# fdisk -l
Disk /dev/sdd: 1000.2 GB, 1000170586112 bytes, 1953458176 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x043df545
Устр-во Загр Начало Конец Блоки Id Система
/dev/sdd1 2048 1953458175 976728064 7 HPFS/NTFS/exFAT
$ lsusb
Protocol spec without prior Class and Subclass spec at line 17403
Bus 002 Device 003: ID 1058:1078 Western Digital Technologies, Inc.
$ dmesg
[ 506.644046] usb 2-2: new high-speed USB device number 3 using xhci_hcd
[ 506.765958] usb-storage 2-2:1.0: USB Mass Storage device detected
[ 506.766068] scsi7 : usb-storage 2-2:1.0
[ 507.767805] scsi 7:0:0:0: Direct-Access WD Elements 1078 1065 PQ: 0 ANSI: 6
[ 507.769685] sd 7:0:0:0: [sdd] Spinning up disk...
[ 508.769835] .....ready
[ 512.779849] sd 7:0:0:0: [sdd] 1953458176 512-byte logical blocks: (1.00 TB/931 GiB)
[ 512.780662] sd 7:0:0:0: [sdd] Write Protect is off
[ 512.780664] sd 7:0:0:0: [sdd] Mode Sense: 53 00 10 08
[ 512.781572] sd 7:0:0:0: [sdd] No Caching mode page found
[ 512.781575] sd 7:0:0:0: [sdd] Assuming drive cache: write through
[ 512.783587] sd 7:0:0:0: [sdd] No Caching mode page found
[ 512.783590] sd 7:0:0:0: [sdd] Assuming drive cache: write through
[ 512.946900] sdd: sdd1
[ 512.948958] sd 7:0:0:0: [sdd] No Caching mode page found
[ 512.948961] sd 7:0:0:0: [sdd] Assuming drive cache: write through
[ 512.948964] sd 7:0:0:0: [sdd] Attached SCSI disk
[ 543.664037] usb 2-2: reset high-speed USB device number 3 using xhci_hcd
[ 543.664149] xhci_hcd 0000:02:00.0: Setup ERROR: setup context command for slot 1.
[ 543.765977] usb 2-2: reset high-speed USB device number 3 using xhci_hcd
[ 543.766087] xhci_hcd 0000:02:00.0: Setup ERROR: setup context command for slot 1.
[ 543.867928] usb 2-2: reset high-speed USB device number 3 using xhci_hcd
[ 543.884334] xhci_hcd 0000:02:00.0: xHCI xhci_drop_endpoint called with disabled ep ffff8800a2d5d880
[ 543.884342] xhci_hcd 0000:02:00.0: xHCI xhci_drop_endpoint called with disabled ep ffff8800a2d5d8c0
[ 762.559852] usb 2-2: reset high-speed USB device number 3 using xhci_hcd
[ 762.559895] xhci_hcd 0000:02:00.0: Setup ERROR: setup context command for slot 1.
[ 762.661847] usb 2-2: reset high-speed USB device number 3 using xhci_hcd
[ 762.661866] xhci_hcd 0000:02:00.0: Setup ERROR: setup context command for slot 1.
[ 762.763823] usb 2-2: reset high-speed USB device number 3 using xhci_hcd
[ 762.780138] xhci_hcd 0000:02:00.0: xHCI xhci_drop_endpoint called with disabled ep ffff8800a2d5d880
[ 762.780141] xhci_hcd 0000:02:00.0: xHCI xhci_drop_endpoint called with disabled ep ffff8800a2d5d8c0
[ 795.566926] usb 2-2: reset high-speed USB device number 3 using xhci_hcd
[ 795.566947] xhci_hcd 0000:02:00.0: Setup ERROR: setup context command for slot 1.
[ 795.668898] usb 2-2: reset high-speed USB device number 3 using xhci_hcd
[ 795.668934] xhci_hcd 0000:02:00.0: Setup ERROR: setup context command for slot 1.
[ 795.770834] usb 2-2: reset high-speed USB device number 3 using xhci_hcd
[ 795.787138] xhci_hcd 0000:02:00.0: xHCI xhci_drop_endpoint called with disabled ep ffff8800a2d5d880
[ 795.787141] xhci_hcd 0000:02:00.0: xHCI xhci_drop_endpoint called with disabled ep ffff8800a2d5d8c0
[ 826.527151] usb 2-2: reset high-speed USB device number 3 using xhci_hcd
[ 826.527271] xhci_hcd 0000:02:00.0: Setup ERROR: setup context command for slot 1.
[ 826.629006] usb 2-2: reset high-speed USB device number 3 using xhci_hcd
[ 826.629045] xhci_hcd 0000:02:00.0: Setup ERROR: setup context command for slot 1.
[ 826.730969] usb 2-2: reset high-speed USB device number 3 using xhci_hcd
[ 826.747255] xhci_hcd 0000:02:00.0: xHCI xhci_drop_endpoint called with disabled ep ffff8800a2d5d880
[ 826.747258] xhci_hcd 0000:02:00.0: xHCI xhci_drop_endpoint called with disabled ep ffff8800a2d5d8c0
# udevadm monnitor
KERNEL[1291.727097] add /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2 (usb)
KERNEL[1291.727313] add /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0 (usb)
KERNEL[1291.727435] add /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0/host8 (scsi)
KERNEL[1291.727463] add /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0/host8/scsi_host/host8 (scsi_host)
UDEV [1291.742763] add /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2 (usb)
UDEV [1291.743601] add /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0 (usb)
UDEV [1291.744303] add /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0/host8 (scsi)
UDEV [1291.744659] add /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0/host8/scsi_host/host8 (scsi_host)
KERNEL[1292.730550] add /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0/host8/target8:0:0 (scsi)
KERNEL[1292.730572] add /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0/host8/target8:0:0/8:0:0:0 (scsi)
KERNEL[1292.730582] add /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0/host8/target8:0:0/8:0:0:0/scsi_disk/8:0:0:0 (scsi_disk)
KERNEL[1292.730591] add /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0/host8/target8:0:0/8:0:0:0/scsi_device/8:0:0:0 (scsi_device)
KERNEL[1292.730640] add /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0/host8/target8:0:0/8:0:0:0/bsg/8:0:0:0 (bsg)
UDEV [1292.730990] add /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0/host8/target8:0:0 (scsi)
UDEV [1292.731413] add /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0/host8/target8:0:0/8:0:0:0 (scsi)
UDEV [1292.732016] add /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0/host8/target8:0:0/8:0:0:0/scsi_disk/8:0:0:0 (scsi_disk)
UDEV [1292.732714] add /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0/host8/target8:0:0/8:0:0:0/scsi_device/8:0:0:0 (scsi_device)
UDEV [1292.732926] add /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0/host8/target8:0:0/8:0:0:0/bsg/8:0:0:0 (bsg)
KERNEL[1297.747851] add /devices/virtual/bdi/8:48 (bdi)
UDEV [1297.748389] add /devices/virtual/bdi/8:48 (bdi)
KERNEL[1297.909713] add /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0/host8/target8:0:0/8:0:0:0/block/sdd (block)
KERNEL[1297.909731] add /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0/host8/target8:0:0/8:0:0:0/block/sdd/sdd1 (block)
UDEV [1298.013803] add /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0/host8/target8:0:0/8:0:0:0/block/sdd (block)
KERNEL[1387.387340] remove /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0/host8/target8:0:0/8:0:0:0/bsg/8:0:0:0 (bsg)
KERNEL[1387.387384] remove /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0/host8/target8:0:0/8:0:0:0/scsi_device/8:0:0:0 (scsi_device)
KERNEL[1387.387441] remove /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0/host8/target8:0:0/8:0:0:0/scsi_disk/8:0:0:0 (scsi_disk)
KERNEL[1387.387528] remove /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0/host8/target8:0:0/8:0:0:0/block/sdd/sdd1 (block)
KERNEL[1387.387618] remove /devices/virtual/bdi/8:48 (bdi)
KERNEL[1387.387680] remove /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0/host8/target8:0:0/8:0:0:0/block/sdd (block)
KERNEL[1387.387696] remove /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0/host8/target8:0:0/8:0:0:0 (scsi)
KERNEL[1387.387739] remove /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0/host8/target8:0:0 (scsi)
KERNEL[1387.387757] remove /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0/host8/scsi_host/host8 (scsi_host)
KERNEL[1387.387766] remove /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0/host8 (scsi)
KERNEL[1387.387840] remove /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0 (usb)
KERNEL[1387.387948] remove /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2 (usb)
UDEV [1387.388382] remove /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0/host8/target8:0:0/8:0:0:0/scsi_device/8:0:0:0 (scsi_device)
UDEV [1387.388393] remove /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0/host8/target8:0:0/8:0:0:0/bsg/8:0:0:0 (bsg)
UDEV [1387.388769] remove /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0/host8/target8:0:0/8:0:0:0/scsi_disk/8:0:0:0 (scsi_disk)
UDEV [1387.388891] remove /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0/host8/scsi_host/host8 (scsi_host)
UDEV [1387.389134] remove /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0/host8/target8:0:0/8:0:0:0/block/sdd/sdd1 (block)
UDEV [1387.389420] remove /devices/virtual/bdi/8:48 (bdi)
UDEV [1387.389534] remove /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0/host8/target8:0:0/8:0:0:0/block/sdd (block)
UDEV [1387.389691] remove /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0/host8/target8:0:0/8:0:0:0 (scsi)
UDEV [1387.389838] remove /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0/host8/target8:0:0 (scsi)
UDEV [1387.389980] remove /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0/host8 (scsi)
UDEV [1387.390347] remove /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2/1-2:1.0 (usb)
UDEV [1387.397214] remove /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb1/1-2 (usb)
# control | grep mount
fusermount fuseonly (public fuseonly wheelonly restricted)
mount public (public wheelonly unprivileged restricted)
nfsmount restricted (public wheelonly restricted)
pmount restricted (public xgrp restricted)
grep: /etc/openssh/sshd_config: Нет такого файла или каталога
И вот самое интересное
$ ls -l /dev/sdd1
brw------- 1 root root 8, 49 фев 19 20:30 /dev/sdd1
