Krandrtray does not rescale desktop
Mayavimmer
Operating system: Rosa Fresh 2012.1 64bit
Сообщение Mayavimmer »
Since the last update Krandrtray only works correctly at the highest (default) resolution, which for me is 1920x1080 -- virtually unusable. If I select any other setting I do get the lower resolution, but the desktop does not rescale as it used to, and therefore I only get to see the upper left portion of the desktop.
I have a continuously updated:
$ cat /etc/rosa-release
ROSA Desktop Fresh R3 release 2012.1 for x86_64
When I run Krandrtray from the console I get these (normal?) messages:
$ krandrtray
QDBusConnection: session D-Bus connection created before QCoreApplication. Application may misbehave.
QGtkStyle cannot be used together with the GTK_Qt engine.
And my new monitor has both VGA and HDMI connected.
How can I lower the screen resolution to a usable level?
