Sid Maier's Alpha Centauri
BOPOH89
Operating system: Mageia 4.1, ROSA Fresh R4
Сообщение BOPOH89 »
Помогите запустить Sid Maier's Alpha Centauri с этой раздачи http://rutracker-pro.ru/viewtopic.php?t=32197 (она на русском языке).
После запуска только черный экран. Нетбук Acer Aspirr One, ROSA Desktop Fresh R4.
Выхлоп отладчика PlayOnLinux
ELF 7e862000-7e9a9000 Deferred user32<elf>
\-PE 7e880000-7e9a9000 \ user32
ELF 7e9a9000-7ea18000 Deferred shlwapi<elf>
\-PE 7e9c0000-7ea18000 \ shlwapi
ELF 7ea18000-7ec34000 Deferred shell32<elf>
\-PE 7ea30000-7ec34000 \ shell32
ELF 7ef9b000-7efe4000 Deferred libm.so.6
ELF 7efe8000-7f000000 Deferred version<elf>
\-PE 7eff0000-7f000000 \ version
ELF b73f1000-b73f6000 Deferred libdl.so.2
ELF b73f7000-b75c8000 Deferred libc.so.6
ELF b75c8000-b75e4000 Deferred libpthread.so.0
ELF b75e7000-b75f0000 Deferred librt.so.1
ELF b7600000-b77b2000 Dwarf libwine.so.1
ELF b77b3000-b77d7000 Deferred ld-linux.so.2
ELF b77d7000-b77d8000 Deferred [vdso].so
Threads:
process tid prio (all id:s are in hex)
00000008 terran.exe
00000009 0
0000000e services.exe
0000001d 0
0000001c 0
00000014 0
00000010 0
0000000f 0
00000012 winedevice.exe
00000020 0
00000019 0
00000017 0
00000013 0
0000001a plugplay.exe
0000001f 0
0000001e 0
0000001b 0
00000021 explorer.exe
00000023 0
00000022 0
00000024 winedbg.exe
00000025 0
00000026 (D) C:\Program Files\SMAC\terran.exe
00000027 0 <==
Unhandled exception: page fault on write access to 0x000030a4 in 32-bit code (0x005eedfa).
Register dump:
CS:0073 SS:007b DS:007b ES:007b FS:0033 GS:003b
EIP:005eedfa ESP:0033f454 EBP:0033f4c8 EFLAGS:00010216( R- -- I -A-P- )
EAX:00000000 EBX:7b8a4610 ECX:00000000 EDX:0069a5d8
ESI:7ffdf000 EDI:0064dbe0
Stack dump:
0x0033f454: 0064dbe0 7ffdf000 7e58ad50 0033f63c
0x0033f464: 00000000 7e8faa5c 7e58ad50 00000000
0x0033f474: 0033f63c 0033f5d8 7e4c109e 0015a6fc
0x0033f484: 0033f4c0 00000000 00000004 00000000
0x0033f494: 7e540b6d 0033f5d8 7e4c0ae5 00000020
0x0033f4a4: ffffffff 0033f4e4 00000000 001579a8
Backtrace:
=>0 0x005eedfa in terran (+0x1eedfa) (0x0033f4c8)
1 0x005f05c4 in terran (+0x1f05c3) (0x0033f614)
2 0x00626b72 in terran (+0x226b71) (0x0033f660)
3 0x00626834 in terran (+0x226833) (0x0033f68c)
4 0x006267e3 in terran (+0x2267e2) (0x0033f6ac)
5 0x0063dbcb in terran (+0x23dbca) (0x0033f6d0)
6 0x0063cdf0 in terran (+0x23cdef) (0x0033fca4)
7 0x005d268d in terran (+0x1d268c) (0x0033fcbc)
8 0x0063016c in terran (+0x23016b) (0x0033fcd8)
9 0x00466605 in terran (+0x66604) (0x0033fd4c)
10 0x004664e3 in terran (+0x664e2) (0x0033fdd0)
11 0x0064dd06 in terran (+0x24dd05) (0x0033fe60)
12 0x7b86127c call_process_entry+0xb() in kernel32 (0x0033fe78)
13 0x7b864ddb in kernel32 (+0x54dda) (0x0033feb8)
14 0x7bc76a80 call_thread_func_wrapper+0xb() in ntdll (0x0033fed8)
15 0x7bc76cdd call_thread_func+0x7c() in ntdll (0x0033ffa8)
16 0x7bc76a5e RtlRaiseException+0x21() in ntdll (0x0033ffc8)
17 0x7bc4e02e in ntdll (+0x3e02d) (0x0033ffe8)
0x005eedfa: movl %ecx,0x30a4(%eax)
Modules:
Module Address Debug info Name (128 modules)
PE 400000- 9e4000 Export terran
ELF 7b800000-7ba4b000 Dwarf kernel32<elf>
\-PE 7b810000-7ba4b000 \ kernel32
ELF 7bc00000-7bcc8000 Dwarf ntdll<elf>
\-PE 7bc10000-7bcc8000 \ ntdll
ELF 7bf00000-7bf03000 Deferred <wine-loader>
ELF 7c5e9000-7c5f4000 Deferred libpciaccess.so.0
ELF 7c5f4000-7c612000 Deferred libgcc_s.so.1
ELF 7c704000-7c713000 Deferred libdrm_radeon.so.1
ELF 7c713000-7c71b000 Deferred libdrm_nouveau.so.2
ELF 7c71b000-7c740000 Deferred libdrm_intel.so.1
ELF 7c740000-7ccfd000 Deferred i915_dri.so
ELF 7ccfd000-7cd13000 Deferred libudev.so.1
ELF 7cd13000-7cd21000 Deferred libdrm.so.2
ELF 7cd21000-7cd24000 Deferred libxshmfence.so.1
ELF 7cd24000-7cd2b000 Deferred libxcb-sync.so.1
ELF 7cd2b000-7cd2f000 Deferred libxcb-present.so.0
ELF 7cd2f000-7cd33000 Deferred libxcb-dri3.so.0
ELF 7cd33000-7cd39000 Deferred libxcb-dri2.so.0
ELF 7cd39000-7cd52000 Deferred libxcb-glx.so.0
ELF 7cd52000-7cd6b000 Deferred libglapi.so.0
ELF 7cd6b000-7cd94000 Deferred libexpat.so.1
ELF 7cd94000-7ce3b000 Deferred libgl.so.1
ELF 7ce57000-7ce79000 Deferred imm32<elf>
\-PE 7ce60000-7ce79000 \ imm32
ELF 7cefb000-7cf03000 Deferred libffi.so.6
ELF 7cf03000-7cf74000 Deferred libfreebl3.so
ELF 7cf74000-7cfd1000 Deferred libdbus-1.so.3
ELF 7cfd1000-7d047000 Deferred libgmp.so.10
ELF 7d047000-7d070000 Deferred libhogweed.so.2
ELF 7d070000-7d0a5000 Deferred libnettle.so.4
ELF 7d0a5000-7d0bc000 Deferred libtasn1.so.6
ELF 7d0bc000-7d0fc000 Deferred libp11-kit.so.0
ELF 7d0fc000-7d118000 Deferred libresolv.so.2
ELF 7d118000-7d11c000 Deferred libkeyutils.so.1
ELF 7d11c000-7d12a000 Deferred libkrb5support.so.0
ELF 7d12a000-7d173000 Deferred libcrypt.so.1
ELF 7d173000-7d187000 Deferred libavahi-client.so.3
ELF 7d187000-7d196000 Deferred libavahi-common.so.3
ELF 7d196000-7d2ba000 Deferred libgnutls.so.28
ELF 7d2ba000-7d2bf000 Deferred libcom_err.so.2
ELF 7d2bf000-7d2f2000 Deferred libk5crypto.so.3
ELF 7d2f2000-7d3d3000 Deferred libkrb5.so.3
ELF 7d3d3000-7d425000 Deferred libgssapi_krb5.so.2
ELF 7d425000-7d4a1000 Deferred libcups.so.2
ELF 7d4a1000-7d4d4000 Deferred uxtheme<elf>
\-PE 7d4b0000-7d4d4000 \ uxtheme
ELF 7d4d4000-7d4db000 Deferred libxfixes.so.3
ELF 7d4db000-7d4e7000 Deferred libxcursor.so.1
ELF 7d4e7000-7d4fa000 Deferred libxi.so.6
ELF 7d4fa000-7d4fe000 Deferred libxcomposite.so.1
ELF 7d4fe000-7d50a000 Deferred libxrandr.so.2
ELF 7d50a000-7d516000 Deferred libxrender.so.1
ELF 7d516000-7d51d000 Deferred libxxf86vm.so.1
ELF 7d51d000-7d521000 Deferred libxinerama.so.1
ELF 7d521000-7d528000 Deferred libxdmcp.so.6
ELF 7d528000-7d52d000 Deferred libxau.so.6
ELF 7d52d000-7d551000 Deferred libxcb.so.1
ELF 7d551000-7d6a1000 Deferred libx11.so.6
ELF 7d6a1000-7d6b6000 Deferred libxext.so.6
ELF 7d6b7000-7d6ba000 Deferred libx11-xcb.so.1
ELF 7d6ba000-7d6be000 Deferred libxdamage.so.1
ELF 7d6be000-7d6d2000 Deferred gnome-keyring-pkcs11.so
ELF 7d6d2000-7d75c000 Deferred winex11<elf>
\-PE 7d6e0000-7d75c000 \ winex11
ELF 7d8f1000-7d92b000 Deferred liblzma.so.5
ELF 7d92b000-7daaa000 Deferred libxml2.so.2
ELF 7daaa000-7daee000 Deferred libfontconfig.so.1
ELF 7daee000-7db60000 Deferred libpcre.so.1
ELF 7db60000-7db81000 Deferred libgraphite2.so.3
ELF 7db81000-7dca2000 Deferred libglib-2.0.so.0
ELF 7dca2000-7dcfe000 Deferred libharfbuzz.so.0
ELF 7dcfe000-7dd60000 Deferred libpng16.so.16
ELF 7dd60000-7dd72000 Deferred libbz2.so.1
ELF 7dd72000-7dd86000 Deferred libz.so.1
ELF 7dd86000-7de33000 Deferred libfreetype.so.6
ELF 7de4f000-7de62000 Deferred comm.drv16.so
PE 7de50000-7de62000 Deferred comm.drv16
ELF 7de62000-7de76000 Deferred system.drv16.so
PE 7de70000-7de76000 Deferred system.drv16
ELF 7de76000-7df18000 Deferred krnl386.exe16.so
PE 7de90000-7df18000 Deferred krnl386.exe16
ELF 7df18000-7df55000 Deferred dplayx<elf>
\-PE 7df20000-7df55000 \ dplayx
ELF 7df55000-7df92000 Deferred winspool<elf>
\-PE 7df60000-7df92000 \ winspool
ELF 7df92000-7e077000 Deferred comdlg32<elf>
\-PE 7dfa0000-7e077000 \ comdlg32
ELF 7e077000-7e0bc000 Deferred dsound<elf>
\-PE 7e080000-7e0bc000 \ dsound
ELF 7e0bc000-7e0e6000 Deferred msvfw32<elf>
\-PE 7e0c0000-7e0e6000 \ msvfw32
ELF 7e0e6000-7e10e000 Deferred msacm32<elf>
\-PE 7e0f0000-7e10e000 \ msacm32
ELF 7e10e000-7e186000 Deferred rpcrt4<elf>
\-PE 7e120000-7e186000 \ rpcrt4
ELF 7e186000-7e29b000 Deferred ole32<elf>
\-PE 7e1a0000-7e29b000 \ ole32
ELF 7e29b000-7e380000 Deferred opengl32<elf>
\-PE 7e2c0000-7e380000 \ opengl32
ELF 7e3a7000-7e45c000 Deferred winmm<elf>
\-PE 7e3b0000-7e45c000 \ winmm
ELF 7e45c000-7e58f000 Deferred wined3d<elf>
\-PE 7e470000-7e58f000 \ wined3d
ELF 7e58f000-7e5f7000 Deferred ddraw<elf>
\-PE 7e5a0000-7e5f7000 \ ddraw
ELF 7e5f7000-7e6ef000 Deferred comctl32<elf>
\-PE 7e600000-7e6ef000 \ comctl32
ELF 7e6ef000-7e755000 Deferred advapi32<elf>
\-PE 7e700000-7e755000 \ advapi32
ELF 7e755000-7e862000 Deferred gdi32<elf>
\-PE 7e760000-7e862000 \ gdi32
ELF b7341000-b7346000 Deferred libdl.so.2
ELF b7347000-b7518000 Deferred libc.so.6
ELF b7518000-b7534000 Deferred libpthread.so.0
ELF b7537000-b7540000 Deferred librt.so.1
ELF b7550000-b7702000 Dwarf libwine.so.1
ELF b7703000-b7727000 Deferred ld-linux.so.2
ELF b7727000-b7728000 Deferred [vdso].so
Threads:
00000008 (D) C:\Program Files\SMAC\terran.exe
00000009 0 <==
0000001d 0
0000001c 0
00000014 0
00000010 0
0000000f 0
00000020 0
00000019 0
00000017 0
00000013 0
0000001f 0
0000001e 0
0000001b 0
00000023 0
00000022 0
[12/01/14 11:54:48] - Running wine-1.6.2 terran.exe (Working directory : /home/homenet/.PlayOnLinux/wineprefix/AlphaCentauri_gog/drive_c/Program Files/SMAC)
fixme:d3d:check_fbo_compat Format WINED3DFMT_B8G8R8A8_UNORM with rendertarget flag is not supported as FBO color attachment, and no fallback specified.
fixme:d3d:check_fbo_compat Format WINED3DFMT_B8G8R8X8_UNORM with rendertarget flag is not supported as FBO color attachment, and no fallback specified.
fixme:win:EnumDisplayDevicesW ((null),0,0x33ef98,0x00000000), stub!
err:x11settings:X11DRV_ChangeDisplaySettingsEx No matching mode found 1024x768x8 @0! (XRandR 1.2)
wine: Unhandled page fault on write access to 0x000030a4 at address 0x5eedfa (thread 0009), starting debugger...
...skipped 11 line(s)...
Backtrace:
...skipped 112 line(s)...
ELF b739c000-b73a1000 Deferred libdl.so.2
ELF b73a2000-b7573000 Deferred libc.so.6
ELF b7573000-b758f000 Deferred libpthread.so.0
ELF b75a2000-b75ab000 Deferred librt.so.1
ELF b75ab000-b775d000 Dwarf libwine.so.1
ELF b775e000-b7782000 Deferred ld-linux.so.2
ELF b7782000-b7783000 Deferred [vdso].so
Threads:
00000009 0 <==
0000001d 0
0000001c 0
00000014 0
00000010 0
0000000f 0
0000001f 0
00000018 0
00000017 0
00000013 0
00000020 0
0000001e 0
0000001b 0
00000023 0
00000022 0
Вернуться в «Игры и Steam»
