shiloh и утомившее исчезновение трафика через wi-fi интерфейс
l2tp
Operating system: ROSA Desktop Fresh R2 KDE
ROSA Desktop Fresh R2 Gnome
Сообщение l2tp »
Часть первая. Фактологическая
[root@ThinkPad-X200]# lspci | grep Wireless
03:00.0 Network controller: Intel Corporation PRO/Wireless 5100 AGN [Shiloh] Network Connection
[root@ThinkPad-X200]# uname -a
Linux ThinkPad-X200 3.10.34-nrj-desktop-2rosa #1 SMP PREEMPT Tue Apr 1 14:19:33 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
И самое радостное, выдержка из dmesg (у меня там радостей много, включая Call Trace), целиком покажу по желанию:
[ 9680.045515] iwlwifi 0000:03:00.0: Failing on timeout while stopping DMA channel 2 [0x5a5a5a5a]
[ 9680.045515] iwlwifi 0000:03:00.0: Failing on timeout while stopping DMA channel 5 [0x5a5a5a5a]
[ 9680.045515] iwlwifi 0000:03:00.0: Failing on timeout while stopping DMA channel 7 [0x5a5a5a5a]
[ 9686.611007] [sched_delayed] sched: RT throttling activated
[ 9688.507035] iwlwifi 0000:03:00.0: L1 Disabled; Enabling L0S
[ 9688.636573] cfg80211: World regulatory domain updated:
[ 9688.636577] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 9688.636580] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 9688.636581] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 9688.636583] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 9688.636585] cfg80211:   (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 9688.636586] cfg80211:   (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 9688.658579] iwlwifi 0000:03:00.0: Radio type=0x1-0x2-0x0
[ 9694.378112] iwlwifi 0000:03:00.0: Failed to load firmware chunk!
[ 9694.378124] iwlwifi 0000:03:00.0: Could not load the [0] uCode section
[ 9694.378136] iwlwifi 0000:03:00.0: Failed to start RT ucode: -110
[ 9695.053138] iwlwifi 0000:03:00.0: Failing on timeout while stopping DMA channel 0 [0x5a5a5a5a]
[ 9695.053138] iwlwifi 0000:03:00.0: Failing on timeout while stopping DMA channel 2 [0x5a5a5a5a]
[ 9695.053138] iwlwifi 0000:03:00.0: Failing on timeout while stopping DMA channel 5 [0x5a5a5a5a]
[ 9695.053138] iwlwifi 0000:03:00.0: Failing on timeout while stopping DMA channel 7 [0x5a5a5a5a]
[ 9704.020274] iwlwifi 0000:03:00.0: Unable to initialize device.
[ 9775.748254] iwlwifi 0000:03:00.0: L1 Disabled; Enabling L0S
[ 9775.895622] iwlwifi 0000:03:00.0: Radio type=0x1-0x2-0x0
[ 9781.606080] iwlwifi 0000:03:00.0: Failed to load firmware chunk!
[ 9781.606087] iwlwifi 0000:03:00.0: Could not load the [0] uCode section
[ 9781.606094] iwlwifi 0000:03:00.0: Failed to start RT ucode: -110
Часть вторая. Лирическая
Ноутбук включается, цепляется к точке (обычный диапазон или 5ГГц, как хочется) и весело бегают пакетики к роутеру и от роутера. А потом значок скайпа в трее становится сереньким, копете начинает блямкать жалобами на ошибки протокола и ваще все плохо. При формально активном соединении с точкой пакетики не ходят. Можно попробовать перецепиться к другой точке (у нас их две в разных диапазонах), но ничего хорошего не будет. До недавнего времени лекарством было отключить-включить радиомодуль функциональными кнопочками ноута. А потом, видимо, в ядре что-то обновилось и единственным лекарством остается ребут.
Муж говорит, что это сочетание шилоха и неудачной версии модулей в ядре, и у него на заебо сабайоне была та же фигня, пока не пришло очередное обновление, после чего все залетало как положено.
Я, в общем-то, лекарство знаю (патчить ядро или менять wi-fi карточку), посему я просто поговорить и рассказать о граблях тем, кто не знал :)
Откланиваюсь и иду оттаскивать детей подальше от телека с Лунтиком
euspectre
Re: shiloh и утомившее исчезновение трафика через wi-fi интерфейс
Сообщение euspectre »
Что выдают след. команды (под root):
modinfo iwlwifi
ls -la /lib/firmware | grep iwl
lspci -vnn
Да, и раз в выводе dmesg есть какая-то ошибка с call trace, выложите, пожалуйста, весь вывод dmesg, а ещё лучше - 'journalctl -ab' (тоже под root).
l2tp
Сообщение l2tp »
Как просили
# modinfo iwlwifi
filename:       /lib/modules/3.10.34-nrj-desktop-2rosa/kernel/drivers/net/wireless/iwlwifi/iwlwifi.ko.xz
license:        GPL
author:         Copyright(c) 2003-2013 Intel Corporation <ilw@linux.intel.com>
version:        in-tree:d
description:    Intel(R) Wireless WiFi driver for Linux
firmware:       iwlwifi-100-5.ucode
firmware:       iwlwifi-1000-5.ucode
firmware:       iwlwifi-135-6.ucode
firmware:       iwlwifi-105-6.ucode
firmware:       iwlwifi-2030-6.ucode
firmware:       iwlwifi-2000-6.ucode
firmware:       iwlwifi-5150-2.ucode
firmware:       iwlwifi-5000-5.ucode
firmware:       iwlwifi-6000g2b-6.ucode
firmware:       iwlwifi-6000g2a-5.ucode
firmware:       iwlwifi-6050-5.ucode
firmware:       iwlwifi-6000-4.ucode
firmware:       iwlwifi-3160-7.ucode
firmware:       iwlwifi-7260-7.ucode
srcversion:     25837E7985CABDB205623F4
alias:          pci:v00008086d000008B3sv*sd00008570bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008470bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00008270bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008062bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008060bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008172bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008170bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008072bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008070bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00000370bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000472bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000470bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00000272bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00000270bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000062bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000060bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000172bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000170bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000072bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000070bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C420bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C220bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C02Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C020bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C360bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C370bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C560bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C570bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C462bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C460bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C472bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C470bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C262bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C26Abc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C260bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C272bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C270bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C760bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C770bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C162bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C062bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C160bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C06Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C060bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C170bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C072bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C070bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004420bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004220bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000402Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004020bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00005070bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004360bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004370bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004560bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004570bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000486Ebc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004870bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004462bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000446Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004460bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004472bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004470bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004262bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000426Abc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004260bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004272bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004270bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004162bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004062bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004160bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000406Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004060bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004170bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004072bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004070bc*sc*i*
alias:          pci:v00008086d00000892sv*sd00000462bc*sc*i*
alias:          pci:v00008086d00000893sv*sd00000262bc*sc*i*
alias:          pci:v00008086d00000892sv*sd00000062bc*sc*i*
alias:          pci:v00008086d00000894sv*sd00000822bc*sc*i*
alias:          pci:v00008086d00000894sv*sd00000422bc*sc*i*
alias:          pci:v00008086d00000895sv*sd00000222bc*sc*i*
alias:          pci:v00008086d00000894sv*sd00000022bc*sc*i*
alias:          pci:v00008086d0000088Fsv*sd00005260bc*sc*i*
alias:          pci:v00008086d0000088Esv*sd00004860bc*sc*i*
alias:          pci:v00008086d0000088Esv*sd0000446Abc*sc*i*
alias:          pci:v00008086d0000088Esv*sd00004460bc*sc*i*
alias:          pci:v00008086d0000088Fsv*sd0000426Abc*sc*i*
alias:          pci:v00008086d0000088Fsv*sd00004260bc*sc*i*
alias:          pci:v00008086d0000088Esv*sd0000406Abc*sc*i*
alias:          pci:v00008086d0000088Esv*sd00004060bc*sc*i*
alias:          pci:v00008086d00000887sv*sd00004462bc*sc*i*
alias:          pci:v00008086d00000888sv*sd00004262bc*sc*i*
alias:          pci:v00008086d00000887sv*sd00004062bc*sc*i*
alias:          pci:v00008086d00000890sv*sd00004822bc*sc*i*
alias:          pci:v00008086d00000890sv*sd00004422bc*sc*i*
alias:          pci:v00008086d00000891sv*sd00004222bc*sc*i*
alias:          pci:v00008086d00000890sv*sd00004022bc*sc*i*
alias:          pci:v00008086d00000896sv*sd00005027bc*sc*i*
alias:          pci:v00008086d00000896sv*sd00005025bc*sc*i*
alias:          pci:v00008086d00000897sv*sd00005017bc*sc*i*
alias:          pci:v00008086d00000897sv*sd00005015bc*sc*i*
alias:          pci:v00008086d00000896sv*sd00005007bc*sc*i*
alias:          pci:v00008086d00000896sv*sd00005005bc*sc*i*
alias:          pci:v00008086d000008AEsv*sd00001027bc*sc*i*
alias:          pci:v00008086d000008AEsv*sd00001025bc*sc*i*
alias:          pci:v00008086d000008AFsv*sd00001017bc*sc*i*
alias:          pci:v00008086d000008AFsv*sd00001015bc*sc*i*
alias:          pci:v00008086d000008AEsv*sd00001007bc*sc*i*
alias:          pci:v00008086d000008AEsv*sd00001005bc*sc*i*
alias:          pci:v00008086d00000084sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00000084sv*sd00001216bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001326bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001226bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001306bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001206bc*sc*i*
alias:          pci:v00008086d00000084sv*sd00001315bc*sc*i*
alias:          pci:v00008086d00000084sv*sd00001215bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001325bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001225bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001305bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001205bc*sc*i*
alias:          pci:v00008086d00000886sv*sd00001317bc*sc*i*
alias:          pci:v00008086d00000886sv*sd00001315bc*sc*i*
alias:          pci:v00008086d00000885sv*sd00001327bc*sc*i*
alias:          pci:v00008086d00000885sv*sd00001325bc*sc*i*
alias:          pci:v00008086d00000885sv*sd00001307bc*sc*i*
alias:          pci:v00008086d00000885sv*sd00001305bc*sc*i*
alias:          pci:v00008086d00000089sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00000089sv*sd00001311bc*sc*i*
alias:          pci:v00008086d00000087sv*sd00001326bc*sc*i*
alias:          pci:v00008086d00000087sv*sd00001321bc*sc*i*
alias:          pci:v00008086d00000087sv*sd00001306bc*sc*i*
alias:          pci:v00008086d00000087sv*sd00001301bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005226bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005225bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005221bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005207bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005206bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005205bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005201bc*sc*i*
alias:          pci:v00008086d00000090sv*sd00005216bc*sc*i*
alias:          pci:v00008086d00000090sv*sd00005215bc*sc*i*
alias:          pci:v00008086d00000090sv*sd00005211bc*sc*i*
alias:          pci:v00008086d0000008Bsv*sd00005317bc*sc*i*
alias:          pci:v00008086d0000008Bsv*sd00005315bc*sc*i*
alias:          pci:v00008086d0000008Asv*sd00005327bc*sc*i*
alias:          pci:v00008086d0000008Asv*sd00005325bc*sc*i*
alias:          pci:v00008086d0000008Asv*sd00005307bc*sc*i*
alias:          pci:v00008086d0000008Asv*sd00005305bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001305bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001304bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00004820bc*sc*i*
alias:          pci:v00008086d00000085sv*sd0000C228bc*sc*i*
alias:          pci:v00008086d00000085sv*sd0000C220bc*sc*i*
alias:          pci:v00008086d00000082sv*sd0000C020bc*sc*i*
alias:          pci:v00008086d00000085sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00000085sv*sd00001318bc*sc*i*
alias:          pci:v00008086d00000085sv*sd00001311bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001328bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001326bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001321bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001308bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001307bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001306bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001301bc*sc*i*
alias:          pci:v00008086d00004239sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00004239sv*sd00001311bc*sc*i*
alias:          pci:v00008086d00004238sv*sd00001118bc*sc*i*
alias:          pci:v00008086d00004238sv*sd00001111bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001326bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001321bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001307bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001306bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001301bc*sc*i*
alias:          pci:v00008086d0000422Bsv*sd00001128bc*sc*i*
alias:          pci:v00008086d0000422Bsv*sd00001121bc*sc*i*
alias:          pci:v00008086d0000422Bsv*sd00001108bc*sc*i*
alias:          pci:v00008086d0000422Bsv*sd00001101bc*sc*i*
alias:          pci:v00008086d0000423Dsv*sd00001316bc*sc*i*
alias:          pci:v00008086d0000423Dsv*sd00001216bc*sc*i*
alias:          pci:v00008086d0000423Dsv*sd00001311bc*sc*i*
alias:          pci:v00008086d0000423Dsv*sd00001211bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001326bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001321bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001221bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001306bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001206bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001301bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001201bc*sc*i*
alias:          pci:v00008086d0000423Bsv*sd00001011bc*sc*i*
alias:          pci:v00008086d0000423Asv*sd00001021bc*sc*i*
alias:          pci:v00008086d0000423Asv*sd00001001bc*sc*i*
alias:          pci:v00008086d00004236sv*sd00001114bc*sc*i*
alias:          pci:v00008086d00004236sv*sd00001014bc*sc*i*
alias:          pci:v00008086d00004236sv*sd00001111bc*sc*i*
alias:          pci:v00008086d00004236sv*sd00001011bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001104bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001004bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001101bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001001bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001124bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001024bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001121bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001021bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001216bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001315bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001215bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001314bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001214bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001311bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001211bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001326bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001226bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001325bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001225bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001324bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001224bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001321bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001221bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001306bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001206bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001305bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001205bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001304bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001204bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001301bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001201bc*sc*i*
depends:        cfg80211
intree:         Y
vermagic:       3.10.34-nrj-desktop-2rosa SMP preempt mod_unload modversions
parm:           debug:debug output mask (uint)
parm:           swcrypto:using crypto in software (default 0 [hardware]) (int)
parm:           11n_disable:disable 11n functionality, bitmap: 1: full, 2: disable agg TX, 4: disable agg RX, 8 enable agg TX (uint)
parm:           amsdu_size_8K:enable 8K amsdu size (default 0) (int)
parm:           fw_restart:restart firmware in case of error (default true) (bool)
parm:           antenna_coupling:specify antenna coupling in dB (defualt: 0 dB) (int)
parm:           bt_ch_inhibition:Enable BT channel inhibition (default: enable) (bool)
parm:           plcp_check:Check plcp health (default: 1 [enabled]) (bool)
parm:           wd_disable:Disable stuck queue watchdog timer 0=system default, 1=disable, 2=enable (default: 0) (int)
parm:           bt_coex_active:enable wifi/bt co-exist (default: enable) (bool)
parm:           led_mode:0=system default, 1=On(RF On)/Off(RF Off), 2=blinking, 3=Off (default: 0) (int)
parm:           power_save:enable WiFi power management (default: disable) (bool)
parm:           power_level:default power save level (range from 1 - 5, default: 1) (int)
parm:           auto_agg:enable agg w/o check traffic load (default: enable) (bool)
l2tp
Сообщение l2tp »
# ls -la /lib/firmware | grep iwl
-rw-r--r--  1 root root  335056 окт.  11  2013 iwlwifi-1000-3.ucode
-rw-r--r--  1 root root  337520 окт.  11  2013 iwlwifi-1000-5.ucode
-rw-r--r--  1 root root  337572 окт.  11  2013 iwlwifi-100-5.ucode
-rw-r--r--  1 root root  689680 окт.  11  2013 iwlwifi-105-6.ucode
-rw-r--r--  1 root root  701228 окт.  11  2013 iwlwifi-135-6.ucode
-rw-r--r--  1 root root  695876 окт.  11  2013 iwlwifi-2000-6.ucode
-rw-r--r--  1 root root  707392 окт.  11  2013 iwlwifi-2030-6.ucode
-rw-r--r--  1 root root  670172 окт.  11  2013 iwlwifi-3160-7.ucode
-rw-r--r--  1 root root  149816 окт.  24  2012 iwlwifi-3945-1.ucode
-rw-r--r--  1 root root  150100 окт.  24  2012 iwlwifi-3945-2.ucode
-rw-r--r--  1 root root  187608 окт.  24  2012 iwlwifi-4965-1.ucode
-rw-r--r--  1 root root  187972 окт.  24  2012 iwlwifi-4965-2.ucode
-rw-r--r--  1 root root  345008 окт.  11  2013 iwlwifi-5000-1.ucode
-rw-r--r--  1 root root  353240 окт.  11  2013 iwlwifi-5000-2.ucode
-rw-r--r--  1 root root  340696 окт.  11  2013 iwlwifi-5000-5.ucode
-rw-r--r--  1 root root  337400 окт.  11  2013 iwlwifi-5150-2.ucode
-rw-r--r--  1 root root  454608 окт.  11  2013 iwlwifi-6000-4.ucode
-rw-r--r--  1 root root  444128 окт.  11  2013 iwlwifi-6000g2a-5.ucode
-rw-r--r--  1 root root  677296 окт.  11  2013 iwlwifi-6000g2a-6.ucode
-rw-r--r--  1 root root  460236 окт.  11  2013 iwlwifi-6000g2b-5.ucode
-rw-r--r--  1 root root  679436 окт.  11  2013 iwlwifi-6000g2b-6.ucode
-rw-r--r--  1 root root  463692 окт.  11  2013 iwlwifi-6050-4.ucode
-rw-r--r--  1 root root  469780 окт.  11  2013 iwlwifi-6050-5.ucode
-rw-r--r--  1 root root  682892 окт.  11  2013 iwlwifi-7260-7.ucode
# lspci -vnn
00:00.0 Host bridge [0600]: Intel Corporation Mobile 4 Series Chipset Memory Controller Hub [8086:2a40] (rev 07)
        Subsystem: Lenovo Device [17aa:20e0]
        Flags: bus master, fast devsel, latency 0
        Capabilities: [e0] Vendor Specific Information: Len=0a <?>
        Kernel driver in use: agpgart-intel
00:02.0 VGA compatible controller [0300]: Intel Corporation Mobile 4 Series Chipset Integrated Graphics Controller [8086:2a42] (rev 07) (prog-if 00 [VGA controller])
        Subsystem: Lenovo Device [17aa:20e4]
        Flags: bus master, fast devsel, latency 0, IRQ 44
        Memory at f2000000 (64-bit, non-prefetchable) [size=4M]
        Memory at d0000000 (64-bit, prefetchable) [size=256M]
        I/O ports at 1800 [size=8]
        Expansion ROM at <unassigned> [disabled]
        Capabilities: [90] MSI: Enable+ Count=1/1 Maskable- 64bit-
        Capabilities: [d0] Power Management version 3
        Kernel driver in use: i915
        Kernel modules: i915
00:02.1 Display controller [0380]: Intel Corporation Mobile 4 Series Chipset Integrated Graphics Controller [8086:2a43] (rev 07)
        Memory at f2400000 (64-bit, non-prefetchable) [size=1M]
00:03.0 Communication controller [0780]: Intel Corporation Mobile 4 Series Chipset MEI Controller [8086:2a44] (rev 07)
        Subsystem: Lenovo Device [17aa:20e6]
        Flags: bus master, fast devsel, latency 0, IRQ 45
        Memory at f2826800 (64-bit, non-prefetchable) [size=16]
        Capabilities: [50] Power Management version 3
        Capabilities: [8c] MSI: Enable+ Count=1/1 Maskable- 64bit+
        Kernel driver in use: mei_me
        Kernel modules: mei_me
00:19.0 Ethernet controller [0200]: Intel Corporation 82567LM Gigabit Network Connection [8086:10f5] (rev 03)
        Subsystem: Lenovo Device [17aa:20ee]
        Flags: bus master, fast devsel, latency 0, IRQ 46
        Memory at f2600000 (32-bit, non-prefetchable) [size=128K]
        Memory at f2625000 (32-bit, non-prefetchable) [size=4K]
        I/O ports at 1840 [size=32]
        Capabilities: [c8] Power Management version 2
        Capabilities: [d0] MSI: Enable+ Count=1/1 Maskable- 64bit+
        Capabilities: [e0] PCI Advanced Features
        Kernel driver in use: e1000e
        Kernel modules: e1000e
00:1a.0 USB controller [0c03]: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #4 [8086:2937] (rev 03) (prog-if 00 [UHCI])
        Subsystem: Lenovo Device [17aa:20f0]
        Flags: bus master, medium devsel, latency 0, IRQ 20
        I/O ports at 1860 [size=32]
        Capabilities: [50] PCI Advanced Features
        Kernel driver in use: uhci_hcd
        Kernel modules: uhci_hcd
00:1a.1 USB controller [0c03]: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #5 [8086:2938] (rev 03) (prog-if 00 [UHCI])
        Flags: bus master, medium devsel, latency 0, IRQ 21
        I/O ports at 1880 [size=32]
00:1a.2 USB controller [0c03]: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #6 [8086:2939] (rev 03) (prog-if 00 [UHCI])
        Flags: bus master, medium devsel, latency 0, IRQ 22
        I/O ports at 18a0 [size=32]
00:1a.7 USB controller [0c03]: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #2 [8086:293c] (rev 03) (prog-if 20 [EHCI])
        Subsystem: Lenovo Device [17aa:20f1]
        Flags: bus master, medium devsel, latency 0, IRQ 23
        Memory at f2826c00 (32-bit, non-prefetchable) [size=1K]
        Capabilities: [50] Power Management version 2
        Capabilities: [58] Debug port: BAR=1 offset=00a0
        Capabilities: [98] PCI Advanced Features
        Kernel driver in use: ehci-pci
        Kernel modules: ehci_pci
00:1b.0 Audio device [0403]: Intel Corporation 82801I (ICH9 Family) HD Audio Controller [8086:293e] (rev 03)
        Subsystem: Lenovo Device [17aa:20f2]
        Flags: bus master, fast devsel, latency 0, IRQ 47
        Memory at f2620000 (64-bit, non-prefetchable) [size=16K]
        Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
        Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
        Capabilities: [100] Virtual Channel
        Capabilities: [130] Root Complex Link
        Kernel driver in use: snd_hda_intel
        Kernel modules: snd_hda_intel
00:1c.0 PCI bridge [0604]: Intel Corporation 82801I (ICH9 Family) PCI Express Port 1 [8086:2940] (rev 03) (prog-if 00 [Normal decode])
        Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
        I/O behind bridge: 00003000-00003fff
        Memory behind bridge: c0000000-c01fffff
        Prefetchable memory behind bridge: 00000000c0200000-00000000c03fffff
        Capabilities: [40] Express Root Port (Slot+), MSI 00
        Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
        Capabilities: [90] Subsystem: Lenovo Device [17aa:20f3]
        Capabilities: [a0] Power Management version 2
        Capabilities: [180] Root Complex Link
        Kernel driver in use: pcieport
        Kernel modules: shpchp
00:1c.1 PCI bridge [0604]: Intel Corporation 82801I (ICH9 Family) PCI Express Port 2 [8086:2942] (rev 03) (prog-if 00 [Normal decode])
        Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
        I/O behind bridge: 00004000-00004fff
        Memory behind bridge: f2500000-f25fffff
        Prefetchable memory behind bridge: 00000000c0400000-00000000c05fffff
00:1c.3 PCI bridge [0604]: Intel Corporation 82801I (ICH9 Family) PCI Express Port 4 [8086:2946] (rev 03) (prog-if 00 [Normal decode])
        Bus: primary=00, secondary=05, subordinate=0c, sec-latency=0
        I/O behind bridge: 00002000-00002fff
        Memory behind bridge: f0000000-f1ffffff
        Prefetchable memory behind bridge: 00000000f2900000-00000000f29fffff
00:1d.0 USB controller [0c03]: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #1 [8086:2934] (rev 03) (prog-if 00 [UHCI])
        Flags: bus master, medium devsel, latency 0, IRQ 16
        I/O ports at 18c0 [size=32]
00:1d.1 USB controller [0c03]: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #2 [8086:2935] (rev 03) (prog-if 00 [UHCI])
        Flags: bus master, medium devsel, latency 0, IRQ 17
        I/O ports at 18e0 [size=32]
00:1d.2 USB controller [0c03]: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #3 [8086:2936] (rev 03) (prog-if 00 [UHCI])
        Flags: bus master, medium devsel, latency 0, IRQ 18
        I/O ports at 1c00 [size=32]
00:1d.7 USB controller [0c03]: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #1 [8086:293a] (rev 03) (prog-if 20 [EHCI])
        Flags: bus master, medium devsel, latency 0, IRQ 19
        Memory at f2827000 (32-bit, non-prefetchable) [size=1K]
00:1e.0 PCI bridge [0604]: Intel Corporation 82801 Mobile PCI Bridge [8086:2448] (rev 93) (prog-if 01 [Subtractive decode])
        Bus: primary=00, secondary=0d, subordinate=0d, sec-latency=0
        Capabilities: [50] Subsystem: Lenovo Device [17aa:20f4]
00:1f.0 ISA bridge [0601]: Intel Corporation ICH9M-E LPC Interface Controller [8086:2917] (rev 03)
        Subsystem: Lenovo Device [17aa:20f5]
        Capabilities: [e0] Vendor Specific Information: Len=0c <?>
        Kernel driver in use: lpc_ich
        Kernel modules: lpc_ich
00:1f.2 SATA controller [0106]: Intel Corporation 82801IBM/IEM (ICH9M/ICH9M-E) 4 port SATA Controller [AHCI mode] [8086:2929] (rev 03) (prog-if 01 [AHCI 1.0])
        Subsystem: Lenovo Device [17aa:20f8]
        Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 43
        I/O ports at 1c48 [size=8]
        I/O ports at 183c [size=4]
        I/O ports at 1c40 [size=8]
        I/O ports at 1838 [size=4]
        I/O ports at 1c20 [size=32]
        Memory at f2826000 (32-bit, non-prefetchable) [size=2K]
        Capabilities: [80] MSI: Enable+ Count=1/16 Maskable- 64bit-
        Capabilities: [70] Power Management version 3
        Capabilities: [a8] SATA HBA v1.0
        Capabilities: [b0] PCI Advanced Features
        Kernel driver in use: ahci
00:1f.3 SMBus [0c05]: Intel Corporation 82801I (ICH9 Family) SMBus Controller [8086:2930] (rev 03)
        Subsystem: Lenovo Device [17aa:20f9]
        Flags: medium devsel, IRQ 23
        Memory at f2827400 (64-bit, non-prefetchable) [size=256]
        I/O ports at 1c60 [size=32]
        Kernel driver in use: i801_smbus
        Kernel modules: i2c_i801
03:00.0 Network controller [0280]: Intel Corporation PRO/Wireless 5100 AGN [Shiloh] Network Connection [8086:4237]
        Subsystem: Intel Corporation WiFi Link 5100 AGN [8086:1211]
        Flags: bus master, fast devsel, latency 0, IRQ 48
        Memory at f2500000 (64-bit, non-prefetchable) [size=8K]
        Capabilities: [c8] Power Management version 3
        Capabilities: [e0] Express Endpoint, MSI 00
        Capabilities: [100] Advanced Error Reporting
        Capabilities: [140] Device Serial Number 00-22-fa-ff-ff-c7-f2-ba
        Kernel driver in use: iwlwifi
        Kernel modules: iwlwifi, wl
l2tp
Сообщение l2tp »
dmesg http://pastebin.com/ViWD9RjJ
journalctl http://pastebin.com/hjPQst31
PS Муж говорит, что с ядром 3.13 сабайон и шилох подружились
Последний раз редактировалось l2tp 28 апр 2014, 17:10, всего редактировалось 1 раз.
euspectre
Ещё можно попробовать обновить firmware для WiFi-адаптера.
Скачать можно отсюда: http://wireless.kernel.org/en/users/Dri ... .5.1-1.tgz
Из этого архива стоит взять файл iwlwifi-5000-5.ucode и положить его в /lib/firmware/ (под root опять), заменив тот файл, что там сейчас лежит. Затем - выполнить команду sync, на всякий случай, и перезагрузить систему.
Можно старый файл iwlwifi-5000-5.ucode тоже сохранить где-нибудь перед этим. Мало ли, вдруг понадобится всё вернуть назад.
l2tp
Сообщение l2tp »
А зачем менять прошивку, если рядом лежит ноутбук, где такой шилох чудесно работает под линуксом? только ядро другое
euspectre
l2tp писал(а):А зачем менять прошивку, если рядом лежит ноутбук, где такой шилох чудесно работает под линуксом? только ядро другое
Как минимум, чтобы проверить, что с firmware всё в порядке на том ноутбуке, где проблема проявилась. Файл мог быть повреждён, например.
Два абсолютно одинаковых WiFi-адаптера с разными firmware могут работать очень разным образом. Тем более, в логе драйвер на firmware ругается как раз.
Также если есть желание попробовать ядро 3.13, это ядро собрано и для ROSA Fresh (хотя официально мы его и не поддерживаем).
Достаточно подключить соотв. репозиторий и установить пару пакетов. Для 64-битных систем это так:
urpmi.addmedia kernel313 http://abf-downloads.rosalinux.ru/kernels_3_13x_personal/repository/rosa2012.1/x86_64/main/release/
urpmi kernel-nrj-desktop-3.13.11-1rosa kernel-nrj-desktop-devel-3.13.11-1rosa
Затем стоит перезагрузить систему, при загрузке выбрать нужное ядро и посмотреть, что будет.
l2tp
Сообщение l2tp »
Спс, ставится 3.13.
Я не думаю, что виновата поврежденная фирмварь (и что она вообще повреждена). В этом случае у меня не было бы вайфая вообще - после возникновения проблемы ноутбук неоднократно перегружался, плюс есть второй ноутбук, на котором были ровно те же проблемы, исчезнувшие после установки ядра 3.13
euspectre
Некоторые сбои, похожие на описанный здесь, были связаны как раз с firmware. Ещё такой момент: тот файл с firmware, что предлагается на сайте Intel (его я и предложил использовать), отличается от того, что сейчас поставляется у нас и во многих других Linux'ах. Там могли какие-то баги поправить. Тем более, проверить это несложно.
Может, и не в этом дело, конечно.
Так или иначе, если с 3.13 всё будет работать нормально, я оттуда перенесу соотв. патчи нам в 3.10, чтобы и тут проблем не было.
l2tp
Сообщение l2tp »
Я понаблюдаю и завтра-послезавтра отчитаюсь
l2tp
Сообщение l2tp »
Отвечаю сейчас
С новым ядром вай-фай таки отвалился, но уже полечилось не ребутом, а просто down-up интерфейс, теперь попробую поменять фирмварь
euspectre
Ага, уже интереснее.
Ещё вывод 'journalctl -ab' для нового ядра выложите, если не трудно. Для случая, когда WiFi отвалился.
l2tp
Сообщение l2tp »
Прошивка по приведенной выше ссылке и ядро
[mari@ThinkPad-X200 ~]$ uname -a
Linux ThinkPad-X200 3.13.11-nrj-desktop-1rosa #1 SMP PREEMPT Fri Apr 25 20:16:43 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
Выдержка из dmesg:
[   14.129703] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[   14.178750] Adding 4088692k swap on /dev/sda5.  Priority:-1 extents:1 across:4088692k FS
[   14.493462] iwlwifi 0000:03:00.0: CONFIG_IWLWIFI_DEBUG enabled
[   14.493466] iwlwifi 0000:03:00.0: CONFIG_IWLWIFI_DEBUGFS disabled
[   14.493468] iwlwifi 0000:03:00.0: CONFIG_IWLWIFI_DEVICE_TRACING disabled
[   14.493471] iwlwifi 0000:03:00.0: Detected Intel(R) WiFi Link 5100 AGN, REV=0x54
[   14.493924] iwlwifi 0000:03:00.0: L1 Disabled; Enabling L0S
[   14.525572] wl: module license 'MIXED/Proprietary' taints kernel.
[   14.525576] Disabling lock debugging due to kernel taint
[   14.569136] ieee80211 phy0: Selected rate control algorithm 'iwl-agn-rs'
[   14.709269] EXT4-fs (sda6): mounted filesystem with ordered data mode. Opts: (null)
[   14.729701] systemd-journald[304]: Received request to flush runtime journal from PID 1
[   15.190211] iTCO_vendor_support: vendor-support=0
[   15.193519] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.10
[   15.193566] iTCO_wdt: Found a ICH9M-E TCO device (Version=2, TCOBASE=0x1060)
[   15.193710] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=1)
[   16.140028] systemd[1]: Unit fedora-loadmodules.service entered failed state.
[   16.374372] cfg80211: World regulatory domain updated:
[   16.374377] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[   16.374379] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[   16.374381] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[   16.374382] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[   16.374384] cfg80211:   (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[   16.374385] cfg80211:   (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[   16.746435] systemd-journald[304]: Received request to flush runtime journal from PID 1
[   19.839702] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   19.839706] Bluetooth: BNEP filters: protocol multicast
[   19.839716] Bluetooth: BNEP socket layer initialized
[   20.186703] Bluetooth: RFCOMM TTY layer initialized
[   20.186717] Bluetooth: RFCOMM socket layer initialized
[   20.186723] Bluetooth: RFCOMM ver 1.11
[   37.440216] e1000e 0000:00:19.0: irq 46 for MSI/MSI-X
[   37.541090] e1000e 0000:00:19.0: irq 46 for MSI/MSI-X
[   37.541212] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   37.543357] iwlwifi 0000:03:00.0: L1 Disabled; Enabling L0S
[   37.543754] iwlwifi 0000:03:00.0: Radio type=0x1-0x2-0x0
[   37.638224] iwlwifi 0000:03:00.0: L1 Disabled; Enabling L0S
[   37.638617] iwlwifi 0000:03:00.0: Radio type=0x1-0x2-0x0
[   37.661254] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   38.025339] NET: Registered protocol family 17
[   44.667414] wlan0: authenticate with 64:70:02:0d:b8:69
[   44.671489] wlan0: send auth to 64:70:02:0d:b8:69 (try 1/3)
[   44.673650] wlan0: authenticated
[   44.674182] wlan0: associate with 64:70:02:0d:b8:69 (try 1/3)
[   44.677558] wlan0: RX AssocResp from 64:70:02:0d:b8:69 (capab=0x431 status=0 aid=3)
[   44.701373] wlan0: associated
[   44.701415] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[  117.717758] fuse init (API version 7.22)
[  527.522793] iwlwifi 0000:03:00.0: Microcode SW error detected.  Restarting 0x82000000.
[  527.522799] iwlwifi 0000:03:00.0: CSR values:
[  527.522802] iwlwifi 0000:03:00.0: (2nd byte of CSR_INT_COALESCING is CSR_INT_PERIODIC_REG)
[  527.522809] iwlwifi 0000:03:00.0:        CSR_HW_IF_CONFIG_REG: 0X00488704
[  527.522814] iwlwifi 0000:03:00.0:          CSR_INT_COALESCING: 0X0000ff40
[  527.522820] iwlwifi 0000:03:00.0:                     CSR_INT: 0X00000000
[  527.522826] iwlwifi 0000:03:00.0:                CSR_INT_MASK: 0X00000000
[  527.522831] iwlwifi 0000:03:00.0:           CSR_FH_INT_STATUS: 0X00000000
[  527.522837] iwlwifi 0000:03:00.0:                 CSR_GPIO_IN: 0X00000000
[  527.522847] iwlwifi 0000:03:00.0:                   CSR_RESET: 0X00000000
[  527.522852] iwlwifi 0000:03:00.0:                CSR_GP_CNTRL: 0X080403c5
[  527.522856] iwlwifi 0000:03:00.0:                  CSR_HW_REV: 0X00000054
[  527.522861] iwlwifi 0000:03:00.0:              CSR_EEPROM_REG: 0X00000000
[  527.522866] iwlwifi 0000:03:00.0:               CSR_EEPROM_GP: 0X90000004
[  527.522870] iwlwifi 0000:03:00.0:              CSR_OTP_GP_REG: 0X00060000
[  527.522875] iwlwifi 0000:03:00.0:                 CSR_GIO_REG: 0X00080044
[  527.522880] iwlwifi 0000:03:00.0:            CSR_GP_UCODE_REG: 0X000056bd
[  527.522884] iwlwifi 0000:03:00.0:           CSR_GP_DRIVER_REG: 0X00000000
[  527.522889] iwlwifi 0000:03:00.0:           CSR_UCODE_DRV_GP1: 0X00000000
[  527.522893] iwlwifi 0000:03:00.0:           CSR_UCODE_DRV_GP2: 0X00000000
[  527.522898] iwlwifi 0000:03:00.0:                 CSR_LED_REG: 0X00000040
[  527.522902] iwlwifi 0000:03:00.0:        CSR_DRAM_INT_TBL_REG: 0X880b5fce
[  527.522907] iwlwifi 0000:03:00.0:        CSR_GIO_CHICKEN_BITS: 0X27800200
[  527.522911] iwlwifi 0000:03:00.0:             CSR_ANA_PLL_CFG: 0X00880300
[  527.522918] iwlwifi 0000:03:00.0:           CSR_HW_REV_WA_REG: 0X0001001a
[  527.522923] iwlwifi 0000:03:00.0:        CSR_DBG_HPET_MEM_REG: 0Xffff0000
[  527.522925] iwlwifi 0000:03:00.0: FH register values:
[  527.522940] iwlwifi 0000:03:00.0:         FH_RSCSR_CHNL0_STTS_WPTR_REG: 0X0b4c0400
[  527.522955] iwlwifi 0000:03:00.0:        FH_RSCSR_CHNL0_RBDCB_BASE_REG: 0X00b92470
[  527.522968] iwlwifi 0000:03:00.0:                  FH_RSCSR_CHNL0_WPTR: 0X00000070
[  527.522983] iwlwifi 0000:03:00.0:         FH_MEM_RCSR_CHNL0_CONFIG_REG: 0X80801114
[  527.523020] iwlwifi 0000:03:00.0:          FH_MEM_RSSR_SHARED_CTRL_REG: 0X000000fc
[  527.523033] iwlwifi 0000:03:00.0:            FH_MEM_RSSR_RX_STATUS_REG: 0X07030000
[  527.523047] iwlwifi 0000:03:00.0:    FH_MEM_RSSR_RX_ENABLE_ERR_IRQ2DRV: 0X00000000
[  527.523060] iwlwifi 0000:03:00.0:                FH_TSSR_TX_STATUS_REG: 0X07ff0001
[  527.523073] iwlwifi 0000:03:00.0:                 FH_TSSR_TX_ERROR_REG: 0X00000000
[  527.523076] iwlwifi 0000:03:00.0: Loaded firmware version: 8.83.5.1 build 33692
[  527.523194] iwlwifi 0000:03:00.0: Start IWL Error Log Dump:
[  527.523196] iwlwifi 0000:03:00.0: Status: 0x0000004C, count: 5
[  527.523199] iwlwifi 0000:03:00.0: 0x00000005 | SYSASSERT
[  527.523201] iwlwifi 0000:03:00.0: 0x0000D49C | uPc
[  527.523202] iwlwifi 0000:03:00.0: 0x0000D414 | branchlink1
[  527.523204] iwlwifi 0000:03:00.0: 0x0000D414 | branchlink2
[  527.523206] iwlwifi 0000:03:00.0: 0x00000916 | interruptlink1
[  527.523208] iwlwifi 0000:03:00.0: 0x00000000 | interruptlink2
[  527.523210] iwlwifi 0000:03:00.0: 0x00000072 | data1
[  527.523211] iwlwifi 0000:03:00.0: 0x0000000C | data2
[  527.523213] iwlwifi 0000:03:00.0: 0x0000070F | line
[  527.523215] iwlwifi 0000:03:00.0: 0x9B00AA3E | beacon time
[  527.523217] iwlwifi 0000:03:00.0: 0x8E6FD5C2 | tsf low
[  527.523219] iwlwifi 0000:03:00.0: 0x0000002B | tsf hi
[  527.523220] iwlwifi 0000:03:00.0: 0x0000018A | time gp1
[  527.523222] iwlwifi 0000:03:00.0: 0x1D32DF5C | time gp2
[  527.523224] iwlwifi 0000:03:00.0: 0x00000000 | time gp3
[  527.523226] iwlwifi 0000:03:00.0: 0x00010853 | uCode version
[  527.523227] iwlwifi 0000:03:00.0: 0x00000054 | hw version
[  527.523229] iwlwifi 0000:03:00.0: 0x00488704 | board version
[  527.523231] iwlwifi 0000:03:00.0: 0x02B4001C | hcmd
[  527.523233] iwlwifi 0000:03:00.0: 0xAFF63002 | isr0
[  527.523234] iwlwifi 0000:03:00.0: 0x0103E000 | isr1
[  527.523236] iwlwifi 0000:03:00.0: 0x0000001A | isr2
[  527.523238] iwlwifi 0000:03:00.0: 0x0043F8C0 | isr3
[  527.523239] iwlwifi 0000:03:00.0: 0x10004112 | isr4
[  527.523241] iwlwifi 0000:03:00.0: 0x0000D414 | isr_pref
[  527.523243] iwlwifi 0000:03:00.0: 0x000000D4 | wait_event
[  527.523245] iwlwifi 0000:03:00.0: 0x000001AC | l2p_control
[  527.523246] iwlwifi 0000:03:00.0: 0x00000007 | l2p_duration
[  527.523248] iwlwifi 0000:03:00.0: 0x00101042 | l2p_mhvalid
[  527.523250] iwlwifi 0000:03:00.0: 0x00000015 | l2p_addr_match
[  527.523252] iwlwifi 0000:03:00.0: 0x02121704 | lmpm_pmg_sel
[  527.523253] iwlwifi 0000:03:00.0: 0x00007080 | timestamp
[  527.523255] iwlwifi 0000:03:00.0: 0x00000100 | flow_handler
[  527.523309] iwlwifi 0000:03:00.0: Start IWL Event Log Dump: display last 20 entries
[  527.523327] iwlwifi 0000:03:00.0: EVT_LOGT:0489873117:0x001a0010:0204
[  527.523338] iwlwifi 0000:03:00.0: EVT_LOGT:0489873122:0x001a0010:0219
[  527.523348] iwlwifi 0000:03:00.0: EVT_LOGT:0489873124:0x01400110:0211
[  527.523359] iwlwifi 0000:03:00.0: EVT_LOGT:0489873129:0x00000000:0212
[  527.523370] iwlwifi 0000:03:00.0: EVT_LOGT:0489873130:0x001a0010:0213
[  527.523380] iwlwifi 0000:03:00.0: EVT_LOGT:0489873161:0x00000000:0215
[  527.523391] iwlwifi 0000:03:00.0: EVT_LOGT:0489873164:0x001a0008:0215
[  527.523401] iwlwifi 0000:03:00.0: EVT_LOGT:0489873168:0x001a0008:0220
[  527.523412] iwlwifi 0000:03:00.0: EVT_LOGT:0489873181:0x00000000:0302
[  527.523423] iwlwifi 0000:03:00.0: EVT_LOGT:0489873210:0x000000d4:0303
[  527.523434] iwlwifi 0000:03:00.0: EVT_LOGT:0489873217:0x00000cb4:0217
[  527.523444] iwlwifi 0000:03:00.0: EVT_LOGT:0489873218:0x02b3001c:0217
[  527.523455] iwlwifi 0000:03:00.0: EVT_LOGT:0489873221:0x00000001:0203
[  527.523465] iwlwifi 0000:03:00.0: EVT_LOGT:0489873224:0x02b4001c:0206
[  527.523476] iwlwifi 0000:03:00.0: EVT_LOGT:0489873225:0x001a0010:0204
[  527.523486] iwlwifi 0000:03:00.0: EVT_LOGT:0489873230:0x001a0010:0219
[  527.523498] iwlwifi 0000:03:00.0: EVT_LOGT:0489873232:0x01400110:0211
[  527.523508] iwlwifi 0000:03:00.0: EVT_LOGT:0489873237:0x00000000:0212
[  527.523519] iwlwifi 0000:03:00.0: EVT_LOGT:0489873238:0x001a0010:0213
[  527.523530] iwlwifi 0000:03:00.0: EVT_LOGT:0489873248:0x00000000:0125
[  527.524539] ieee80211 phy0: Hardware restart was requested
[  527.524597] iwlwifi 0000:03:00.0: L1 Disabled; Enabling L0S
[  527.525014] iwlwifi 0000:03:00.0: Radio type=0x1-0x2-0x0
[  755.683695] iwlwifi 0000:03:00.0: Microcode SW error detected.  Restarting 0x82000000.
[  755.683708] iwlwifi 0000:03:00.0: CSR values:
[  755.683714] iwlwifi 0000:03:00.0: (2nd byte of CSR_INT_COALESCING is CSR_INT_PERIODIC_REG)
[  755.683723] iwlwifi 0000:03:00.0:        CSR_HW_IF_CONFIG_REG: 0X00488704
[  755.683732] iwlwifi 0000:03:00.0:          CSR_INT_COALESCING: 0X0000ff40
[  755.683741] iwlwifi 0000:03:00.0:                     CSR_INT: 0X00000000
[  755.683750] iwlwifi 0000:03:00.0:                CSR_INT_MASK: 0X00000000
[  755.683758] iwlwifi 0000:03:00.0:           CSR_FH_INT_STATUS: 0X00000000
[  755.683767] iwlwifi 0000:03:00.0:                 CSR_GPIO_IN: 0X00000000
[  755.683775] iwlwifi 0000:03:00.0:                   CSR_RESET: 0X00000000
[  755.683784] iwlwifi 0000:03:00.0:                CSR_GP_CNTRL: 0X080403c5
[  755.683793] iwlwifi 0000:03:00.0:                  CSR_HW_REV: 0X00000054
[  755.683801] iwlwifi 0000:03:00.0:              CSR_EEPROM_REG: 0X00000000
[  755.683810] iwlwifi 0000:03:00.0:               CSR_EEPROM_GP: 0X90000004
[  755.683819] iwlwifi 0000:03:00.0:              CSR_OTP_GP_REG: 0X00060000
[  755.683828] iwlwifi 0000:03:00.0:                 CSR_GIO_REG: 0X00080044
[  755.683836] iwlwifi 0000:03:00.0:            CSR_GP_UCODE_REG: 0X000030a1
[  755.683845] iwlwifi 0000:03:00.0:           CSR_GP_DRIVER_REG: 0X00000000
[  755.683853] iwlwifi 0000:03:00.0:           CSR_UCODE_DRV_GP1: 0X00000000
[  755.683862] iwlwifi 0000:03:00.0:           CSR_UCODE_DRV_GP2: 0X00000000
[  755.683871] iwlwifi 0000:03:00.0:                 CSR_LED_REG: 0X00000040
[  755.683879] iwlwifi 0000:03:00.0:        CSR_DRAM_INT_TBL_REG: 0X880b5fce
[  755.683888] iwlwifi 0000:03:00.0:        CSR_GIO_CHICKEN_BITS: 0X27800200
[  755.683896] iwlwifi 0000:03:00.0:             CSR_ANA_PLL_CFG: 0X00880300
[  755.683905] iwlwifi 0000:03:00.0:           CSR_HW_REV_WA_REG: 0X0001001a
[  755.683913] iwlwifi 0000:03:00.0:        CSR_DBG_HPET_MEM_REG: 0Xffff0000
[  755.683919] iwlwifi 0000:03:00.0: FH register values:
[  755.683938] iwlwifi 0000:03:00.0:         FH_RSCSR_CHNL0_STTS_WPTR_REG: 0X0b4c0400
[  755.683957] iwlwifi 0000:03:00.0:        FH_RSCSR_CHNL0_RBDCB_BASE_REG: 0X00b92470
[  755.683975] iwlwifi 0000:03:00.0:                  FH_RSCSR_CHNL0_WPTR: 0X00000078
[  755.683993] iwlwifi 0000:03:00.0:         FH_MEM_RCSR_CHNL0_CONFIG_REG: 0X80801114
[  755.684046] iwlwifi 0000:03:00.0:          FH_MEM_RSSR_SHARED_CTRL_REG: 0X000000fc
[  755.684067] iwlwifi 0000:03:00.0:            FH_MEM_RSSR_RX_STATUS_REG: 0X07030000
[  755.684089] iwlwifi 0000:03:00.0:    FH_MEM_RSSR_RX_ENABLE_ERR_IRQ2DRV: 0X00000000
[  755.684109] iwlwifi 0000:03:00.0:                FH_TSSR_TX_STATUS_REG: 0X07ff0001
[  755.684137] iwlwifi 0000:03:00.0:                 FH_TSSR_TX_ERROR_REG: 0X00000000
[  755.684153] iwlwifi 0000:03:00.0: Loaded firmware version: 8.83.5.1 build 33692
[  755.684297] iwlwifi 0000:03:00.0: Start IWL Error Log Dump:
[  755.684304] iwlwifi 0000:03:00.0: Status: 0x0000004C, count: 5
[  755.684310] iwlwifi 0000:03:00.0: 0x00000005 | SYSASSERT
[  755.684316] iwlwifi 0000:03:00.0: 0x0000D49C | uPc
[  755.684321] iwlwifi 0000:03:00.0: 0x0000D414 | branchlink1
[  755.684327] iwlwifi 0000:03:00.0: 0x0000D414 | branchlink2
[  755.684332] iwlwifi 0000:03:00.0: 0x00000916 | interruptlink1
[  755.684338] iwlwifi 0000:03:00.0: 0x00000000 | interruptlink2
[  755.684344] iwlwifi 0000:03:00.0: 0x0000007A | data1
[  755.684349] iwlwifi 0000:03:00.0: 0x0000000C | data2
[  755.684354] iwlwifi 0000:03:00.0: 0x0000070F | line
[  755.684360] iwlwifi 0000:03:00.0: 0x2D40789B | beacon time
[  755.684365] iwlwifi 0000:03:00.0: 0x9C094765 | tsf low
[  755.684371] iwlwifi 0000:03:00.0: 0x0000002B | tsf hi
[  755.684376] iwlwifi 0000:03:00.0: 0x000007C4 | time gp1
[  755.684382] iwlwifi 0000:03:00.0: 0x0D9947FE | time gp2
[  755.684387] iwlwifi 0000:03:00.0: 0x00000000 | time gp3
[  755.684392] iwlwifi 0000:03:00.0: 0x00010853 | uCode version
[  755.684398] iwlwifi 0000:03:00.0: 0x00000054 | hw version
[  755.684403] iwlwifi 0000:03:00.0: 0x00488704 | board version
[  755.684408] iwlwifi 0000:03:00.0: 0x0246001C | hcmd
[  755.684414] iwlwifi 0000:03:00.0: 0xAF863002 | isr0
[  755.684419] iwlwifi 0000:03:00.0: 0x0103E000 | isr1
[  755.684424] iwlwifi 0000:03:00.0: 0x0000001A | isr2
[  755.684430] iwlwifi 0000:03:00.0: 0x0043FCC0 | isr3
[  755.684435] iwlwifi 0000:03:00.0: 0x00004110 | isr4
[  755.684440] iwlwifi 0000:03:00.0: 0x0000D414 | isr_pref
[  755.684445] iwlwifi 0000:03:00.0: 0x000000D4 | wait_event
[  755.684451] iwlwifi 0000:03:00.0: 0x00000013 | l2p_control
[  755.684456] iwlwifi 0000:03:00.0: 0x00000007 | l2p_duration
[  755.684461] iwlwifi 0000:03:00.0: 0x00101042 | l2p_mhvalid
[  755.684466] iwlwifi 0000:03:00.0: 0x00000015 | l2p_addr_match
[  755.684472] iwlwifi 0000:03:00.0: 0x02121704 | lmpm_pmg_sel
[  755.684477] iwlwifi 0000:03:00.0: 0x00007888 | timestamp
[  755.684482] iwlwifi 0000:03:00.0: 0x00000100 | flow_handler
[  755.684548] iwlwifi 0000:03:00.0: Start IWL Event Log Dump: display last 20 entries
[  755.684573] iwlwifi 0000:03:00.0: EVT_LOGT:0228148903:0x001a0010:0204
[  755.684598] iwlwifi 0000:03:00.0: EVT_LOGT:0228148908:0x00180010:0219
[  755.684622] iwlwifi 0000:03:00.0: EVT_LOGT:0228148910:0x01400110:0211
[  755.684646] iwlwifi 0000:03:00.0: EVT_LOGT:0228148914:0x00000000:0212
[  755.684669] iwlwifi 0000:03:00.0: EVT_LOGT:0228148951:0x00000000:0215
[  755.684685] iwlwifi 0000:03:00.0: EVT_LOGT:0228148954:0x00100008:0220
[  755.684701] iwlwifi 0000:03:00.0: EVT_LOGT:0228148971:0x00000000:0302
[  755.684718] iwlwifi 0000:03:00.0: EVT_LOGT:0228149000:0x000000d4:0303
[  755.684734] iwlwifi 0000:03:00.0: EVT_LOGT:0228149004:0x00000a46:0217
[  755.684750] iwlwifi 0000:03:00.0: EVT_LOGT:0228149005:0x0245001c:0217
[  755.684766] iwlwifi 0000:03:00.0: EVT_LOGT:0228149186:0x0246001c:0206
[  755.684782] iwlwifi 0000:03:00.0: EVT_LOGT:0228149188:0x00120001:0204
[  755.684799] iwlwifi 0000:03:00.0: EVT_LOGT:0228149194:0x00120001:0214
[  755.684815] iwlwifi 0000:03:00.0: EVT_LOGT:0228149195:0x01022110:0209
[  755.684831] iwlwifi 0000:03:00.0: EVT_LOGT:0228149216:0x00000000:0210
[  755.684847] iwlwifi 0000:03:00.0: EVT_LOGT:0228149232:0x00000000:0207
[  755.684863] iwlwifi 0000:03:00.0: EVT_LOGT:0228149234:0x01022110:0211
[  755.684881] iwlwifi 0000:03:00.0: EVT_LOGT:0228149239:0x00000000:0212
[  755.684897] iwlwifi 0000:03:00.0: EVT_LOGT:0228149240:0x00120001:0213
[  755.684913] iwlwifi 0000:03:00.0: EVT_LOGT:0228149250:0x00000000:0125
[  755.685587] ieee80211 phy0: Hardware restart was requested
[  755.685662] iwlwifi 0000:03:00.0: L1 Disabled; Enabling L0S
[  755.686076] iwlwifi 0000:03:00.0: Radio type=0x1-0x2-0x0
[  785.832421] iwlwifi 0000:03:00.0: Microcode SW error detected.  Restarting 0x82000000.
[  785.832428] iwlwifi 0000:03:00.0: CSR values:
[  785.832431] iwlwifi 0000:03:00.0: (2nd byte of CSR_INT_COALESCING is CSR_INT_PERIODIC_REG)
[  785.832437] iwlwifi 0000:03:00.0:        CSR_HW_IF_CONFIG_REG: 0X00488704
[  785.832443] iwlwifi 0000:03:00.0:          CSR_INT_COALESCING: 0X0000ff40
[  785.832449] iwlwifi 0000:03:00.0:                     CSR_INT: 0X00000000
[  785.832454] iwlwifi 0000:03:00.0:                CSR_INT_MASK: 0X00000000
[  785.832460] iwlwifi 0000:03:00.0:           CSR_FH_INT_STATUS: 0X00000000
[  785.832465] iwlwifi 0000:03:00.0:                 CSR_GPIO_IN: 0X00000000
[  785.832471] iwlwifi 0000:03:00.0:                   CSR_RESET: 0X00000000
[  785.832477] iwlwifi 0000:03:00.0:                CSR_GP_CNTRL: 0X080403c5
[  785.832482] iwlwifi 0000:03:00.0:                  CSR_HW_REV: 0X00000054
[  785.832488] iwlwifi 0000:03:00.0:              CSR_EEPROM_REG: 0X00000000
[  785.832493] iwlwifi 0000:03:00.0:               CSR_EEPROM_GP: 0X90000004
[  785.832499] iwlwifi 0000:03:00.0:              CSR_OTP_GP_REG: 0X00060000
[  785.832505] iwlwifi 0000:03:00.0:                 CSR_GIO_REG: 0X00080044
[  785.832511] iwlwifi 0000:03:00.0:            CSR_GP_UCODE_REG: 0X00002df7
[  785.832516] iwlwifi 0000:03:00.0:           CSR_GP_DRIVER_REG: 0X00000000
[  785.832522] iwlwifi 0000:03:00.0:           CSR_UCODE_DRV_GP1: 0X00000000
[  785.832527] iwlwifi 0000:03:00.0:           CSR_UCODE_DRV_GP2: 0X00000000
[  785.832533] iwlwifi 0000:03:00.0:                 CSR_LED_REG: 0X00000040
[  785.832538] iwlwifi 0000:03:00.0:        CSR_DRAM_INT_TBL_REG: 0X880b5fce
[  785.832544] iwlwifi 0000:03:00.0:        CSR_GIO_CHICKEN_BITS: 0X27800200
[  785.832550] iwlwifi 0000:03:00.0:             CSR_ANA_PLL_CFG: 0X00880300
[  785.832555] iwlwifi 0000:03:00.0:           CSR_HW_REV_WA_REG: 0X0001001a
[  785.832561] iwlwifi 0000:03:00.0:        CSR_DBG_HPET_MEM_REG: 0Xffff0000
[  785.832564] iwlwifi 0000:03:00.0: FH register values:
[  785.832579] iwlwifi 0000:03:00.0:         FH_RSCSR_CHNL0_STTS_WPTR_REG: 0X0b4c0400
[  785.832595] iwlwifi 0000:03:00.0:        FH_RSCSR_CHNL0_RBDCB_BASE_REG: 0X00b92470
[  785.832610] iwlwifi 0000:03:00.0:                  FH_RSCSR_CHNL0_WPTR: 0X00000020
[  785.832625] iwlwifi 0000:03:00.0:         FH_MEM_RCSR_CHNL0_CONFIG_REG: 0X80801114
[  785.832640] iwlwifi 0000:03:00.0:          FH_MEM_RSSR_SHARED_CTRL_REG: 0X000000fc
[  785.832655] iwlwifi 0000:03:00.0:            FH_MEM_RSSR_RX_STATUS_REG: 0X07030000
[  785.832671] iwlwifi 0000:03:00.0:    FH_MEM_RSSR_RX_ENABLE_ERR_IRQ2DRV: 0X00000000
[  785.832686] iwlwifi 0000:03:00.0:                FH_TSSR_TX_STATUS_REG: 0X07ff0001
[  785.832701] iwlwifi 0000:03:00.0:                 FH_TSSR_TX_ERROR_REG: 0X00000000
[  785.832705] iwlwifi 0000:03:00.0: Loaded firmware version: 8.83.5.1 build 33692
[  785.832831] iwlwifi 0000:03:00.0: Start IWL Error Log Dump:
[  785.832834] iwlwifi 0000:03:00.0: Status: 0x0000004C, count: 5
[  785.832838] iwlwifi 0000:03:00.0: 0x00000005 | SYSASSERT
[  785.832840] iwlwifi 0000:03:00.0: 0x0000D49C | uPc
[  785.832843] iwlwifi 0000:03:00.0: 0x0000D414 | branchlink1
[  785.832846] iwlwifi 0000:03:00.0: 0x0000D414 | branchlink2
[  785.832849] iwlwifi 0000:03:00.0: 0x00000916 | interruptlink1
[  785.832851] iwlwifi 0000:03:00.0: 0x00000000 | interruptlink2
[  785.832854] iwlwifi 0000:03:00.0: 0x00000072 | data1
[  785.832857] iwlwifi 0000:03:00.0: 0x0000000C | data2
[  785.832859] iwlwifi 0000:03:00.0: 0x0000070F | line
[  785.832862] iwlwifi 0000:03:00.0: 0x49C1605C | beacon time
[  785.832865] iwlwifi 0000:03:00.0: 0x9DD54FA4 | tsf low
[  785.832867] iwlwifi 0000:03:00.0: 0x0000002B | tsf hi
[  785.832870] iwlwifi 0000:03:00.0: 0x00000459 | time gp1
[  785.832872] iwlwifi 0000:03:00.0: 0x01CBE253 | time gp2
[  785.832875] iwlwifi 0000:03:00.0: 0x00000000 | time gp3
[  785.832877] iwlwifi 0000:03:00.0: 0x00010853 | uCode version
[  785.832880] iwlwifi 0000:03:00.0: 0x00000054 | hw version
[  785.832883] iwlwifi 0000:03:00.0: 0x00488704 | board version
[  785.832885] iwlwifi 0000:03:00.0: 0x0263001C | hcmd
[  785.832888] iwlwifi 0000:03:00.0: 0xAFE63882 | isr0
[  785.832891] iwlwifi 0000:03:00.0: 0x0103E000 | isr1
[  785.832893] iwlwifi 0000:03:00.0: 0x0000001A | isr2
[  785.832896] iwlwifi 0000:03:00.0: 0x0043FCC0 | isr3
[  785.832898] iwlwifi 0000:03:00.0: 0x11004112 | isr4
[  785.832901] iwlwifi 0000:03:00.0: 0x0000D414 | isr_pref
[  785.832903] iwlwifi 0000:03:00.0: 0x000000D4 | wait_event
[  785.832906] iwlwifi 0000:03:00.0: 0x00000064 | l2p_control
[  785.832909] iwlwifi 0000:03:00.0: 0x00000007 | l2p_duration
[  785.832911] iwlwifi 0000:03:00.0: 0x00101042 | l2p_mhvalid
[  785.832914] iwlwifi 0000:03:00.0: 0x00000015 | l2p_addr_match
[  785.832917] iwlwifi 0000:03:00.0: 0x02121704 | lmpm_pmg_sel
[  785.832919] iwlwifi 0000:03:00.0: 0x00002030 | timestamp
[  785.832922] iwlwifi 0000:03:00.0: 0x00000100 | flow_handler
[  785.832975] iwlwifi 0000:03:00.0: Start IWL Event Log Dump: display last 20 entries
[  785.832994] iwlwifi 0000:03:00.0: EVT_LOGT:0030138844:0x000a0010:0204
[  785.833006] iwlwifi 0000:03:00.0: EVT_LOGT:0030138849:0x000a0010:0219
[  785.833007] iwlwifi 0000:03:00.0: EVT_LOGT:0030138850:0x01400110:0211
[  785.833007] iwlwifi 0000:03:00.0: EVT_LOGT:0030138855:0x00000000:0212
[  785.833007] iwlwifi 0000:03:00.0: EVT_LOGT:0030138856:0x000a0010:0213
[  785.833007] iwlwifi 0000:03:00.0: EVT_LOGT:0030138882:0x00000000:0215
[  785.833007] iwlwifi 0000:03:00.0: EVT_LOGT:0030138885:0x000a0008:0215
[  785.833007] iwlwifi 0000:03:00.0: EVT_LOGT:0030138888:0x000a0008:0220
[  785.833007] iwlwifi 0000:03:00.0: EVT_LOGT:0030138901:0x00000000:0302
[  785.833007] iwlwifi 0000:03:00.0: EVT_LOGT:0030138931:0x000000d4:0303
[  785.833007] iwlwifi 0000:03:00.0: EVT_LOGT:0030138938:0x00000e63:0217
[  785.833007] iwlwifi 0000:03:00.0: EVT_LOGT:0030138939:0x0262001c:0217
[  785.833007] iwlwifi 0000:03:00.0: EVT_LOGT:0030138941:0x00000001:0203
[  785.833007] iwlwifi 0000:03:00.0: EVT_LOGT:0030138944:0x0263001c:0206
[  785.833007] iwlwifi 0000:03:00.0: EVT_LOGT:0030138945:0x000a0010:0204
[  785.833007] iwlwifi 0000:03:00.0: EVT_LOGT:0030138950:0x000a0010:0219
[  785.833007] iwlwifi 0000:03:00.0: EVT_LOGT:0030138952:0x01400110:0211
[  785.833007] iwlwifi 0000:03:00.0: EVT_LOGT:0030138956:0x00000000:0212
[  785.833007] iwlwifi 0000:03:00.0: EVT_LOGT:0030138957:0x000a0010:0213
[  785.833007] iwlwifi 0000:03:00.0: EVT_LOGT:0030138968:0x00000000:0125
[  785.838240] ieee80211 phy0: Hardware restart was requested
[  785.838294] iwlwifi 0000:03:00.0: L1 Disabled; Enabling L0S
[  785.838692] iwlwifi 0000:03:00.0: Radio type=0x1-0x2-0x0
Пакетики пока ходят (я без ребута и дерганья интерфейса сообщение отправила)
euspectre
Ясно, спасибо.
В обоих случаях на одно и то же ругается.
Посмотрите тогда, воспроизведётся ли проблема после перезагрузки. Без перезугрузки новая прошивка не применится.
Если проблема останется, тогда ещё раз выложите dmesg, лучше полностью.
l2tp
Сообщение l2tp »
Я перегружала после замены прошивки. Это dmesg уже после ребута
l2tp
Сообщение l2tp »
Опять померло, полечилось только ребутом.
http://pastebin.com/L4ayqZHB dmesg перед ребутом
http://pastebin.com/hWf5XbDv dmesg сразу после логина в кде
rfkill перед ребутом вайфайной карточки не видел, только ВТ
euspectre
1. Тогда верните то firmware (iwlwifi-5000-5.ucode), что было раньше. Если не сохранили его, взять можно отсюда: http://git.kernel.org/cgit/linux/kernel ... 00-5.ucode. Перезагрузите систему после копирования его в /lib/firmware, как и раньше.
2. Заодно, кстати, стоит удалить пакет dkms-broadcom-wl. Проблема не из-за него, скорее всего, но на Вашем ноутбуке он не нужен (нет соотв. устройств). Чем меньше проприетарных драйверов установлено, тем проще анализировать ошибки в остальных драйверах.
3. Когда проблема снова проявится, ещё раз выложите вывод 'journalctl -ab', под root, как обычно.
dmesg недостаточно: много warning'ов идёт, и данные о самых первых ошибках и warning'ах там не сохранились. А мне именно они и нужны сейчас.
4. Ещё выложите, пожалуйста, что выводит 'lspci -vvxxx' на момент сразу после логина в KDE и после того, как проблема проявится.
l2tp
Сообщение l2tp »
OK
l2tp
Сообщение l2tp »
http://pastebin.com/MCLYpsXM - journalctl -ab
http://pastebin.com/QHCbsxLm lspci
все на момент, когда перестали ходить пакетики.
http://pastebin.com/uMuuduSc - lspci и http://pastebin.com/F6K1VVwv journalctl - пакеты забегали после передергивания интерфейса
Прошу прощения, файлик с lspci на момент логина нечаянно затерла :(
euspectre
Спасибо, логи пригодятся. Странно, что сейчас тех warning'ов ядра нет, ну, да ладно.
Я завёл баг ядерщикам по этой проблеме: https://bugzilla.kernel.org/show_bug.cgi?id=75141. Посмотрим, что авторы iwlwifi скажут. Обычно, правда, всё, что касается ошибок "Microcode SW error", они отбрасывают, но мало ли. Может, какой workaround подскажут.
l2tp
Сообщение l2tp »
Прошел почти год, получилось интересное :) Какое-то время я маялась с ручным передергиванием интерфейса, потом освободился USB-свисток на реалтековском чипе (правда, его регулярно пыталась выковырять младшая дочь), недели три назад муж забрал ноут почистить и смазать кулер и заодно поменял shiloh на валявшийся в коробочке со всяким барахлом Intel 5300:
[root@mari-ThinkPad-X200 ~]# lspci | grep 5300
03:00.0 Network controller: Intel Corporation Ultimate N WiFi Link 5300
Не помогло :( Я уже думала воткнуть на ноут pcbsd, но там засада со скайпом, который мне нужен позарез и нужен с видеозвонками :( Плюнула, повесила rsyslog-у партзадание по появлению в логе строки "ieee80211 phy0: Hardware restart was requested" передергивать интерфейс. Стало реально даже смотреть видео на ютубе ;) Правда, каждые 2-3 минуты, а то и чаще линк отваливался и передергивался, но браузер обычно успевал накэшировать достаточно, чтобы спокойно смотреть, не замечая дисконнектов.
И вот, и вот... Муж принес домой новый винт и сказал, что будет менять винчестер на гейте, заодно фрю апдейтнет до 11 ветки. И шо вы думаете? За последние 36 часов rsyslog передергивал интерфейс всего дважды. И это при том, что часов 10 из 36 фоном болтали всякие интервью с ютуба, видео из моих подписок и детские мультики Для сравнения: вечером 15 марта я успокаивала ребенка мультклипами про мишку Гаммибера с ютуба, а потом на ютубе же смотрела что-то еще, пока фря апдейтилась. Выглядело это так:
# grep "Hardware restart" /var/log/messages
...кусь
Mar 15 21:47:28 mari-ThinkPad-X200 kernel: [909111.333529] ieee80211 phy0: Hardware restart was requested
Mar 15 21:50:58 mari-ThinkPad-X200 kernel: [909321.479176] ieee80211 phy0: Hardware restart was requested
Mar 15 21:51:55 mari-ThinkPad-X200 kernel: [909378.503343] ieee80211 phy0: Hardware restart was requested
Mar 15 21:52:06 mari-ThinkPad-X200 kernel: [909388.997614] ieee80211 phy0: Hardware restart was requested
Mar 15 21:53:09 mari-ThinkPad-X200 kernel: [909452.189227] ieee80211 phy0: Hardware restart was requested
Mar 15 21:53:54 mari-ThinkPad-X200 kernel: [909497.193358] ieee80211 phy0: Hardware restart was requested
Mar 15 22:25:52 mari-ThinkPad-X200 kernel: [911415.127267] ieee80211 phy0: Hardware restart was requested
Mar 15 22:26:01 mari-ThinkPad-X200 kernel: [911423.797861] ieee80211 phy0: Hardware restart was requested
Mar 15 22:26:09 mari-ThinkPad-X200 kernel: [911432.615074] ieee80211 phy0: Hardware restart was requested
Mar 15 22:26:22 mari-ThinkPad-X200 kernel: [911445.128831] ieee80211 phy0: Hardware restart was requested
Mar 15 22:26:31 mari-ThinkPad-X200 kernel: [911453.690245] ieee80211 phy0: Hardware restart was requested
Mar 15 22:26:58 mari-ThinkPad-X200 kernel: [911480.748437] ieee80211 phy0: Hardware restart was requested
Mar 15 22:28:25 mari-ThinkPad-X200 kernel: [911568.545364] ieee80211 phy0: Hardware restart was requested
Mar 15 22:29:39 mari-ThinkPad-X200 kernel: [911641.948468] ieee80211 phy0: Hardware restart was requested
Mar 15 22:30:09 mari-ThinkPad-X200 kernel: [911672.342445] ieee80211 phy0: Hardware restart was requested
Mar 15 22:30:34 mari-ThinkPad-X200 kernel: [911697.051368] ieee80211 phy0: Hardware restart was requested
Mar 15 22:31:39 mari-ThinkPad-X200 kernel: [911761.947630] ieee80211 phy0: Hardware restart was requested
Mar 15 22:32:18 mari-ThinkPad-X200 kernel: [911801.585376] ieee80211 phy0: Hardware restart was requested
Mar 15 22:32:32 mari-ThinkPad-X200 kernel: [911815.426133] ieee80211 phy0: Hardware restart was requested
Mar 15 22:44:12 mari-ThinkPad-X200 kernel: [  358.257839] ieee80211 phy0: Hardware restart was requested
Mar 16 00:31:28 mari-ThinkPad-X200 kernel: [ 6794.471603] ieee80211 phy0: Hardware restart was requested
Mar 16 00:31:46 mari-ThinkPad-X200 kernel: [ 6813.034681] ieee80211 phy0: Hardware restart was requested
Mar 16 00:33:50 mari-ThinkPad-X200 kernel: [ 6937.035825] ieee80211 phy0: Hardware restart was requested
Mar 16 00:36:35 mari-ThinkPad-X200 kernel: [ 7101.685061] ieee80211 phy0: Hardware restart was requested
Mar 16 00:38:50 mari-ThinkPad-X200 kernel: [ 7236.909564] ieee80211 phy0: Hardware restart was requested
Mar 16 00:42:57 mari-ThinkPad-X200 kernel: [ 7483.477350] ieee80211 phy0: Hardware restart was requested
Mar 16 00:43:30 mari-ThinkPad-X200 kernel: [ 7516.975243] ieee80211 phy0: Hardware restart was requested
Mar 16 00:44:06 mari-ThinkPad-X200 kernel: [ 7552.146961] ieee80211 phy0: Hardware restart was requested
Mar 16 00:44:18 mari-ThinkPad-X200 kernel: [ 7564.478017] ieee80211 phy0: Hardware restart was requested
Mar 16 00:44:28 mari-ThinkPad-X200 kernel: [ 7574.075532] ieee80211 phy0: Hardware restart was requested
Mar 16 00:47:00 mari-ThinkPad-X200 kernel: [ 7726.955196] ieee80211 phy0: Hardware restart was requested
Mar 16 00:47:55 mari-ThinkPad-X200 kernel: [ 7781.990344] ieee80211 phy0: Hardware restart was requested
Mar 16 00:49:14 mari-ThinkPad-X200 kernel: [ 7860.924356] ieee80211 phy0: Hardware restart was requested
Mar 16 00:49:45 mari-ThinkPad-X200 kernel: [ 7891.730996] ieee80211 phy0: Hardware restart was requested
Mar 16 00:50:31 mari-ThinkPad-X200 kernel: [ 7937.085291] ieee80211 phy0: Hardware restart was requested
Mar 16 00:51:26 mari-ThinkPad-X200 kernel: [ 7992.307862] ieee80211 phy0: Hardware restart was requested
Mar 16 00:52:31 mari-ThinkPad-X200 kernel: [ 8057.413246] ieee80211 phy0: Hardware restart was requested
Mar 16 00:53:51 mari-ThinkPad-X200 kernel: [ 8137.673250] ieee80211 phy0: Hardware restart was requested
Mar 16 00:56:49 mari-ThinkPad-X200 kernel: [ 8315.387899] ieee80211 phy0: Hardware restart was requested
Mar 16 00:58:11 mari-ThinkPad-X200 kernel: [ 8397.259137] ieee80211 phy0: Hardware restart was requested
Mar 16 01:02:38 mari-ThinkPad-X200 kernel: [ 8664.307249] ieee80211 phy0: Hardware restart was requested
Mar 16 01:02:48 mari-ThinkPad-X200 kernel: [ 8674.280340] ieee80211 phy0: Hardware restart was requested
Mar 16 01:04:26 mari-ThinkPad-X200 kernel: [ 8772.949169] ieee80211 phy0: Hardware restart was requested
Mar 16 01:08:18 mari-ThinkPad-X200 kernel: [ 9004.078314] ieee80211 phy0: Hardware restart was requested
Mar 16 01:09:00 mari-ThinkPad-X200 kernel: [ 9046.318218] ieee80211 phy0: Hardware restart was requested
Mar 16 01:09:31 mari-ThinkPad-X200 kernel: [ 9078.030277] ieee80211 phy0: Hardware restart was requested
Mar 16 01:09:40 mari-ThinkPad-X200 kernel: [ 9086.764450] ieee80211 phy0: Hardware restart was requested
Mar 16 01:11:02 mari-ThinkPad-X200 kernel: [ 9168.757412] ieee80211 phy0: Hardware restart was requested
Mar 16 01:11:12 mari-ThinkPad-X200 kernel: [ 9178.725838] ieee80211 phy0: Hardware restart was requested
Mar 16 01:11:56 mari-ThinkPad-X200 kernel: [ 9222.323396] ieee80211 phy0: Hardware restart was requested
Mar 16 01:12:06 mari-ThinkPad-X200 kernel: [ 9232.363359] ieee80211 phy0: Hardware restart was requested
Mar 16 01:12:17 mari-ThinkPad-X200 kernel: [ 9243.098319] ieee80211 phy0: Hardware restart was requested
Mar 16 01:12:50 mari-ThinkPad-X200 kernel: [ 9276.292364] ieee80211 phy0: Hardware restart was requested
Mar 16 01:17:30 mari-ThinkPad-X200 kernel: [ 9557.064338] ieee80211 phy0: Hardware restart was requested
Mar 16 01:17:59 mari-ThinkPad-X200 kernel: [ 9585.391515] ieee80211 phy0: Hardware restart was requested
Mar 16 01:18:47 mari-ThinkPad-X200 kernel: [ 9633.753266] ieee80211 phy0: Hardware restart was requested
Mar 16 01:19:46 mari-ThinkPad-X200 kernel: [ 9692.511877] ieee80211 phy0: Hardware restart was requested
Mar 16 01:20:07 mari-ThinkPad-X200 kernel: [ 9713.992984] ieee80211 phy0: Hardware restart was requested
Mar 16 02:30:38 mari-ThinkPad-X200 kernel: [13944.464916] ieee80211 phy0: Hardware restart was requested
Mar 16 02:33:37 mari-ThinkPad-X200 kernel: [14123.148193] ieee80211 phy0: Hardware restart was requested
... кусь
Т.е. проблема _почти_ исчезла после апдейта Freebsd на гейте, он же wi-fi точка. Справедливости ради надо сказать, что муж активно вел переписку с автором драйвера для wifi-карт на гейте и донатил на сопутствующие расходы типа покупки аналогичной карты автором драйвера для карт с атеросовским чипом.
Надеюсь, кому-то будет интересно
euspectre
Интересный поворот! Спасибо за информацию.
aponomarenko
Operating system: ROSA Linux
Сообщение aponomarenko »
l2tp, а можете загрузить данные по компьютеру в базу РОСЫ http://wiki.rosalinux.com/ru/index.php/ ... 0%B8%D1%8F?
hw-probe -all -upload
l2tp
Operating system: ROSA Desktop Fresh R2 KDE
ROSA Desktop Fresh R2 Gnome
Сообщение l2tp »
aponomarenko писал(а):l2tp, а можете загрузить данные по компьютеру в базу РОСЫ http://wiki.rosalinux.com/ru/index.php/ ... 0%B8%D1%8F?
https://linux-hardware.org/?probe=2500464441
Извините, Т410 дети напоили кофе, на нем РОСА без проблем работала
KA-25
Operating system: Rosa 64bit
Сообщение KA-25 »
извините, не удержался :D :D
хорошая дружная семья с общими интересами ! :D :D
Когда-нибудь я слезу с винды
l2tp
Re: shiloh и утомившее исчезновение трафика через wi-fi интерфейс
Сообщение l2tp »
KA-25 писал(а):извините, не удержался :D :D
Пасиба. Дружно поржали вместе
