Hi all!
diyanaparker0
Operating system: I want to register to connect with others who share similar interests and passions. Engaging in discussions can help me build meaningful relationships with community members.
Hi all!
Сообщение diyanaparker0 »
I have ROSA Fresh R11. I will outline the obstacles that prevent Rosa from becoming a replacement for Windows worldwide. Yes, no more, no less.
So, it freezes sometimes, and it would be better if it were faster. Then there are drivers, for example, I could not find them for my Canon. Also, some accounting programs that are very necessary for individual entrepreneurs do not work on Rosa, no matter what. For example, PU-6.
And another problem, after serious system freezes and forced reboots, it is very problematic to connect to the Internet again. Neither automatically nor manually. Not at all. That's how it is. Work, guys. Improve the product. And otherwise, it seems fine, your OS will work, I am using it.
Good luck!
Hi all!
diyanaparker0 писал(а): 28 окт 2024, 20:20 I have ROSA Fresh R11.
R11 is deprecated and no longer supported.
Sartorius
Hi all!
Сообщение Sartorius »
Hello! I recommend using the forum search, there is a solution to all problems here.
