Issues with ROSA R6
prabhuchelladurai
Operating system: ubuntu 14.04
Issues with ROSA R6
Сообщение prabhuchelladurai »
I have installed ROSA Desktop Fresh R5 in my laptop. First time it smoothly loads and when I shut down and restart again, it is not working properly. It asks for login details and when I give the login details, it gives an error message ' Module is Unknown'.
I got fed up with too many installations and some how managed to upgrade to R6.
Now, the same problem rises but with some progress..
The graphical user interface is not invoked. It asks for login. When the details are given, it logs in and ends up with the command terminal.
When startx command is given in the terminal, there is another error, which says 'couldn't find charset data for locale en_US; using ISO 8859-1'
I am terribly upset with ROSA.
Could you please help me get out of this problems..?
Also, when installing, I selected 'shell', disabled UUID. How can i reset these? or is it ok if it is left as it is?
I am getting command line as some thing starting with 'sh 3.14 $' instead of the computer name..
Please help me find solutions to these issues...
Thanks...
Re: Issues with ROSA R6
Please provide your laptop specs and possibly the 'lspci' and 'lsusb' outputs from the root console.
euspectre
Issues with ROSA R6
Сообщение euspectre »
prabhuchelladurai писал(а):Could you please help me get out of this problems..?
First of all, we need more info about the hardware and the system. If the system boots in text mode at least and the network is available, please use hw-probe as described here https://linux-hardware.org/?show=check to upload these data to us.
If possible, I would recommend reinstalling ROSA R6, without touching that UUID option and such. Otherwise, well, it will depend on what is in the data hw-probe collects. It is difficult to recommend anything without that diagnostics.
prabhuchelladurai
Hi,
Thanks for the quick reply and kindness...
I have added the lspci and lsusb output here under. I will try with hw-probe also and add that as soon as possible.
Thank you very much.
lspci:
00:00.0 Host bridge: Intel Corporation Haswell-ULT DRAM Controller (rev 0b)
00:02.0 VGA compatible controller: Intel Corporation Haswell-ULT Integrated Graphics Controller (rev 0b)
00:03.0 Audio device: Intel Corporation Haswell-ULT HD Audio Controller (rev 0b)
00:14.0 USB controller: Intel Corporation Lynx Point-LP USB xHCI HC (rev 04)
00:16.0 Communication controller: Intel Corporation Lynx Point-LP HECI #0 (rev 04)
00:1b.0 Audio device: Intel Corporation Lynx Point-LP HD Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation Lynx Point-LP PCI Express Root Port 4 (rev e4)
00:1c.1 PCI bridge: Intel Corporation Lynx Point-LP PCI Express Root Port 3 (rev e4)
00:1d.0 USB controller: Intel Corporation Lynx Point-LP USB EHCI #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation Lynx Point-LP LPC Controller (rev 04)
00:1f.2 SATA controller: Intel Corporation Lynx Point-LP SATA Controller 1 [AHCI mode] (rev 04)
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 10)
02:00.0 Network controller: Intel Corporation Wireless 3160 (rev cb)
lsusb:
Bus 001 Device 002: ID 8087:8000 Intel Corp.
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 046: ID 8087:07dc Intel Corp.
Bus 002 Device 007: ID 12d1:1436 Huawei Technologies Co., Ltd. E173 3G Modem (modem-mode)
Bus 002 Device 004: ID 04f2:b446 Chicony Electronics Co., Ltd
Bus 002 Device 003: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
Bus 002 Device 002: ID 054c:05ba Sony Corp.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Вернуться в «ROSA Fresh R4-R7 (2014.1)»
