Aggiornamento/Update coordgenlibs
MikiLinux
Operating system: Rosa13
Сообщение MikiLinux »
Ciao,
ho corretto nello spec file un paio di problemi con la libreria Coordgenlibs. Allegato il file spec in fomrato zip.
1) Immagine in basso:
2) Dopo il comando rpm-lint --> outside-libdir-files
P.S.: Sto aggiornando anche il pacchetto Openabebel: ho trovato 3 errori.
Hi,
I have corrected a couple of issues in spec file, package Coordgenlibs. Spec's file enclosed (zip format)
1) Image enclosed
2) After command rpm-lint --> outside-libdir-files
P.S.: I'm updating Openbabel package also; I have found 3 errors.
coordgen-3.0.2-2.src.zip
(165.14 КБ) 65 скачиваний
Desktop: Rosa13 KDE/Plasma
PC Lab: Rosa13 XFCE
Laptop: Rosa13 LxQt
https://elettrolinux.com
i'm not have rpmlint errors "outside-libdir-files"
coordgen fixed in 2023.1, thank you.
