Yubico - Yubikey
MuggiGuggi
Operating system: Rosa 10 kde
Yubico - Yubikey
Сообщение MuggiGuggi »
Hi there, i am using a hardware crypto dongle from Yubico - unfortunately i am not able to get it up and running - here´s the link to the vendor files: https://www.yubico.com/support/knowledg ... downloads/ - thank you for you interest and patience with a newbe ;-) :beer:
Михайлов О. А.
Operating system: ROSA Fresh R8.1
Re: Yubico - Yubikey
Сообщение Михайлов О. А. »
I don't know much about Yubico's devices, but for about every dongle you should first install ccid and opensc (maybe lib64usb1 too) and then start and enable pcscd: sudo systemctl start pcscd; sudo systemctl enable pcscd. I guess there are some GUI for working with these devices, but you can also use pkcs11-tool --module <pkcs11_lib_for_dongle> (in some cases you can even use default lib which is /usr/lib64/opensc-pkcs11.so)
Вернуться в «Desktop»
