KDE 5
KDE 5
Witam. Używa ktoś KDE5 na Rosa 6. Jak to działa?
Re: KDE 5
Works good.
See this disk image https://abf.rosalinux.ru/platforms/rosa ... ists/13579
Re: KDE 5
Possible update from KDE4/R6 or fresh install?
Re: KDE 5
Possible update.mariuszp писал(а):Possible update from KDE4/R6 or fresh install?
Press Ctrl+Alt+F2 and there Login.
urpmi task-plasma5 --no-installКод: Выделить всё
urpme -a task-kde4Код: Выделить всё
urpmi task-plasma5after
systemctl enable sddmКод: Выделить всё
rebootRe: KDE 5
Thanks. Works fine, looks better then KDE4.
Re: KDE 5
Here are some additional packages for plasma5.
http://abf-downloads.rosalinux.ru/victo ... osa2014.1/
There are plasma5-kdeconnect, plasma5-knemo and additional wallpapers.
There are http://abf-downloads.rosalinux.ru/victo ... n/release/
plasma5-skype for Rosa-plasma5 x86_64 and display an icon in the system tray skype.
Re: KDE 5
Rpmdrake dont work in GUI mode. I added your repo, update and now it is working.
Big thx.
Big thx.
