Aggiornamento/Update sw: dos2unix, libgit2, meld, ngspice, doxygen
Salve,
dopo wxGlade (viewtopic.php?f=48&t=11195) ho aggiornato altri pacchetti: dos2unix, libgit2, meld, ngspice, doxygen. Allegati i file ".spec.zip" e 1 patch per Doxygen.
Software con interfaccia grafica come Meld e Doxygen Wizard sembrano funzionare senza alcun problema (immagini allegate).
Per Doxygen è stato eseguito questo tutorial senza alcun problema:
https://embeddedinventor.com/guide-to-c ... beginners/
Hi,
after wxGlade sw (viewtopic.php?f=48&t=11195) I have updated some others packages: dos2unix, libgit2, meld, ngspice and doxygen. File ".spec.zip" enclosed together wit patch file for Doxygen.
Sw with GUI like Meld and Doxygen Wizard seems work without problems (enclosed image).
Doxygen wizard (command line doxywizard); this tutorial works any problems at all:
Bye
- MikiLinux
- Вложения
- meld.spec.zip
- (1.11 КБ) 101 скачивание
- doxygen-1.2.12-fix-latex.patch.zip
- (7.21 КБ) 102 скачивания
- doxygen.spec.zip
- (1.01 КБ) 108 скачиваний
- MikiLinux
Here spec file for dos2unix, libgit2, ngspice,
- Вложения
- ngspice.spec.zip
- (915 байт) 105 скачиваний
- libgit2.spec.zip
- (999 байт) 117 скачиваний
- dos2unix.spec.zip
- (813 байт) 108 скачиваний
https://bugzilla.rosalinux.ru/show_bug.cgi?id=14568 i send it to QA
ngspice updated in repo contrib
libgit2 and other lib* dangerous update in stable platform.
