touchpad not working
tundra
Operating system: LINUX
Сообщение tundra »
i just install rosa kde like it very much. everything worked for a while but the touchpad stopped working. I need to use a usb mouse to navigate. i am a newbie to linux .is there is a way to fix this issue?
thanks a bunch
Re: touchpad not working
tundra писал(а):i just install rosa kde like it very much. everything worked for a while but the touchpad stopped working. I need to use a usb mouse to navigate. i am a newbie to linux .is there is a way to fix this issue?
thanks a bunch
Try install new version of kernel
tundra
Сообщение tundra »
how to do that ?
Thanks
Delles
Сообщение Delles »
Log in as root (type su in Konsole, then the root password) and enter these two commands:
for i586:
urpmi.addmedia kernel4.4 http://abf-downloads.rosalinux.ru/kernels_stable_personal/repository/rosa2014.1/i586/kernel_4_4/release/ --update
for x64:
urpmi.addmedia kernel4.4 http://abf-downloads.rosalinux.ru/kernels_stable_personal/repository/rosa2014.1/x86_64/kernel_4_4/release/ --update
then:
urpmi kernel-nrj-desktop-4.4-latest
Reboot.
(To switch back to the previous kernel, just select it in the menu of grub — the menu which appears first when booting).
Linus Torvalds
tundra
Сообщение tundra »
Thanks for the help. i tried the new kernel but the same result, still no working touchpad :(
tundra
Сообщение tundra »
I re-install rosa worked for while .done the updates then later i close the lid and woke the system later and the samething happen the touchpad did not work no more
tundra
Сообщение tundra »
I did try the best I can but no luck So i will go back to mint to bad !
Вернуться в «Desktop»
