# A fatal error has been detected by the Java Runtime Environment:
#  SIGSEGV (0xb) at pc=0x00007f8f6268a0ad, pid=11017, tid=140253173839616
# JRE version: OpenJDK Runtime Environment (8.0_60-b16) (build 1.8.0_60-b16)
# Java VM: OpenJDK 64-Bit Server VM (25.60-b16 mixed mode linux-amd64 compressed oops)
# Problematic frame:
# C  [libX11.so.6+0x380ad]  XQueryExtension+0x1d
# Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
# If you would like to submit a bug report, please visit:
http://bugreport.java.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
---------------  T H R E A D  ---------------
Current thread (0x00007f8f18003800):  JavaThread "J3D-Renderer-1" [_thread_in_native, id=11101, stack(0x00007f8f3c8af000,0x00007f8f3c9b0000)]
siginfo: si_signo: 11 (SIGSEGV), si_code: 128 (SI_KERNEL), si_addr: 0x0000000000000000
Registers:
RAX=0x00007f8f0c286c50, RBX=0x0c10000000010006, RCX=0x00007f8f3c9ae448, RDX=0x00007f8f3c9ae444
RSP=0x00007f8f3c9ae3e0, RBP=0x00007f8f3e901f78, RSI=0x00007f8f3e901f78, RDI=0x0c10000000010006
R8 =0x00007f8f3c9ae44c, R9 =0x00007f8f0c000208, R10=0x0000000000000081, R11=0x0000000000000206
R12=0x00007f8f3c9ae44c, R13=0x00007f8f3c9ae448, R14=0x00007f8f3c9ae444, R15=0x00007f8f3eb2b600
RIP=0x00007f8f6268a0ad, EFLAGS=0x0000000000010202, CSGSFS=0x0000000000000033, ERR=0x0000000000000000
  TRAPNO=0x000000000000000d
Top of Stack: (sp=0x00007f8f3c9ae3e0)
0x00007f8f3c9ae3e0:   00007f8f0c28d490 00007f8f0c383840
0x00007f8f3c9ae3f0:   0000000000000002 00007f8f139cdce7
0x00007f8f3c9ae400:   0000000000000027 0c10000000010006
0x00007f8f3c9ae410:   0000000100000002 00007f8f3e901f78
0x00007f8f3c9ae420:   0000000000000000 00007f8f62991510
0x00007f8f3c9ae430:   00007f8f3eb2b600 00007f8f6267e3d2
0x00007f8f3c9ae440:   00007f8f0c28cc30 0000000000000000
0x00007f8f3c9ae450:   00007f8f0c286c50 0000000100000002
0x00007f8f3c9ae460:   0c10000000010006 00007f8f3e8af2d1
0x00007f8f3c9ae470:   00007f8f0c2dec50 00007f8f0c28cc30
0x00007f8f3c9ae480:   00007f8f0c28cc30 00007f8f0c286c50
0x00007f8f3c9ae490:   0000000100000002 00007f8f0c334d90
0x00007f8f3c9ae4a0:   0000000000000000 00007f8f0c298f00
0x00007f8f3c9ae4b0:   00007f8f3eb2b600 00007f8f3e8d08f6
0x00007f8f3c9ae4c0:   0000000000000000 0000000000000000
0x00007f8f3c9ae4d0:   00007f8f0c334d90 0000000000000000
0x00007f8f3c9ae4e0:   00007f8f0c298f00 00007f8f13627135
0x00007f8f3c9ae4f0:   0000000000000000 00007f8f133feae0
0x00007f8f3c9ae500:   00007f8f94a94900 00007f8f9012c1d0
0x00007f8f3c9ae510:   00007f8f18003800 00007f8f18003800
0x00007f8f3c9ae520:   00007f8f3c9ae5a0 0000000000000000
0x00007f8f3c9ae530:   0000000000000000 0000000000000000
0x00007f8f3c9ae540:   00007f8f0c000cb0 00007f8f0c298f60
0x00007f8f3c9ae550:   00007f8f3eb2b680 00007f8f1355e32b
0x00007f8f3c9ae560:   00007f8f3c9ae5d0 0000003000000018
0x00007f8f3c9ae570:   00007f8f13db93c0 00007f8f0c377640
0x00007f8f3c9ae580:   000000000180007e 00007f8f13626f6f
0x00007f8f3c9ae590:   0000000000000000 00007f8f0c299100
0x00007f8f3c9ae5a0:   000000000180007e 00007f8f13626a16
0x00007f8f3c9ae5b0:   00007f8f0c15a880 000000000180007e
0x00007f8f3c9ae5c0:   000000000180007e 00007f8f3e8ae12d
0x00007f8f3c9ae5d0:   00007f8f3c9ae6c0 00007f8f3c9ae5e0
Instructions: (pc=0x00007f8f6268a0ad)
0x00007f8f6268a08d:   00 00 90 41 57 41 56 49 89 d6 41 55 41 54 49 89
0x00007f8f6268a09d:   cd 55 53 48 89 f5 48 89 fb 4d 89 c4 48 83 ec 28
0x00007f8f6268a0ad:   48 8b 87 68 09 00 00 48 85 c0 74 02 ff 10 ba 08
0x00007f8f6268a0bd:   00 00 00 be 62 00 00 00 48 89 df e8 c3 4c fe ff
Register to memory mapping:
RAX=0x00007f8f0c286c50 is an unknown value
RBX=0x0c10000000010006 is an unknown value
RCX=0x00007f8f3c9ae448 is pointing into the stack for thread: 0x00007f8f18003800
RDX=0x00007f8f3c9ae444 is pointing into the stack for thread: 0x00007f8f18003800
RSP=0x00007f8f3c9ae3e0 is pointing into the stack for thread: 0x00007f8f18003800
RBP=0x00007f8f3e901f78: <offset 0x6ff78> in /usr/lib64/libGL.so.1 at 0x00007f8f3e892000
RSI=0x00007f8f3e901f78: <offset 0x6ff78> in /usr/lib64/libGL.so.1 at 0x00007f8f3e892000
RDI=0x0c10000000010006 is an unknown value
R8 =0x00007f8f3c9ae44c is pointing into the stack for thread: 0x00007f8f18003800
R9 =0x00007f8f0c000208 is an unknown value
R10=0x0000000000000081 is an unknown value
R11=0x0000000000000206 is an unknown value
R12=0x00007f8f3c9ae44c is pointing into the stack for thread: 0x00007f8f18003800
R13=0x00007f8f3c9ae448 is pointing into the stack for thread: 0x00007f8f18003800
R14=0x00007f8f3c9ae444 is pointing into the stack for thread: 0x00007f8f18003800
R15=0x00007f8f3eb2b600: <offset 0x299600> in /usr/lib64/libGL.so.1 at 0x00007f8f3e892000
Stack: [0x00007f8f3c8af000,0x00007f8f3c9b0000],  sp=0x00007f8f3c9ae3e0,  free space=1020k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j  javax.media.j3d.NativePipeline.useCtx(JJJ)Z+0
j  javax.media.j3d.NativePipeline.useCtx(Ljavax/media/j3d/Context;JLjavax/media/j3d/Drawable;)Z+43
j  javax.media.j3d.Canvas3D.useCtx(Ljavax/media/j3d/Context;JLjavax/media/j3d/Drawable;)Z+6
j  javax.media.j3d.Canvas3D.makeCtxCurrent(Ljavax/media/j3d/Context;JLjavax/media/j3d/Drawable;)V+51
j  javax.media.j3d.Canvas3D.makeCtxCurrent()V+16
j  javax.media.j3d.Renderer.doWork(J)V+4036
j  javax.media.j3d.J3dThread.run()V+19
v  ~StubRoutines::call_stub
---------------  P R O C E S S  ---------------
Java Threads: ( => current thread )
  0x00007f8f18022800 JavaThread "J3D-InputDeviceScheduler-2" [_thread_blocked, id=11123, stack(0x00007f8f09441000,0x00007f8f09542000)]
  0x00007f8f18021000 JavaThread "J3D-SoundSchedulerUpdateThread-2" [_thread_blocked, id=11122, stack(0x00007f8f096e6000,0x00007f8f097e7000)]
  0x00007f8f1801f000 JavaThread "J3D-RenderStructureUpdateThread-2" [_thread_blocked, id=11121, stack(0x00007f8f097e7000,0x00007f8f098e8000)]
  0x00007f8f1801d800 JavaThread "J3D-BehaviorScheduler-2" [_thread_blocked, id=11120, stack(0x00007f8f098e8000,0x00007f8f099e9000)]
  0x00007f8f1801b800 JavaThread "J3D-TransformStructureUpdateThread-2" [_thread_blocked, id=11119, stack(0x00007f8f099e9000,0x00007f8f09aea000)]
  0x00007f8f1801a800 JavaThread "J3D-RenderingEnvironmentStructureUpdateThread-2" [_thread_blocked, id=11118, stack(0x00007f8f09aea000,0x00007f8f09beb000)]
  0x00007f8f18018000 JavaThread "J3D-SoundStructureUpdateThread-2" [_thread_blocked, id=11117, stack(0x00007f8f09beb000,0x00007f8f09cec000)]
  0x00007f8f18016000 JavaThread "J3D-GeometryStructureUpdateThread-2" [_thread_blocked, id=11116, stack(0x00007f8f09cec000,0x00007f8f09ded000)]
  0x00007f8f18014800 JavaThread "J3D-BehaviorStructureUpdateThread-2" [_thread_blocked, id=11115, stack(0x00007f8f0a09f000,0x00007f8f0a1a0000)]
  0x00007f8f3020d000 JavaThread "TimerQueue" daemon [_thread_blocked, id=11114, stack(0x00007f8f0a1a0000,0x00007f8f0a2a1000)]
  0x00007f8f18013000 JavaThread "J3D-InputDeviceScheduler-1" [_thread_blocked, id=11113, stack(0x00007f8f0a4f5000,0x00007f8f0a5f6000)]
  0x00007f8f18011000 JavaThread "J3D-SoundSchedulerUpdateThread-1" [_thread_blocked, id=11112, stack(0x00007f8f0a5f6000,0x00007f8f0a6f7000)]
  0x00007f8f1800f800 JavaThread "J3D-RenderStructureUpdateThread-1" [_thread_blocked, id=11111, stack(0x00007f8f0a6f7000,0x00007f8f0a7f8000)]
  0x00007f8f1800e000 JavaThread "J3D-BehaviorScheduler-1" [_thread_blocked, id=11110, stack(0x00007f8f0a7f8000,0x00007f8f0a8f9000)]
  0x00007f8f18007000 JavaThread "J3D-TransformStructureUpdateThread-1" [_thread_blocked, id=11109, stack(0x00007f8f0a8f9000,0x00007f8f0a9fa000)]
  0x00007f8f18005800 JavaThread "J3D-RenderingEnvironmentStructureUpdateThread-1" [_thread_blocked, id=11108, stack(0x00007f8f0a9fa000,0x00007f8f0aafb000)]
  0x00007f8f1800a800 JavaThread "J3D-SoundStructureUpdateThread-1" [_thread_blocked, id=11107, stack(0x00007f8f0aafb000,0x00007f8f0abfc000)]
  0x00007f8f1800a000 JavaThread "J3D-GeometryStructureUpdateThread-1" [_thread_blocked, id=11106, stack(0x00007f8f10005000,0x00007f8f10106000)]
  0x00007f8f18008800 JavaThread "J3D-BehaviorStructureUpdateThread-1" [_thread_blocked, id=11105, stack(0x00007f8f3f252000,0x00007f8f3f353000)]
  0x00007f8f30119000 JavaThread "Image Fetcher 0" daemon [_thread_blocked, id=11104, stack(0x00007f8f1024f000,0x00007f8f10350000)]
  0x00007f8f90009000 JavaThread "DestroyJavaVM" [_thread_blocked, id=11075, stack(0x00007f8f98f0b000,0x00007f8f9900c000)]
  0x00007f8f9045e800 JavaThread "autoSaveTimer" daemon [_thread_blocked, id=11103, stack(0x00007f8f10350000,0x00007f8f10451000)]
=>0x00007f8f18003800 JavaThread "J3D-Renderer-1" [_thread_in_native, id=11101, stack(0x00007f8f3c8af000,0x00007f8f3c9b0000)]
  0x00007f8f90428000 JavaThread "J3D-MasterControl-1" [_thread_blocked, id=11100, stack(0x00007f8f3c9b0000,0x00007f8f3cab1000)]
  0x00007f8f90426800 JavaThread "J3D-NotificationThread" [_thread_blocked, id=11099, stack(0x00007f8f3cab1000,0x00007f8f3cbb2000)]
  0x00007f8f9042a800 JavaThread "J3D-TimerThread" [_thread_blocked, id=11098, stack(0x00007f8f3cbb2000,0x00007f8f3ccb3000)]
  0x00007f8f90401000 JavaThread "J3D-RenderingAttributesStructureUpdateThread" [_thread_blocked, id=11097, stack(0x00007f8f3ccb3000,0x00007f8f3cdb4000)]
  0x00007f8f9039a000 JavaThread "pool-2-thread-1" [_thread_in_native, id=11095, stack(0x00007f8f3ef51000,0x00007f8f3f052000)]
  0x00007f8f9034d000 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=11093, stack(0x00007f8f3f353000,0x00007f8f3f454000)]
  0x00007f8f90344800 JavaThread "AWT-Shutdown" [_thread_blocked, id=11092, stack(0x00007f8f3f454000,0x00007f8f3f555000)]
  0x00007f8f9032b800 JavaThread "AWT-XAWT" daemon [_thread_in_native, id=11091, stack(0x00007f8f60058000,0x00007f8f60159000)]
  0x00007f8f902a2800 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=11090, stack(0x00007f8f614df000,0x00007f8f615e0000)]
  0x00007f8f901a6800 JavaThread "Timer-0" daemon [_thread_blocked, id=11089, stack(0x00007f8f630c8000,0x00007f8f631c9000)]
  0x00007f8f900c8800 JavaThread "Service Thread" daemon [_thread_blocked, id=11087, stack(0x00007f8f632ca000,0x00007f8f633cb000)]
  0x00007f8f900bb800 JavaThread "C1 CompilerThread2" daemon [_thread_blocked, id=11086, stack(0x00007f8f633cb000,0x00007f8f634cc000)]
  0x00007f8f900b9800 JavaThread "C2 CompilerThread1" daemon [_thread_blocked, id=11085, stack(0x00007f8f634cc000,0x00007f8f635cd000)]
  0x00007f8f900b7000 JavaThread "C2 CompilerThread0" daemon [_thread_blocked, id=11084, stack(0x00007f8f635cd000,0x00007f8f636ce000)]
  0x00007f8f900b5800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=11083, stack(0x00007f8f7807f000,0x00007f8f78180000)]
  0x00007f8f9007d800 JavaThread "Finalizer" daemon [_thread_blocked, id=11082, stack(0x00007f8f800f1000,0x00007f8f801f2000)]
  0x00007f8f9007b800 JavaThread "Reference Handler" daemon [_thread_blocked, id=11081, stack(0x00007f8f801f2000,0x00007f8f802f3000)]
Other Threads:
  0x00007f8f90076800 VMThread [stack: 0x00007f8f802f3000,0x00007f8f803f4000] [id=11080]
  0x00007f8f900cb000 WatcherThread [stack: 0x00007f8f631c9000,0x00007f8f632ca000] [id=11088]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap:
 PSYoungGen      total 37888K, used 2349K [0x00000000d6580000, 0x00000000d8f80000, 0x0000000100000000)
  eden space 32768K, 7% used [0x00000000d6580000,0x00000000d67cb578,0x00000000d8580000)
  from space 5120K, 0% used [0x00000000d8a80000,0x00000000d8a80000,0x00000000d8f80000)
  to   space 5120K, 0% used [0x00000000d8580000,0x00000000d8580000,0x00000000d8a80000)
 ParOldGen       total 86016K, used 10796K [0x0000000083000000, 0x0000000088400000, 0x00000000d6580000)
  object space 86016K, 12% used [0x0000000083000000,0x0000000083a8b220,0x0000000088400000)
 Metaspace       used 28159K, capacity 28472K, committed 28672K, reserved 1075200K
  class space    used 3432K, capacity 3559K, committed 3584K, reserved 1048576K
Card table byte_map: [0x00007f8f958cb000,0x00007f8f95cb4000] byte_map_base: 0x00007f8f954b3000
Marking Bits: (ParMarkBitMap*) 0x00007f8f981eedc0
 Begin Bits: [0x00007f8f78180000, 0x00007f8f7a0c0000)
 End Bits:   [0x00007f8f7a0c0000, 0x00007f8f7c000000)
Polling page: 0x00007f8f99036000
CodeCache: size=245760Kb used=7940Kb max_used=7940Kb free=237819Kb
 bounds [0x00007f8f81000000, 0x00007f8f817d0000, 0x00007f8f90000000]
 total_blobs=3247 nmethods=2356 adapters=804
 compilation: enabled
Compilation events (10 events):
Event: 2,771 Thread 0x00007f8f900bb800 2351       1       java.awt.image.SampleModel::getWidth (5 bytes)
Event: 2,771 Thread 0x00007f8f900bb800 nmethod 2351 0x00007f8f817bca90 code [0x00007f8f817bcbe0, 0x00007f8f817bccf0]
Event: 2,771 Thread 0x00007f8f900bb800 2352       1       java.awt.image.SampleModel::getHeight (5 bytes)
Event: 2,771 Thread 0x00007f8f900bb800 nmethod 2352 0x00007f8f817bc7d0 code [0x00007f8f817bc920, 0x00007f8f817bca30]
Event: 2,774 Thread 0x00007f8f900bb800 2354       3       javax.media.j3d.Transform3D::setIdentity (135 bytes)
Event: 2,774 Thread 0x00007f8f900bb800 nmethod 2354 0x00007f8f817c3690 code [0x00007f8f817c3820, 0x00007f8f817c3c10]
Event: 2,786 Thread 0x00007f8f900bb800 2355  s    3       javax.media.j3d.UnorderList::toArray (99 bytes)
Event: 2,786 Thread 0x00007f8f900bb800 nmethod 2355 0x00007f8f817c3e50 code [0x00007f8f817c4000, 0x00007f8f817c4738]
Event: 2,786 Thread 0x00007f8f900bb800 2356  s!   3       javax.media.j3d.J3dThread::runMonitor (199 bytes)
Event: 2,787 Thread 0x00007f8f900bb800 nmethod 2356 0x00007f8f817c48d0 code [0x00007f8f817c4b80, 0x00007f8f817c60a8]
GC Heap History (10 events):
Event: 0,662 GC heap before
{Heap before GC invocations=2 (full 0):
 PSYoungGen      total 37888K, used 9050K [0x00000000d6580000, 0x00000000d8f80000, 0x0000000100000000)
  eden space 32768K, 12% used [0x00000000d6580000,0x00000000d6959310,0x00000000d8580000)
  from space 5120K, 99% used [0x00000000d8580000,0x00000000d8a7d550,0x00000000d8a80000)
  to   space 5120K, 0% used [0x00000000d8a80000,0x00000000d8a80000,0x00000000d8f80000)
 ParOldGen       total 86016K, used 930K [0x0000000083000000, 0x0000000088400000, 0x00000000d6580000)
  object space 86016K, 1% used [0x0000000083000000,0x00000000830e8a98,0x0000000088400000)
 Metaspace       used 17149K, capacity 17302K, committed 17536K, reserved 1064960K
  class space    used 1970K, capacity 2062K, committed 2176K, reserved 1048576K
Event: 0,665 GC heap after
Heap after GC invocations=2 (full 0):
 PSYoungGen      total 37888K, used 5101K [0x00000000d6580000, 0x00000000d8f80000, 0x0000000100000000)
  eden space 32768K, 0% used [0x00000000d6580000,0x00000000d6580000,0x00000000d8580000)
  from space 5120K, 99% used [0x00000000d8a80000,0x00000000d8f7b708,0x00000000d8f80000)
 ParOldGen       total 86016K, used 938K [0x0000000083000000, 0x0000000088400000, 0x00000000d6580000)
  object space 86016K, 1% used [0x0000000083000000,0x00000000830eaa98,0x0000000088400000)
Event: 0,665 GC heap before
{Heap before GC invocations=3 (full 1):
Event: 0,681 GC heap after
Heap after GC invocations=3 (full 1):
 PSYoungGen      total 37888K, used 0K [0x00000000d6580000, 0x00000000d8f80000, 0x0000000100000000)
 ParOldGen       total 86016K, used 5007K [0x0000000083000000, 0x0000000088400000, 0x00000000d6580000)
  object space 86016K, 5% used [0x0000000083000000,0x00000000834e3c40,0x0000000088400000)
Event: 1,445 GC heap before
{Heap before GC invocations=4 (full 1):
 PSYoungGen      total 37888K, used 32529K [0x00000000d6580000, 0x00000000d8f80000, 0x0000000100000000)
  eden space 32768K, 99% used [0x00000000d6580000,0x00000000d85445e8,0x00000000d8580000)
 Metaspace       used 26216K, capacity 26438K, committed 26752K, reserved 1073152K
  class space    used 3249K, capacity 3330K, committed 3456K, reserved 1048576K
Event: 1,453 GC heap after
Heap after GC invocations=4 (full 1):
 PSYoungGen      total 37888K, used 5080K [0x00000000d6580000, 0x00000000d8f80000, 0x0000000100000000)
  from space 5120K, 99% used [0x00000000d8580000,0x00000000d8a76168,0x00000000d8a80000)
 ParOldGen       total 86016K, used 5015K [0x0000000083000000, 0x0000000088400000, 0x00000000d6580000)
  object space 86016K, 5% used [0x0000000083000000,0x00000000834e5c40,0x0000000088400000)
Event: 2,720 GC heap before
{Heap before GC invocations=5 (full 1):
 PSYoungGen      total 37888K, used 13999K [0x00000000d6580000, 0x00000000d8f80000, 0x0000000100000000)
  eden space 32768K, 27% used [0x00000000d6580000,0x00000000d6e35ce0,0x00000000d8580000)
 Metaspace       used 28078K, capacity 28408K, committed 28672K, reserved 1075200K
  class space    used 3424K, capacity 3559K, committed 3584K, reserved 1048576K
Event: 2,725 GC heap after
Heap after GC invocations=5 (full 1):
 PSYoungGen      total 37888K, used 5118K [0x00000000d6580000, 0x00000000d8f80000, 0x0000000100000000)
  from space 5120K, 99% used [0x00000000d8a80000,0x00000000d8f7fbb8,0x00000000d8f80000)
 ParOldGen       total 86016K, used 6259K [0x0000000083000000, 0x0000000088400000, 0x00000000d6580000)
  object space 86016K, 7% used [0x0000000083000000,0x000000008361cd20,0x0000000088400000)
Event: 2,725 GC heap before
{Heap before GC invocations=6 (full 2):
Event: 2,768 GC heap after
Heap after GC invocations=6 (full 2):
Deoptimization events (10 events):
Event: 2,575 Thread 0x00007f8f9034d000 Uncommon trap: reason=class_check action=maybe_recompile pc=0x00007f8f8149fc40 method=javax.swing.UIDefaults.getFromHashtable(Ljava/lang/Object;)Ljava/lang/Object; @ 92
Event: 2,583 Thread 0x00007f8f9034d000 Uncommon trap: reason=bimorphic action=maybe_recompile pc=0x00007f8f8156cd18 method=javax.swing.ArrayTable.get(Ljava/lang/Object;)Ljava/lang/Object; @ 44
Event: 2,587 Thread 0x00007f8f9034d000 Uncommon trap: reason=unstable_if action=reinterpret pc=0x00007f8f8112c4a0 method=java.lang.CharacterData.of(I)Ljava/lang/CharacterData; @ 4
Event: 2,666 Thread 0x00007f8f9034d000 Uncommon trap: reason=class_check action=maybe_recompile pc=0x00007f8f8149fc40 method=javax.swing.UIDefaults.getFromHashtable(Ljava/lang/Object;)Ljava/lang/Object; @ 92
Event: 2,668 Thread 0x00007f8f9034d000 Uncommon trap: reason=bimorphic action=maybe_recompile pc=0x00007f8f8156cd18 method=javax.swing.ArrayTable.get(Ljava/lang/Object;)Ljava/lang/Object; @ 44
Event: 2,695 Thread 0x00007f8f9034d000 Uncommon trap: reason=unstable_if action=reinterpret pc=0x00007f8f81795df4 method=sun.font.Type1Font.skip(Ljava/nio/ByteBuffer;)B @ 19
Event: 2,697 Thread 0x00007f8f9034d000 Uncommon trap: reason=unstable_if action=reinterpret pc=0x00007f8f81768510 method=java.nio.Buffer.nextGetIndex()I @ 8
Event: 2,702 Thread 0x00007f8f9034d000 Uncommon trap: reason=unloaded action=reinterpret pc=0x00007f8f817a8380 method=java.nio.Buffer.nextGetIndex()I @ 11
Event: 2,709 Thread 0x00007f8f9034d000 Uncommon trap: reason=class_check action=maybe_recompile pc=0x00007f8f8149fc40 method=javax.swing.UIDefaults.getFromHashtable(Ljava/lang/Object;)Ljava/lang/Object; @ 92
Event: 2,711 Thread 0x00007f8f9034d000 Uncommon trap: reason=bimorphic action=maybe_recompile pc=0x00007f8f8156cd18 method=javax.swing.ArrayTable.get(Ljava/lang/Object;)Ljava/lang/Object; @ 44
Internal exceptions (10 events):
Event: 0,198 Thread 0x00007f8f90009000 Exception <a 'java/io/FileNotFoundException'> (0x00000000d6a05db0) thrown at [/builddir/build/BUILD/java-1.8.0-openjdk/jdk8/hotspot/src/share/vm/prims/jni.cpp, line 709]
Event: 0,198 Thread 0x00007f8f90009000 Exception <a 'java/io/FileNotFoundException'> (0x00000000d6a068c0) thrown at [/builddir/build/BUILD/java-1.8.0-openjdk/jdk8/hotspot/src/share/vm/prims/jni.cpp, line 709]
Event: 0,228 Thread 0x00007f8f90009000 Exception <a 'java/lang/ClassNotFoundException': sun/dc/DuctusRenderingEngine> (0x00000000d6ac6108) thrown at [/builddir/build/BUILD/java-1.8.0-openjdk/jdk8/hotspot/src/share/vm/classfile/systemDictionary.cpp, line 210]
Event: 0,420 Thread 0x00007f8f90009000 Exception <a 'java/io/FileNotFoundException'> (0x00000000d723ea40) thrown at [/builddir/build/BUILD/java-1.8.0-openjdk/jdk8/hotspot/src/share/vm/prims/jni.cpp, line 709]
Event: 0,580 Thread 0x00007f8f9034d000 Implicit null exception at 0x00007f8f8125e0b5 to 0x00007f8f8125e411
Event: 0,581 Thread 0x00007f8f9034d000 Implicit null exception at 0x00007f8f8122e575 to 0x00007f8f8122e8c5
Event: 0,584 Thread 0x00007f8f9034d000 Implicit null exception at 0x00007f8f8130e0b5 to 0x00007f8f8130e2ed
Event: 0,584 Thread 0x00007f8f9034d000 Implicit null exception at 0x00007f8f8126036f to 0x00007f8f812603d9
Event: 1,065 Thread 0x00007f8f9034d000 Implicit null exception at 0x00007f8f81560d22 to 0x00007f8f81561c6d
Event: 1,395 Thread 0x00007f8f9034d000 Exception <a 'java/lang/UnsupportedOperationException': > (0x00000000d8222e48) thrown at [/builddir/build/BUILD/java-1.8.0-openjdk/jdk8/hotspot/src/share/vm/prims/jni.cpp, line 735]
Events (10 events):
Event: 2,772 loading class javax/media/j3d/ImageComponentRetained$ImageData done
Event: 2,774 Thread 0x00007f8f18014800 Thread added: 0x00007f8f18014800
Event: 2,776 Thread 0x00007f8f18016000 Thread added: 0x00007f8f18016000
Event: 2,777 Thread 0x00007f8f18018000 Thread added: 0x00007f8f18018000
Event: 2,778 Thread 0x00007f8f1801a800 Thread added: 0x00007f8f1801a800
Event: 2,779 Thread 0x00007f8f1801b800 Thread added: 0x00007f8f1801b800
Event: 2,780 Thread 0x00007f8f1801d800 Thread added: 0x00007f8f1801d800
Event: 2,781 Thread 0x00007f8f1801f000 Thread added: 0x00007f8f1801f000
Event: 2,783 Thread 0x00007f8f18021000 Thread added: 0x00007f8f18021000
Event: 2,784 Thread 0x00007f8f18022800 Thread added: 0x00007f8f18022800
Dynamic libraries:
00400000-00401000 r-xp 00000000 08:21 840601                             /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/bin/java-abrt
00600000-00601000 r--p 00000000 08:21 840601                             /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/bin/java-abrt
00601000-00602000 rw-p 00001000 08:21 840601                             /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/bin/java-abrt
01126000-01147000 rw-p 00000000 00:00 0                                  [heap]
83000000-88400000 rw-p 00000000 00:00 0
88400000-d6580000 ---p 00000000 00:00 0
d6580000-d8f80000 rw-p 00000000 00:00 0
d8f80000-100000000 ---p 00000000 00:00 0
100000000-100380000 rw-p 00000000 00:00 0
100380000-140000000 ---p 00000000 00:00 0
7f8ef4000000-7f8ef40af000 rw-p 00000000 00:00 0
7f8ef40af000-7f8ef8000000 ---p 00000000 00:00 0
7f8ef8000000-7f8ef8021000 rw-p 00000000 00:00 0
7f8ef8021000-7f8efc000000 ---p 00000000 00:00 0
7f8efc000000-7f8efc1a5000 rw-p 00000000 00:00 0
7f8efc1a5000-7f8f00000000 ---p 00000000 00:00 0
7f8f00000000-7f8f00095000 rw-p 00000000 00:00 0
7f8f00095000-7f8f04000000 ---p 00000000 00:00 0
7f8f04000000-7f8f04021000 rw-p 00000000 00:00 0
7f8f04021000-7f8f08000000 ---p 00000000 00:00 0
7f8f09441000-7f8f09444000 ---p 00000000 00:00 0
7f8f09444000-7f8f09542000 rw-p 00000000 00:00 0                          [stack:11123]
7f8f09542000-7f8f0954d000 r--s 00000000 08:21 413189                     /var/cache/fontconfig/20b58f14c9b581391d79ea335a81488a-le64.cache-4
7f8f0954d000-7f8f09551000 r--s 00000000 08:21 413208                     /var/cache/fontconfig/e6845615947634e89d319e77806483ba-le64.cache-4
7f8f09551000-7f8f0955c000 r--s 00000000 08:21 413205                     /var/cache/fontconfig/d4b6e1db2c46a3b281c413657cd2bc49-le64.cache-4
7f8f0955c000-7f8f09561000 r--s 00000000 08:21 413198                     /var/cache/fontconfig/87f5e051180a7a75f16eb6fe7dbd3749-le64.cache-4
7f8f09561000-7f8f0956c000 r--s 00000000 08:21 410089                     /var/cache/fontconfig/b79f3aaa7d385a141ab53ec885cc22a8-le64.cache-4
7f8f0956c000-7f8f09571000 r--s 00000000 08:21 413194                     /var/cache/fontconfig/5d999c1bbe32f61af008974facb58b71-le64.cache-4
7f8f09571000-7f8f0957c000 r--s 00000000 08:21 413196                     /var/cache/fontconfig/79aeb4e90a401e55ec91db207072ba77-le64.cache-4
7f8f0957c000-7f8f095a9000 r--s 00000000 08:21 410084                     /var/cache/fontconfig/0c8c704313a61b8a850327d2059470f7-le64.cache-4
7f8f095a9000-7f8f09610000 r--s 00000000 08:21 413163                     /var/cache/fontconfig/17090aa38d5c6f09fb8c5c354938f1d7-le64.cache-4
7f8f096e6000-7f8f096e9000 ---p 00000000 00:00 0
7f8f096e9000-7f8f097e7000 rw-p 00000000 00:00 0                          [stack:11122]
7f8f097e7000-7f8f097ea000 ---p 00000000 00:00 0
7f8f097ea000-7f8f098e8000 rw-p 00000000 00:00 0                          [stack:11121]
7f8f098e8000-7f8f098eb000 ---p 00000000 00:00 0
7f8f098eb000-7f8f099e9000 rw-p 00000000 00:00 0                          [stack:11120]
7f8f099e9000-7f8f099ec000 ---p 00000000 00:00 0
7f8f099ec000-7f8f09aea000 rw-p 00000000 00:00 0                          [stack:11119]
7f8f09aea000-7f8f09aed000 ---p 00000000 00:00 0
7f8f09aed000-7f8f09beb000 rw-p 00000000 00:00 0                          [stack:11118]
7f8f09beb000-7f8f09bee000 ---p 00000000 00:00 0
7f8f09bee000-7f8f09cec000 rw-p 00000000 00:00 0                          [stack:11117]
7f8f09cec000-7f8f09cef000 ---p 00000000 00:00 0
7f8f09cef000-7f8f09ded000 rw-p 00000000 00:00 0                          [stack:11116]
7f8f09ded000-7f8f09def000 r--s 00000000 08:21 413195                     /var/cache/fontconfig/69fb4bbe1b2fa860e172a32ebf28505c-le64.cache-4
7f8f09def000-7f8f09df4000 r--s 00000000 08:21 413204                     /var/cache/fontconfig/c776f34310d03ef601d6f862ef1a19b0-le64.cache-4
7f8f09df4000-7f8f09e0d000 r--s 00000000 08:21 413199                     /var/cache/fontconfig/8d4af663993b81a124ee82e610bb31f9-le64.cache-4
7f8f09e0d000-7f8f09e11000 r--s 00000000 08:21 410088                     /var/cache/fontconfig/f6b893a7224233d96cb72fd88691c0b4-le64.cache-4
7f8f09e11000-7f8f09e91000 rw-p 00000000 00:00 0
7f8f09e91000-7f8f0a011000 ---p 00000000 00:00 0
7f8f0a08f000-7f8f0a09f000 rw-s 12f5e6000 00:06 1552                      /dev/dri/card0
7f8f0a09f000-7f8f0a0a2000 ---p 00000000 00:00 0
7f8f0a0a2000-7f8f0a1a0000 rw-p 00000000 00:00 0                          [stack:11115]
7f8f0a1a0000-7f8f0a1a3000 ---p 00000000 00:00 0
7f8f0a1a3000-7f8f0a2a1000 rw-p 00000000 00:00 0                          [stack:11114]
7f8f0a2a1000-7f8f0a2a9000 rw-s 12f714000 00:06 1552                      /dev/dri/card0
7f8f0a2a9000-7f8f0a2b1000 rw-s 12f70c000 00:06 1552                      /dev/dri/card0
7f8f0a2b1000-7f8f0a2b9000 rw-s 12f704000 00:06 1552                      /dev/dri/card0
7f8f0a2b9000-7f8f0a2c1000 rw-s 12f6fc000 00:06 1552                      /dev/dri/card0
7f8f0a2c5000-7f8f0a2d5000 rw-s 1294aa000 00:06 1552                      /dev/dri/card0
7f8f0a2d5000-7f8f0a3d5000 rw-s 1293aa000 00:06 1552                      /dev/dri/card0
7f8f0a3d5000-7f8f0a3e5000 rw-s 13272b000 00:06 1552                      /dev/dri/card0
7f8f0a3e5000-7f8f0a3f5000 rw-s 12dc9b000 00:06 1552                      /dev/dri/card0
7f8f0a3f5000-7f8f0a4f5000 rw-s 12db9b000 00:06 1552                      /dev/dri/card0
7f8f0a4f5000-7f8f0a4f8000 ---p 00000000 00:00 0
7f8f0a4f8000-7f8f0a5f6000 rw-p 00000000 00:00 0                          [stack:11113]
7f8f0a5f6000-7f8f0a5f9000 ---p 00000000 00:00 0
7f8f0a5f9000-7f8f0a6f7000 rw-p 00000000 00:00 0                          [stack:11112]
7f8f0a6f7000-7f8f0a6fa000 ---p 00000000 00:00 0
7f8f0a6fa000-7f8f0a7f8000 rw-p 00000000 00:00 0                          [stack:11111]
7f8f0a7f8000-7f8f0a7fb000 ---p 00000000 00:00 0
7f8f0a7fb000-7f8f0a8f9000 rw-p 00000000 00:00 0                          [stack:11110]
7f8f0a8f9000-7f8f0a8fc000 ---p 00000000 00:00 0
7f8f0a8fc000-7f8f0a9fa000 rw-p 00000000 00:00 0                          [stack:11109]
7f8f0a9fa000-7f8f0a9fd000 ---p 00000000 00:00 0
7f8f0a9fd000-7f8f0aafb000 rw-p 00000000 00:00 0                          [stack:11108]
7f8f0aafb000-7f8f0aafe000 ---p 00000000 00:00 0
7f8f0aafe000-7f8f0adfc000 rw-p 00000000 00:00 0                          [stack:11107]
7f8f0adfc000-7f8f0affc000 rw-p 00000000 00:00 0
7f8f0affc000-7f8f0affe000 r-xp 00000000 08:21 917683                     /lib64/libnss_mdns4_minimal.so.2
7f8f0affe000-7f8f0b1fd000 ---p 00002000 08:21 917683                     /lib64/libnss_mdns4_minimal.so.2
7f8f0b1fd000-7f8f0b1fe000 r--p 00001000 08:21 917683                     /lib64/libnss_mdns4_minimal.so.2
7f8f0b1fe000-7f8f0b1ff000 rw-p 00002000 08:21 917683                     /lib64/libnss_mdns4_minimal.so.2
7f8f0b1ff000-7f8f0b3ff000 rw-p 00000000 00:00 0
7f8f0b3ff000-7f8f0b5ff000 rw-p 00000000 00:00 0
7f8f0b5ff000-7f8f0b7ff000 rw-p 00000000 00:00 0
7f8f0b7ff000-7f8f0b800000 ---p 00000000 00:00 0
7f8f0b800000-7f8f0c000000 rw-p 00000000 00:00 0                          [stack:11102]
7f8f0c000000-7f8f0c570000 rw-p 00000000 00:00 0
7f8f0c570000-7f8f10000000 ---p 00000000 00:00 0
7f8f10001000-7f8f10005000 rw-s 12f720000 00:06 1552                      /dev/dri/card0
7f8f10005000-7f8f10008000 ---p 00000000 00:00 0
7f8f10008000-7f8f10106000 rw-p 00000000 00:00 0                          [stack:11106]
7f8f10106000-7f8f10111000 r--s 00000000 08:21 413189                     /var/cache/fontconfig/20b58f14c9b581391d79ea335a81488a-le64.cache-4
7f8f10111000-7f8f10115000 r--s 00000000 08:21 413208                     /var/cache/fontconfig/e6845615947634e89d319e77806483ba-le64.cache-4
7f8f10115000-7f8f10120000 r--s 00000000 08:21 413205                     /var/cache/fontconfig/d4b6e1db2c46a3b281c413657cd2bc49-le64.cache-4
7f8f10120000-7f8f1012b000 r--s 00000000 08:21 410089                     /var/cache/fontconfig/b79f3aaa7d385a141ab53ec885cc22a8-le64.cache-4
7f8f1012b000-7f8f10158000 r--s 00000000 08:21 410084                     /var/cache/fontconfig/0c8c704313a61b8a850327d2059470f7-le64.cache-4
7f8f10158000-7f8f101bf000 r--s 00000000 08:21 413163                     /var/cache/fontconfig/17090aa38d5c6f09fb8c5c354938f1d7-le64.cache-4
7f8f101bf000-7f8f101ca000 r--s 00000000 08:21 413189                     /var/cache/fontconfig/20b58f14c9b581391d79ea335a81488a-le64.cache-4
7f8f101ca000-7f8f101d5000 r--s 00000000 08:21 413205                     /var/cache/fontconfig/d4b6e1db2c46a3b281c413657cd2bc49-le64.cache-4
7f8f101d5000-7f8f101da000 r--s 00000000 08:21 413198                     /var/cache/fontconfig/87f5e051180a7a75f16eb6fe7dbd3749-le64.cache-4
7f8f101da000-7f8f101e5000 r--s 00000000 08:21 410089                     /var/cache/fontconfig/b79f3aaa7d385a141ab53ec885cc22a8-le64.cache-4
7f8f101e5000-7f8f10212000 r--s 00000000 08:21 410084                     /var/cache/fontconfig/0c8c704313a61b8a850327d2059470f7-le64.cache-4
7f8f10212000-7f8f10215000 r--s 00000000 08:21 413206                     /var/cache/fontconfig/d62e99ef547d1d24cdb1bd22ec1a2976-le64.cache-4
7f8f10215000-7f8f1021a000 r--s 00000000 08:21 413198                     /var/cache/fontconfig/87f5e051180a7a75f16eb6fe7dbd3749-le64.cache-4
7f8f1021a000-7f8f1021f000 r--s 00000000 08:21 413194                     /var/cache/fontconfig/5d999c1bbe32f61af008974facb58b71-le64.cache-4
7f8f1021f000-7f8f10224000 r--s 00000000 08:21 413204                     /var/cache/fontconfig/c776f34310d03ef601d6f862ef1a19b0-le64.cache-4
7f8f10224000-7f8f1022f000 r--s 00000000 08:21 413196                     /var/cache/fontconfig/79aeb4e90a401e55ec91db207072ba77-le64.cache-4
7f8f1022f000-7f8f10248000 r--s 00000000 08:21 413199                     /var/cache/fontconfig/8d4af663993b81a124ee82e610bb31f9-le64.cache-4
7f8f10248000-7f8f1024b000 r--s 00000000 08:21 413206                     /var/cache/fontconfig/d62e99ef547d1d24cdb1bd22ec1a2976-le64.cache-4
7f8f1024b000-7f8f1024f000 r--s 00000000 08:21 410088                     /var/cache/fontconfig/f6b893a7224233d96cb72fd88691c0b4-le64.cache-4
7f8f1024f000-7f8f10252000 ---p 00000000 00:00 0
7f8f10252000-7f8f10350000 rw-p 00000000 00:00 0                          [stack:11104]
7f8f10350000-7f8f10353000 ---p 00000000 00:00 0
7f8f10353000-7f8f10651000 rw-p 00000000 00:00 0                          [stack:11103]
7f8f10651000-7f8f10658000 r-xp 00000000 08:21 13724                      /usr/lib64/libffi.so.6.0.2
7f8f10658000-7f8f10858000 ---p 00007000 08:21 13724                      /usr/lib64/libffi.so.6.0.2
7f8f10858000-7f8f10859000 r--p 00007000 08:21 13724                      /usr/lib64/libffi.so.6.0.2
7f8f10859000-7f8f1085a000 rw-p 00008000 08:21 13724                      /usr/lib64/libffi.so.6.0.2
7f8f1085a000-7f8f10862000 r-xp 00000000 08:21 14153                      /usr/lib64/libpciaccess.so.0.11.1
7f8f10862000-7f8f10a62000 ---p 00008000 08:21 14153                      /usr/lib64/libpciaccess.so.0.11.1
7f8f10a62000-7f8f10a64000 r--p 00008000 08:21 14153                      /usr/lib64/libpciaccess.so.0.11.1
7f8f10a64000-7f8f10a65000 rw-p 0000a000 08:21 14153                      /usr/lib64/libpciaccess.so.0.11.1
7f8f10a65000-7f8f12c87000 r-xp 00000000 08:21 13459                      /usr/lib64/libLLVM-3.7.so
7f8f12c87000-7f8f12e87000 ---p 02222000 08:21 13459                      /usr/lib64/libLLVM-3.7.so
7f8f12e87000-7f8f1311f000 r--p 02222000 08:21 13459                      /usr/lib64/libLLVM-3.7.so
7f8f1311f000-7f8f13125000 rw-p 024ba000 08:21 13459                      /usr/lib64/libLLVM-3.7.so
7f8f13125000-7f8f13148000 rw-p 00000000 00:00 0
7f8f13148000-7f8f13161000 r-xp 00000000 08:21 13703                      /usr/lib64/libelf-0.159.so
7f8f13161000-7f8f13360000 ---p 00019000 08:21 13703                      /usr/lib64/libelf-0.159.so
7f8f13360000-7f8f13361000 r--p 00018000 08:21 13703                      /usr/lib64/libelf-0.159.so
7f8f13361000-7f8f13362000 rw-p 00019000 08:21 13703                      /usr/lib64/libelf-0.159.so
7f8f13362000-7f8f13bb3000 r-xp 00000000 08:21 266553                     /usr/lib64/dri/radeonsi_dri.so
7f8f13bb3000-7f8f13db3000 ---p 00851000 08:21 266553                     /usr/lib64/dri/radeonsi_dri.so
7f8f13db3000-7f8f13e11000 r--p 00851000 08:21 266553                     /usr/lib64/dri/radeonsi_dri.so
7f8f13e11000-7f8f13e1a000 rw-p 008af000 08:21 266553                     /usr/lib64/dri/radeonsi_dri.so
7f8f13e1a000-7f8f14000000 rw-p 00000000 00:00 0
7f8f14000000-7f8f14021000 rw-p 00000000 00:00 0
7f8f14021000-7f8f18000000 ---p 00000000 00:00 0
7f8f18000000-7f8f18237000 rw-p 00000000 00:00 0
7f8f18237000-7f8f1c000000 ---p 00000000 00:00 0
7f8f1c000000-7f8f1c021000 rw-p 00000000 00:00 0
7f8f1c021000-7f8f20000000 ---p 00000000 00:00 0
7f8f20000000-7f8f20021000 rw-p 00000000 00:00 0
7f8f20021000-7f8f24000000 ---p 00000000 00:00 0
7f8f24000000-7f8f24021000 rw-p 00000000 00:00 0
7f8f24021000-7f8f28000000 ---p 00000000 00:00 0
7f8f28000000-7f8f28021000 rw-p 00000000 00:00 0
7f8f28021000-7f8f2c000000 ---p 00000000 00:00 0
7f8f2c000000-7f8f2c021000 rw-p 00000000 00:00 0
7f8f2c021000-7f8f30000000 ---p 00000000 00:00 0
7f8f30000000-7f8f304c0000 rw-p 00000000 00:00 0
7f8f304c0000-7f8f34000000 ---p 00000000 00:00 0
7f8f34000000-7f8f34021000 rw-p 00000000 00:00 0
7f8f34021000-7f8f38000000 ---p 00000000 00:00 0
7f8f38000000-7f8f38021000 rw-p 00000000 00:00 0
7f8f38021000-7f8f3c000000 ---p 00000000 00:00 0
7f8f3c000000-7f8f3c00b000 r--s 00000000 08:21 413196                     /var/cache/fontconfig/79aeb4e90a401e55ec91db207072ba77-le64.cache-4
7f8f3c00b000-7f8f3c072000 r--s 00000000 08:21 413163                     /var/cache/fontconfig/17090aa38d5c6f09fb8c5c354938f1d7-le64.cache-4
7f8f3c072000-7f8f3c079000 r-xp 00000000 08:21 13686                      /usr/lib64/libdrm_amdgpu.so.1.0.0
7f8f3c079000-7f8f3c278000 ---p 00007000 08:21 13686                      /usr/lib64/libdrm_amdgpu.so.1.0.0
7f8f3c278000-7f8f3c279000 r--p 00006000 08:21 13686                      /usr/lib64/libdrm_amdgpu.so.1.0.0
7f8f3c279000-7f8f3c27a000 rw-p 00007000 08:21 13686                      /usr/lib64/libdrm_amdgpu.so.1.0.0
7f8f3c27a000-7f8f3c285000 r-xp 00000000 08:21 13689                      /usr/lib64/libdrm_radeon.so.1.0.1
7f8f3c285000-7f8f3c484000 ---p 0000b000 08:21 13689                      /usr/lib64/libdrm_radeon.so.1.0.1
7f8f3c484000-7f8f3c486000 r--p 0000a000 08:21 13689                      /usr/lib64/libdrm_radeon.so.1.0.1
7f8f3c486000-7f8f3c487000 rw-p 0000c000 08:21 13689                      /usr/lib64/libdrm_radeon.so.1.0.1
7f8f3c487000-7f8f3c48d000 r-xp 00000000 08:21 13688                      /usr/lib64/libdrm_nouveau.so.2.0.0
7f8f3c48d000-7f8f3c68c000 ---p 00006000 08:21 13688                      /usr/lib64/libdrm_nouveau.so.2.0.0
7f8f3c68c000-7f8f3c68d000 r--p 00005000 08:21 13688                      /usr/lib64/libdrm_nouveau.so.2.0.0
7f8f3c68d000-7f8f3c68e000 rw-p 00006000 08:21 13688                      /usr/lib64/libdrm_nouveau.so.2.0.0
7f8f3c68e000-7f8f3c6ae000 r-xp 00000000 08:21 13687                      /usr/lib64/libdrm_intel.so.1.0.0
7f8f3c6ae000-7f8f3c8ad000 ---p 00020000 08:21 13687                      /usr/lib64/libdrm_intel.so.1.0.0
7f8f3c8ad000-7f8f3c8ae000 r--p 0001f000 08:21 13687                      /usr/lib64/libdrm_intel.so.1.0.0
7f8f3c8ae000-7f8f3c8af000 rw-p 00020000 08:21 13687                      /usr/lib64/libdrm_intel.so.1.0.0
7f8f3c8af000-7f8f3c8b2000 ---p 00000000 00:00 0
7f8f3c8b2000-7f8f3c9b0000 rw-p 00000000 00:00 0                          [stack:11101]
7f8f3c9b0000-7f8f3c9b3000 ---p 00000000 00:00 0
7f8f3c9b3000-7f8f3cab1000 rw-p 00000000 00:00 0                          [stack:11100]
7f8f3cab1000-7f8f3cab4000 ---p 00000000 00:00 0
7f8f3cab4000-7f8f3cbb2000 rw-p 00000000 00:00 0                          [stack:11099]
7f8f3cbb2000-7f8f3cbb5000 ---p 00000000 00:00 0
7f8f3cbb5000-7f8f3ccb3000 rw-p 00000000 00:00 0                          [stack:11098]
7f8f3ccb3000-7f8f3ccb6000 ---p 00000000 00:00 0
7f8f3ccb6000-7f8f3cdb4000 rw-p 00000000 00:00 0                          [stack:11097]
7f8f3cdb4000-7f8f3cdc1000 r-xp 00000000 08:21 13685                      /usr/lib64/libdrm.so.2.4.0
7f8f3cdc1000-7f8f3cfc0000 ---p 0000d000 08:21 13685                      /usr/lib64/libdrm.so.2.4.0
7f8f3cfc0000-7f8f3cfc1000 r--p 0000c000 08:21 13685                      /usr/lib64/libdrm.so.2.4.0
7f8f3cfc1000-7f8f3cfc2000 rw-p 0000d000 08:21 13685                      /usr/lib64/libdrm.so.2.4.0
7f8f3cfc2000-7f8f3cfc6000 r-xp 00000000 08:21 13558                      /usr/lib64/libXxf86vm.so.1.0.0
7f8f3cfc6000-7f8f3d1c6000 ---p 00004000 08:21 13558                      /usr/lib64/libXxf86vm.so.1.0.0
7f8f3d1c6000-7f8f3d1c7000 r--p 00004000 08:21 13558                      /usr/lib64/libXxf86vm.so.1.0.0
7f8f3d1c7000-7f8f3d1c8000 rw-p 00005000 08:21 13558                      /usr/lib64/libXxf86vm.so.1.0.0
7f8f3d1c8000-7f8f3d1c9000 r-xp 00000000 08:21 14420                      /usr/lib64/libxshmfence.so.1.0.0
7f8f3d1c9000-7f8f3d3c9000 ---p 00001000 08:21 14420                      /usr/lib64/libxshmfence.so.1.0.0
7f8f3d3c9000-7f8f3d3ca000 r--p 00001000 08:21 14420                      /usr/lib64/libxshmfence.so.1.0.0
7f8f3d3ca000-7f8f3d3cb000 rw-p 00002000 08:21 14420                      /usr/lib64/libxshmfence.so.1.0.0
7f8f3d3cb000-7f8f3d3d0000 r-xp 00000000 08:21 14411                      /usr/lib64/libxcb-sync.so.1.0.0
7f8f3d3d0000-7f8f3d5cf000 ---p 00005000 08:21 14411                      /usr/lib64/libxcb-sync.so.1.0.0
7f8f3d5cf000-7f8f3d5d0000 r--p 00004000 08:21 14411                      /usr/lib64/libxcb-sync.so.1.0.0
7f8f3d5d0000-7f8f3d5d1000 rw-p 00005000 08:21 14411                      /usr/lib64/libxcb-sync.so.1.0.0
7f8f3d5d1000-7f8f3d5d3000 r-xp 00000000 08:21 14404                      /usr/lib64/libxcb-present.so.0.0.0
7f8f3d5d3000-7f8f3d7d2000 ---p 00002000 08:21 14404                      /usr/lib64/libxcb-present.so.0.0.0
7f8f3d7d2000-7f8f3d7d3000 r--p 00001000 08:21 14404                      /usr/lib64/libxcb-present.so.0.0.0
7f8f3d7d3000-7f8f3d7d4000 rw-p 00002000 08:21 14404                      /usr/lib64/libxcb-present.so.0.0.0
7f8f3d7d4000-7f8f3d7d6000 r-xp 00000000 08:21 14399                      /usr/lib64/libxcb-dri3.so.0.0.0
7f8f3d7d6000-7f8f3d9d5000 ---p 00002000 08:21 14399                      /usr/lib64/libxcb-dri3.so.0.0.0
7f8f3d9d5000-7f8f3d9d6000 r--p 00001000 08:21 14399                      /usr/lib64/libxcb-dri3.so.0.0.0
7f8f3d9d6000-7f8f3d9d7000 rw-p 00002000 08:21 14399                      /usr/lib64/libxcb-dri3.so.0.0.0
7f8f3d9d7000-7f8f3d9da000 r-xp 00000000 08:21 14398                      /usr/lib64/libxcb-dri2.so.0.0.0
7f8f3d9da000-7f8f3dbda000 ---p 00003000 08:21 14398                      /usr/lib64/libxcb-dri2.so.0.0.0
7f8f3dbda000-7f8f3dbdb000 r--p 00003000 08:21 14398                      /usr/lib64/libxcb-dri2.so.0.0.0
7f8f3dbdb000-7f8f3dbdc000 rw-p 00004000 08:21 14398                      /usr/lib64/libxcb-dri2.so.0.0.0
7f8f3dbdc000-7f8f3dbf1000 r-xp 00000000 08:21 14400                      /usr/lib64/libxcb-glx.so.0.0.0
7f8f3dbf1000-7f8f3ddf1000 ---p 00015000 08:21 14400                      /usr/lib64/libxcb-glx.so.0.0.0
7f8f3ddf1000-7f8f3ddf3000 r--p 00015000 08:21 14400                      /usr/lib64/libxcb-glx.so.0.0.0
7f8f3ddf3000-7f8f3ddf4000 rw-p 00017000 08:21 14400                      /usr/lib64/libxcb-glx.so.0.0.0
7f8f3ddf4000-7f8f3ddf5000 r-xp 00000000 08:21 13527                      /usr/lib64/libX11-xcb.so.1.0.0
7f8f3ddf5000-7f8f3dff4000 ---p 00001000 08:21 13527                      /usr/lib64/libX11-xcb.so.1.0.0
7f8f3dff4000-7f8f3dff5000 r--p 00000000 08:21 13527                      /usr/lib64/libX11-xcb.so.1.0.0
7f8f3dff5000-7f8f3dff6000 rw-p 00001000 08:21 13527                      /usr/lib64/libX11-xcb.so.1.0.0
7f8f3dff6000-7f8f3dff8000 r-xp 00000000 08:21 13534                      /usr/lib64/libXdamage.so.1.1.0
7f8f3dff8000-7f8f3e1f7000 ---p 00002000 08:21 13534                      /usr/lib64/libXdamage.so.1.1.0
7f8f3e1f7000-7f8f3e1f8000 r--p 00001000 08:21 13534                      /usr/lib64/libXdamage.so.1.1.0
7f8f3e1f8000-7f8f3e1f9000 rw-p 00002000 08:21 13534                      /usr/lib64/libXdamage.so.1.1.0
7f8f3e1f9000-7f8f3e247000 r-xp 00000000 08:21 13787                      /usr/lib64/libglapi.so.0.0.0
7f8f3e247000-7f8f3e447000 ---p 0004e000 08:21 13787                      /usr/lib64/libglapi.so.0.0.0
7f8f3e447000-7f8f3e44d000 r--p 0004e000 08:21 13787                      /usr/lib64/libglapi.so.0.0.0
7f8f3e44d000-7f8f3e44e000 rw-p 00054000 08:21 13787                      /usr/lib64/libglapi.so.0.0.0
7f8f3e44e000-7f8f3e44f000 rw-p 00000000 00:00 0
7f8f3e44f000-7f8f3e476000 r-xp 00000000 08:21 13716                      /usr/lib64/libexpat.so.1.6.0
7f8f3e476000-7f8f3e675000 ---p 00027000 08:21 13716                      /usr/lib64/libexpat.so.1.6.0
7f8f3e675000-7f8f3e678000 r--p 00026000 08:21 13716                      /usr/lib64/libexpat.so.1.6.0
7f8f3e678000-7f8f3e679000 rw-p 00029000 08:21 13716                      /usr/lib64/libexpat.so.1.6.0
7f8f3e679000-7f8f3e68f000 r-xp 00000000 08:21 917553                     /lib64/libnsl-2.19.so
7f8f3e68f000-7f8f3e88e000 ---p 00016000 08:21 917553                     /lib64/libnsl-2.19.so
7f8f3e88e000-7f8f3e88f000 r--p 00015000 08:21 917553                     /lib64/libnsl-2.19.so
7f8f3e88f000-7f8f3e890000 rw-p 00016000 08:21 917553                     /lib64/libnsl-2.19.so
7f8f3e890000-7f8f3e892000 rw-p 00000000 00:00 0
7f8f3e892000-7f8f3e929000 r-xp 00000000 08:21 13370                      /usr/lib64/libGL.so.1.2.0
7f8f3e929000-7f8f3eb28000 ---p 00097000 08:21 13370                      /usr/lib64/libGL.so.1.2.0
7f8f3eb28000-7f8f3eb2b000 r--p 00096000 08:21 13370                      /usr/lib64/libGL.so.1.2.0
7f8f3eb2b000-7f8f3eb2c000 rw-p 00099000 08:21 13370                      /usr/lib64/libGL.so.1.2.0
7f8f3eb2c000-7f8f3eb2d000 rw-p 00000000 00:00 0
7f8f3eb2d000-7f8f3eb4e000 r-xp 00000000 08:21 15326                      /usr/lib64/libj3dcore-ogl.so
7f8f3eb4e000-7f8f3ed4d000 ---p 00021000 08:21 15326                      /usr/lib64/libj3dcore-ogl.so
7f8f3ed4d000-7f8f3ed4e000 r--p 00020000 08:21 15326                      /usr/lib64/libj3dcore-ogl.so
7f8f3ed4e000-7f8f3ed4f000 rw-p 00021000 08:21 15326                      /usr/lib64/libj3dcore-ogl.so
7f8f3ed4f000-7f8f3ed50000 r-xp 00000000 08:21 840674                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libjawt.so
7f8f3ed50000-7f8f3ef4f000 ---p 00001000 08:21 840674                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libjawt.so
7f8f3ef4f000-7f8f3ef50000 r--p 00000000 08:21 840674                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libjawt.so
7f8f3ef50000-7f8f3ef51000 rw-p 00001000 08:21 840674                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libjawt.so
7f8f3ef51000-7f8f3ef54000 ---p 00000000 00:00 0
7f8f3ef54000-7f8f3f252000 rw-p 00000000 00:00 0                          [stack:11095]
7f8f3f252000-7f8f3f255000 ---p 00000000 00:00 0
7f8f3f255000-7f8f3f353000 rw-p 00000000 00:00 0                          [stack:11105]
7f8f3f353000-7f8f3f356000 ---p 00000000 00:00 0
7f8f3f356000-7f8f3f454000 rw-p 00000000 00:00 0                          [stack:11093]
7f8f3f454000-7f8f3f457000 ---p 00000000 00:00 0
7f8f3f457000-7f8f3f755000 rw-p 00000000 00:00 0                          [stack:11092]
7f8f3f755000-7f8f3f75a000 r-xp 00000000 08:21 13538                      /usr/lib64/libXfixes.so.3.1.0
7f8f3f75a000-7f8f3f959000 ---p 00005000 08:21 13538                      /usr/lib64/libXfixes.so.3.1.0
7f8f3f959000-7f8f3f95a000 r--p 00004000 08:21 13538                      /usr/lib64/libXfixes.so.3.1.0
7f8f3f95a000-7f8f3f95b000 rw-p 00005000 08:21 13538                      /usr/lib64/libXfixes.so.3.1.0
7f8f3f95b000-7f8f3f965000 r-xp 00000000 08:21 13533                      /usr/lib64/libXcursor.so.1.0.2
7f8f3f965000-7f8f3fb64000 ---p 0000a000 08:21 13533                      /usr/lib64/libXcursor.so.1.0.2
7f8f3fb64000-7f8f3fb65000 r--p 00009000 08:21 13533                      /usr/lib64/libXcursor.so.1.0.2
7f8f3fb65000-7f8f3fb66000 rw-p 0000a000 08:21 13533                      /usr/lib64/libXcursor.so.1.0.2
7f8f3fb66000-7f8f3fbd2000 r-xp 00000000 08:21 917699                     /lib64/libpcre.so.1.2.3
7f8f3fbd2000-7f8f3fdd1000 ---p 0006c000 08:21 917699                     /lib64/libpcre.so.1.2.3
7f8f3fdd1000-7f8f3fdd2000 r--p 0006b000 08:21 917699                     /lib64/libpcre.so.1.2.3
7f8f3fdd2000-7f8f3fdd3000 rw-p 0006c000 08:21 917699                     /lib64/libpcre.so.1.2.3
7f8f3fdd3000-7f8f3fdfd000 r-xp 00000000 08:21 12611                      /usr/lib64/libgraphite2.so.3.0.1
7f8f3fdfd000-7f8f3fffd000 ---p 0002a000 08:21 12611                      /usr/lib64/libgraphite2.so.3.0.1
7f8f3fffd000-7f8f3ffff000 r--p 0002a000 08:21 12611                      /usr/lib64/libgraphite2.so.3.0.1
7f8f3ffff000-7f8f40000000 rw-p 0002c000 08:21 12611                      /usr/lib64/libgraphite2.so.3.0.1
7f8f40000000-7f8f40021000 rw-p 00000000 00:00 0
7f8f40021000-7f8f44000000 ---p 00000000 00:00 0
7f8f44000000-7f8f44021000 rw-p 00000000 00:00 0
7f8f44021000-7f8f48000000 ---p 00000000 00:00 0
7f8f48000000-7f8f485e0000 rw-p 00000000 00:00 0
7f8f485e0000-7f8f4c000000 ---p 00000000 00:00 0
7f8f4c000000-7f8f4c021000 rw-p 00000000 00:00 0
7f8f4c021000-7f8f50000000 ---p 00000000 00:00 0
7f8f50000000-7f8f50402000 rw-p 00000000 00:00 0
7f8f50402000-7f8f54000000 ---p 00000000 00:00 0
7f8f54000000-7f8f54444000 rw-p 00000000 00:00 0
7f8f54444000-7f8f58000000 ---p 00000000 00:00 0
7f8f58000000-7f8f58021000 rw-p 00000000 00:00 0
7f8f58021000-7f8f5c000000 ---p 00000000 00:00 0
7f8f5c000000-7f8f5c021000 rw-p 00000000 00:00 0
7f8f5c021000-7f8f60000000 ---p 00000000 00:00 0
7f8f60000000-7f8f60004000 r--s 00000000 08:21 413208                     /var/cache/fontconfig/e6845615947634e89d319e77806483ba-le64.cache-4
7f8f60004000-7f8f60009000 r--s 00000000 08:21 413194                     /var/cache/fontconfig/5d999c1bbe32f61af008974facb58b71-le64.cache-4
7f8f60009000-7f8f60058000 rw-s 00000000 00:05 360453                     /SYSV00000000 (deleted)
7f8f60058000-7f8f6005b000 ---p 00000000 00:00 0
7f8f6005b000-7f8f60159000 rw-p 00000000 00:00 0                          [stack:11091]
7f8f60159000-7f8f60264000 r-xp 00000000 08:21 917650                     /lib64/libglib-2.0.so.0.4400.1
7f8f60264000-7f8f60464000 ---p 0010b000 08:21 917650                     /lib64/libglib-2.0.so.0.4400.1
7f8f60464000-7f8f60465000 r--p 0010b000 08:21 917650                     /lib64/libglib-2.0.so.0.4400.1
7f8f60465000-7f8f60466000 rw-p 0010c000 08:21 917650                     /lib64/libglib-2.0.so.0.4400.1
7f8f60466000-7f8f60467000 rw-p 00000000 00:00 0
7f8f60467000-7f8f604bb000 r-xp 00000000 08:21 13870                      /usr/lib64/libharfbuzz.so.0.929.0
7f8f604bb000-7f8f606ba000 ---p 00054000 08:21 13870                      /usr/lib64/libharfbuzz.so.0.929.0
7f8f606ba000-7f8f606bc000 r--p 00053000 08:21 13870                      /usr/lib64/libharfbuzz.so.0.929.0
7f8f606bc000-7f8f606bd000 rw-p 00055000 08:21 13870                      /usr/lib64/libharfbuzz.so.0.929.0
7f8f606bd000-7f8f6071e000 r-xp 00000000 08:21 14170                      /usr/lib64/libpng16.so.16.16.0
7f8f6071e000-7f8f6091e000 ---p 00061000 08:21 14170                      /usr/lib64/libpng16.so.16.16.0
7f8f6091e000-7f8f6091f000 r--p 00061000 08:21 14170                      /usr/lib64/libpng16.so.16.16.0
7f8f6091f000-7f8f60920000 rw-p 00062000 08:21 14170                      /usr/lib64/libpng16.so.16.16.0
7f8f60920000-7f8f6092f000 r-xp 00000000 08:21 13615                      /usr/lib64/libbz2.so.1.0.0
7f8f6092f000-7f8f60b2e000 ---p 0000f000 08:21 13615                      /usr/lib64/libbz2.so.1.0.0
7f8f60b2e000-7f8f60b2f000 r--p 0000e000 08:21 13615                      /usr/lib64/libbz2.so.1.0.0
7f8f60b2f000-7f8f60b30000 rw-p 0000f000 08:21 13615                      /usr/lib64/libbz2.so.1.0.0
7f8f60b30000-7f8f60bd2000 r-xp 00000000 08:21 13741                      /usr/lib64/libfreetype.so.6.11.4
7f8f60bd2000-7f8f60dd2000 ---p 000a2000 08:21 13741                      /usr/lib64/libfreetype.so.6.11.4
7f8f60dd2000-7f8f60dd8000 r--p 000a2000 08:21 13741                      /usr/lib64/libfreetype.so.6.11.4
7f8f60dd8000-7f8f60dd9000 rw-p 000a8000 08:21 13741                      /usr/lib64/libfreetype.so.6.11.4
7f8f60dd9000-7f8f60ddb000 r--s 00000000 08:21 413195                     /var/cache/fontconfig/69fb4bbe1b2fa860e172a32ebf28505c-le64.cache-4
7f8f60ddb000-7f8f60ddd000 r--s 00000000 08:21 413195                     /var/cache/fontconfig/69fb4bbe1b2fa860e172a32ebf28505c-le64.cache-4
7f8f60ddd000-7f8f60de2000 r--s 00000000 08:21 413204                     /var/cache/fontconfig/c776f34310d03ef601d6f862ef1a19b0-le64.cache-4
7f8f60de2000-7f8f60dfb000 r--s 00000000 08:21 413199                     /var/cache/fontconfig/8d4af663993b81a124ee82e610bb31f9-le64.cache-4
7f8f60dfb000-7f8f60dff000 r--s 00000000 08:21 410088                     /var/cache/fontconfig/f6b893a7224233d96cb72fd88691c0b4-le64.cache-4
7f8f60dff000-7f8f60e4f000 r-xp 00000000 08:21 840619                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libfontmanager.so
7f8f60e4f000-7f8f6104f000 ---p 00050000 08:21 840619                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libfontmanager.so
7f8f6104f000-7f8f61052000 r--p 00050000 08:21 840619                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libfontmanager.so
7f8f61052000-7f8f61053000 rw-p 00053000 08:21 840619                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libfontmanager.so
7f8f61053000-7f8f610d3000 r-xp 00000000 08:21 13906                      /usr/lib64/libjpeg.so.8.0.2
7f8f610d3000-7f8f612d2000 ---p 00080000 08:21 13906                      /usr/lib64/libjpeg.so.8.0.2
7f8f612d2000-7f8f612d3000 r--p 0007f000 08:21 13906                      /usr/lib64/libjpeg.so.8.0.2
7f8f612d3000-7f8f612d4000 rw-p 00080000 08:21 13906                      /usr/lib64/libjpeg.so.8.0.2
7f8f612d4000-7f8f612de000 r-xp 00000000 08:21 840628                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libjavajpeg.so
7f8f612de000-7f8f614dd000 ---p 0000a000 08:21 840628                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libjavajpeg.so
7f8f614dd000-7f8f614de000 r--p 00009000 08:21 840628                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libjavajpeg.so
7f8f614de000-7f8f614df000 rw-p 0000a000 08:21 840628                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libjavajpeg.so
7f8f614df000-7f8f614e2000 ---p 00000000 00:00 0
7f8f614e2000-7f8f615e0000 rw-p 00000000 00:00 0                          [stack:11090]
7f8f615e0000-7f8f615f6000 r-xp 00000000 08:21 840636                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libnet.so
7f8f615f6000-7f8f617f5000 ---p 00016000 08:21 840636                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libnet.so
7f8f617f5000-7f8f617f6000 r--p 00015000 08:21 840636                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libnet.so
7f8f617f6000-7f8f617f7000 rw-p 00016000 08:21 840636                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libnet.so
7f8f617f7000-7f8f61807000 r-xp 00000000 08:21 840637                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libnio.so
7f8f61807000-7f8f61a06000 ---p 00010000 08:21 840637                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libnio.so
7f8f61a06000-7f8f61a07000 r--p 0000f000 08:21 840637                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libnio.so
7f8f61a07000-7f8f61a08000 rw-p 00010000 08:21 840637                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libnio.so
7f8f61a08000-7f8f61a0d000 r-xp 00000000 08:21 13535                      /usr/lib64/libXdmcp.so.6.0.0
7f8f61a0d000-7f8f61c0c000 ---p 00005000 08:21 13535                      /usr/lib64/libXdmcp.so.6.0.0
7f8f61c0c000-7f8f61c0d000 r--p 00004000 08:21 13535                      /usr/lib64/libXdmcp.so.6.0.0
7f8f61c0d000-7f8f61c0e000 rw-p 00005000 08:21 13535                      /usr/lib64/libXdmcp.so.6.0.0
7f8f61c0e000-7f8f61c10000 r-xp 00000000 08:21 13530                      /usr/lib64/libXau.so.6.0.0
7f8f61c10000-7f8f61e10000 ---p 00002000 08:21 13530                      /usr/lib64/libXau.so.6.0.0
7f8f61e10000-7f8f61e11000 r--p 00002000 08:21 13530                      /usr/lib64/libXau.so.6.0.0
7f8f61e11000-7f8f61e12000 rw-p 00003000 08:21 13530                      /usr/lib64/libXau.so.6.0.0
7f8f61e12000-7f8f61e31000 r-xp 00000000 08:21 14415                      /usr/lib64/libxcb.so.1.1.0
7f8f61e31000-7f8f62030000 ---p 0001f000 08:21 14415                      /usr/lib64/libxcb.so.1.1.0
7f8f62030000-7f8f62031000 r--p 0001e000 08:21 14415                      /usr/lib64/libxcb.so.1.1.0
7f8f62031000-7f8f62032000 rw-p 0001f000 08:21 14415                      /usr/lib64/libxcb.so.1.1.0
7f8f62032000-7f8f62041000 r-xp 00000000 08:21 13541                      /usr/lib64/libXi.so.6.1.0
7f8f62041000-7f8f62240000 ---p 0000f000 08:21 13541                      /usr/lib64/libXi.so.6.1.0
7f8f62240000-7f8f62241000 r--p 0000e000 08:21 13541                      /usr/lib64/libXi.so.6.1.0
7f8f62241000-7f8f62242000 rw-p 0000f000 08:21 13541                      /usr/lib64/libXi.so.6.1.0
7f8f62242000-7f8f62247000 r-xp 00000000 08:21 13551                      /usr/lib64/libXtst.so.6.1.0
7f8f62247000-7f8f62446000 ---p 00005000 08:21 13551                      /usr/lib64/libXtst.so.6.1.0
7f8f62446000-7f8f62447000 r--p 00004000 08:21 13551                      /usr/lib64/libXtst.so.6.1.0
7f8f62447000-7f8f62448000 rw-p 00005000 08:21 13551                      /usr/lib64/libXtst.so.6.1.0
7f8f62448000-7f8f62451000 r-xp 00000000 08:21 13547                      /usr/lib64/libXrender.so.1.3.0
7f8f62451000-7f8f62650000 ---p 00009000 08:21 13547                      /usr/lib64/libXrender.so.1.3.0
7f8f62650000-7f8f62651000 r--p 00008000 08:21 13547                      /usr/lib64/libXrender.so.1.3.0
7f8f62651000-7f8f62652000 rw-p 00009000 08:21 13547                      /usr/lib64/libXrender.so.1.3.0
7f8f62652000-7f8f6278b000 r-xp 00000000 08:21 13528                      /usr/lib64/libX11.so.6.3.0
7f8f6278b000-7f8f6298a000 ---p 00139000 08:21 13528                      /usr/lib64/libX11.so.6.3.0
7f8f6298a000-7f8f6298e000 r--p 00138000 08:21 13528                      /usr/lib64/libX11.so.6.3.0
7f8f6298e000-7f8f62992000 rw-p 0013c000 08:21 13528                      /usr/lib64/libX11.so.6.3.0
7f8f62992000-7f8f629a3000 r-xp 00000000 08:21 13537                      /usr/lib64/libXext.so.6.4.0
7f8f629a3000-7f8f62ba2000 ---p 00011000 08:21 13537                      /usr/lib64/libXext.so.6.4.0
7f8f62ba2000-7f8f62ba3000 r--p 00010000 08:21 13537                      /usr/lib64/libXext.so.6.4.0
7f8f62ba3000-7f8f62ba4000 rw-p 00011000 08:21 13537                      /usr/lib64/libXext.so.6.4.0
7f8f62ba4000-7f8f62bf6000 r-xp 00000000 08:21 840673                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libawt_xawt.so
7f8f62bf6000-7f8f62df5000 ---p 00052000 08:21 840673                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libawt_xawt.so
7f8f62df5000-7f8f62df6000 r--p 00051000 08:21 840673                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libawt_xawt.so
7f8f62df6000-7f8f62df9000 rw-p 00052000 08:21 840673                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libawt_xawt.so
7f8f62df9000-7f8f62dfa000 rw-p 00000000 00:00 0
7f8f62dfa000-7f8f62e98000 r-xp 00000000 08:21 840616                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libawt.so
7f8f62e98000-7f8f63097000 ---p 0009e000 08:21 840616                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libawt.so
7f8f63097000-7f8f63098000 r--p 0009d000 08:21 840616                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libawt.so
7f8f63098000-7f8f630a3000 rw-p 0009e000 08:21 840616                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libawt.so
7f8f630a3000-7f8f630c8000 rw-p 00000000 00:00 0
7f8f630c8000-7f8f630cb000 ---p 00000000 00:00 0
7f8f630cb000-7f8f631c9000 rw-p 00000000 00:00 0                          [stack:11089]
7f8f631c9000-7f8f631ca000 ---p 00000000 00:00 0
7f8f631ca000-7f8f632ca000 rw-p 00000000 00:00 0                          [stack:11088]
7f8f632ca000-7f8f632cd000 ---p 00000000 00:00 0
7f8f632cd000-7f8f633cb000 rw-p 00000000 00:00 0                          [stack:11087]
7f8f633cb000-7f8f633ce000 ---p 00000000 00:00 0
7f8f633ce000-7f8f634cc000 rw-p 00000000 00:00 0                          [stack:11086]
7f8f634cc000-7f8f634cf000 ---p 00000000 00:00 0
7f8f634cf000-7f8f635cd000 rw-p 00000000 00:00 0                          [stack:11085]
7f8f635cd000-7f8f635d0000 ---p 00000000 00:00 0
7f8f635d0000-7f8f636ce000 rw-p 00000000 00:00 0                          [stack:11084]
7f8f636ce000-7f8f64000000 r--p 00000000 08:21 7240                       /usr/lib/locale/locale-archive
7f8f64000000-7f8f64021000 rw-p 00000000 00:00 0
7f8f64021000-7f8f68000000 ---p 00000000 00:00 0
7f8f68000000-7f8f68021000 rw-p 00000000 00:00 0
7f8f68021000-7f8f6c000000 ---p 00000000 00:00 0
7f8f6c000000-7f8f6c021000 rw-p 00000000 00:00 0
7f8f6c021000-7f8f70000000 ---p 00000000 00:00 0
7f8f70000000-7f8f7002f000 rw-p 00000000 00:00 0
7f8f7002f000-7f8f74000000 ---p 00000000 00:00 0
7f8f74000000-7f8f74021000 rw-p 00000000 00:00 0
7f8f74021000-7f8f78000000 ---p 00000000 00:00 0
7f8f78000000-7f8f78003000 r--s 00000000 08:21 413206                     /var/cache/fontconfig/d62e99ef547d1d24cdb1bd22ec1a2976-le64.cache-4
7f8f78003000-7f8f7801f000 r--s 00393000 08:21 939477                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/ext/cldrdata.jar
7f8f7801f000-7f8f78050000 rw-p 00000000 00:00 0
7f8f78050000-7f8f7807f000 r--p 00000000 08:21 924118                     /usr/share/locale/ru/LC_MESSAGES/libc.mo
7f8f7807f000-7f8f78082000 ---p 00000000 00:00 0
7f8f78082000-7f8f7c000000 rw-p 00000000 00:00 0                          [stack:11083]
7f8f7c000000-7f8f7c021000 rw-p 00000000 00:00 0
7f8f7c021000-7f8f80000000 ---p 00000000 00:00 0
7f8f80001000-7f8f80014000 r-xp 00000000 08:21 917729                     /lib64/libudev.so.1.6.2
7f8f80014000-7f8f80015000 r--p 00012000 08:21 917729                     /lib64/libudev.so.1.6.2
7f8f80015000-7f8f80016000 rw-p 00013000 08:21 917729                     /lib64/libudev.so.1.6.2
7f8f80016000-7f8f80029000 r--s 00345000 08:21 840661                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/resources.jar
7f8f80029000-7f8f8002f000 r--s 002f8000 08:21 840645                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/charsets.jar
7f8f8002f000-7f8f80039000 r--s 00116000 08:21 939479                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/ext/localedata.jar
7f8f80039000-7f8f8003e000 r--s 00094000 08:21 840653                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/jsse.jar
7f8f8003e000-7f8f80054000 r--s 00131000 08:21 543732                     /usr/share/icedtea-web/netx.jar
7f8f80054000-7f8f80061000 r--s 00105000 08:21 543769                     /usr/share/java/itext-2.1.5.jar
7f8f80061000-7f8f8006f000 r--s 0018c000 08:21 543778                     /usr/share/java/java3d/j3dutils-1.5.2.jar
7f8f8006f000-7f8f800ba000 r--s 002f6000 08:21 543782                     /usr/share/java/batik-all-1.8.jar
7f8f800ba000-7f8f800f1000 r--s 002ae000 08:21 543787                     /usr/share/java/SweetHome3D/SweetHome3D-5.2.jar
7f8f800f1000-7f8f800f4000 ---p 00000000 00:00 0
7f8f800f4000-7f8f801f2000 rw-p 00000000 00:00 0                          [stack:11082]
7f8f801f2000-7f8f801f5000 ---p 00000000 00:00 0
7f8f801f5000-7f8f802f3000 rw-p 00000000 00:00 0                          [stack:11081]
7f8f802f3000-7f8f802f4000 ---p 00000000 00:00 0
7f8f802f4000-7f8f81000000 rw-p 00000000 00:00 0                          [stack:11080]
7f8f81000000-7f8f817d0000 rwxp 00000000 00:00 0
7f8f817d0000-7f8f90000000 ---p 00000000 00:00 0
7f8f90000000-7f8f90499000 rw-p 00000000 00:00 0
7f8f90499000-7f8f94000000 ---p 00000000 00:00 0
7f8f94000000-7f8f94008000 r--s 000e6000 08:21 543780                     /usr/share/java/sunflow-0.07.3.jar
7f8f94008000-7f8f94013000 r--s 002a3000 08:21 543776                     /usr/share/java/java3d/j3dcore-1.5.2.jar
7f8f94013000-7f8f9402d000 r--s 00686000 08:21 543786                     /usr/share/java/SweetHome3D/Help.jar
7f8f9402d000-7f8f94401000 rw-p 00000000 00:00 0
7f8f94401000-7f8f945ce000 r--s 03bd5000 08:21 840662                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/rt.jar
7f8f945ce000-7f8f9522c000 rw-p 00000000 00:00 0
7f8f9522c000-7f8f9522d000 ---p 00000000 00:00 0
7f8f9522d000-7f8f9532d000 rw-p 00000000 00:00 0                          [stack:11079]
7f8f9532d000-7f8f9532e000 ---p 00000000 00:00 0
7f8f9532e000-7f8f9542e000 rw-p 00000000 00:00 0                          [stack:11078]
7f8f9542e000-7f8f9542f000 ---p 00000000 00:00 0
7f8f9542f000-7f8f9552f000 rw-p 00000000 00:00 0                          [stack:11077]
7f8f9552f000-7f8f95530000 ---p 00000000 00:00 0
7f8f95530000-7f8f9565a000 rw-p 00000000 00:00 0                          [stack:11076]
7f8f9565a000-7f8f958cb000 ---p 00000000 00:00 0
7f8f958cb000-7f8f958f5000 rw-p 00000000 00:00 0
7f8f958f5000-7f8f95b65000 ---p 00000000 00:00 0
7f8f95b65000-7f8f95b7b000 rw-p 00000000 00:00 0
7f8f95b7b000-7f8f95cb3000 ---p 00000000 00:00 0
7f8f95cb3000-7f8f95cd4000 rw-p 00000000 00:00 0
7f8f95cd4000-7f8f96074000 ---p 00000000 00:00 0
7f8f96074000-7f8f9607c000 r-xp 00000000 08:21 840643                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libzip.so
7f8f9607c000-7f8f9627b000 ---p 00008000 08:21 840643                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libzip.so
7f8f9627b000-7f8f9627c000 r--p 00007000 08:21 840643                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libzip.so
7f8f9627c000-7f8f9627d000 rw-p 00008000 08:21 840643                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libzip.so
7f8f9627d000-7f8f96288000 r-xp 00000000 08:21 917561                     /lib64/libnss_files-2.19.so
7f8f96288000-7f8f96487000 ---p 0000b000 08:21 917561                     /lib64/libnss_files-2.19.so
7f8f96487000-7f8f96488000 r--p 0000a000 08:21 917561                     /lib64/libnss_files-2.19.so
7f8f96488000-7f8f96489000 rw-p 0000b000 08:21 917561                     /lib64/libnss_files-2.19.so
7f8f96489000-7f8f964b4000 r-xp 00000000 08:21 840626                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libjava.so
7f8f964b4000-7f8f966b4000 ---p 0002b000 08:21 840626                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libjava.so
7f8f966b4000-7f8f966b5000 r--p 0002b000 08:21 840626                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libjava.so
7f8f966b5000-7f8f966b7000 rw-p 0002c000 08:21 840626                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libjava.so
7f8f966b7000-7f8f966c4000 r-xp 00000000 08:21 840642                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libverify.so
7f8f966c4000-7f8f968c3000 ---p 0000d000 08:21 840642                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libverify.so
7f8f968c3000-7f8f968c6000 r--p 0000c000 08:21 840642                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libverify.so
7f8f968c6000-7f8f968c7000 rw-p 0000f000 08:21 840642                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/libverify.so
7f8f968c7000-7f8f968ce000 r-xp 00000000 08:21 917581                     /lib64/librt-2.19.so
7f8f968ce000-7f8f96acd000 ---p 00007000 08:21 917581                     /lib64/librt-2.19.so
7f8f96acd000-7f8f96ace000 r--p 00006000 08:21 917581                     /lib64/librt-2.19.so
7f8f96ace000-7f8f96acf000 rw-p 00007000 08:21 917581                     /lib64/librt-2.19.so
7f8f96acf000-7f8f96ae5000 r-xp 00000000 08:21 917648                     /lib64/libgcc_s.so.1
7f8f96ae5000-7f8f96ce4000 ---p 00016000 08:21 917648                     /lib64/libgcc_s.so.1
7f8f96ce4000-7f8f96ce5000 r--p 00015000 08:21 917648                     /lib64/libgcc_s.so.1
7f8f96ce5000-7f8f96ce6000 rw-p 00016000 08:21 917648                     /lib64/libgcc_s.so.1
7f8f96ce6000-7f8f96dec000 r-xp 00000000 08:21 917533                     /lib64/libm-2.19.so
7f8f96dec000-7f8f96feb000 ---p 00106000 08:21 917533                     /lib64/libm-2.19.so
7f8f96feb000-7f8f96fec000 r--p 00105000 08:21 917533                     /lib64/libm-2.19.so
7f8f96fec000-7f8f96fed000 rw-p 00106000 08:21 917533                     /lib64/libm-2.19.so
7f8f96fed000-7f8f970d9000 r-xp 00000000 08:21 917719                     /lib64/libstdc++.so.6.0.20
7f8f970d9000-7f8f972d9000 ---p 000ec000 08:21 917719                     /lib64/libstdc++.so.6.0.20
7f8f972d9000-7f8f972e1000 r--p 000ec000 08:21 917719                     /lib64/libstdc++.so.6.0.20
7f8f972e1000-7f8f972e3000 rw-p 000f4000 08:21 917719                     /lib64/libstdc++.so.6.0.20
7f8f972e3000-7f8f972f8000 rw-p 00000000 00:00 0
7f8f972f8000-7f8f97f0f000 r-xp 00000000 08:21 939466                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/server/libjvm.so
7f8f97f0f000-7f8f9810f000 ---p 00c17000 08:21 939466                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/server/libjvm.so
7f8f9810f000-7f8f981b2000 r--p 00c17000 08:21 939466                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/server/libjvm.so
7f8f981b2000-7f8f981db000 rw-p 00cba000 08:21 939466                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/server/libjvm.so
7f8f981db000-7f8f9820a000 rw-p 00000000 00:00 0
7f8f9820a000-7f8f983c5000 r-xp 00000000 08:21 917514                     /lib64/libc-2.19.so
7f8f983c5000-7f8f985c4000 ---p 001bb000 08:21 917514                     /lib64/libc-2.19.so
7f8f985c4000-7f8f985c8000 r--p 001ba000 08:21 917514                     /lib64/libc-2.19.so
7f8f985c8000-7f8f985ca000 rw-p 001be000 08:21 917514                     /lib64/libc-2.19.so
7f8f985ca000-7f8f985ce000 rw-p 00000000 00:00 0
7f8f985ce000-7f8f985d1000 r-xp 00000000 08:21 917526                     /lib64/libdl-2.19.so
7f8f985d1000-7f8f987d0000 ---p 00003000 08:21 917526                     /lib64/libdl-2.19.so
7f8f987d0000-7f8f987d1000 r--p 00002000 08:21 917526                     /lib64/libdl-2.19.so
7f8f987d1000-7f8f987d2000 rw-p 00003000 08:21 917526                     /lib64/libdl-2.19.so
7f8f987d2000-7f8f987df000 r-xp 00000000 08:21 939462                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/jli/libjli.so
7f8f987df000-7f8f989de000 ---p 0000d000 08:21 939462                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/jli/libjli.so
7f8f989de000-7f8f989df000 r--p 0000c000 08:21 939462                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/jli/libjli.so
7f8f989df000-7f8f989e0000 rw-p 0000d000 08:21 939462                     /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.60.x86_64/jre/lib/amd64/jli/libjli.so
7f8f989e0000-7f8f989fa000 r-xp 00000000 08:21 917735                     /lib64/libz.so.1.2.8
7f8f989fa000-7f8f98bf9000 ---p 0001a000 08:21 917735                     /lib64/libz.so.1.2.8
7f8f98bf9000-7f8f98bfa000 r--p 00019000 08:21 917735                     /lib64/libz.so.1.2.8
7f8f98bfa000-7f8f98bfb000 rw-p 0001a000 08:21 917735                     /lib64/libz.so.1.2.8
7f8f98bfb000-7f8f98c13000 r-xp 00000000 08:21 917566                     /lib64/libpthread-2.19.so
7f8f98c13000-7f8f98e12000 ---p 00018000 08:21 917566                     /lib64/libpthread-2.19.so
7f8f98e12000-7f8f98e13000 r--p 00017000 08:21 917566                     /lib64/libpthread-2.19.so
7f8f98e13000-7f8f98e14000 rw-p 00018000 08:21 917566                     /lib64/libpthread-2.19.so
7f8f98e14000-7f8f98e18000 rw-p 00000000 00:00 0
7f8f98e18000-7f8f98e39000 r-xp 00000000 08:21 945566                     /lib64/ld-2.19.so
7f8f98e39000-7f8f98e3a000 rw-s 129587000 00:06 1552                      /dev/dri/card0
7f8f98e3a000-7f8f98e3c000 r--s 0004b000 08:21 543784                     /usr/share/java/vecmath.jar
7f8f98e3c000-7f8f98e3d000 r--s 00001000 08:21 543792                     /usr/share/java/SweetHome3D/jnlp.jar
7f8f98e3d000-7f8f98e3f000 r--s 00077000 08:21 543789                     /usr/share/java/SweetHome3D/Textures.jar
7f8f98e3f000-7f8f98f0b000 rw-p 00000000 00:00 0
7f8f98f0b000-7f8f98f0e000 ---p 00000000 00:00 0
7f8f98f0e000-7f8f99011000 rw-p 00000000 00:00 0                          [stack:11075]
7f8f99011000-7f8f9901f000 r--s 000e1000 08:21 543791                     /usr/share/java/SweetHome3D/jmf.jar
7f8f9901f000-7f8f99026000 r--s 00349000 08:21 535903                     /usr/share/java/SweetHome3D/Furniture.jar
7f8f99026000-7f8f9902d000 r--s 0006d000 08:21 543790                     /usr/share/java/SweetHome3D/freehep-vectorgraphics-svg-2.1.1b.jar
7f8f9902d000-7f8f99035000 rw-s 00000000 00:22 80718                      /tmp/hsperfdata_root/11017
7f8f99035000-7f8f99036000 rw-p 00000000 00:00 0
7f8f99036000-7f8f99037000 r--p 00000000 00:00 0
7f8f99037000-7f8f99038000 rw-p 00000000 00:00 0
7f8f99038000-7f8f99039000 r--p 00020000 08:21 945566                     /lib64/ld-2.19.so
7f8f99039000-7f8f9903a000 rw-p 00021000 08:21 945566                     /lib64/ld-2.19.so
7f8f9903a000-7f8f9903b000 rw-p 00000000 00:00 0
7ffc356c0000-7ffc356e2000 rw-p 00000000 00:00 0                          [stack]
7ffc35708000-7ffc3570a000 r--p 00000000 00:00 0                          [vvar]
7ffc3570a000-7ffc3570c000 r-xp 00000000 00:00 0                          [vdso]
ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0                  [vsyscall]
VM Arguments:
jvm_args: -Djava.library.path=/usr/lib64:/usr/lib
java_command: com.eteks.sweethome3d.SweetHome3D
java_class_path (initial): /usr/share/java/SweetHome3D/freehep-vectorgraphics-svg-2.1.1b.jar:/usr/share/java/SweetHome3D/SweetHome3D-5.2.jar:/usr/share/java/SweetHome3D/Furniture.jar:/usr/share/java/SweetHome3D/jmf.jar:/usr/share/java/SweetHome3D/Textures.jar:/usr/share/java/SweetHome3D/jnlp.jar:/usr/share/java/SweetHome3D/Help.jar:/usr/share/java/batik-all.jar:/usr/share/java/java3d/j3dcore-1.5.2.jar:/usr/share/java/java3d/j3dutils-1.5.2.jar:/usr/share/java/sunflow.jar:/usr/share/java/itext.jar:/usr/share/java/vecmath.jar:/usr/share/java-1.8.0/../icedtea-web/netx.jar:
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=/sbin:/usr/sbin:/bin:/usr/bin:/usr/X11R6/bin:/usr/local/bin:/usr/local/sbin:/usr/lib/qt4/bin
USERNAME=root
SHELL=/bin/bash
DISPLAY=:0
Signal Handlers:
SIGSEGV: [libjvm.so+0xa1a2e0], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
SIGBUS: [libjvm.so+0xa1a2e0], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
SIGFPE: [libjvm.so+0x8783b0], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
SIGPIPE: [libjvm.so+0x8783b0], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
SIGXFSZ: [libjvm.so+0x8783b0], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
SIGILL: [libjvm.so+0x8783b0], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
SIGUSR1: SIG_DFL, sa_mask[0]=00000000000000000000000000000000, sa_flags=none
SIGUSR2: [libjvm.so+0x878280], sa_mask[0]=00000000000000000000000000000000, sa_flags=SA_RESTART|SA_SIGINFO
SIGHUP: [libjvm.so+0x878470], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
SIGINT: [libjvm.so+0x878470], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
SIGTERM: [libjvm.so+0x878470], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
SIGQUIT: [libjvm.so+0x878470], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
---------------  S Y S T E M  ---------------
OS:ROSA Desktop Fresh R7 release 2014.1 for x86_64
uname:Linux 4.4.4-nrj-desktop-1rosa-x86_64 #1 SMP PREEMPT Fri Mar 4 20:22:51 UTC 2016 x86_64
libc:glibc 2.19 NPTL 2.19
rlimit: STACK 8192k, CORE 0k, NPROC 31669, NOFILE 4096, AS infinity
load average:0,85 1,24 0,83
/proc/meminfo:
MemTotal:        8188972 kB
MemFree:         6575476 kB
MemAvailable:    7454680 kB
Buffers:           62652 kB
Cached:           811096 kB
SwapCached:            0 kB
Active:           920636 kB
Inactive:         454920 kB
Active(anon):     502964 kB
Inactive(anon):     4104 kB
Active(file):     417672 kB
Inactive(file):   450816 kB
Unevictable:           0 kB
Mlocked:               0 kB
SwapTotal:       4094972 kB
SwapFree:        4094972 kB
Dirty:               120 kB
Writeback:             0 kB
AnonPages:        501848 kB
Mapped:           228808 kB
Shmem:              5268 kB
Slab:              83176 kB
SReclaimable:      53328 kB
SUnreclaim:        29848 kB
KernelStack:        4752 kB
PageTables:        23180 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:     8189456 kB
Committed_AS:    1565116 kB
VmallocTotal:   34359738367 kB
VmallocUsed:           0 kB
VmallocChunk:          0 kB
HardwareCorrupted:     0 kB
AnonHugePages:         0 kB
CmaTotal:              0 kB
CmaFree:               0 kB
HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
Hugepagesize:       2048 kB
DirectMap4k:      224928 kB
DirectMap2M:     8110080 kB
CPU:total 4 (4 cores per cpu, 1 threads per core) family 6 model 58 stepping 9, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, avx, aes, clmul, erms, tsc, tscinvbit, tscinv
/proc/cpuinfo:
processor	: 0
vendor_id	: GenuineIntel
cpu family	: 6
model		: 58
model name	: Intel(R) Core(TM) i5-3470 CPU @ 3.20GHz
stepping	: 9
microcode	: 0x17
cpu MHz		: 3425.250
cache size	: 6144 KB
physical id	: 0
siblings	: 4
core id		: 0
cpu cores	: 4
apicid		: 0
initial apicid	: 0
fpu		: yes
fpu_exception	: yes
cpuid level	: 13
wp		: yes
flags		: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf eagerfpu pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm ida arat epb pln pts dtherm tpr_shadow vnmi flexpriority ept vpid fsgsbase smep erms xsaveopt
bugs		:
bogomips	: 6591.47
clflush size	: 64
cache_alignment	: 64
address sizes	: 36 bits physical, 48 bits virtual
power management:
processor	: 1
cpu family	: 6
model		: 58
stepping	: 9
microcode	: 0x17
cpu MHz		: 3242.750
physical id	: 0
siblings	: 4
core id		: 1
cpu cores	: 4
apicid		: 2
initial apicid	: 2
fpu		: yes
fpu_exception	: yes
cpuid level	: 13
wp		: yes
bugs		:
bogomips	: 6591.47
clflush size	: 64
power management:
processor	: 2
cpu family	: 6
model		: 58
stepping	: 9
microcode	: 0x17
cpu MHz		: 3375.750
physical id	: 0
siblings	: 4
core id		: 2
cpu cores	: 4
apicid		: 4
initial apicid	: 4
fpu		: yes
fpu_exception	: yes
cpuid level	: 13
wp		: yes
bugs		:
bogomips	: 6591.47
clflush size	: 64
power management:
processor	: 3
cpu family	: 6
model		: 58
stepping	: 9
microcode	: 0x17
cpu MHz		: 3439.875
physical id	: 0
siblings	: 4
core id		: 3
cpu cores	: 4
apicid		: 6
initial apicid	: 6
fpu		: yes
fpu_exception	: yes
cpuid level	: 13
wp		: yes
bugs		:
bogomips	: 6591.47
clflush size	: 64
power management:
Memory: 4k page, physical 8188972k(6575476k free), swap 4094972k(4094972k free)
vm_info: OpenJDK 64-Bit Server VM (25.60-b16) for linux-amd64 JRE (1.8.0_60-b16), built on Aug 24 2015 08:40:16 by "mockbuild" with gcc 4.9.2 20140811 (ROSA)
time: Tue Mar  8 23:40:41 2016
elapsed time: 2 seconds (0d 0h 0m 2s)
