Amavis блокирует почту
ROSA Enterprise Linux Server -- вопросы и проблемы
Правила форума
Yamah
Нетбук: Rosa Fresh R10
Сообщение Yamah »
Почему-то вся почта перестала доходить до пользователей локального почтового сервера
Фильтры я не менял.
Apr 12 15:37:00 pdc postfix/anvil[12243]: statistics: max connection rate 1/60s for (smtp:192.168.0.52) at Apr 12 15:33:40
Apr 12 15:37:00 pdc postfix/anvil[12243]: statistics: max connection count 1 for (smtp:192.168.0.52) at Apr 12 15:33:40
Apr 12 15:37:00 pdc postfix/anvil[12243]: statistics: max cache size 1 at Apr 12 15:33:40
Apr 12 15:37:16 pdc postfix/smtpd[12316]: connect from unknown[192.168.0.52]
Apr 12 15:37:16 pdc postfix/smtpd[12316]: setting up TLS connection from unknown[192.168.0.52]
Apr 12 15:37:16 pdc postfix/smtpd[12316]: Anonymous TLS connection established from unknown[192.168.0.52]: TLSv1 with cipher DHE-RSA-AES128-SHA (128/128 bits)
Apr 12 15:37:16 pdc postfix/smtpd[12316]: 83BE91E0025: client=unknown[192.168.0.52], sasl_method=PLAIN, sasl_username=user_1@mydomen.ru
Apr 12 15:37:16 pdc postfix/cleanup[12319]: 83BE91E0025: message-id=<570CC1D7.7070703@mydomen.ru>
Apr 12 15:37:16 pdc postfix/qmgr[25953]: 83BE91E0025: from=<user_1@mydomen.ru>, size=734, nrcpt=1 (queue active)
Apr 12 15:37:16 pdc amavis[11072]: (11072-02) loaded policy bank "MYNETS"
Apr 12 15:37:16 pdc postfix/smtpd[12316]: disconnect from unknown[192.168.0.52]
Apr 12 15:37:16 pdc amavis[11072]: (11072-02) ESMTP::10025 /var/amavis/tmp/amavis-20160412T150135-11072: <user_1@mydomen.ru> -> <user_2@mydomen.ru> SIZE=734 BODY=8BITMIME Received: from mail.sibgipro.ru ([127.0.0.1]) by localhost (mail.mydomen.ru [127.0.0.1]) (amavisd-new, port 10025) with ESMTP for <user_2@mydomen.ru>; Tue, 12 Apr 2016 16:37:16 +0700 (KRAT)
Apr 12 15:37:16 pdc amavis[11072]: (11072-02) Checking: 8FAX5sByuIMe MYNETS [192.168.0.52] <user_1@mydomen.ru> -> <user_2@mydomen.ru>
Apr 12 15:37:17 pdc amavis[11072]: (11072-02) dkim: candidate originators: 2822.From:<user_1@mydomen.ru>, 2821.mail_from:<user_1@mydomen.ru>
Apr 12 15:37:17 pdc amavis[11072]: (11072-02) dkim: not signing, no applicable private key for domains sibgipro.ru, s=, From: <user_1@mydomen.ru>
Apr 12 15:37:17 pdc postfix/smtpd[12322]: connect from pdc.mydomen.ru[127.0.0.1]
Apr 12 15:37:17 pdc postfix/smtpd[12322]: 266A21E0056: client=pdc.mydomen.ru[127.0.0.1]
Apr 12 15:37:17 pdc postfix/cleanup[12319]: 266A21E0056: message-id=<570CC1D7.7070703@mydomen.ru>
Apr 12 15:37:17 pdc postfix/smtpd[12322]: disconnect from pdc.mydomen.ru[127.0.0.1]
Apr 12 15:37:17 pdc postfix/qmgr[25953]: 266A21E0056: from=<user_1@mydomen.ru>, size=1193, nrcpt=1 (queue active)
Apr 12 15:37:17 pdc amavis[11072]: (11072-02) FWD via SMTP: <user_1@mydomen.ru> -> <user_2@mydomen.ru>,BODY=8BITMIME 250 2.0.0 Ok, id=11072-02, from MTA([127.0.0.1]:10026): 250 2.0.0 Ok: queued as 266A21E0056
Apr 12 15:37:17 pdc amavis[11072]: (11072-02) Passed CLEAN, MYNETS LOCAL [192.168.0.52] [192.168.0.52] <user_1@mydomen.ru> -> <user_2@mydomen.ru>, Message-ID: <570CC1D7.7070703@mydomen.ru>, mail_id: 8FAX5sByuIMe, Hits: -1, size: 734, queued_as: 266A21E0056, 571 ms
Apr 12 15:37:17 pdc amavis[11072]: (11072-02) TIMING-SA total 466 ms - parse: 2 (0.4%), extract_message_metadata: 3 (0.7%), get_uri_detail_list: 0.47 (0.1%), tests_pri_-1000: 5 (1.1%), tests_pri_-950: 1.81 (0.4%), tests_pri_-900: 1.43 (0.3%), tests_pri_-400: 1.11 (0.2%), tests_pri_0: 413 (88.7%), check_dkim_adsp: 4 (0.9%), check_spf: 0.40 (0.1%), check_razor2: 361 (77.5%), check_pyzor: 0.05 (0.0%), tests_pri_500: 5 (1.0%), learn: 19 (4.1%), get_report: 1.12 (0.2%)
Apr 12 15:37:17 pdc postfix/smtp[12320]: 83BE91E0025: to=<user_2@mydomen.ru>, relay=127.0.0.1[127.0.0.1]:10025, delay=0.66, delays=0.08/0.01/0.01/0.57, dsn=2.0.0, status=sent (250 2.0.0 Ok, id=11072-02, from MTA([127.0.0.1]:10026): 250 2.0.0 Ok: queued as 266A21E0056)
Apr 12 15:37:17 pdc postfix/qmgr[25953]: 83BE91E0025: removed
Apr 12 15:37:17 pdc amavis[11072]: (11072-02) TIMING [total 577 ms] - SMTP greeting: 4 (1%)1, SMTP EHLO: 1 (0%)1, SMTP pre-MAIL: 1 (0%)1, lookup_ldap: 23 (4%)5, SMTP pre-DATA-flush: 1 (0%)5, SMTP DATA: 16 (3%)8, check_init: 1 (0%)8, digest_hdr: 2 (0%)8, digest_body_dkim: 0 (0%)8, gen_mail_id: 1 (0%)8, check_header: 2 (0%)9, AV-scan-1: 5 (1%)10, spam-wb-list: 1 (0%)10, SA parse: 3 (1%)10, SA check: 461 (80%)90, update_cache: 5 (1%)91, decide_mail_destiny: 1 (0%)91, fwd-connect: 21 (4%)95, fwd-mail-pip: 4 (1%)96, fwd-rcpt-pip: 0 (0%)96, fwd-data-chkpnt: 0 (0%)96, write-header: 1 (0%)96, fwd-data-contents: 0 (0%)96, fwd-end-chkpnt: 10 (2%)98, prepare-dsn: 1 (0%)98, main_log_entry: 8 (1%)99, update_snmp: 3 (1%)100, SMTP pre-response: 0 (0%)100, SMTP response: 0 (0%)100, unlink-1-files: 0 (0%)100, rundown: 0 (0%)100
Apr 12 15:37:17 pdc postfix/smtp[12323]: 266A21E0056: to=<user_2@mydomen.ru>, relay=none, delay=0.02, delays=0.01/0.01/0/0, dsn=5.4.6, status=bounced (mail for sibgipro.ru loops back to myself)
Apr 12 15:37:17 pdc postfix/cleanup[12319]: 3170E1E0077: message-id=<20160412093717.3170E1E0077@mail.mydomen.ru>
Apr 12 15:37:17 pdc postfix/bounce[12324]: 266A21E0056: sender non-delivery notification: 3170E1E0077
Apr 12 15:37:17 pdc postfix/qmgr[25953]: 3170E1E0077: from=<>, size=3086, nrcpt=1 (queue active)
Apr 12 15:37:17 pdc postfix/qmgr[25953]: 266A21E0056: removed
Apr 12 15:37:17 pdc postfix/smtp[12323]: 3170E1E0077: to=<user_1@mydomen.ru>, relay=none, delay=0.02, delays=0.02/0/0/0, dsn=5.4.6, status=bounced (mail for mydomen.ru loops back to myself)
Apr 12 15:37:17 pdc postfix/qmgr[25953]: 3170E1E0077: removed
RELS 6.5
sef_1976
Operating system: RELS 6.6
Re: Amavis блокирует почту
Сообщение sef_1976 »
mydestination и mynetworks проверь
у тебя логическое кольцо
Вернуться в «Сервер»
