `leo's exit function
[23:55:55.062785] [dll] sane_exit: calling backend `kvs40xx's exit function
[23:55:55.062868] [dll] sane_exit: calling backend `kvs20xx's exit function
[23:55:55.062951] [dll] sane_exit: calling backend `kvs1025's exit function
[23:55:55.063043] [dll] sane_exit: calling backend `kodakaio's exit function
[23:55:55.063131] [dll] sane_exit: calling backend `kodak's exit function
[23:55:55.063201] [dll] sane_exit: calling backend `ibm's exit function
[23:55:55.063274] [dll] sane_exit: calling backend `hs2p's exit function
[23:55:55.063353] [dll] sane_exit: calling backend `hpsj5s's exit function
[23:55:55.063503] [dll] sane_exit: calling backend `hpljm1005's exit function
[23:55:55.063603] [dll] sane_exit: calling backend `hp5590's exit function
[23:55:55.063696] [dll] sane_exit: calling backend `hp5400's exit function
[23:55:55.063808] [dll] sane_exit: calling backend `hp4200's exit function
[23:55:55.063910] [dll] sane_exit: calling backend `hp3900's exit function
[23:55:55.064038] [dll] sane_exit: calling backend `hp3500's exit function
[23:55:55.064149] [dll] sane_exit: calling backend `hp's exit function
[23:55:55.064268] [dll] sane_exit: calling backend `gt68xx's exit function
[23:55:55.064382] [dll] sane_exit: calling backend `genesys's exit function
[23:55:55.064426] [genesys] void genesys::sane_exit_impl(): start
[23:55:55.064570] [genesys] UsbDevice not closed; closing automatically[23:55:55.064584] [genesys] virtual void genesys::UsbDevice::close(): start
[23:55:55.064630] [genesys] virtual void genesys::UsbDevice::close(): completed
[23:55:55.064672] [genesys] void genesys::sane_exit_impl(): completed
[23:55:55.064843] [dll] sane_exit: calling backend `fujitsu's exit function
[23:55:55.064936] [dll] sane_exit: calling backend `epjitsu's exit function
[23:55:55.065020] [dll] sane_exit: calling backend `dmc's exit function
[23:55:55.065154] [dll] sane_exit: calling backend `dell1600n_net's exit function
[23:55:55.065268] [dll] sane_exit: calling backend `coolscan3's exit function
[23:55:55.065356] [dll] sane_exit: calling backend `coolscan's exit function
[23:55:55.065449] [dll] sane_exit: calling backend `cardscan's exit function
[23:55:55.065539] [dll] sane_exit: calling backend `canon_lide70's exit function
[23:55:55.065625] [dll] sane_exit: calling backend `canon_dr's exit function
[23:55:55.065720] [dll] sane_exit: calling backend `canon630u's exit function
[23:55:55.065807] [dll] sane_exit: calling backend `canon's exit function
[23:55:55.065875] [dll] sane_exit: calling backend `bh's exit function
[23:55:55.065947] [dll] sane_exit: calling backend `avision's exit function
[23:55:55.066082] [dll] sane_exit: calling backend `artec_eplus48u's exit function
[23:55:55.066153] [dll] sane_exit: calling backend `artec's exit function
[23:55:55.066227] [dll] sane_exit: calling backend `apple's exit function
[23:55:55.066343] [dll] sane_exit: calling backend `agfafocus's exit function
[23:55:55.066429] [dll] sane_exit: calling backend `abaton's exit function
[23:55:55.066516] [dll] sane_exit: calling backend `net's exit function
[23:55:55.066598] [dll] sane_exit: calling backend `epsonscan2's exit function
[23:55:55.066644] [dll] sane_exit: calling backend `airscan's exit function
[23:55:55.068709] [dll] sane_exit: calling backend `hpaio's exit function
[23:55:55.069156] [dll] sane_exit: finished
[+19,68s] DEBUG: scanner.vala
sane_exit ()
