Avogadro/AvogadroLibs aggiornamento/update 1.97.0
MikiLinux
Operating system: Rosa13
Сообщение MikiLinux »
Ciao/Привет
per la piattaforma 2021.1 ho aggiornato AvogadroLibs e AvogadroApp alla versione 1.97.0.
In allegato i file spec.src.zip.
P.S.: Non è possibile aggiornare alla versione 1.99.0 perché occorre CMake >= 3.24 e Qt6; e Rosa 2021.1 presenta la versione 3.21.3
Oltre l'aggiornamento anche questa correzione: Fix "Unable to retrieve program name"
https://discuss.avogadro.cc/t/errors-in ... linux/4883
Seguendo questo tutorial sembra funzionare senza alcun problema:
https://rutube.ru/video/8cff590a9fabcee ... a16fdcbc6/
Avogadro 1.97.0
Avogadro 1.97.0
Hi,
updated AvogadroLibs e AvogadroApp to 1.97.0 (only for Rosa 2021.1 platform)
Enclosed spec.src.zip files.
P.S.: It's not possible to update to 1.99.0 version because its needs of CMake >= 3.24 and Qt6; Rosa 2021.1 platform has Cmake 3.21.3 version.
I have also patched with this fix: Fix "Unable to retrieve program name"
Now it seems to be all right.
Avogadro 1.97.0
Avogadro 1.97.0
avogadrolibs-1.97.0-1.src.zip
(6.17 КБ) 291 скачивание
avogadro-1.97.0-1.src.zip
(1.24 КБ) 309 скачиваний
Desktop: Rosa13 KDE/Plasma
PC Lab: Rosa13 XFCE
Laptop: Rosa13 LxQt
https://elettrolinux.com
not forget: Rosa not use network to internet on build stage. All projects compile without network.
updated in 2021.1
