[РЕШЕНО] Clementine перестала работать
После обновления системы (с февраля не обновлял) перестала работать clementine. Запуск в консоли дает такой вывод:
clementine
16:48:44.630 INFO  main:334                         Clementine 1.3
16:48:44.790 DEBUG WorkerPool<HandlerType>:281      Starting worker 0x7f2fdfa1d8e0 "/usr/bin/clementine-tagreader" "/tmp/clementine_502678081"
16:48:44.791 DEBUG WorkerPool<HandlerType>:281      Starting worker 0x7f2fdfa1d8e0 "/usr/bin/clementine-tagreader" "/tmp/clementine_1193972795"
16:48:44.792 DEBUG WorkerPool<HandlerType>:281      Starting worker 0x7f2fdfa1d8e0 "/usr/bin/clementine-tagreader" "/tmp/clementine_532436628"
16:48:44.792 WARN  Database:274                     Couldn't register FTS3 tokenizer
16:48:44.793 DEBUG WorkerPool<HandlerType>:281      Starting worker 0x7f2fdfa1d8e0 "/usr/bin/clementine-tagreader" "/tmp/clementine_2130005023"
16:48:44.798 DEBUG Database:444                     Applying database schema update 47 from ":/schema/schema-47.sql"
16:48:44.800 ERROR Database:573                     db error:  QSqlError(1, "Невозможно получить строку", "unknown tokenizer: unicode")
16:48:44.800 ERROR Database:574                     faulty query:  "CREATE VIRTUAL TABLE seafile_songs_fts USING fts3 (
  ftstitle, ftsalbum, ftsartist, ftsalbumartist, ftscomposer, ftsperformer, ftsgrouping, ftsgenre, ftscomment,
  tokenize=unicode
16:48:44.800 ERROR Database:575                     bound values:  QMap()
16:48:44.801 ERROR unknown                          Unable to update music library database
16:48:44.807 INFO  main:48                          TagReader worker connecting to "/tmp/clementine_502678081"
16:48:44.807 INFO  main:48                          TagReader worker connecting to "/tmp/clementine_1193972795"
16:48:44.818 INFO  main:48                          TagReader worker connecting to "/tmp/clementine_532436628"
16:48:44.827 INFO  main:48                          TagReader worker connecting to "/tmp/clementine_2130005023"
После того как переименовал папки кленентины в хомяке в папках .cache и .config вывод стал таким:
clementine
16:59:02.562 INFO  main:334                         Clementine 1.3
16:59:02.725 DEBUG WorkerPool<HandlerType>:281      Starting worker 0x7f75bfffe8e0 "/usr/bin/clementine-tagreader" "/tmp/clementine_520912641"
16:59:02.725 WARN  Database:274                     Couldn't register FTS3 tokenizer
16:59:02.727 DEBUG WorkerPool<HandlerType>:281      Starting worker 0x7f75bfffe8e0 "/usr/bin/clementine-tagreader" "/tmp/clementine_1171302779"
16:59:02.730 DEBUG WorkerPool<HandlerType>:281      Starting worker 0x7f75bfffe8e0 "/usr/bin/clementine-tagreader" "/tmp/clementine_491154388"
16:59:02.732 DEBUG WorkerPool<HandlerType>:281      Starting worker 0x7f75bfffe8e0 "/usr/bin/clementine-tagreader" "/tmp/clementine_2081386847"
16:59:02.733 INFO  Database:282                     Creating initial database schema
16:59:02.734 DEBUG Database:444                     Applying database schema update 0 from ":/schema/schema.sql"
16:59:02.742 INFO  main:48                          TagReader worker connecting to "/tmp/clementine_520912641"
16:59:02.742 DEBUG WorkerPool<HandlerType>:301      Worker 0x7f75b8014cd0 connected to "/tmp/clementine_520912641"
16:59:02.747 INFO  main:48                          TagReader worker connecting to "/tmp/clementine_1171302779"
16:59:02.748 DEBUG WorkerPool<HandlerType>:301      Worker 0x7f75b80162f0 connected to "/tmp/clementine_1171302779"
16:59:02.752 INFO  main:48                          TagReader worker connecting to "/tmp/clementine_491154388"
16:59:02.752 INFO  main:48                          TagReader worker connecting to "/tmp/clementine_2081386847"
16:59:02.752 DEBUG WorkerPool<HandlerType>:301      Worker 0x7f75b8014b70 connected to "/tmp/clementine_491154388"
16:59:02.752 DEBUG WorkerPool<HandlerType>:301      Worker 0x7f75b8018d50 connected to "/tmp/clementine_2081386847"
16:59:02.904 DEBUG Database:444                     Applying database schema update 1 from ":/schema/schema-1.sql"
16:59:02.984 DEBUG Database:444                     Applying database schema update 2 from ":/schema/schema-2.sql"
16:59:03.061 DEBUG Database:444                     Applying database schema update 3 from ":/schema/schema-3.sql"
16:59:03.138 DEBUG Database:444                     Applying database schema update 4 from ":/schema/schema-4.sql"
16:59:03.214 DEBUG Database:444                     Applying database schema update 5 from ":/schema/schema-5.sql"
16:59:03.333 DEBUG Database:444                     Applying database schema update 6 from ":/schema/schema-6.sql"
16:59:03.454 DEBUG Database:444                     Applying database schema update 7 from ":/schema/schema-7.sql"
16:59:03.608 DEBUG Database:444                     Applying database schema update 8 from ":/schema/schema-8.sql"
16:59:03.730 DEBUG Database:444                     Applying database schema update 9 from ":/schema/schema-9.sql"
16:59:03.851 DEBUG Database:444                     Applying database schema update 10 from ":/schema/schema-10.sql"
16:59:03.936 DEBUG Database:444                     Applying database schema update 11 from ":/schema/schema-11.sql"
16:59:04.013 DEBUG Database:444                     Applying database schema update 12 from ":/schema/schema-12.sql"
16:59:04.093 DEBUG Database:444                     Applying database schema update 13 from ":/schema/schema-13.sql"
16:59:04.094 ERROR Database:573                     db error:  QSqlError(1, "Невозможно получить строку", "unknown tokenizer: unicode")
16:59:04.094 ERROR Database:574                     faulty query:  "CREATE VIRTUAL TABLE songs_fts USING fts3(
  ftstitle, ftsalbum, ftsartist, ftsalbumartist, ftscomposer, ftsgenre, ftscomment,
  tokenize=unicode
16:59:04.094 ERROR Database:575                     bound values:  QMap()
16:59:04.094 ERROR unknown                          Unable to update music library database
Переустановка ничего не изменила. Как вернуть работоспособность клементине?
Последний раз редактировалось va9(2) 30 май 2016, 14:52, всего редактировалось 1 раз.
Re: Clementine перестала работать
Вот-вот прилетит в обновлениях. Там клементина не умела работать с новым SQLite при первом запуске. Исправили сразу, но в связи с задержкой публикаций из-за массовой пересборки обновление еще не долетело до репозиториев.
Прилетело обновление. Теперь клементина работает. Премного благодарен.
