Не работает konqueror
kartavenko
Сообщение kartavenko »
Добрый день plasma 6 не работает konqueror
В консоли выдает
kf.parts: KPluginMetaData(name:"Программа просмотра изображений Gwenview", plugin-id:"gvpart") still defined ServiceTypes - this is deprecated in favor of providing a  "Capabilities" list in the "KParts" object in the root of the metadata
kf.parts: KPluginMetaData(name:"Встроенный расширенный текстовый редактор", plugin-id:"katepart") still defined ServiceTypes - this is deprecated in favor of providing a  "Capabilities" list in the "KParts" object in the root of the metadata
kf.parts: KPluginMetaData(name:"Шестнадцатеричный просмотрщик Okteta", plugin-id:"oktetapart") still defined ServiceTypes - this is deprecated in favor of providing a  "Capabilities" list in the "KParts" object in the root of the metadata
kf.parts: KPluginMetaData(name:"Компонент проигрывателя Dragon Player", plugin-id:"dragonpart") still defined ServiceTypes - this is deprecated in favor of providing a  "Capabilities" list in the "KParts" object in the root of the metadata
kf.parts: KPluginMetaData(name:"KGraphViewer", plugin-id:"kgraphviewerpart") still defined ServiceTypes - this is deprecated in favor of providing a  "Capabilities" list in the "KParts" object in the root of the metadata
kf.parts: KPluginMetaData(name:"Okular", plugin-id:"okularpart") still defined ServiceTypes - this is deprecated in favor of providing a  "Capabilities" list in the "KParts" object in the root of the metadata
kf.parts: KPluginMetaData(name:"KUIViewerPart", plugin-id:"kuiviewerpart") still defined ServiceTypes - this is deprecated in favor of providing a  "Capabilities" list in the "KParts" object in the root of the metadata
kf.parts: KPluginMetaData(name:"Архиватор", plugin-id:"arkpart") still defined ServiceTypes - this is deprecated in favor of providing a  "Capabilities" list in the "KParts" object in the root of the metadata
kf.parts: KPluginMetaData(name:"Компонент Cantor", plugin-id:"cantorpart") still defined ServiceTypes - this is deprecated in favor of providing a  "Capabilities" list in the "KParts" object in the root of the metadata
kf.parts: KPluginMetaData(name:"Компонент просмотра Svg", plugin-id:"svgpart") still defined ServiceTypes - this is deprecated in favor of providing a  "Capabilities" list in the "KParts" object in the root of the metadata
kf.parts: KPluginMetaData(name:"Просмотр Markdown", plugin-id:"markdownpart") still defined ServiceTypes - this is deprecated in favor of providing a  "Capabilities" list in the "KParts" object in the root of the metadata
kf.parts: KPluginMetaData(name:"Компонент KmPlot", plugin-id:"kmplotpart") still defined ServiceTypes - this is deprecated in favor of providing a  "Capabilities" list in the "KParts" object in the root of the metadata
kf.parts: KPluginMetaData(name:"Эмулятор терминала", plugin-id:"konsolepart") still defined ServiceTypes - this is deprecated in favor of providing a  "Capabilities" list in the "KParts" object in the root of the metadata
kf.parts: ServiceType "inode/directory" from KPluginMetaData(name:"Эмулятор терминала", plugin-id:"konsolepart") is not a known value that can be mapped to new Capability enum values
kf.parts: ServiceType "TerminalEmulator" from KPluginMetaData(name:"Эмулятор терминала", plugin-id:"konsolepart") is not a known value that can be mapped to new Capability enum values
kf.parts: KPluginMetaData(name:"Просмотр размеров файлов", plugin-id:"fsviewpart") still defined ServiceTypes - this is deprecated in favor of providing a  "Capabilities" list in the "KParts" object in the root of the metadata
kf.coreaddons: The plugin "/usr/lib64/qt6/plugins/amarok_importer-banshee.so" explicitly states an 'Id' in the embedded metadata. This value should be removed, the resulting pluginId will not be affected by it
kf.parts: KPluginMetaData(name:"Импорт из Banshee", plugin-id:"amarok_importer-banshee") still defined ServiceTypes - this is deprecated in favor of providing a  "Capabilities" list in the "KParts" object in the root of the metadata
kf.parts: ServiceType "Amarok/Plugin" from KPluginMetaData(name:"Импорт из Banshee", plugin-id:"amarok_importer-banshee") is not a known value that can be mapped to new Capability enum values
kf.coreaddons: The plugin "/usr/lib64/qt6/plugins/amarok_service_ampache.so" explicitly states an 'Id' in the embedded metadata. This value should be removed, the resulting pluginId will not be affected by it
kf.parts: KPluginMetaData(name:"Ampache", plugin-id:"amarok_service_ampache") still defined ServiceTypes - this is deprecated in favor of providing a  "Capabilities" list in the "KParts" object in the root of the metadata
kf.parts: ServiceType "Amarok/Plugin" from KPluginMetaData(name:"Ampache", plugin-id:"amarok_service_ampache") is not a known value that can be mapped to new Capability enum values
kf.coreaddons: The plugin "/usr/lib64/qt6/plugins/amarok_collection-daapcollection.so" explicitly states an 'Id' in the embedded metadata. This value should be removed, the resulting pluginId will not be affected by it
kf.parts: KPluginMetaData(name:"Коллекция DAAP", plugin-id:"amarok_collection-daapcollection") still defined ServiceTypes - this is deprecated in favor of providing a  "Capabilities" list in the "KParts" object in the root of the metadata
kf.parts: ServiceType "Amarok/Plugin" from KPluginMetaData(name:"Коллекция DAAP", plugin-id:"amarok_collection-daapcollection") is not a known value that can be mapped to new Capability enum values
kf.parts: KPluginMetaData(name:"Marble Part", plugin-id:"libmarble_part") still defined ServiceTypes - this is deprecated in favor of providing a  "Capabilities" list in the "KParts" object in the root of the metadata
kf.coreaddons: The plugin "/usr/lib64/qt6/plugins/amarok_service_opmldirectory.so" explicitly states an 'Id' in the embedded metadata. This value should be removed, the resulting pluginId will not be affected by it
kf.parts: KPluginMetaData(name:"Каталог подкастов", plugin-id:"amarok_service_opmldirectory") still defined ServiceTypes - this is deprecated in favor of providing a  "Capabilities" list in the "KParts" object in the root of the metadata
kf.parts: ServiceType "Amarok/Plugin" from KPluginMetaData(name:"Каталог подкастов", plugin-id:"amarok_service_opmldirectory") is not a known value that can be mapped to new Capability enum values
kf.coreaddons: The plugin "/usr/lib64/qt6/plugins/amarok_importer-amarok.so" explicitly states an 'Id' in the embedded metadata. This value should be removed, the resulting pluginId will not be affected by it
kf.parts: KPluginMetaData(name:"Импорт из Amarok 2.x", plugin-id:"amarok_importer-amarok") still defined ServiceTypes - this is deprecated in favor of providing a  "Capabilities" list in the "KParts" object in the root of the metadata
kf.parts: ServiceType "Amarok/Plugin" from KPluginMetaData(name:"Импорт из Amarok 2.x", plugin-id:"amarok_importer-amarok") is not a known value that can be mapped to new Capability enum values
kf.coreaddons: The plugin "/usr/lib64/qt6/plugins/amarok_importer-clementine.so" explicitly states an 'Id' in the embedded metadata. This value should be removed, the resulting pluginId will not be affected by it
kf.parts: KPluginMetaData(name:"Импорт из Clementine", plugin-id:"amarok_importer-clementine") still defined ServiceTypes - this is deprecated in favor of providing a  "Capabilities" list in the "KParts" object in the root of the metadata
kf.parts: ServiceType "Amarok/Plugin" from KPluginMetaData(name:"Импорт из Clementine", plugin-id:"amarok_importer-clementine") is not a known value that can be mapped to new Capability enum values
kf.coreaddons: The plugin "/usr/lib64/qt6/plugins/amarok_storage-mysqlestorage.so" explicitly states an 'Id' in the embedded metadata. This value should be removed, the resulting pluginId will not be affected by it
kf.parts: KPluginMetaData(name:"MySQLe Storage", plugin-id:"amarok_storage-mysqlestorage") still defined ServiceTypes - this is deprecated in favor of providing a  "Capabilities" list in the "KParts" object in the root of the metadata
kf.parts: ServiceType "Amarok/Plugin" from KPluginMetaData(name:"MySQLe Storage", plugin-id:"amarok_storage-mysqlestorage") is not a known value that can be mapped to new Capability enum values
kf.coreaddons: The plugin "/usr/lib64/qt6/plugins/amarok_service_magnatunestore.so" explicitly states an 'Id' in the embedded metadata. This value should be removed, the resulting pluginId will not be affected by it
kf.parts: KPluginMetaData(name:"Магазин Magnatune", plugin-id:"amarok_service_magnatunestore") still defined ServiceTypes - this is deprecated in favor of providing a  "Capabilities" list in the "KParts" object in the root of the metadata
kf.parts: ServiceType "Amarok/Plugin" from KPluginMetaData(name:"Магазин Magnatune", plugin-id:"amarok_service_magnatunestore") is not a known value that can be mapped to new Capability enum values
kf.coreaddons: The plugin "/usr/lib64/qt6/plugins/amarok_collection-mtpcollection.so" explicitly states an 'Id' in the embedded metadata. This value should be removed, the resulting pluginId will not be affected by it
kf.parts: KPluginMetaData(name:"Коллекция MTP", plugin-id:"amarok_collection-mtpcollection") still defined ServiceTypes - this is deprecated in favor of providing a  "Capabilities" list in the "KParts" object in the root of the metadata
kf.parts: ServiceType "Amarok/Plugin" from KPluginMetaData(name:"Коллекция MTP", plugin-id:"amarok_collection-mtpcollection") is not a known value that can be mapped to new Capability enum values
kf.parts: KPluginMetaData(name:"Настройка службы Magnatune", plugin-id:"kcm_amarok_service_magnatunestore") still defined ServiceTypes - this is deprecated in favor of providing a  "Capabilities" list in the "KParts" object in the root of the metadata
kf.parts: ServiceType "KCModule" from KPluginMetaData(name:"Настройка службы Magnatune", plugin-id:"kcm_amarok_service_magnatunestore") is not a known value that can be mapped to new Capability enum values
kf.coreaddons: The plugin "/usr/lib64/qt6/plugins/amarok_importer-itunes.so" explicitly states an 'Id' in the embedded metadata. This value should be removed, the resulting pluginId will not be affected by it
kf.parts: KPluginMetaData(name:"Импорт из Apple iTunes", plugin-id:"amarok_importer-itunes") still defined ServiceTypes - this is deprecated in favor of providing a  "Capabilities" list in the "KParts" object in the root of the metadata
kf.parts: ServiceType "Amarok/Plugin" from KPluginMetaData(name:"Импорт из Apple iTunes", plugin-id:"amarok_importer-itunes") is not a known value that can be mapped to new Capability enum values
kf.coreaddons: The plugin "/usr/lib64/qt6/plugins/amarok_collection-mysqlcollection.so" explicitly states an 'Id' in the embedded metadata. This value should be removed, the resulting pluginId will not be affected by it
kf.parts: KPluginMetaData(name:"MySQL Collection", plugin-id:"amarok_collection-mysqlcollection") still defined ServiceTypes - this is deprecated in favor of providing a  "Capabilities" list in the "KParts" object in the root of the metadata
kf.parts: ServiceType "Amarok/Plugin" from KPluginMetaData(name:"MySQL Collection", plugin-id:"amarok_collection-mysqlcollection") is not a known value that can be mapped to new Capability enum values
kf.parts: KPluginMetaData(name:"Настройка службы Ampache", plugin-id:"kcm_amarok_service_ampache") still defined ServiceTypes - this is deprecated in favor of providing a  "Capabilities" list in the "KParts" object in the root of the metadata
kf.parts: ServiceType "KCModule" from KPluginMetaData(name:"Настройка службы Ampache", plugin-id:"kcm_amarok_service_ampache") is not a known value that can be mapped to new Capability enum values
kf.coreaddons: The plugin "/usr/lib64/qt6/plugins/amarok_importer-fastforward.so" explicitly states an 'Id' in the embedded metadata. This value should be removed, the resulting pluginId will not be affected by it
kf.parts: KPluginMetaData(name:"Импорт из Amarok 1.4", plugin-id:"amarok_importer-fastforward") still defined ServiceTypes - this is deprecated in favor of providing a  "Capabilities" list in the "KParts" object in the root of the metadata
kf.parts: ServiceType "Amarok/Plugin" from KPluginMetaData(name:"Импорт из Amarok 1.4", plugin-id:"amarok_importer-fastforward") is not a known value that can be mapped to new Capability enum values
kf.coreaddons: The plugin "/usr/lib64/qt6/plugins/amarok_importer-rhythmbox.so" explicitly states an 'Id' in the embedded metadata. This value should be removed, the resulting pluginId will not be affected by it
kf.parts: KPluginMetaData(name:"Импорт из Rhythmbox", plugin-id:"amarok_importer-rhythmbox") still defined ServiceTypes - this is deprecated in favor of providing a  "Capabilities" list in the "KParts" object in the root of the metadata
kf.parts: ServiceType "Amarok/Plugin" from KPluginMetaData(name:"Импорт из Rhythmbox", plugin-id:"amarok_importer-rhythmbox") is not a known value that can be mapped to new Capability enum values
kf.coreaddons: The plugin "/usr/lib64/qt6/plugins/amarok_collection-umscollection.so" explicitly states an 'Id' in the embedded metadata. This value should be removed, the resulting pluginId will not be affected by it
kf.parts: KPluginMetaData(name:"Коллекция UMS", plugin-id:"amarok_collection-umscollection") still defined ServiceTypes - this is deprecated in favor of providing a  "Capabilities" list in the "KParts" object in the root of the metadata
kf.parts: ServiceType "Amarok/Plugin" from KPluginMetaData(name:"Коллекция UMS", plugin-id:"amarok_collection-umscollection") is not a known value that can be mapped to new Capability enum values
kf.coreaddons: The plugin "/usr/lib64/qt6/plugins/amarok_storage-mysqlserverstorage.so" explicitly states an 'Id' in the embedded metadata. This value should be removed, the resulting pluginId will not be affected by it
kf.parts: KPluginMetaData(name:"MySQLServer Storage", plugin-id:"amarok_storage-mysqlserverstorage") still defined ServiceTypes - this is deprecated in favor of providing a  "Capabilities" list in the "KParts" object in the root of the metadata
kf.parts: ServiceType "Amarok/Plugin" from KPluginMetaData(name:"MySQLServer Storage", plugin-id:"amarok_storage-mysqlserverstorage") is not a known value that can be mapped to new Capability enum values
kf.coreaddons: The plugin "/usr/lib64/qt6/plugins/amarok_collection-audiocdcollection.so" explicitly states an 'Id' in the embedded metadata. This value should be removed, the resulting pluginId will not be affected by it
kf.parts: KPluginMetaData(name:"Коллекция AudioCD", plugin-id:"amarok_collection-audiocdcollection") still defined ServiceTypes - this is deprecated in favor of providing a  "Capabilities" list in the "KParts" object in the root of the metadata
kf.parts: ServiceType "Amarok/Plugin" from KPluginMetaData(name:"Коллекция AudioCD", plugin-id:"amarok_collection-audiocdcollection") is not a known value that can be mapped to new Capability enum values
kf.coreaddons: The plugin "/usr/lib64/qt6/plugins/amarok_collection-playdarcollection.so" explicitly states an 'Id' in the embedded metadata. This value should be removed, the resulting pluginId will not be affected by it
kf.parts: KPluginMetaData(name:"Коллекция Playdar", plugin-id:"amarok_collection-playdarcollection") still defined ServiceTypes - this is deprecated in favor of providing a  "Capabilities" list in the "KParts" object in the root of the metadata
kf.parts: ServiceType "Amarok/Plugin" from KPluginMetaData(name:"Коллекция Playdar", plugin-id:"amarok_collection-playdarcollection") is not a known value that can be mapped to new Capability enum values
KCrash: Application 'konqueror' crashing... crashRecursionCounter = 2
Ошибка сегментирования (стек памяти сброшен на диск
av179120
Re: Не работает konqueror
Сообщение av179120 »
Поставил plasma6-konqueror для поглядеть.
Запустился... :unknown:
kartavenko
Проблема так же как здесь https://forum.rosa.ru/viewtopic.php?p=122109#p122109 решилась откатом драйверов nvidia
av179120 писал(а): 06 июл 2025, 17:57 Поставил plasma6-konqueror для поглядеть.
Я его в основном для ютуба использую.
Но в нем куча плюсов.
Ещё со времён, когда он заменял в одном лице и dolphin, и web браузер.
Таланты он не теряет.
Только сменил движёк для сети.
Зато куча удобст.
Разделил экран.
В одном файлы или видео играет, или музыка,
во второй половине в сети лазишь.
Силища. :)
VictorR2007 писал(а): 10 авг 2025, 19:53 Я его в основном для ютуба использую.
С моей стороны это оффтоп, но не выдержал.
Выше написали, что поставили просто посмотреть.
Хотелось пояснить, что его функционал освоить не быстро.
