How to change plymouth theme? Solved.
Non-Desktop related topics
benbullard79
Operating system: ROSA Fresh R5
OpenMandriva Lx 2014.1
openSuSE 13.2
Сообщение benbullard79 »
Currently using (among others) Rosa Marathon 2012 EE x86_64.
I do some things with graphics from time to time so I need to change things to see what I've done. For some reason I can't change plymouth theme in Rosa operating systems. I can in Mandriva or Fedora. For instance say I want to use MIB-Ossigeno-Ultimate plymouth theme following instructions here:
http://mib.pianetalinux.org/forum/viewt ... =38#p14227
# plymouth-set-default-theme MIB-Ossigeno-Ultimate-Plymouth
# /usr/libexec/plymouth/plymouth-generate-initrd
4264 blocks
# /usr/libexec/plymouth/plymouth-update-initrd
I: *** Including module: dash ***
I: *** Including module: i18n ***
I: *** Including module: rpmversion ***
I: *** Including module: usrmove ***
I: *** Including module: network ***
I: Possible missing firmware "ct2fw.bin" for kernel module "bna.ko"
I: Possible missing firmware "ctfw.bin" for kernel module "bna.ko"
I: *** Including module: ifcfg ***
I: *** Including module: plymouth ***
I: Possible missing firmware "radeon/SUMO2_me.bin" for kernel module "radeon.ko"
I: Possible missing firmware "radeon/SUMO2_pfp.bin" for kernel module "radeon.ko"
I: Possible missing firmware "radeon/SUMO_me.bin" for kernel module "radeon.ko"
I: Possible missing firmware "radeon/SUMO_pfp.bin" for kernel module "radeon.ko"
I: *** Including module: btrfs ***
I: *** Including module: crypt ***
I: *** Including module: dm ***
I: Skipping udev rule: 64-device-mapper.rules
I: *** Including module: dmraid ***
I: *** Including module: dmsquash-live ***
I: *** Including module: kernel-modules ***
I: Possible missing firmware "ct2fw.bin" for kernel module "bfa.ko"
I: Possible missing firmware "ctfw.bin" for kernel module "bfa.ko"
I: Possible missing firmware "cbfw.bin" for kernel module "bfa.ko"
I: Possible missing firmware "aic94xx-seq.fw" for kernel module "aic94xx.ko"
I: *** Including module: lvm ***
I: *** Including module: mdraid ***
I: *** Including module: fcoe ***
I: *** Including module: nfs ***
I: *** Including module: resume ***
I: *** Including module: rootfs-block ***
I: *** Including module: terminfo ***
I: *** Including module: udev-rules ***
I: Skipping udev rule: 50-udev.rules
I: Skipping udev rule: 95-late.rules
I: *** Including module: usrmount ***
I: *** Including module: aufs-mount ***
I: *** Including module: base ***
I: *** Including module: fs-lib ***
I: *** Including module: shutdown ***
I: Skipping program kexec as it cannot be found and is flagged to be optional
I: *** Including modules done ***
I: Wrote /boot/initrd-3.2.18-desktop-1rosa.lts.img:
I: -rw-r--r-- 1 root root 32267203 Jul  8 02:00 /boot/initrd-3.2.18-desktop-1rosa.lts.img
When I reboot I still get POCA screen. What am I doing wrong?
Последний раз редактировалось benbullard79 19 июл 2012, 20:15, всего редактировалось 1 раз.
Thanks,
Ben Bullard
Re: How to change plymouth theme?
benbullard79
openSuSE 13.2
VictorR2007 писал(а):plymouth-set-default-theme MIB-Ossigeno-Ultimate-Plymouth
Thanks for reply. If you read what I posted in code that is exactly what I have been doing and it isn't working. I still get POCA light grey plymouth theme not MIB-Ossigeno-Ultimate-Plymouth. What I don't understand is why. This works in Mandriva but not in Rosa.
Thanks,
Ben Bullard
Later I will give an answer to the problem.
benbullard79
openSuSE 13.2
Looking forward to that.
Thanks,
Ben Bullard
benbullard79 писал(а):Looking forward to that.
I also could not do anything. Three hour spent.
Tried in another program plymouth-theme-switcher of ftp://ftp.mandrivauser.de/rpm/GPL/2010. ... 4/release/
I renamed /usr/share/plymouth/themes/Mandriva-Rosa to old.Mandriva-Rosa
further
Then install a new kernel.
Everything was working.
benbullard79
openSuSE 13.2
Thanks. I did something similiar I moved Mandriva-Rosa elsewhere. Now I can change plymouth theme as I wish. :mrgreen: :lol: :!:
Thanks,
Ben Bullard
