Игра Unvanquished не стартует
выдает следующее:
tty console mode disabled
Unvanquished 0.28.0 Linux x86_64 Sep  8 2014
+set fs_libpath /usr/lib64/unvanquished +set fs_basepath /usr/share/unvanquished ""
Home path: /home/delta/.unvanquished
Pak path: /usr/share/unvanquished/pkg
Pak path: /home/delta/.unvanquished/pkg
Loading pak '/usr/share/unvanquished/pkg/unvanquished_0.28.0.pk3'...
^3Warn: Could not find pak 'unvanquished' with version '0.27.0' required by '/usr/share/unvanquished/pkg/unvanquished_0.28.0.pk3'
Failed to load pak 'unvanquished': Missing dependency
Could not load base pak 'unvanquished', falling back to default
Loading pak '/usr/share/unvanquished/pkg/map-UTCS_trem.pk3'...
Loading pak '/usr/share/unvanquished/pkg/map-arachnid2_trem.pk3'...
Loading pak '/usr/share/unvanquished/pkg/map-chasm_b1.pk3'...
Loading pak '/usr/share/unvanquished/pkg/map-forlorn_a4.pk3'...
Loading pak '/usr/share/unvanquished/pkg/map-karith_trem.pk3'...
Loading pak '/usr/share/unvanquished/pkg/map-methane-beta1_trem.pk3'...
Loading pak '/usr/share/unvanquished/pkg/map-nano_trem.pk3'...
Loading pak '/usr/share/unvanquished/pkg/map-nexus6_trem.pk3'...
Loading pak '/usr/share/unvanquished/pkg/map-niveus_trem.pk3'...
Loading pak '/usr/share/unvanquished/pkg/map-orion_trem.pk3'...
Loading pak '/usr/share/unvanquished/pkg/map-parpax_d02d.pk3'...
Loading pak '/usr/share/unvanquished/pkg/map-perseus_b4d.pk3'...
Loading pak '/usr/share/unvanquished/pkg/map-plat23_b11+1.pk3'...
Loading pak '/usr/share/unvanquished/pkg/map-plat23_b11.pk3'...
Loading pak '/usr/share/unvanquished/pkg/map-spacetracks-r1_trem.pk3'...
Loading pak '/usr/share/unvanquished/pkg/map-station15-r1_trem.pk3'...
Loading pak '/usr/share/unvanquished/pkg/map-thunder_b3.pk3'...
Loading pak '/usr/share/unvanquished/pkg/map-tremor_trem.pk3'...
Loading pak '/usr/share/unvanquished/pkg/map-yocto_b2a+1.pk3'...
^3Warn: Could not find pak 'map-yocto' with version 'b2a' required by '/usr/share/unvanquished/pkg/map-yocto_b2a+1.pk3'
Failed to load pak 'map-yocto': Missing dependency
Loaded 0 languages
couldn't exec 'default.cfg'
^3Warning: ^7Language "Russian (Russia" (ru_RU) not found. Default to "English" (en)
Set language to English
Couldn't read conhistory.
----- Client Initialization -----
----- Client Initialization Complete -----
Calling GetRefAPI…
SDL_Init( SDL_INIT_VIDEO )...
Using SDL Version 2.0.3
SDL using driver "x11"
Initializing OpenGL display
Display aspect: 1.778
...setting mode -2:
 1920 1080
Using 24 Color bits, 24 depth, 8 stencil display.
Using GLEW 1.10.0
Using enhanced (GL3) Renderer in GL 3.x mode...
Available modes: '1920x1080 800x600 1024x768 1280x960 1600x1200 1280x1024 '
GL_RENDERER: GeForce GT 240/PCIe/SSE2
Detected graphics driver class 'OpenGL 3+'
Detected graphics hardware class 'generic'
Initializing OpenGL extensions
...ignoring GL_ARB_debug_output
...using GL_ARB_fragment_shader
...using GL_ARB_vertex_shader
...using GL_ARB_shading_language_100
...found shading language version 330
...using GL_ARB_depth_texture
...using GL_ARB_texture_cube_map
...using GL_ARB_half_float_pixel
...using GL_ARB_texture_float
...using GL_ARB_texture_rg
...using GL_EXT_packed_depth_stencil
...ignoring GL_ARB_texture_compression
...ignoring GL_EXT_texture_compression_s3tc
...using GL_ARB_texture_non_power_of_two
...using GL_SGIS_generate_mipmap
...using GL_EXT_texture_filter_anisotropic
...using GL_ARB_vertex_buffer_object
...using GL_EXT_framebuffer_object
...using GL_EXT_framebuffer_blit
...using GL_ARB_shader_objects
...using GL_ARB_occlusion_query
...using GL_ARB_draw_buffers
...GL_GREMEDY_string_marker not found
...using GL_ARB_get_program_binary
^8Couldn't load glsl/vertexSkinning_vp.glsl
Calling GetRefAPI…
recursive error 'R_InitImages: could not load 'gfx/2d/consolechars'' after: Couldn't load glsl/vertexSkinning_vp.glsl
Вернуться в «Игры и Steam»
