[RESOLVED] Network is down ...
monty
Operating system: Linux - Rosa linux, CentOS / Debian
Сообщение monty »
Hi,
I did install Rosa Linux R8 64bit MATE. Great distro. I have only one problem. After start system, I must disconnect and then connect wired network. It doesn't work automatic :-( And in throught working it writes me (sometimes) Network is down. It makes me on wired network in the PC and in the notebook too. WiFi on the notebook works great. And Wired network is good configured. Can you help me, please?
Screenshots in attachment.
You can answer me in russian ... I don't have russian keyboard installed, but I understan. Thank you.
Rene
lan_error.pdf
(189.11 КБ) 968 скачиваний
Последний раз редактировалось monty 16 янв 2017, 09:06, всего редактировалось 1 раз.
Re: Network is down ...
try
1) systemctl disable systemd-named.service
systemctl disable systemd-networkd.service
2) if you use pptp, set
[ppp]
mtu=1492
into you connection file
monty
Сообщение monty »
Thank you. I test it in my job on Monday. At home, I have it over WiFi and it works great.
Rene
monty
Сообщение monty »
Hi,
it works after reboot. I will wait a little time, if it will works without shuting down network ;-)
Thank you very much-
Rene
Вернуться в «Desktop»
