Sound problems on LENOVO IdeaPad Slim 5 (SOLVED)
erfan
Operating system: Rosa Fresh 13 Plasma 6
Сообщение erfan »
Hello to everyone!
Brief history of the landing to Rosa is linked to my sound problems.
I am new to Rosa (I have checked it from time to time, but never installed and used is regularly), but not new in linux. This summer I have got a new laptop, a LENOVO IdeaPad Slim 5 15ARP10, AMD Ryzen 7 7735HS, with no OS. I have tried more than 20 linux distibution, of different kind and base, from the most well known ones to obscure ones, up-to-date ones – but I had troubles with the sound in speakers – the headphones were OK. The most distros had no sound in speakers trying the live iso. The last try was Rosa Fresh 13 – KDE version. Also no sound in speakers. But during my trial on the live iso, when a video were playing (no sound from the built-in speakers), I was interrupted in my work and closed the lid of the laptop. The laptop went to sleep mode. When I turned back and opened the lid, the sound was working.
After this experience I retested the other distros, and happened the same – after waking up from sleep, the sound was working. I decided to install one of the two distros (only 2 from 20!) which had sound without going first to sleep. But after installation I had no sound again. I did not found any solution on internet for my problem, having sound only after wake-up.
I was in doubts what to do after this experience. Because I had the luck with Rosa to discover a way to make the sound working, also because it looked polished, snappy, and using the smallest amount of RAM from those 20 distros, I decided to install it. No sound in speakers after installation. I made a complete update, without any issue, and after that, BIG and GOOD SURPRISE, the sound in speakers began to work. So a BIG LIKE for Rosa. Something from the updates helped. I decided to stay with Rosa.
And here is the biggest problem I have, with the microphone, to which I have not found a solution. I suspect that the source of the problem might be kernel-related. I am running the latest 6.12.34 kernel available in Rosa’s repository.
I installed, personalized and tweaked everything I needed (it was a big work, few weeks). At the end of it, more than a week ago, I discovered that the built-in microphone is not working. I did not checked this right after installation, but it does not appear in volume plasmoid, and is grayed out in the plasma sound settings. I cannot record anything. I have tested all possible combinations which gaved me audacity. The default settings functions like a monitor (if a sound is played on the computer, that is recorded directly by audacity, not thru the microphone). But if I use a headphone with microphone, with the default settings, everything is working OK, the headphone’s microphone appears in the volume settings and plasmoid too.
But I need the built-in ones to work.
Then, I retested the most representative ones from those 20 distros, and all has the same problem, no microphone (the sleep does not help getting microphone to work). Actually, I have downloaded yesterday two new snapshots of some rolling ones, and now the built-in microphones works on one of them. So, now is confirmed, that it is not a hardware problem. Also, I don’t want to reinstall everything, just stay with Rosa, I hope I can, at least for the next 5 years minimum, but I am hoping for more.
Sorry for the long writing. I hope the info help others too. In the next post I will be shorter. :-)
Thank You for Your work and help!
Последний раз редактировалось erfan 12 сен 2025, 11:46, всего редактировалось 1 раз.
Re: Sound problems on LENOVO IdeaPad Slim 5
check this method:
To use the IdeaPad Slim 5 microphone on Linux, you may need to load the snd-acp3x-rn kernel module by adding snd_rn_pci_acp3x.dmic_acpi_check=1 to your kernel parameters if the microphone isn't recognized by your system.
also may be need kernel > 6.13
https://www.phoronix.com/news/Linux-6.13-Sound
fdrt
Operating system: Rosa 2023.1
Сообщение fdrt »
Install this kernel and check the microphone and sound:
https://abf-downloads.rosa.ru/victorr20 ... n/release/
erfan
Сообщение erfan »
Thank You for the answers!
fdrt, the 6.15.11 kernel works! :good: I have working speakers and microphones with it.
So for now, Rosa is the only distro with working sound on my laptop :D. The biggest problem for its everyday use is solved.
Irton, unfortunately adding the parameters did not helped. Nothing changed.
During my research I have read before the linked article from phoronix, but I have tried distros with higher kernels also, and didn't have sound in speakers, so I thrown them without checking if the microphones are working or not. Also have seen mentioned somewhere, that those changes were ported to the 6.12. too, but didn't found to which version.
This Lenovo sound problem might be also distro-specific. I will exemplify with the few tests on live isos with 6.12. kernel (excepting Rosa, which is installed):
Distro name | Kernel | Speaker | Mics
Rosa 13 inst. | 6.12.13 | YES * | No |
Rosa 13 inst. | 6.12.34 | YES | No
Openmamba
20250902 iso | 6.12.37 | After Sleep | YES**
Debian 13.0
plasma 6 iso | 6.12.38 | After Sleep | No
PcLinuxOS
2025.07 iso | 6.12.39 | YES | No
Debian 13.1
plasma 6 iso | 6.12.43 | After Sleep | YES
PcLinuxOS
2025.08 iso | 6.12.45 | YES | No
*speakers were working only after sleep on the installation from the iso, but normally with 6.12.13 after updating the system. This makes me think, that the speaker problem might have other source than the kernel, that's why it generally does not work on other distros.
**also the microphone's functioning might depend on some distro-specific settings, patches, not only the official kernel itself
fdrt писал(а): 11 сен 2025, 12:29 Install this kernel and check the microphone and sound:
This container
https://abf-downloads.rosa.ru/victorr2007_personal/container/5472081/x86_64/main/release/
will be removed after some time.
If you need this kernel, you should use the target repository with this kernel.
https://abf-downloads.rosa.ru/victorr2007_personal/repository/rosa13/x86_64/main/release/
erfan
Re: Sound problems on LENOVO IdeaPad Slim 5 (SOLVED)
Сообщение erfan »
Thank You!
erfan
Сообщение erfan »
Just as an information, the sound now works OK (built-in speakers and microphones) with the recently updated main 6.12.47 kernel too. :good:
Вернуться в «Desktop»
