I have ROSA Fresh R7 installed in my laptop.
I tried to install composer as instructed in the magestead installation instructions with this command:
composer global require "richdynamix/magestead"
I am getting the following error:
The phar extension is missing.
Install it or recompile php without --disable-phar
can anyone help me out to resolve this? I searched a while to find a solution but in vain...
thanks
Phar extension is missing
prabhuchelladurai
Re: Phar extension is missing
Likely you need to install php-phar package. Please check if it helps.
