Доброго времени суток! Нужна помощь.
При обращении к «Seagate Backup Plus Drive» произошла ошибка, ответ системы: The requested operation has failed: Error mounting /dev/sdf2 at /media/lester/Seagate Backup Plus Drive: Command-line `mount -t "ntfs" -o "uhelper=udisks2,nodev,nosuid,uid=500,gid=500" "/dev/sdf2" "/media/lester/Seagate Backup Plus Drive"' exited with non-zero exit status 13: $MFTMirr does not match $MFT (record 0). Failed to mount '/dev/sdf2': Ошибка ввода/вывода NTFS is either inconsistent, or there is a hardware fault, or it's a SoftRAID/FakeRAID hardware. In the first case run chkdsk /f on Windows then reboot into Windows twice. The usage of the /f parameter is very important! If the device is a SoftRAID/FakeRAID then first activate it and mount a different device under the /dev/mapper/ directory, (e.g. /dev/mapper/nvidia_eahaabcc1). Please see the 'dmraid' documentation for more details.
Проблема при подключении внешнего HDD.
lester7777
lester7777
sudo ntfsfix /dev/sdf2
Mounting volume... $MFTMirr does not match $MFT (record 0).
FAILED
Attempting to correct errors...
Processing $MFT and $MFTMirr...
Reading $MFT... OK
Reading $MFTMirr... OK
Comparing $MFTMirr to $MFT... FAILED
Correcting differences in $MFTMirr record 0...OK
Processing of $MFT and $MFTMirr completed successfully.
Setting required flags on partition... OK
Going to empty the journal ($LogFile)... OK
Checking the alternate boot sector... OK
NTFS volume version is 3.1.
NTFS partition /dev/sdf2 was processed successfully.
Благодарю за помощь.
FAILED
Reading $MFT... OK
