Can't fix RPM database
nitroflow
Operating system: Rosa Fresh 2014.1
Сообщение nitroflow »
Something corrupted rpm database during an update and now I can't fix it.
Here's everything I have tried so far:
root  Darkstar  var  lib  rpm  #  db52_recover -vh /var/lib/rpm
BDB2526 Finding last valid log LSN: file: 166 offset 8814728
BDB1518 Recovery complete at Fri Feb 19 23:57:31 2016
BDB1519 Maximum transaction ID 0 recovery checkpoint [166][8814636]
 root  Darkstar  var  lib  rpm  #  rpm --rebuilddb -vv
D: pool fd:	created size 392 limit -1 flags 0
D: pool ds:	created size 232 limit -1 flags 0
D: pool syck:	created size 40 limit -1 flags 0
D: pool ht:	created size 72 limit -1 flags 0
D: pool mire:	created size 136 limit -1 flags 0
D: pool lua:	created size 64 limit -1 flags 0
D: pool ts:	created size 1200 limit -1 flags 0
D: pool db:	created size 328 limit -1 flags 0
D: pool dbi:	created size 472 limit -1 flags 0
D: rpmdb: cpus 2 physmem 11962Mb
D: opening  db environment /var/lib/rpm/Packages create:thread:lock:log:mpool:txn
D: opening  db index       /var/lib/rpm/Packages create:thread:auto_commit mode=0x2
D: opening  db index       /var/lib/rpm/Name create:thread:auto_commit mode=0x2
D: pool h:	created size 360 limit -1 flags 0
error: db3: header #3266 cannot be loaded -- skipping.
error: db3: header #3606 cannot be loaded -- skipping.
error: db3: header #3607 cannot be loaded -- skipping.
rpm: header.c:1079: headerLoad: Assertion `(rpmint32_t)rdl >= 0' failed.
Aborted (core dumped)
 root  Darkstar  var  lib  rpm  #  rpm -qa 2>&1 | tail -2
drakx-net-1.1-8-rosa2014.1.noarch
 root  Darkstar  var  lib  rpm  #  db52_verify Packages
db52_verify: BDB0540 Page 55: invalid next_pgno 21359
db52_verify: BDB0540 Page 283: invalid next_pgno 20180
db52_verify: BDB0540 Page 301: invalid next_pgno 18880
db52_verify: BDB1057 Page 425: offpage item 119 has bad pgno 19700
db52_verify: BDB1057 Page 425: offpage item 121 has bad pgno 19695
db52_verify: BDB1057 Page 425: offpage item 123 has bad pgno 18794
db52_verify: BDB1057 Page 425: offpage item 127 has bad pgno 19693
db52_verify: BDB1057 Page 425: offpage item 129 has bad pgno 19691
db52_verify: BDB1057 Page 425: offpage item 131 has bad pgno 19689
db52_verify: BDB1057 Page 425: offpage item 141 has bad pgno 19658
db52_verify: BDB1057 Page 425: offpage item 143 has bad pgno 19660
db52_verify: BDB1057 Page 425: offpage item 145 has bad pgno 19662
db52_verify: BDB1057 Page 425: offpage item 147 has bad pgno 19664
db52_verify: BDB1057 Page 425: offpage item 149 has bad pgno 19667
db52_verify: BDB1057 Page 425: offpage item 217 has bad pgno 18907
db52_verify: BDB1045 Page 425: item order check unsafe: skipping
db52_verify: BDB0539 Page 767: invalid prev_pgno 20183
db52_verify: BDB0540 Page 768: invalid next_pgno 20162
db52_verify: BDB0539 Page 769: invalid prev_pgno 21327
db52_verify: BDB1057 Page 775: offpage item 5 has bad pgno 18873
db52_verify: BDB1057 Page 775: offpage item 173 has bad pgno 18779
db52_verify: BDB1057 Page 775: offpage item 265 has bad pgno 18684
db52_verify: BDB1057 Page 775: offpage item 267 has bad pgno 18680
db52_verify: BDB1057 Page 775: offpage item 269 has bad pgno 18678
db52_verify: BDB1057 Page 775: offpage item 271 has bad pgno 18676
db52_verify: BDB1057 Page 775: offpage item 273 has bad pgno 18674
db52_verify: BDB1045 Page 775: item order check unsafe: skipping
db52_verify: BDB0540 Page 790: invalid next_pgno 21362
db52_verify: BDB0539 Page 792: invalid prev_pgno 21364
db52_verify: BDB0540 Page 793: invalid next_pgno 21357
db52_verify: BDB0539 Page 795: invalid prev_pgno 21365
db52_verify: BDB0539 Page 799: invalid prev_pgno 21361
db52_verify: BDB0539 Page 802: invalid prev_pgno 21368
db52_verify: BDB0540 Page 809: invalid next_pgno 21360
db52_verify: BDB0540 Page 811: invalid next_pgno 21366
db52_verify: BDB0540 Page 1082: invalid next_pgno 19586
db52_verify: BDB0539 Page 1083: invalid prev_pgno 19574
db52_verify: BDB0539 Page 1085: invalid prev_pgno 19586
db52_verify: BDB0540 Page 1086: invalid next_pgno 19585
db52_verify: BDB0538 Page 1121: invalid next_pgno 19866
db52_verify: BDB0538 Page 1439: invalid next_pgno 19540
db52_verify: BDB0539 Page 1470: invalid prev_pgno 18872
db52_verify: BDB0540 Page 1559: invalid next_pgno 20130
db52_verify: BDB0540 Page 1563: invalid next_pgno 18778
db52_verify: BDB0538 Page 1749: invalid next_pgno 19864
db52_verify: BDB0540 Page 2257: invalid next_pgno 19724
db52_verify: BDB0538 Page 2643: invalid next_pgno 19899
db52_verify: BDB0540 Page 3303: invalid next_pgno 21358
db52_verify: BDB0539 Page 3306: invalid prev_pgno 20409
db52_verify: BDB0539 Page 3359: invalid prev_pgno 18882
db52_verify: BDB0540 Page 3399: invalid next_pgno 19699
db52_verify: BDB0539 Page 4158: invalid prev_pgno 18685
db52_verify: BDB0539 Page 4198: invalid prev_pgno 21363
db52_verify: BDB0540 Page 4384: invalid next_pgno 20706
db52_verify: BDB0540 Page 4573: invalid next_pgno 20404
db52_verify: BDB0540 Page 4602: invalid next_pgno 20409
db52_verify: BDB0539 Page 4617: invalid prev_pgno 19369
db52_verify: BDB0539 Page 4752: invalid prev_pgno 19710
db52_verify: BDB0540 Page 4779: invalid next_pgno 20186
db52_verify: BDB0540 Page 4826: invalid next_pgno 18890
db52_verify: BDB0538 Page 4981: invalid next_pgno 19900
db52_verify: BDB0540 Page 5119: invalid next_pgno 20119
db52_verify: BDB1057 Page 5144: offpage item 5 has bad pgno 18672
db52_verify: BDB1057 Page 5144: offpage item 7 has bad pgno 18670
db52_verify: BDB1057 Page 5144: offpage item 9 has bad pgno 18668
db52_verify: BDB1057 Page 5144: offpage item 11 has bad pgno 18622
db52_verify: BDB1057 Page 5144: offpage item 33 has bad pgno 18879
db52_verify: BDB1045 Page 5144: item order check unsafe: skipping
db52_verify: BDB0539 Page 5190: invalid prev_pgno 18886
db52_verify: BDB0540 Page 5352: invalid next_pgno 20188
db52_verify: BDB0540 Page 5491: invalid next_pgno 21356
db52_verify: BDB0539 Page 5523: invalid prev_pgno 19698
db52_verify: BDB0539 Page 5860: invalid prev_pgno 19688
db52_verify: BDB0539 Page 5925: invalid prev_pgno 20187
db52_verify: BDB0538 Page 6151: invalid next_pgno 18638
db52_verify: BDB0540 Page 6473: invalid next_pgno 18653
db52_verify: BDB0540 Page 6590: invalid next_pgno 18883
db52_verify: BDB0538 Page 6678: invalid next_pgno 18599
db52_verify: BDB1057 Page 6729: offpage item 67 has bad pgno 21354
db52_verify: BDB1057 Page 6729: offpage item 69 has bad pgno 21352
db52_verify: BDB1057 Page 6729: offpage item 71 has bad pgno 21350
db52_verify: BDB1057 Page 6729: offpage item 145 has bad pgno 19723
db52_verify: BDB1057 Page 6729: offpage item 147 has bad pgno 19721
db52_verify: BDB1057 Page 6729: offpage item 169 has bad pgno 19719
db52_verify: BDB1057 Page 6729: offpage item 171 has bad pgno 19717
db52_verify: BDB1057 Page 6729: offpage item 221 has bad pgno 20070
db52_verify: BDB1057 Page 6729: offpage item 223 has bad pgno 19897
db52_verify: BDB1057 Page 6729: offpage item 241 has bad pgno 18989
db52_verify: BDB1045 Page 6729: item order check unsafe: skipping
db52_verify: BDB0538 Page 6961: invalid next_pgno 19857
db52_verify: BDB0538 Page 6963: invalid next_pgno 19859
db52_verify: BDB0540 Page 7118: invalid next_pgno 20071
db52_verify: BDB0539 Page 7119: invalid prev_pgno 20096
db52_verify: BDB0540 Page 7148: invalid next_pgno 19698
db52_verify: BDB0540 Page 7547: invalid next_pgno 21329
db52_verify: BDB0540 Page 7665: invalid next_pgno 21390
db52_verify: BDB0540 Page 8911: invalid next_pgno 18612
db52_verify: BDB0540 Page 8927: invalid next_pgno 18878
db52_verify: BDB0538 Page 9232: invalid next_pgno 18618
db52_verify: BDB0538 Page 9495: invalid next_pgno 21401
db52_verify: BDB0539 Page 9499: invalid prev_pgno 21405
db52_verify: BDB0540 Page 9501: invalid next_pgno 21380
db52_verify: BDB0539 Page 9502: invalid prev_pgno 21386
db52_verify: BDB0539 Page 9505: invalid prev_pgno 21389
db52_verify: BDB0540 Page 9516: invalid next_pgno 18685
db52_verify: BDB0538 Page 9658: invalid next_pgno 18605
db52_verify: BDB0539 Page 9996: invalid prev_pgno 18781
db52_verify: BDB0540 Page 9996: invalid next_pgno 18795
db52_verify: BDB0540 Page 10097: invalid next_pgno 18625
db52_verify: BDB0538 Page 10283: invalid next_pgno 18652
db52_verify: BDB1057 Page 10809: offpage item 47 has bad pgno 19697
db52_verify: BDB1057 Page 10809: offpage item 125 has bad pgno 21364
db52_verify: BDB1057 Page 10809: offpage item 127 has bad pgno 21387
db52_verify: BDB1057 Page 10809: offpage item 129 has bad pgno 21389
db52_verify: BDB1057 Page 10809: offpage item 145 has bad pgno 19367
db52_verify: BDB1057 Page 10809: offpage item 147 has bad pgno 19369
db52_verify: BDB1057 Page 10809: offpage item 179 has bad pgno 21403
db52_verify: BDB1057 Page 10809: offpage item 181 has bad pgno 21396
db52_verify: BDB1057 Page 10809: offpage item 215 has bad pgno 21404
db52_verify: BDB1045 Page 10809: item order check unsafe: skipping
db52_verify: BDB0538 Page 10855: invalid next_pgno 18601
db52_verify: BDB0538 Page 11343: invalid next_pgno 21126
db52_verify: BDB0538 Page 11360: invalid next_pgno 19657
db52_verify: BDB0539 Page 11727: invalid prev_pgno 19757
db52_verify: BDB0538 Page 11792: invalid next_pgno 18629
db52_verify: BDB0540 Page 11800: invalid next_pgno 19702
db52_verify: BDB0540 Page 12287: invalid next_pgno 20102
db52_verify: BDB0539 Page 12294: invalid prev_pgno 20115
db52_verify: BDB0540 Page 12309: invalid next_pgno 20118
db52_verify: BDB0538 Page 12547: invalid next_pgno 18617
db52_verify: BDB0540 Page 12689: invalid next_pgno 18911
db52_verify: BDB0540 Page 13173: invalid next_pgno 19541
db52_verify: BDB0538 Page 13200: invalid next_pgno 19343
db52_verify: BDB0539 Page 13633: invalid prev_pgno 18908
db52_verify: BDB1057 Page 13647: offpage item 155 has bad pgno 21363
db52_verify: BDB1057 Page 13647: offpage item 185 has bad pgno 20445
db52_verify: BDB1057 Page 13647: offpage item 187 has bad pgno 20442
db52_verify: BDB1057 Page 13647: offpage item 189 has bad pgno 20431
db52_verify: BDB1057 Page 13647: offpage item 249 has bad pgno 19568
db52_verify: BDB1057 Page 13647: offpage item 251 has bad pgno 19572
db52_verify: BDB1045 Page 13647: item order check unsafe: skipping
db52_verify: BDB0538 Page 13698: invalid next_pgno 19654
db52_verify: BDB0538 Page 14041: invalid next_pgno 19643
db52_verify: BDB1057 Page 14114: offpage item 13 has bad pgno 18686
db52_verify: BDB1057 Page 14114: offpage item 17 has bad pgno 18792
db52_verify: BDB1057 Page 14114: offpage item 19 has bad pgno 18790
db52_verify: BDB1057 Page 14114: offpage item 21 has bad pgno 18788
db52_verify: BDB1057 Page 14114: offpage item 23 has bad pgno 18786
db52_verify: BDB1057 Page 14114: offpage item 25 has bad pgno 18829
db52_verify: BDB1057 Page 14114: offpage item 27 has bad pgno 18832
db52_verify: BDB1057 Page 14114: offpage item 29 has bad pgno 18837
db52_verify: BDB1057 Page 14114: offpage item 31 has bad pgno 18839
db52_verify: BDB1057 Page 14114: offpage item 33 has bad pgno 18846
db52_verify: BDB1057 Page 14114: offpage item 35 has bad pgno 18854
db52_verify: BDB1057 Page 14114: offpage item 37 has bad pgno 18864
db52_verify: BDB1057 Page 14114: offpage item 39 has bad pgno 18868
db52_verify: BDB1057 Page 14114: offpage item 41 has bad pgno 18874
db52_verify: BDB1057 Page 14114: offpage item 43 has bad pgno 18904
db52_verify: BDB1057 Page 14114: offpage item 45 has bad pgno 18912
db52_verify: BDB1057 Page 14114: offpage item 47 has bad pgno 18918
db52_verify: BDB1057 Page 14114: offpage item 77 has bad pgno 18926
db52_verify: BDB1057 Page 14114: offpage item 79 has bad pgno 18990
db52_verify: BDB1057 Page 14114: offpage item 81 has bad pgno 18994
db52_verify: BDB1057 Page 14114: offpage item 83 has bad pgno 18996
db52_verify: BDB1045 Page 14114: item order check unsafe: skipping
db52_verify: BDB0539 Page 14308: invalid prev_pgno 20410
db52_verify: BDB0539 Page 14569: invalid prev_pgno 18607
db52_verify: BDB0539 Page 14595: invalid prev_pgno 19760
db52_verify: BDB1057 Page 14595: offpage item 57 has bad pgno 21852
db52_verify: BDB1057 Page 14595: offpage item 141 has bad pgno 18884
db52_verify: BDB1057 Page 14595: offpage item 165 has bad pgno 18611
db52_verify: BDB1057 Page 14595: offpage item 167 has bad pgno 18609
db52_verify: BDB1045 Page 14595: item order check unsafe: skipping
db52_verify: BDB0540 Page 14623: invalid next_pgno 18898
db52_verify: BDB0539 Page 14644: invalid prev_pgno 18892
db52_verify: BDB0540 Page 14645: invalid next_pgno 18893
db52_verify: BDB0540 Page 14648: invalid next_pgno 18891
db52_verify: BDB0539 Page 14649: invalid prev_pgno 18903
db52_verify: BDB0538 Page 14828: invalid next_pgno 21136
db52_verify: BDB0538 Page 14831: invalid next_pgno 21137
db52_verify: BDB0539 Page 15063: invalid prev_pgno 19567
db52_verify: BDB0538 Page 15347: invalid next_pgno 20068
db52_verify: BDB0540 Page 15443: invalid next_pgno 21402
db52_verify: BDB0539 Page 15450: invalid prev_pgno 21358
db52_verify: BDB0539 Page 15462: invalid prev_pgno 21380
db52_verify: BDB0538 Page 15630: invalid next_pgno 19642
db52_verify: BDB0538 Page 15697: invalid next_pgno 21399
db52_verify: BDB0539 Page 15749: invalid prev_pgno 19697
db52_verify: BDB0540 Page 16402: invalid next_pgno 18923
db52_verify: BDB0539 Page 16448: invalid prev_pgno 20179
db52_verify: BDB0540 Page 16551: invalid next_pgno 20478
db52_verify: BDB1057 Page 16852: offpage item 51 has bad pgno 19711
db52_verify: BDB1057 Page 16852: offpage item 53 has bad pgno 19713
db52_verify: BDB1057 Page 16852: offpage item 133 has bad pgno 19754
db52_verify: BDB1057 Page 16852: offpage item 137 has bad pgno 20408
db52_verify: BDB1057 Page 16852: offpage item 139 has bad pgno 20406
db52_verify: BDB1057 Page 16852: offpage item 143 has bad pgno 20379
db52_verify: BDB1057 Page 16852: offpage item 145 has bad pgno 19346
db52_verify: BDB1057 Page 16852: offpage item 147 has bad pgno 19354
db52_verify: BDB1057 Page 16852: offpage item 149 has bad pgno 19728
db52_verify: BDB1057 Page 16852: offpage item 151 has bad pgno 19726
db52_verify: BDB1045 Page 16852: item order check unsafe: skipping
db52_verify: BDB0538 Page 16876: invalid next_pgno 19892
db52_verify: BDB0538 Page 16905: invalid next_pgno 20161
db52_verify: BDB0539 Page 17050: invalid prev_pgno 18877
db52_verify: BDB0539 Page 17060: invalid prev_pgno 18883
db52_verify: BDB0539 Page 17062: invalid prev_pgno 18879
db52_verify: BDB0538 Page 17369: invalid next_pgno 18650
db52_verify: BDB0540 Page 17386: invalid next_pgno 21381
db52_verify: BDB0538 Page 17399: invalid next_pgno 20358
db52_verify: BDB0538 Page 17410: invalid next_pgno 18499
db52_verify: BDB0540 Page 17438: invalid next_pgno 21345
db52_verify: BDB0540 Page 17554: invalid next_pgno 19760
db52_verify: BDB1057 Page 17554: offpage item 3 has bad pgno 18623
db52_verify: BDB1057 Page 17554: offpage item 5 has bad pgno 18615
db52_verify: BDB1057 Page 17554: offpage item 51 has bad pgno 18613
db52_verify: BDB1045 Page 17554: item order check unsafe: skipping
db52_verify: BDB0540 Page 17576: invalid next_pgno 21343
db52_verify: BDB1057 Page 17889: offpage item 173 has bad pgno 20114
db52_verify: BDB1057 Page 17889: offpage item 175 has bad pgno 20107
db52_verify: BDB1057 Page 17889: offpage item 183 has bad pgno 20101
db52_verify: BDB1057 Page 17889: offpage item 185 has bad pgno 20098
db52_verify: BDB1045 Page 17889: item order check unsafe: skipping
db52_verify: Packages: BDB0090 DB_VERIFY_BAD: Database verification failed
BDB5105 Verification of Packages failed.
Intel G3420 i7 4790K / 2032 GB RAM / GeForce GTX 750 ti / Rosa 2014.1 Rosa 2016.1 x64
Вернуться в «ROSA Fresh R4-R7 (2014.1)»
