update problems
qap
Operating system: ROSA R5, Netrunner 14
update problems
Сообщение qap »
There was a problem during the installation:
lib64udev1 = 219-1.20150505.16:2014.1 is needed by lib64udev-devel-219-1.20150505.16.x86_64
lib64systemd-id1280-devel = 219-1.20150505.16:2014.1 is needed by lib64systemd-journal0-devel-219-1.20150505.16.x86_64
lib64udev1 = 219-1.20150505.16:2014.1 is needed by systemd-219-1.20150505.16.x86_64
lib64udev1 = 219-1.20150505.16:2014.1 is needed by lib64gudev1.0_0-219-1.20150505.16.x86_64
lib64systemd0 = 219-1.20150505.14:2014.1 is needed by (installed) lib64systemd-id1280-devel-219-1.20150505.14.x86_64
lib64systemd-id1280 = 219-1.20150505.14:2014.1 is needed by (installed) lib64systemd-id1280-devel-219-1.20150505.14.x86_64
lib64udev1 = 219-1.20150505.14:2014.1 is needed by (installed) lib64gudev1.0_0-219-1.20150505.14.x86_64
lib64udev1 = 219-1.20150505.14:2014.1 is needed by (installed) lib64udev-devel-219-1.20150505.14.x86_64
lib64udev1 = 219-1.20150505.14:2014.1 is needed by (installed) systemd-219-1.20150505.14.x86_64
lib64systemd-id1280 = 219-1.20150505.16:2014.1 is needed by lib64systemd-id1280-devel-219-1.20150505.16.x86_64
lib64systemd0 = 219-1.20150505.16:2014.1 is needed by lib64systemd-id1280-devel-219-1.20150505.16.x86_64
lib64systemd-id1280-devel = 219-1.20150505.14:2014.1 is needed by (installed) lib64systemd-journal0-devel-219-1.20150505.14.x86_64
Mayavimmer
Operating system: Rosa Fresh 2012.1 64bit
Re: update problems
Сообщение Mayavimmer »
I also had similar problems yesterday with udev/systemd. Today I rebooted with a previous kernel, which completed the boot without problems, then updated the system, and rebooted with the normal kernel. No further problems -- it sorted itself out.
qap
Re: update problems
Сообщение qap »
Thank You!
Problem solved.
Вернуться в «ROSA Fresh R4-R7 (2014.1)»
