Проблемы на kde4
Гость 25
Operating system: Rosa Fresh
Проблемы на kde4
Сообщение Гость 25 »
При установки пакета через urpmi видно бывает вот что (это на Rosa Plazma 11.1 Версия ядра 5.4.40-generic-1rosa -x86_64) Это только один пример. А так у каждого пакета через urpmi примерно такое же. (ну разве что по количеству строк меньше)
warning: LOOP:
warning: removing vlc-3.0.8-2plf.x86_64 "Requires(hint): vlc-plugin-mpc" from tsort relations.
warning: removing vlc-plugin-mpc-3.0.8-2plf.x86_64 "Requires: vlc = 3.0.8" from tsort relations.
warning: LOOP:
warning: removing vlc-3.0.8-2plf.x86_64 "Requires(hint): vlc-plugin-opus" from tsort relations.
warning: removing vlc-plugin-opus-3.0.8-2plf.x86_64 "Requires: vlc = 3.0.8" from tsort relations.
warning: LOOP:
warning: removing vlc-3.0.8-2plf.x86_64 "Requires(hint): vlc-plugin-schroedinger" from tsort relations.
warning: removing vlc-plugin-schroedinger-3.0.8-2plf.x86_64 "Requires: vlc = 3.0.8" from tsort relations.
warning: LOOP:
warning: removing vlc-3.0.8-2plf.x86_64 "Requires(hint): vlc-plugin-lua" from tsort relations.
warning: removing vlc-plugin-lua-3.0.8-2plf.x86_64 "Requires: vlc = 3.0.8" from tsort relations.
warning: LOOP:
warning: removing vlc-3.0.8-2plf.x86_64 "Requires(hint): vlc-plugin-kate" from tsort relations.
warning: removing vlc-plugin-kate-3.0.8-2plf.x86_64 "Requires: vlc = 3.0.8" from tsort relations.
warning: LOOP:
warning: removing vlc-3.0.8-2plf.x86_64 "Requires(hint): vlc-plugin-theora" from tsort relations.
warning: removing vlc-plugin-theora-3.0.8-2plf.x86_64 "Requires: vlc = 3.0.8" from tsort relations.
warning: LOOP:
warning: removing vlc-3.0.8-2plf.x86_64 "Requires(hint): vlc-plugin-libass" from tsort relations.
warning: removing vlc-plugin-libass-3.0.8-2plf.x86_64 "Requires: vlc = 3.0.8" from tsort relations.
warning: LOOP:
warning: removing vlc-3.0.8-2plf.x86_64 "Requires(hint): vlc-plugin-flac" from tsort relations.
warning: removing vlc-plugin-flac-3.0.8-2plf.x86_64 "Requires: vlc = 3.0.8" from tsort relations.
warning: LOOP:
warning: removing vlc-3.0.8-2plf.x86_64 "Requires(hint): vlc-plugin-pulse" from tsort relations.
warning: removing vlc-plugin-pulse-3.0.8-2plf.x86_64 "Requires: vlc = 3.0.8" from tsort relations.
warning: LOOP:
warning: removing vlc-3.0.8-2plf.x86_64 "Requires(auto): libvlc_xcb_events.so.0()(64bit)" from tsort relations.
warning: removing vlc-plugin-opengl-3.0.8-2plf.x86_64 "Requires: vlc = 3.0.8" from tsort relations.
warning: LOOP:
warning: removing vlc-3.0.8-2plf.x86_64 "Requires(hint): vlc-plugin-upnp" from tsort relations.
warning: removing vlc-plugin-upnp-3.0.8-2plf.x86_64 "Requires: vlc = 3.0.8" from tsort relations.
warning: LOOP:
warning: removing vlc-3.0.8-2plf.x86_64 "Requires(hint): vlc-plugin-dv" from tsort relations.
Последний раз редактировалось Гость 25 18 июн 2020, 16:38, всего редактировалось 1 раз.
Гость 25
Пятничное тестирование - загляни в будущее Росы!
И еще: Изображение у видеоплееров не в полное окно как на KDE а вот так. Я проверил не одно а все много видео где на KDE все показывало в полное окно видеоплеера. Хотел скриншоты добавить но выходит такая надпись. Поэтому не могу добавить скрины. Но просто проверьте видео. Они показывают не на все окно видеоплеера.
Гость 25
И еще вот такое: Сетевая ошибка 5: Операция отменена
Проблемы у одного нашего пользователя
Отделил сообщения в отдельную тему.
Раз товарищ Гость 25 ленится создавать себе тему, то смог придумать только такое название темы.
Гость 25, не нужно писать в первой попавшейся теме.
Создавайте тему, если есть проблема, и там можно будет попробовать её решить.
Тема по пятничному тестированию именно по тестированию определённых пакетов,
опубликованных в соответствующий репозиторий,
а не обсуждения проблем частного характера.
Гость 25
VictorR2007 писал(а): 23 июн 2020, 12:32 Отделил сообщения в отдельную тему.
Я не ленился. Я просто не знал как лучше. Буду теперь знать. Просто думал что там лучше об ошибках сообщать.
av179120
Сообщение av179120 »
Гость 25 писал(а): 18 июн 2020, 16:12 И еще: Изображение у видеоплееров не в полное окно как на KDE а вот так. Я проверил не одно а все много видео где на KDE все показывало в полное окно видеоплеера. Хотел скриншоты добавить но выходит такая надпись. Поэтому не могу добавить скрины. Но просто проверьте видео. Они показывают не на все окно видеоплеера.
О каком плеере речь? "Видео" - понятие расяжииимое, очень много параметров следует учитывать.
Гость 25 писал(а): 23 июн 2020, 10:02 И еще вот такое: Сетевая ошибка 5: Операция отменена
У меня также, только ни на что не влияет - всё устанавливается.
Гость 25
av179120 писал(а): 23 июн 2020, 19:49
О всех видео плеерах :) На всех плеерах такая проблема. :) Просто на KDE такого не было.
av179120 писал(а): 23 июн 2020, 19:49 "Видео" - понятие расяжииимое
Как и слово «KDE»
Гость 25
Алзим писал(а): 23 июн 2020, 20:19 Как и слово «KDE»
На Росе KDE 11
Гость 25
Как говориться "Мелочь но неприятная". Я то просто хотел сообщить о кучке проблем которые заметил но раз в той теме нельзя то попал вот сюда. :)
Гость 25 писал(а): 23 июн 2020, 20:20 На Росе KDE 11
В ROSA два KDE: KDE4 и KDE5
KDE5 очень часто называют Plasma5. Но, на самом деле, Plasma5 — это всего-лишь часть KDE5
av179120
На Росе KDE 11
Есть Роса Фреш КДЕ 4, и есть Роса Фреш Плазма 5 (проще - КДЕ 5)
Тут бы форум нужно переделать по окружениям рабстола
ЗЫ. SMPlayer у меня показывает РОВНО ТАК, в каких параметрах записано или транслируется видео!
Гость 25
av179120 писал(а): 23 июн 2020, 20:41
На Росе KDE вроде тоже у меня нормально все показывает. А На Plazma мне в глаза бросилось что не во все окно. Можно конечно увеличить размер во весь экран но качество хуже.
Гость 25
Алзим писал(а): 23 июн 2020, 20:32
Под Росой KDE я конечно имею ввиду последнюю 4 версию. Поэтому и подчеркиваю что говорю о Росе Plazma сравнивая ее с KDE 4. То есть KDE 5 я называю Plazma а KDE 4 просто KDE. Ну Роса Fresh это само собой. Иначе бы я подчеркнул
euspectre
Проблемы на kde4
Сообщение euspectre »
Ещё полезно было бы собрать информацию о системе с помощью hw-probe ('sudo -E hw-probe -all -upload', http://linux-hardware.org/index.php?view=howto) и указать в теме ссылку на страницу с этой информацией.
Это очень экономит время во многих случаях: сразу видно, какая именно система установлена, какие пакеты в системе стоят, что за железо и пр.
Гость 25
Проблемы на kde4
euspectre писал(а): 23 июн 2020, 22:58 Ещё полезно было бы собрать информацию о системе с помощью hw-probe ('sudo -E hw-probe -all -upload', http://linux-hardware.org/index.php?view=howto) и указать в теме ссылку на страницу с этой информацией.
https://linux-hardware.org/?probe=4463e47fe4
Гость 25
Проблемы на kde4
Проблема при установки через urpmi вроде решена! Но вот хочется чтобы видеоплееры отображали видео во все окно в нормальном качестве по умолчанию.
