Does Rosa have the Modules package? It is used to manage complex non homogeneous environments, and sports the Modulefiles system. Fedora calls it environment-modules-*.rpm.
Does Rosa have packages which perform same or similar functions?
If not, why not? Is there a discussion of this issue? Can it be ported over?
Does anybody have any experience with this? Advantages vs. disadvantages? Opinions?
So far I have been managing configs with ad hoc scripts, but now thinking of getting into it more deeply. One downside is the Tcl scripting language instead of my favorite, Python.
[SOLVED] Requesting environment-modules modulefiles
Последний раз редактировалось Mayavimmer 23 янв 2014, 15:49, всего редактировалось 1 раз.
Re: Requesting environment-modules modulefiles
Hello,
Please consider subscribing to the rosa-devel mailing list ( rosa-devel@lists.rosalab.ru , http://lists.rosalab.ru/mailman/listinfo/rosa-devel ). It's the most appropriate place to ask this kind of questions. Meaning you'll probably receive more detailed info there
Thanks, will do. Changing to SOLVED.
