Hello,
I set up auto-login in "Login screen (SDDM)", but after reboot the user is displayed in login screen but not logged in automatically. What is wrong?
Thanks
						Auto login not working
The default was gdm, not sddm.
Check what you have running:
If gdm, try add to /etc/gdm/custom.conf
Or, if you need sddm, try do:
systemctl status gdm
systemctl status sddmКод: Выделить всё
[daemon]
AutomaticLoginEnable=True
AutomaticLogin=user
sudo systemctl disable gdm
sudo systemctl enable sddm
Thanks for hint. I enabled sddm and now it works.
Btw. which one should I use? I though that when I use plasma, means KDE, that SDDM and not Gnome's gdm. Or?
